This is an issue that has, in various forms, repeatedly plagued me with various versions of CCS Theia (knowing fully well that it was still semi-experimental software), but still persists with CCS 20.1.
I am using an ostensibly rather simple file-based workspace, with three folders that are adjacent to the projectname.theia-workspace file. Each folder contains one CCS project (CPU1, CPU2, CM; the three cores on a TMS320F28386D). This setup was last working with CCS Theia 1.4.0.
Before the below steps, both cache directories listed on the CCS troubleshooting page (%LOCALAPPDATA%\Texas Instruments\CCS\.ccs-server\workspaces\22def2ca02b59dc614d7e2fb59ea9423 and %LOCALAPPDATA%\Texas Instruments\CCS\ccs2010) had been deleted.
With CCS 20.1, opening the workspace will have an endlessly loading "Code Composer Studio - Initializing" notification in the bottom right. Additionally, none of the projects in the folders are recognised as such (as evidenced by the lack of project-related options in the right-click menu). The general log file in %LOCALAPPDATA%\Texas Instruments\CCS\.ccs-server\workspaces\22def2ca02b59dc614d7e2fb59ea9423 repeatedly contains the following error:
!SESSION 2025-03-10 14:05:05.937 ----------------------------------------------- eclipse.buildId=unknown java.version=17.0.2 java.vendor=Eclipse Adoptium BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE Framework arguments: -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2010\ccs\eclipse\ccs.preferences.ini -ccs.socketPath \\.\pipe\22def2ca02b59dc614d7e2fb59ea9423.sock -ccs.workspaceFolderPaths e:\Git\projectname\Firmware\CPU1;e:\Git\projectname\Firmware\CPU2;e:\Git\projectname\Firmware\CM -ccs.defaultImportDestinationPath c:\Users\m.grosser\workspace_ccstheia -ccs.buildSecurityPolicy level:desktop Command-line arguments: -os win32 -ws win32 -arch x86_64 -application com.ti.ccs.server.start -pluginCustomization C:\ti\ccs2010\ccs\eclipse\ccs.preferences.ini -data C:\Users\m.grosser\AppData\Local\Texas Instruments\CCS\.ccs-server\workspaces\22def2ca02b59dc614d7e2fb59ea9423 -ccs.socketPath \\.\pipe\22def2ca02b59dc614d7e2fb59ea9423.sock -ccs.workspaceFolderPaths e:\Git\projectname\Firmware\CPU1;e:\Git\projectname\Firmware\CPU2;e:\Git\projectname\Firmware\CM -ccs.defaultImportDestinationPath c:\Users\m.grosser\workspace_ccstheia -ccs.buildSecurityPolicy level:desktop This is a continuation of log file C:\Users\m.grosser\AppData\Local\Texas Instruments\CCS\.ccs-server\workspaces\22def2ca02b59dc614d7e2fb59ea9423\.metadata\.bak_1.log Created Time: 2025-03-10 14:18:45.603 !ENTRY org.eclipse.core.jobs 4 2 2025-03-10 14:18:45.603 !MESSAGE An internal error occurred during: "Sending build events with disabled autobuild". !STACK 0 java.lang.StackOverflowError at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:142) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:203) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:142) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:203) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:128) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:203) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:142) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:203) at org.eclipse.core.internal.dtree.AbstractDataTreeNode.assembleWith(AbstractDataTreeNode.java:128) at org.eclipse.core.internal.dtree.DeltaDataTree.getChildNodes(DeltaDataTree.java:520) at org.eclipse.core.internal.dtree.DeltaDataTree.getNamesOfChildren(DeltaDataTree.java:619) at org.eclipse.core.internal.dtree.DeltaDataTree.safeNaiveCopyCompleteSubtree(DeltaDataTree.java:870) at org.eclipse.core.internal.dtree.DeltaDataTree.safeCopyCompleteSubtree(DeltaDataTree.java:855) at org.eclipse.core.internal.watson.ElementTreeIterator.<init>(ElementTreeIterator.java:69) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:94) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:55) at org.eclipse.core.internal.resources.Resource.accept(Resource.java:117) at com.ti.ccs.project.ProjectCoreUtils.findFirstFileOfContentType(ProjectCoreUtils.java:2149) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:273) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:105) at com.ti.ccs.server.model.ProjectDescriptor.create(ProjectDescriptor.java:96) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:479) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.refresh(ProjectPropertiesHandler.java:462) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$ProjectDescriptorCache.getProjectDescriptor(ProjectPropertiesHandler.java:495) at com.ti.ccs.server.handlers.ProjectPropertiesHandler.encodeProjectDescriptor(ProjectPropertiesHandler.java:2504) at com.ti.ccs.server.handlers.ProjectPropertiesHandler$33.activeConfigurationChanged(ProjectPropertiesHandler.java:726) at com.ti.ccs.project.target.TargetConfigurationManager.setActiveConfiguration(TargetConfigurationManager.java:240) at com.ti.ccs.project.target.TargetConfigurationManager.getActiveConfiguration(TargetConfigurationManager.java:276) at com.ti.ccs.project.target.TargetConfigurationManager.getConnection(TargetConfigurationManager.java:359) at com.ti.ccs.project.ProjectCoreUtils.getConnection(ProjectCoreUtils.java:3992) at com.ti.ccs.server.model.ConnectionDescriptor.create(ConnectionDescriptor.java:59) at com.ti.ccs.server.model.ProjectDescriptor.<init>(ProjectDescriptor.java:141)
The same issue
Going back to CCS Theia 1.4.0 has not worked out as planned either -- after various attempts, the projects get recognised as such, but the StackOverflowErrors still appear whenever trying to build the project, without anything actually happening.
Details about the projects (including .project/.cproject/.ccsproject files) can be shared in private if required.
Hi, please accept my request to start private conversation regarding your workspace/projects details.
