JVM terminated. Exit code=1
# An unexpected error has been detected by HotSpot Virtual Machine:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x4b09053f, pid=3108, tid=2408
# Java VM: Java HotSpot(TM) Client VM (1.5.0_14-b03 mixed mode)
# Problematic frame:
# C  [ctools.dll+0x2053f]
---------------  T H R E A D  ---------------
Current thread (0x4cf0a350):  JavaThread "pool-2-thread-1" [_thread_in_native, id=2408]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
Registers:
EAX=0x4abf7bb0, EBX=0x4e55ede4, ECX=0x00000000, EDX=0x00000000
ESP=0x4e55ecb4, EBP=0x4e55edf0, ESI=0x4e55ede4, EDI=0x4b0c3fe0
EIP=0x4b09053f, EFLAGS=0x00010202
Top of Stack: (sp=0x4e55ecb4)
0x4e55ecb4:   4abf7bd0 50220020 4feebc18 00000000
0x4e55ecc4:   4abf7bd0 7c00133c 4abf0000 4abf44a8
0x4e55ecd4:   7c001341 4abf7bb0 4feebc18 00000000
0x4e55ece4:   7c03dfe0 ffffffff 00000000 7c0016d7
0x4e55ecf4:   4e55ecd8 7c0016c4 4e55edd8 7c081ecc
0x4e55ed04:   00000000 4feebc18 7c081c72 00000001
0x4e55ed14:   4b085608 4abf7bb0 4e55e9fc 4e55ea00
0x4e55ed24:   00000000 50566bc0 00000000 00000001
Instructions: (pc=0x4b09053f)
0x4b09052f:   e8 fe ff ff 8b 4a 7c 8b 85 e8 fe ff ff 8b 50 7c
0x4b09053f:   8b 02 ff 10 8b 8d e8 fe ff ff c6 81 20 01 00 00
Stack: [0x4e520000,0x4e560000),  sp=0x4e55ecb4,  free space=251k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [ctools.dll+0x15b17]
C  [DebugServer.dll+0x730fa]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J  org.mozilla.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;Ljava/lang/String;)Ljava/lang/Object;
J  org.mozilla.xpcom.internal.XPCOMJavaProxy$3.call()Ljava/lang/Object;
J  java.util.concurrent.FutureTask$Sync.innerRun()V
J  java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run()V
J  java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Ljava/lang/Runnable;)V
J  java.util.concurrent.ThreadPoolExecutor$Worker.run()V
v  ~OSRAdapter
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x4be8f638 JavaThread "Timer-8" daemon [_thread_blocked, id=1048]
  0x4bf6be00 JavaThread "Timer-7" daemon [_thread_blocked, id=2688]
  0x4bf01ff0 JavaThread "Timer-6" daemon [_thread_blocked, id=2156]
  0x4bf49bd0 JavaThread "Process monitor" daemon [_thread_blocked, id=3712]
  0x4bf49190 JavaThread "Input Stream Monitor" daemon [_thread_blocked, id=3604]
  0x4bf48808 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=2072]
  0x4bf39c88 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=3580]
  0x4bf392a0 JavaThread "Process monitor" daemon [_thread_blocked, id=3624]
  0x4bf388b0 JavaThread "Input Stream Monitor" daemon [_thread_blocked, id=3656]
  0x4bf37ec0 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=2604]
  0x4bf37d18 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=3272]
  0x4bf36248 JavaThread "Output Message Thread" [_thread_blocked, id=880]
  0x4bf24e10 JavaThread "Output Message Thread" [_thread_blocked, id=3116]
  0x4bf21858 JavaThread "Output Message Thread" [_thread_blocked, id=1768]
  0x4bf3de68 JavaThread "Output Message Thread" [_thread_blocked, id=2640]
  0x4bf219e0 JavaThread "MemoryServer.EventQueue" [_thread_blocked, id=3044]
  0x491012d8 JavaThread "Worker-46" [_thread_blocked, id=2664]
  0x490ff2f0 JavaThread "Worker-45" [_thread_blocked, id=3840]
  0x4bf24488 JavaThread "Worker-44" [_thread_blocked, id=1612]
  0x4ce87190 JavaThread "Worker-43" [_thread_blocked, id=3440]
  0x4bf12f38 JavaThread "Worker-39" [_thread_blocked, id=748]
  0x4bef4b28 JavaThread "Worker-37" [_thread_blocked, id=3736]
  0x4bdd4db8 JavaThread "Worker-36" [_thread_blocked, id=3456]
  0x4bdada38 JavaThread "pool-3-thread-1" [_thread_blocked, id=1472]
  0x494242b8 JavaThread "pool-1-thread-1" [_thread_blocked, id=3252]
  0x4bbe5618 JavaThread "Worker-29" [_thread_blocked, id=2260]
  0x4d4879d8 JavaThread "polling thread" daemon [_thread_blocked, id=3896]
=>0x4cf0a350 JavaThread "pool-2-thread-1" [_thread_in_native, id=2408]
  0x490d5d10 JavaThread "org.eclipse.jface.text.reconciler.MonoReconciler" daemon [_thread_blocked, id=2256]
  0x493dbe80 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=2628]
  0x493c7530 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=2724]
  0x493cde80 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=1680]
  0x490add18 JavaThread "State Data Manager" daemon [_thread_blocked, id=2940]
  0x008ea708 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=1352]
  0x008e9438 JavaThread "CompilerThread0" daemon [_thread_blocked, id=2232]
  0x008e87c8 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=2948]
  0x008db638 JavaThread "Finalizer" daemon [_thread_blocked, id=624]
  0x008da1c8 JavaThread "Reference Handler" daemon [_thread_blocked, id=3788]
  0x003c6b00 JavaThread "main" [_thread_in_native, id=904]
Other Threads:
  0x003c4d28 VMThread [id=2296]
  0x008e8668 WatcherThread [id=1172]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
 def new generation   total 3584K, used 2956K [0x02a20000, 0x02e00000, 0x078e0000)
  eden space 3200K,  90% used [0x02a20000, 0x02cf4e00, 0x02d40000)
  from space 384K,  14% used [0x02d40000, 0x02d4e3a0, 0x02da0000)
  to   space 384K,   0% used [0x02da0000, 0x02da0000, 0x02e00000)
 tenured generation   total 46144K, used 31051K [0x078e0000, 0x0a5f0000, 0x42a20000)
   the space 46144K,  67% used [0x078e0000, 0x09732c48, 0x09732e00, 0x0a5f0000)
 compacting perm gen  total 45568K, used 45349K [0x42a20000, 0x456a0000, 0x48a20000)
   the space 45568K,  99% used [0x42a20000, 0x45669480, 0x45669600, 0x456a0000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
0x7c930000 - 0x7c9ce000 	C:\WINDOWS\system32\ntdll.dll
0x7c7d0000 - 0x7c900000 	C:\WINDOWS\system32\kernel32.dll
0x77f50000 - 0x77ff8000 	C:\WINDOWS\system32\ADVAPI32.dll
0x77d80000 - 0x77e13000 	C:\WINDOWS\system32\RPCRT4.dll
0x77ef0000 - 0x77f01000 	C:\WINDOWS\system32\Secur32.dll
0x77cf0000 - 0x77d80000 	C:\WINDOWS\system32\USER32.dll
0x77e20000 - 0x77e69000 	C:\WINDOWS\system32\GDI32.dll
0x77bc0000 - 0x77c18000 	C:\WINDOWS\system32\MSVCRT.dll
0x762e0000 - 0x762fd000 	C:\WINDOWS\system32\IMM32.DLL
0x62340000 - 0x62349000 	C:\WINDOWS\system32\LPK.DLL
0x73f80000 - 0x73feb000 	C:\WINDOWS\system32\USP10.dll
0x6d640000 - 0x6d7de000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\client\jvm.dll
0x76af0000 - 0x76b1b000 	C:\WINDOWS\system32\WINMM.dll
0x6d290000 - 0x6d298000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\hpi.dll
0x76ba0000 - 0x76bab000 	C:\WINDOWS\system32\PSAPI.DLL
0x6d610000 - 0x6d61c000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\verify.dll
0x6d310000 - 0x6d32d000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\java.dll
0x6d630000 - 0x6d63f000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\zip.dll
0x76d90000 - 0x76db2000 	C:\WINDOWS\system32\Apphelp.dll
0x6d4d0000 - 0x6d4e3000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\net.dll
0x719e0000 - 0x719f7000 	C:\WINDOWS\system32\WS2_32.dll
0x719d0000 - 0x719d8000 	C:\WINDOWS\system32\WS2HELP.dll
0x6d4f0000 - 0x6d4f9000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\nio.dll
0x6d1f0000 - 0x6d203000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\deploy.dll
0x49720000 - 0x49806000 	C:\WINDOWS\system32\WININET.dll
0x77e70000 - 0x77ee6000 	C:\WINDOWS\system32\SHLWAPI.dll
0x49810000 - 0x49819000 	C:\WINDOWS\system32\Normaliz.dll
0x49820000 - 0x49953000 	C:\WINDOWS\system32\urlmon.dll
0x76970000 - 0x76aae000 	C:\WINDOWS\system32\ole32.dll
0x770d0000 - 0x7715b000 	C:\WINDOWS\system32\OLEAUT32.dll
0x49960000 - 0x49b4b000 	C:\WINDOWS\system32\iertutil.dll
0x7d5a0000 - 0x7dd9d000 	C:\WINDOWS\system32\SHELL32.dll
0x765c0000 - 0x76654000 	C:\WINDOWS\system32\CRYPT32.dll
0x77c40000 - 0x77c52000 	C:\WINDOWS\system32\MSASN1.dll
0x77160000 - 0x77263000 	C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.6028_x-ww_61e65202\comctl32.dll
0x5c820000 - 0x5c8ba000 	C:\WINDOWS\system32\comctl32.dll
0x6d5c0000 - 0x6d5e5000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\RegUtils.dll
0x77bb0000 - 0x77bb8000 	C:\WINDOWS\system32\VERSION.dll
0x49ea0000 - 0x4a2e1000 	C:\WINDOWS\system32\msi.dll
0x76e90000 - 0x76ecc000 	C:\WINDOWS\system32\RASAPI32.dll
0x76e40000 - 0x76e52000 	C:\WINDOWS\system32\rasman.dll
0x605f0000 - 0x60645000 	C:\WINDOWS\system32\NETAPI32.dll
0x76e60000 - 0x76e8f000 	C:\WINDOWS\system32\TAPI32.dll
0x76e30000 - 0x76e3e000 	C:\WINDOWS\system32\rtutils.dll
0x7e8c0000 - 0x7e971000 	C:\WINDOWS\system32\USERENV.dll
0x77f10000 - 0x77f35000 	C:\WINDOWS\system32\msv1_0.dll
0x76740000 - 0x7674c000 	C:\WINDOWS\system32\cryptdll.dll
0x76d10000 - 0x76d29000 	C:\WINDOWS\system32\iphlpapi.dll
0x72220000 - 0x72225000 	C:\WINDOWS\system32\sensapi.dll
0x4a6e0000 - 0x4a732000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\218\1\.cp\swt-win32-3232.dll
0x76300000 - 0x76347000 	C:\WINDOWS\system32\comdlg32.dll
0x73b20000 - 0x73b40000 	C:\WINDOWS\system32\MSVFW32.dll
0x74660000 - 0x746ac000 	C:\WINDOWS\system32\MSCTF.dll
0x75110000 - 0x7513e000 	C:\WINDOWS\system32\msctfime.ime
0x4a8d0000 - 0x4a8ec000 	C:\WINDOWS\system32\imekr70.ime
0x4a910000 - 0x4a918000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\170\1\.cp\os\win32\x86\localfile_1_0_0.dll
0x4aa30000 - 0x4aa38000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\174\1\.cp\os\win32\x86\win32refresh.dll
0x5a480000 - 0x5a4b8000 	C:\WINDOWS\system32\uxtheme.dll
0x61880000 - 0x618ba000 	C:\WINDOWS\system32\oleacc.dll
0x4ac10000 - 0x4ac23000 	C:\Program Files\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\218\1\.cp\swt-gdip-win32-3232.dll
0x4b230000 - 0x4b3db000 	C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.6002.22791_x-ww_c8dff154\gdiplus.dll
0x4b3e0000 - 0x4b93b000 	C:\WINDOWS\system32\xpsp2res.dll
0x76f80000 - 0x76fff000 	C:\WINDOWS\system32\CLBCATQ.DLL
0x77000000 - 0x770a7000 	C:\WINDOWS\system32\COMRes.dll
0x74cd0000 - 0x74d61000 	C:\WINDOWS\system32\mlang.dll
0x7c000000 - 0x7c054000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\msvcr70.dll
0x7c080000 - 0x7c0f7000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\msvcp70.dll
0x7c140000 - 0x7c23d000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\mfc70.dll
0x4b050000 - 0x4b061000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\cToolsIF.dll
0x4b070000 - 0x4b0d8000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\ctools.dll
0x4c340000 - 0x4c532000 	C:\Program Files\Texas Instruments\ccsv4\common\bin\xerces-c_2_5_0.dll
0x78130000 - 0x781cb000 	C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCR80.dll
0x4b0e0000 - 0x4b0f6000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\JTrace.dll
0x4b100000 - 0x4b10f000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\TraceFactory.dll
0x4b120000 - 0x4b162000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\ICECD.dll
0x4b170000 - 0x4b191000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\icestorm21.dll
0x4b1a0000 - 0x4b1bf000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\iceutil21.dll
0x4c540000 - 0x4c61c000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\ice21.dll
0x4b1c0000 - 0x4b1dc000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\LIBBZ2.dll
0x762d0000 - 0x762d5000 	C:\WINDOWS\system32\msimg32.dll
0x4aba0000 - 0x4abab000 	C:\Program Files\Texas Instruments\ccsv4\emulation\analysis\bin\TraceJNI.dll
0x4abb0000 - 0x4abb7000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\bin\win32\LibraryLoader.dll
0x7c420000 - 0x7c4a7000 	C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.6195_x-ww_44262b86\MSVCP80.dll
0x4c8b0000 - 0x4c913000 	C:\Program Files\Texas Instruments\ccsv4\common\bin\CCReg.dll
0x4c920000 - 0x4c971000 	C:\Program Files\Texas Instruments\ccsv4\common\bin\Logger.dll
0x4c990000 - 0x4ca23000 	C:\Program Files\Texas Instruments\ccsv4\common\bin\rtdx.dll
0x4ca30000 - 0x4cbcb000 	C:\Program Files\Texas Instruments\ccsv4\common\bin\setup_parser.dll
0x4cbe0000 - 0x4cbeb000 	C:\Program Files\Texas Instruments\ccsv4\common\uscif\jtagdata.dll
0x4ccf0000 - 0x4ccfe000 	C:\Program Files\Texas Instruments\ccsv4\common\bin\ti_targetdb_parser.dll
0x4cd10000 - 0x4cd17000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\javaxpcomglue.dll
0x4cd20000 - 0x4cd48000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\nspr4.dll
0x71a00000 - 0x71a0b000 	C:\WINDOWS\system32\WSOCK32.dll
0x4cd50000 - 0x4cd57000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\plc4.dll
0x4cd60000 - 0x4cd66000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\plds4.dll
0x4cd80000 - 0x4cdf2000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\js3250.dll
0x4b020000 - 0x4b02d000 	C:\Documents and Settings\20704004\Local Settings\Temp\ext59555.dll
0x4de10000 - 0x4e4f4000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\xul.dll
0x72f50000 - 0x72f76000 	C:\WINDOWS\system32\WINSPOOL.DRV
0x75fd0000 - 0x76035000 	C:\WINDOWS\system32\MSVCP60.dll
0x4e510000 - 0x4e516000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\xpcom.dll
0x71980000 - 0x719bf000 	C:\WINDOWS\System32\mswsock.dll
0x76ed0000 - 0x76ef7000 	C:\WINDOWS\system32\DNSAPI.dll
0x76f60000 - 0x76f68000 	C:\WINDOWS\System32\winrnr.dll
0x76f10000 - 0x76f3c000 	C:\WINDOWS\system32\WLDAP32.dll
0x76f70000 - 0x76f76000 	C:\WINDOWS\system32\rasadhlp.dll
0x4e5f0000 - 0x4e78f000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\components\mdex.dll
0x4e7a0000 - 0x4ea1d000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\license\mdexutil.dll
0x71eb0000 - 0x71eb8000 	C:\WINDOWS\system32\snmpapi.dll
0x76040000 - 0x76199000 	C:\WINDOWS\system32\SETUPAPI.dll
0x68000000 - 0x68036000 	C:\WINDOWS\system32\rsaenh.dll
0x751d0000 - 0x75207000 	C:\WINDOWS\system32\wbem\wbemcomn.dll
0x755d0000 - 0x75646000 	C:\WINDOWS\system32\wbem\fastprox.dll
0x76750000 - 0x76763000 	C:\WINDOWS\system32\NTDSAPI.dll
0x4ef30000 - 0x4f4b2000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\components\DebugServer.dll
0x4ed70000 - 0x4edd8000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\bin\win32\tiofr11.dll
0x4f4c0000 - 0x4f529000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\bin\win32\XPCOMUtility.dll
0x4f530000 - 0x4f692000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\bin\win32\CollectorServer.dll
0x4f6a0000 - 0x4f790000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\bin\win32\DatasetServer.dll
0x76be0000 - 0x76c0e000 	C:\WINDOWS\system32\WINTRUST.dll
0x76c40000 - 0x76c68000 	C:\WINDOWS\system32\IMAGEHLP.dll
0x65cb0000 - 0x65d06000 	C:\WINDOWS\system32\hnetcfg.dll
0x58de0000 - 0x58e81000 	C:\WINDOWS\system32\DBGHELP.DLL
0x719c0000 - 0x719c8000 	C:\WINDOWS\System32\wshtcpip.dll
0x4c620000 - 0x4c69c000 	C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32\components\DebugProperties.dll
0x50200000 - 0x50213000 	C:\Program Files\Texas Instruments\ccsv4\emulation\tpi\tpi_icepick.dll
0x73d10000 - 0x73e02000 	C:\WINDOWS\system32\MFC42.DLL
0x61300000 - 0x6130d000 	C:\WINDOWS\system32\MFC42LOC.DLL
VM Arguments:
jvm_args: -Xms40m -Xmx1024m -XX:MaxPermSize=96m -DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32 -Dxpcom.bridge.executeOnDedicatedThread=yes -Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32 -Dosgi.instance.area.default=file:/C:/Documents and Settings/20704004/My Documents/workspace/
java_command: C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar -os win32 -ws win32 -arch x86 -launcher C:\Program Files\Texas Instruments\ccsv4\eclipse\eclipse.exe -name Eclipse -showsplash 600 -exitdata ef4_b0 -vm C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe -vmargs -Xms40m -Xmx1024m -XX:MaxPermSize=96m -DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32 -Dxpcom.bridge.executeOnDedicatedThread=yes -Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32 -Dosgi.instance.area.default=file:/C:/Documents and Settings/20704004/My Documents/workspace/ -jar C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Texas Instruments\ccsv4\common\bin;C:\Program Files\Texas Instruments\ccsv4\common\uscif;C:\Program Files\Texas Instruments\ccsv4\DebugServer\slicense;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\bin;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\common\uscif;C:\Program Files\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;C:\Perl\site\bin;C:\Perl\bin;C:\ORA817\bin;c:\htcs\dll;c:\htcs\htcs_cp;c:\htcs\prod;c:\htcs\prod_CHINA;c:\htcs\eis;c:\htcs\sale;c:\htcs\slip;c:\htcs\pay;c:\htcs\svc;c:\htcs\acnt;c:\htcs\pss;C:\Program Files\Oracle\jre\1.1.7\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\ESTsoft\ALZip;C:\WINDOWS\system32\WindowsPowerShell\v1.0;C:\Program Files\ESTsoft\ALZip;C:\Program Files\IDM Computer Solutions\UltraEdit\;C:\Program Files\Texas Instruments\ccsv4\emulation\drivers
USERNAME=20704004
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 6 Model 23 Stepping 10, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 2 (cores per cpu 2, threads per core 1) family 6 model 7 stepping 10, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 2097151k(2097151k free), swap 4194303k(4125760k free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_14-b03) for windows-x86, built on Oct  5 2007 01:21:52 by "java_re" with MS VC++ 6.0
Please help to fix JVM termination error as below. Please also refer to the attached hs_err_pid3108.log file.
CCS version: CCS 4.1.02006
JTAG: XDS510
