Part Number: CODECOMPOSER
Other Parts Discussed in Thread: CCSTUDIO
I just installed CCS 12.7.0.00007 on my ubuntu machine
Can anyone please help figure out what is wrong here.
Can you confirm that you resolved the ubuntu dependencies has mentioned in the article below?
https://software-dl.ti.com/ccs/esd/documents/ccsv12_linux_host_support.html
If so, what exact ubuntu version are you using?
ki
Yes i resolved all the dependencies but still the issue is there and i am running ubuntu 22.04
Please provide the following:
1) Eclipse Error Log in <WORKSPACE DIR>/.metadata/.log
2) Eclipse Debug Log (must be generated, see: https://software-dl.ti.com/ccs/esd/documents/ccs_diagnostic-logs.html)
Here is the log file. Since the .ccstudio file throws segmentation error just at the outset. It doesnot create any workspace. But i ran the ./eclipse and created a workspace when prompted for.
!SESSION 2024-04-22 09:15:07.361 -----------------------------------------------
eclipse.buildId=4.23.0.I20220308-0310
java.version=11.0.13
java.vendor=Eclipse Adoptium
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64
!ENTRY com.ti.common.core 1 0 2024-04-22 09:15:26.217
!MESSAGE path=ccs_base/DebugServer
!MESSAGE debugServerDir=/home/mda5si/ti/ccs1270/ccs/ccs_base/DebugServer
!ENTRY com.ti.ccstudio.ui 1 0 2024-04-22 09:15:28.767
!MESSAGE CCS IDE session started!
CCS build: 12.7.0.00007
CCS location: /home/mda5si/ti/ccs1270/ccs
Workspace location: /home/mda5si/workspaceCCS
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-04-22 09:15:28.881
!MESSAGE constructor
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-04-22 09:15:28.882
!MESSAGE done with directories
!MESSAGE loading ti_logger
!MESSAGE Platform os: linux
!MESSAGE loading cTools
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-04-22 09:15:28.883
!MESSAGE loading TraceFactory
!MESSAGE loading sqlite3
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-04-22 09:15:28.884
!MESSAGE loading CloudTrace
!ENTRY com.ti.dbgtrc.webapp.CloudTraceInterface 0 0 2024-04-22 09:15:28.887
!MESSAGE CloudTrace interface loaded
!ENTRY com.ti.ccstudio.project.ui.webcontent 1 0 2024-04-22 09:15:28.957
!MESSAGE CCS HTTP adapter started! [ccs.port:43459] - Open 'http://localhost:43459/ide' in web browser to see listing of available APIs...
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:31.448
!MESSAGE Using unsafe http transport to retrieve software-dl.ti.com/.../artifacts.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:34.155
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:36.778
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:39.713
!MESSAGE Using unsafe http transport to retrieve software-dl.ti.com/.../content.xml.xz, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:43.152
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:46.655
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:50.508
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:52.081
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:53.538
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:54.872
!MESSAGE Using unsafe http transport to retrieve software-dl.ti.com/.../, see CVE-2021-41033. Consider using https instead.
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:57.733
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:15:59.761
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:16:01.501
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:16:03.052
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:16:06.459
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:16:07.767
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:16:09.190
!ENTRY org.eclipse.equinox.p2.repository 2 0 2024-04-22 09:16:10.980
Debug log
These look like install logs. I am looking for a generated eclipse debug log. See the "Eclipse Debug Logs" section in the document I referenced earlier.
