I use CCS V5.5.0.00077. If I use the "-s" option in the gmake the "Problems" window does not get updated after having had errors (just syntax errors for example) in it and those errors are corrected.
If I remove the "-s" option from gmake then the window is updated as it should.
I thought this problems have been solved in earlier versions of CCS!?
Any ideas what the problem may be?
Patrick
