CCS5.1 project import problems
On some PCs and for some projects CCS5.1 reports this error when a project shall be imported:
What does this error mean? When I click 'ok' at a first glance everything seems to be ok, but links to source files are empty in the project.
I work in a ClearCase environment using the latest ClearCase Plugin for Eclipse.
    short overview:
    The not existing resources are caused by the fact that the project files were checked in after a successful build. When importing a project to another PC of course the build results do not exist yet.
    The complete log file is attached.
    !ENTRY org.eclipse.cdt.core 4 0 2011-11-15 08:01:10.154
    !MESSAGE Error: assertion failed: Operation was not prepared.
    !STACK 0
    org.eclipse.core.runtime.AssertionFailedException: assertion failed: Operation was not prepared.
    	at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
    	at org.eclipse.core.internal.resources.Workspace.beginOperation(Workspace.java:367)
    	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2340)
    	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.runAtomic(CProjectDescriptionManager.java:498)
    	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.runWspModification(CProjectDescriptionManager.java:463)
    	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.runWspModification(CProjectDescriptionManager.java:433)
    	at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager.handleEvent(CExternalSettingsManager.java:620)
    	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.notifyListeners(CProjectDescriptionManager.java:2170)
    	at org.eclipse.cdt.internal.core.settings.model.AbstractCProjectDescriptionStorage.fireLoadedEvent(AbstractCProjectDescriptionStorage.java:268)
    	at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:255)
    	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:416)
    	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:398)
    	at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.findBuildInfo(ManagedBuildManager.java:2709)
    	at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.getBuildInfo(ManagedBuildManager.java:2970)
    	at com.ti.common.project.core.util.CTIProjectCoreUtils.getBuildInfo(CTIProjectCoreUtils.java:132)
    	at com.ti.common.project.core.util.CTIProjectCoreUtils.getBuildInfo(CTIProjectCoreUtils.java:119)
    	at com.ti.common.project.core.util.CTIProjectCoreUtils.getActiveBuildConfiguration(CTIProjectCoreUtils.java:344)
    	at com.ti.common.project.core.util.CTIProjectCoreUtils.getBuildArtifactLocation(CTIProjectCoreUtils.java:158)
    	at com.ti.ccstudio.project.core.internal.variables.CCSPathVariableResolver__EXTERNAL_BUILD_ARTIFACT.getValue(CCSPathVariableResolver__EXTERNAL_BUILD_ARTIFACT.java:36)
    	at org.eclipse.core.internal.resources.ProjectVariableProviderManager$Descriptor.getValue(ProjectVariableProviderManager.java:59)
    	at org.eclipse.core.internal.resources.ProjectPathVariableManager.internalGetValue(ProjectPathVariableManager.java:152)
    	at org.eclipse.core.internal.resources.ProjectPathVariableManager.resolveVariable(ProjectPathVariableManager.java:226)
    	at org.eclipse.core.internal.resources.ProjectPathVariableManager.resolveVariable(ProjectPathVariableManager.java:211)
    	at org.eclipse.core.internal.resources.ProjectPathVariableManager.resolveURI(ProjectPathVariableManager.java:278)
    	at org.eclipse.core.internal.resources.LocationValidator.validateLinkLocationURI(LocationValidator.java:106)
    	at org.eclipse.core.internal.resources.Workspace.validateLinkLocationURI(Workspace.java:2597)
    	at org.eclipse.core.internal.resources.Resource.assertLinkRequirements(Resource.java:156)
    	at org.eclipse.core.internal.resources.Resource.createLink(Resource.java:649)
    	at org.eclipse.core.internal.resources.Project.reconcileLinksAndGroups(Project.java:1256)
    	at org.eclipse.core.internal.resources.Project.open(Project.java:1131)
    	at org.eclipse.core.internal.resources.Project.open(Project.java:1178)
    	at com.ti.ccstudio.project.core.services.ProjectImporter.internalImportProject(ProjectImporter.java:388)
    	at com.ti.ccstudio.project.core.services.ProjectImporter.access$1(ProjectImporter.java:332)
    	at com.ti.ccstudio.project.core.services.ProjectImporter$1.run(ProjectImporter.java:298)
    	at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2344)
    	at com.ti.ccstudio.project.core.services.ProjectImporter.importProject(ProjectImporter.java:296)
    	at com.ti.ccstudio.project.ui.internal.wizards.importexport.temp.WizardProjectsImportPage.createExistingProject(WizardProjectsImportPage.java:1257)
    	at com.ti.ccstudio.project.ui.internal.wizards.importexport.temp.WizardProjectsImportPage.access$24(WizardProjectsImportPage.java:1157)
    	at com.ti.ccstudio.project.ui.internal.wizards.importexport.temp.WizardProjectsImportPage$18.execute(WizardProjectsImportPage.java:1109)
    	at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(WorkspaceModifyOperation.java:106)
    	at org.eclipse.ui.actions.WorkspaceModifyOperation.run(WorkspaceModifyOperation.java:118)
    	at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
    !ENTRY org.eclipse.cdt.core 1 0 2011-11-15 08:01:10.904
    !MESSAGE Indexed 'Twin_dspDI' (0 sources, 19 headers) in 0,42 sec: 378 declarations; 426 references; 4 unresolved inclusions; 3 syntax errors; 7 unresolved names (0,86 %)
    !ENTRY org.eclipse.core.resources 4 368 2011-11-15 08:01:17.701
    !MESSAGE Resource '/Twin_dspDI/Release/DSPT_xxxxx_gblanke_DI.out' does not exist.
    !MESSAGE Resource '/Twin_uplink/Release/Twin_uplink.lib' does not exist.
    !ENTRY org.eclipse.cdt.core 1 0 2011-11-15 08:01:17.904
    !MESSAGE Indexed 'Twin_dspDI' (0 sources, 19 headers) in 0,20 sec: 378 declarations; 426 references; 4 unresolved inclusions; 3 syntax errors; 7 unresolved names (0,86 %)
    !ENTRY org.eclipse.core.resources 4 368 2011-11-15 08:01:19.451
    Can you recognize something from the details of 'Error: assertion failed: Operation was not prepared.'?
  • This is blocking us more and more - do you have any idea what the problem could be?
  • gbl,
    This turned out to be a strange Eclipse bug (or design limitation).  I've implemented a code work-around for it, and it will be available with CCSv5.1.1, which is currently scheduled for end of January 2012.
    Unfortunately, I can't think of any easy way for you to work-around it in the meantime.  This happens to any project that has dependencies on other projects, and that generates an OUT-file that's external to the project.  So, one work-around would be to change the project so that it generates the OUT-file physically within the build-directory (which is the default behaviour).
    - Baltasar
