EZDSPF2812 target connection problem with ccs v4. (JVM terminated)
Other Parts Discussed in Thread: CCSTUDIO
Hello.
now i'm trying to connect ezdspF2812 with ccs V4 ( ver 4.2.0.7) using XDS510USB.
I checked target configuration EZDSPF2812 in the connection menu ( Specturm Digital XDS510USB Emulator).
After that I execute Target- Launch TI Debugger and Debug window shows up.
Then I execute "Connect Target" but CCS v4 suddenly closed and error message shows up as below.
Eclipse
JVM terminated. Exit code=1
C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
-DXPCOM.RUNTIME=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dxpcom.bridge.executeOnDedicatedThread=yes
-Dorg.eclipse.swt.browser.XULRunnerPath=C:\Program Files\Texas Instruments\ccsv4\DebugServer\win32
-Dosgi.instance.area.default=file:/C:/Users/jay/Documents/workspace/
-jar C:\Program Files\Texas Instruments\ccsv4\eclipse\startup.jar
-os win32
-ws win32
-arch x86
-launcher C:\Program Files\Texas Instruments\ccsv4\eclipse\eclipse.exe
-name Eclipse
-showsplash 600
-exitdata b48_c8
-vm C:\Program Files\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
-vmargs
-Xms40m
-Xmx256m
-XX:MaxPermSize=96m
XDS510USB works fine because sdConfigEX v4 reset and emu test OK and i also connect DM365 DVEVM. it works fine.
EZDSP board also works fine with CCS3.3
What can I try for ? please give a answer.
melon
    Some suggestions can be found in the troubleshooting guide:
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS
    If thise tips fail to help, sending us some of the various diagnostic logs can help us find the cause of the issue:
    http://processors.wiki.ti.com/index.php/Troubleshooting_CCS#CCS_Diagnostic_Logs
    • Crash Dump Files,
    • JVM and Eclipse Error Logs
    • Debug Server Logging
    ki
    # An unexpected error has been detected by HotSpot Virtual Machine:
    #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x3ca4ab0a, pid=5188, tid=4148
    # Java VM: Java HotSpot(TM) Client VM (1.5.0_14-b03 mixed mode)
    # Problematic frame:
    # C  0x3ca4ab0a
    ---------------  T H R E A D  ---------------
    Current thread (0x35d124b0):  JavaThread "pool-2-thread-1" [_thread_in_native, id=4148]
    siginfo: ExceptionCode=0xc0000005, reading address 0x00000000
    Registers:
    EAX=0x00000000, EBX=0xffffffff, ECX=0x00000000, EDX=0x000004f0
    ESP=0x38fcf118, EBP=0x00000000, ESI=0x37a04888, EDI=0x37a04888
    EIP=0x3ca4ab0a, EFLAGS=0x00010246
    Top of Stack: (sp=0x38fcf118)
    0x38fcf118:   00000000 37a04888 00000000 ffffffff
    0x38fcf128:   3ca4aee7 00000000 38fcf4e8 ffffffff
    0x38fcf138:   37a04888 00000000 01001c72 00000000
    0x38fcf148:   00000000 748ec71a 37a023c8 382b5d1e
    0x38fcf158:   39cfb4f9 382ca2a0 0000005f 0000005f
    0x38fcf168:   49ca3418 38fcf300 3ca4f0c9 00000000
    0x38fcf178:   3cdc0b85 00006ddf 3d3f0020 3d3f0028
    0x38fcf188:   37070000 00000000 7c001341 00000010
    Instructions: (pc=0x3ca4ab0a)
    0x3ca4aafa:   90 90 90 90 90 90 53 55 56 57 8b f9 8b 4c 24 14
    0x3ca4ab0a:   8b 01 ff 50 14 8b 2d 2c 01 a5 3c 8b f0 b3 01 8d
    Stack: [0x38f90000,0x38fd0000),  sp=0x38fcf118,  free space=252k
    Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
    C  0x3ca4ab0a
    [error occurred during error reporting, step 120, id 0xc0000005]
    Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
    J  org.mozilla.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(Ljava/lang/Object;Ljava/lang/String;[Ljava/lang/Object;Ljava/lang/String;)Ljava/lang/Object;
    J  org.mozilla.xpcom.internal.XPCOMJavaProxy$3.call()Ljava/lang/Object;
    J  java.util.concurrent.FutureTask$Sync.innerRun()V
    J  java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run()V
    J  java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Ljava/lang/Runnable;)V
    j  java.util.concurrent.ThreadPoolExecutor$Worker.run()V+28
    j  java.lang.Thread.run()V+11
    v  ~StubRoutines::call_stub
    ---------------  P R O C E S S  ---------------
    Java Threads: ( => current thread )
      0x3a6cba38 JavaThread "Worker-15" [_thread_blocked, id=5444]
      0x3a4ee840 JavaThread "pool-3-thread-1" [_thread_blocked, id=5600]
      0x3a6cb5a0 JavaThread "Worker-12" [_thread_blocked, id=1160]
      0x3a6cb418 JavaThread "Timer-2" daemon [_thread_blocked, id=4852]
      0x340448d8 JavaThread "Timer-1" daemon [_thread_blocked, id=5136]
      0x34044750 JavaThread "Timer-0" daemon [_thread_blocked, id=5292]
      0x34044440 JavaThread "Process monitor" daemon [_thread_blocked, id=4372]
      0x340442b8 JavaThread "Input Stream Monitor" daemon [_thread_blocked, id=1176]
      0x34044130 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=964]
      0x34043fa8 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=3500]
      0x34043e20 JavaThread "Process monitor" daemon [_thread_blocked, id=4532]
      0x34043c98 JavaThread "Input Stream Monitor" daemon [_thread_blocked, id=4184]
      0x34043b10 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=5664]
      0x35f11198 JavaThread "Output Stream Monitor" daemon [_thread_blocked, id=2840]
      0x3a4ee9c8 JavaThread "Output Message Thread" [_thread_blocked, id=5008]
      0x3a4eee60 JavaThread "Output Message Thread" [_thread_blocked, id=5044]
      0x3a4ee530 JavaThread "Output Message Thread" [_thread_blocked, id=1236]
      0x35d12328 JavaThread "Output Message Thread" [_thread_blocked, id=3712]
      0x3a4eecd8 JavaThread "MemoryServer.EventQueue" [_thread_blocked, id=6124]
      0x3a4ee6b8 JavaThread "pool-1-thread-1" [_thread_blocked, id=2376]
      0x3a4ee220 JavaThread "Worker-8" [_thread_blocked, id=5560]
      0x35e93bc8 JavaThread "Worker-7" [_thread_blocked, id=5780]
      0x35e89e48 JavaThread "polling thread" daemon [_thread_blocked, id=4984]
    =>0x35d124b0 JavaThread "pool-2-thread-1" [_thread_in_native, id=4148]
      0x341352b0 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=5064]
      0x3415ef18 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=216]
      0x34162b88 JavaThread "traceMsgQueueThread" daemon [_thread_blocked, id=2468]
      0x341651f8 JavaThread "State Data Manager" daemon [_thread_blocked, id=4200]
      0x012f3b00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=5756]
      0x012f2ec0 JavaThread "CompilerThread0" daemon [_thread_blocked, id=4632]
      0x012e4320 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=4908]
      0x012e3938 JavaThread "Finalizer" daemon [_thread_blocked, id=4128]
      0x012e2360 JavaThread "Reference Handler" daemon [_thread_blocked, id=3860]
      0x0060a7e8 JavaThread "main" [_thread_blocked, id=2276]
    Other Threads:
      0x012dd360 VMThread [id=4484]
      0x012904f0 WatcherThread [id=2444]
    VM state:not at safepoint (normal execution)
    VM Mutex/Monitor currently owned by a thread: None
    Heap
     def new generation   total 6912K, used 4934K [0x039e0000, 0x04150000, 0x06140000)
      eden space 6208K,  69% used [0x039e0000, 0x03e17d60, 0x03ff0000)
      from space 704K,  87% used [0x040a0000, 0x04139b78, 0x04150000)
      to   space 704K,   0% used [0x03ff0000, 0x03ff0000, 0x040a0000)
     tenured generation   total 90752K, used 49657K [0x06140000, 0x0b9e0000, 0x239e0000)
       the space 90752K,  54% used [0x06140000, 0x091be5e0, 0x091be600, 0x0b9e0000)
     compacting perm gen  total 48384K, used 48310K [0x239e0000, 0x26920000, 0x339e0000)
       the space 48384K,  99% used [0x239e0000, 0x2690d878, 0x2690da00, 0x26920000)
    No shared spaces configured.
    Dynamic libraries:
    0x00400000 - 0x0040d000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe
    0x77110000 - 0x7724c000 	C:\Windows\SYSTEM32\ntdll.dll
    0x75ca0000 - 0x75d74000 	C:\Windows\system32\kernel32.dll
    0x75500000 - 0x7554a000 	C:\Windows\system32\KERNELBASE.dll
    0x759a0000 - 0x75a40000 	C:\Windows\system32\ADVAPI32.dll
    0x77010000 - 0x770bc000 	C:\Windows\system32\msvcrt.dll
    0x77320000 - 0x77339000 	C:\Windows\SYSTEM32\sechost.dll
    0x76ab0000 - 0x76b51000 	C:\Windows\system32\RPCRT4.dll
    0x75a40000 - 0x75b09000 	C:\Windows\system32\USER32.dll
    0x769d0000 - 0x76a1e000 	C:\Windows\system32\GDI32.dll
    0x75b70000 - 0x75b7a000 	C:\Windows\system32\LPK.dll
    0x75660000 - 0x756fd000 	C:\Windows\system32\USP10.dll
    0x75570000 - 0x7558f000 	C:\Windows\system32\IMM32.DLL
    0x75700000 - 0x757cc000 	C:\Windows\system32\MSCTF.dll
    0x6d640000 - 0x6d7de000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\client\jvm.dll
    0x734d0000 - 0x73502000 	C:\Windows\system32\WINMM.dll
    0x75170000 - 0x751bb000 	C:\Windows\system32\apphelp.dll
    0x6d290000 - 0x6d298000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\hpi.dll
    0x757d0000 - 0x757d5000 	C:\Windows\system32\PSAPI.DLL
    0x6d610000 - 0x6d61c000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\verify.dll
    0x6d310000 - 0x6d32d000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\java.dll
    0x6d630000 - 0x6d63f000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\zip.dll
    0x6d4d0000 - 0x6d4e3000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\net.dll
    0x75620000 - 0x75655000 	C:\Windows\system32\WS2_32.dll
    0x77280000 - 0x77286000 	C:\Windows\system32\NSI.dll
    0x74ca0000 - 0x74cdc000 	C:\Windows\system32\mswsock.dll
    0x74e00000 - 0x74e06000 	C:\Windows\System32\wship6.dll
    0x6d4f0000 - 0x6d4f9000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\nio.dll
    0x6d1f0000 - 0x6d203000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\deploy.dll
    0x75b80000 - 0x75c98000 	C:\Windows\system32\WININET.dll
    0x75940000 - 0x75997000 	C:\Windows\system32\SHLWAPI.dll
    0x75590000 - 0x75593000 	C:\Windows\system32\Normaliz.dll
    0x76c70000 - 0x76e69000 	C:\Windows\system32\iertutil.dll
    0x76b60000 - 0x76c70000 	C:\Windows\system32\urlmon.dll
    0x757e0000 - 0x7593c000 	C:\Windows\system32\ole32.dll
    0x77290000 - 0x7731f000 	C:\Windows\system32\OLEAUT32.dll
    0x754d0000 - 0x754ff000 	C:\Windows\system32\XmlLite.dll
    0x75d80000 - 0x769c9000 	C:\Windows\system32\SHELL32.dll
    0x75380000 - 0x7549c000 	C:\Windows\system32\CRYPT32.dll
    0x752b0000 - 0x752bc000 	C:\Windows\system32\MSASN1.dll
    0x75240000 - 0x7524b000 	C:\Windows\system32\profapi.dll
    0x6d5c0000 - 0x6d5e5000 	D:\Texas Instruments\ccsv4\eclipse\jre\bin\RegUtils.dll
    0x746f0000 - 0x746f9000 	C:\Windows\system32\VERSION.dll
    0x68ad0000 - 0x68d10000 	C:\Windows\system32\msi.dll
    0x74f00000 - 0x74f08000 	C:\Windows\system32\Secur32.dll
    0x75150000 - 0x7516a000 	C:\Windows\system32\SSPICLI.DLL
    0x74160000 - 0x742fe000 	C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16661_none_420fe3fa2b8113bd\comctl32.dll
    0x74b60000 - 0x74ba4000 	C:\Windows\system32\dnsapi.DLL
    0x73040000 - 0x7305c000 	C:\Windows\system32\iphlpapi.DLL
    0x73030000 - 0x73037000 	C:\Windows\system32\WINNSI.DLL
    0x362a0000 - 0x362f2000 	D:\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\233\1\.cp\swt-win32-3232.dll
    0x755a0000 - 0x7561b000 	C:\Windows\system32\comdlg32.dll
    0x61810000 - 0x61831000 	C:\Windows\system32\MSVFW32.dll
    0x73fe0000 - 0x74020000 	C:\Windows\system32\uxtheme.dll
    0x73c80000 - 0x73c93000 	C:\Windows\system32\dwmapi.dll
    0x751c0000 - 0x751cc000 	C:\Windows\system32\CRYPTBASE.dll
    0x367f0000 - 0x367f8000 	D:\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\186\1\.cp\os\win32\x86\localfile_1_0_0.dll
    0x368f0000 - 0x368f8000 	D:\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\190\1\.cp\os\win32\x86\win32refresh.dll
    0x735d0000 - 0x7360c000 	C:\Windows\system32\oleacc.dll
    0x36cb0000 - 0x36cc3000 	D:\Texas Instruments\ccsv4\eclipse\configuration\org.eclipse.osgi\bundles\233\1\.cp\swt-gdip-win32-3232.dll
    0x73e50000 - 0x73fe0000 	C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca\gdiplus.dll
    0x74ce0000 - 0x74cf6000 	C:\Windows\system32\CRYPTSP.dll
    0x74a80000 - 0x74abb000 	C:\Windows\system32\rsaenh.dll
    0x75230000 - 0x7523e000 	C:\Windows\system32\RpcRtRemote.dll
    0x7c000000 - 0x7c054000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\msvcr70.dll
    0x7c080000 - 0x7c0f7000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\msvcp70.dll
    0x7c140000 - 0x7c23d000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\mfc70.dll
    0x37020000 - 0x37031000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\cToolsIF.dll
    0x37ad0000 - 0x37b38000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\ctools.dll
    0x37b40000 - 0x37dae000 	C:\Windows\system32\xerces-c_2_5_0.dll
    0x37040000 - 0x37058000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\JTrace.dll
    0x37080000 - 0x37091000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\TraceFactory.dll
    0x37db0000 - 0x37df2000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\ICECD.dll
    0x37e00000 - 0x37e21000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\icestorm21.dll
    0x37e30000 - 0x37e4f000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\iceutil21.dll
    0x37e50000 - 0x37f2c000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\ice21.dll
    0x37f30000 - 0x37f4c000 	D:\Texas Instruments\ccsv4\emulation\analysis\bin\LIBBZ2.dll
    0x73700000 - 0x73705000 	C:\Windows\system32\msimg32.dll
    0x36ae0000 - 0x36af7000 	C:\Program Files\Common Files\PPLiveNetwork\kernel\VAProxyD.dll
    0x66dc0000 - 0x66e26000 	C:\Windows\system32\MSVCP60.dll
    0x36b00000 - 0x36b07000 	D:\Texas Instruments\ccsv4\DebugServer\bin\win32\LibraryLoader.dll
    0x703e0000 - 0x70467000 	C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCP80.dll
    0x70340000 - 0x703db000 	C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4927_none_d08a205e442db5b5\MSVCR80.dll
    0x38190000 - 0x381f3000 	D:\Texas Instruments\ccsv4\common\bin\CCReg.dll
    0x38280000 - 0x382d1000 	D:\Texas Instruments\ccsv4\common\bin\Logger.dll
    0x382e0000 - 0x38331000 	D:\Texas Instruments\ccsv4\common\bin\fsutil.dll
    0x38340000 - 0x383d3000 	D:\Texas Instruments\ccsv4\common\bin\rtdx.dll
    0x383e0000 - 0x38586000 	D:\Texas Instruments\ccsv4\common\bin\setup_parser.dll
    0x38210000 - 0x3821b000 	D:\Texas Instruments\ccsv4\common\uscif\jtagdata.dll
    0x38220000 - 0x3822e000 	D:\Texas Instruments\ccsv4\common\bin\ti_targetdb_parser.dll
    0x385a0000 - 0x38792000 	D:\Texas Instruments\ccsv4\common\bin\xerces-c_2_5_0.dll
    0x387b0000 - 0x387b7000 	D:\Texas Instruments\ccsv4\DebugServer\win32\javaxpcomglue.dll
    0x387c0000 - 0x387e8000 	D:\Texas Instruments\ccsv4\DebugServer\win32\nspr4.dll
    0x704e0000 - 0x704e7000 	C:\Windows\system32\WSOCK32.dll
    0x387f0000 - 0x387f7000 	D:\Texas Instruments\ccsv4\DebugServer\win32\plc4.dll
    0x38800000 - 0x38806000 	D:\Texas Instruments\ccsv4\DebugServer\win32\plds4.dll
    0x38810000 - 0x38882000 	D:\Texas Instruments\ccsv4\DebugServer\win32\js3250.dll
    0x38890000 - 0x38f74000 	D:\Texas Instruments\ccsv4\DebugServer\win32\xul.dll
    0x71a50000 - 0x71aa1000 	C:\Windows\system32\WINSPOOL.DRV
    0x38f80000 - 0x38f86000 	D:\Texas Instruments\ccsv4\DebugServer\win32\xpcom.dll
    0x76a20000 - 0x76aa3000 	C:\Windows\system32\CLBCatQ.DLL
    0x39050000 - 0x391ef000 	D:\Texas Instruments\ccsv4\DebugServer\win32\components\mdex.dll
    0x73880000 - 0x73891000 	C:\Windows\system32\NETAPI32.dll
    0x73870000 - 0x73879000 	C:\Windows\system32\netutils.dll
    0x74e90000 - 0x74ea9000 	C:\Windows\system32\srvcli.dll
    0x738c0000 - 0x738cf000 	C:\Windows\system32\wkscli.dll
    0x74780000 - 0x74785000 	C:\Windows\System32\wshtcpip.dll
    0x704b0000 - 0x704d5000 	C:\Program Files\Bonjour\mdnsNSP.dll
    0x70480000 - 0x704a7000 	C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
    0x70470000 - 0x70476000 	C:\Windows\system32\rasadhlp.dll
    0x39390000 - 0x3960d000 	D:\Texas Instruments\ccsv4\DebugServer\license\mdexutil.dll
    0x692e0000 - 0x692e9000 	C:\Windows\system32\snmpapi.dll
    0x76e70000 - 0x7700d000 	C:\Windows\system32\SETUPAPI.dll
    0x752c0000 - 0x752e7000 	C:\Windows\system32\CFGMGR32.dll
    0x75550000 - 0x75562000 	C:\Windows\system32\DEVOBJ.dll
    0x71870000 - 0x7187d000 	C:\Windows\system32\dhcpcsvc6.DLL
    0x71850000 - 0x71862000 	C:\Windows\system32\dhcpcsvc.DLL
    0x733e0000 - 0x733f0000 	C:\Windows\system32\NLAapi.dll
    0x6a3f0000 - 0x6a3f8000 	C:\Windows\System32\winrnr.dll
    0x6a3e0000 - 0x6a3f0000 	C:\Windows\system32\napinsp.dll
    0x6a3c0000 - 0x6a3d2000 	C:\Windows\system32\pnrpnsp.dll
    0x6abc0000 - 0x6abca000 	C:\Windows\system32\wbem\wbemprox.dll
    0x6abd0000 - 0x6ac2c000 	C:\Windows\system32\wbemcomn.dll
    0x71930000 - 0x71968000 	C:\Windows\System32\fwpuclnt.dll
    0x754a0000 - 0x754cd000 	C:\Windows\system32\WINTRUST.dll
    0x6a400000 - 0x6a40f000 	C:\Windows\system32\wbem\wbemsvc.dll
    0x39c10000 - 0x3a1a0000 	D:\Texas Instruments\ccsv4\DebugServer\win32\components\DebugServer.dll
    0x392c0000 - 0x39329000 	D:\Texas Instruments\ccsv4\DebugServer\bin\win32\tiofr11.dll
    VM Arguments:
    jvm_args: -Xms96m -Xmx512m -XX:MaxPermSize=256m -DXPCOM.RUNTIME=D:\Texas Instruments\ccsv4\DebugServer\win32 -Dxpcom.bridge.executeOnDedicatedThread=yes -Dorg.eclipse.swt.browser.XULRunnerPath=D:\Texas Instruments\ccsv4\DebugServer\win32 -Dosgi.instance.area.default=file:/F:/Documents/workspace/
    java_command: D:\Texas Instruments\ccsv4\eclipse\startup.jar -os win32 -ws win32 -arch x86 -launcher D:\Texas Instruments\ccsv4\eclipse\eclipse.exe -name Eclipse -showsplash 600 -exitdata af8_b4 -vm D:\Texas Instruments\ccsv4\eclipse\jre\bin\javaw.exe -vmargs -Xms96m -Xmx512m -XX:MaxPermSize=256m -DXPCOM.RUNTIME=D:\Texas Instruments\ccsv4\DebugServer\win32 -Dxpcom.bridge.executeOnDedicatedThread=yes -Dorg.eclipse.swt.browser.XULRunnerPath=D:\Texas Instruments\ccsv4\DebugServer\win32 -Dosgi.instance.area.default=file:/F:/Documents/workspace/ -jar D:\Texas Instruments\ccsv4\eclipse\startup.jar
    Launcher Type: SUN_STANDARD
    Environment Variables:
    CLASSPATH=.;D:\java6\lib\ext\QTJava.zip
    PATH=D:\Texas Instruments\ccsv4\common\bin;D:\Texas Instruments\ccsv4\common\uscif;D:\Texas Instruments\ccsv4\DebugServer\slicense;D:\Texas Instruments\ccsv4\eclipse\..\common\bin;D:\Texas Instruments\ccsv4\eclipse\..\common\uscif;D:\Texas Instruments\ccsv4\eclipse\..\DebugServer\license;D:/Texas Instruments/xdctools_3_16_02_32;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files\PC Connectivity Solution\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Microsoft SQL Server\90\Tools\binn\;D:\Altium Designer Winter 09\System;C:\Program Files\Common Files\Thunder Network\KanKan\Codecs;D:\MATLAB\R2010b\runtime\win32;D:\MATLAB\R2010b\bin;C:\Program Files\Common Files\TTKN\Bin;C:\Program Files\Windows Live\Shared;D:\Final Codecs\QTSystem\;D:/Texas Instruments/xdctools_3_16_02_32;D:\Texas Instruments\ccsv4\emulation\drivers
    USERNAME=MVP
    OS=Windows_NT
    PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 13, GenuineIntel
    ---------------  S Y S T E M  ---------------
    OS: Windows NT 6.1 Build 7600
    CPU:total 2 (cores per cpu 2, threads per core 1) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2
    Memory: 4k page, physical 2097151k(952860k free), swap 4194303k(3749116k free)
    vm_info: Java HotSpot(TM) Client VM (1.5.0_14-b03) for windows-x86, built on Oct  5 2007 01:21:52 by "java_re" with MS VC++ 6.0
    I have the same problem...Please help me with it. I tried almost everything, but all in vein.
    !SESSION 2011-01-20 19:00:04.603 -----------------------------------------------
    eclipse.buildId=4.1.2.00027
    java.version=1.5.0_14
    java.vendor=Sun Microsystems Inc.
    BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
    Command-line arguments:  -os win32 -ws win32 -arch x86
    !ENTRY org.eclipse.ui.ide 4 4 2011-01-20 19:10:16.326
    !MESSAGE Must specify a URI scheme:EXT_ROOT__F28335_example_BIOS_flash/ePWM_isr.c
    !ENTRY org.eclipse.core.filesystem 4 566 2011-01-20 19:10:16.329
    !SESSION 2011-01-20 19:15:01.951 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2011-01-20 19:15:04.875
    !MESSAGE A workspace crash was detected. The previous session did not exit normally.
    !SESSION 2011-01-20 19:42:01.332 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2011-01-20 19:42:04.234
    !ENTRY org.eclipse.ui.editors 2 0 2011-01-20 19:44:28.589
    !MESSAGE The selected spelling engine does not exist
    !ENTRY com.ti.ccstudio.debug.core 4 0 2011-01-20 19:59:49.013
    !MESSAGE Fatal Error: C28xx: Error connecting to the target: Error 0x80000240/-171 Fatal Error during: Initialization, OCS,
    !SESSION 2011-01-20 20:00:24.853 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2011-01-20 20:00:28.359
    !SESSION 2011-01-20 20:10:56.455 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2011-01-20 20:10:59.052
    !SESSION 2011-01-20 20:26:55.173 -----------------------------------------------
    !ENTRY org.eclipse.core.resources 2 10035 2011-01-20 20:26:58.487
    this is the eclipse error and the JVM error. Please help. I have been stuck in this for days...
  • In my case,I just upgrade CCSv4 and it works fine -_-a.
