Our current applicational DSP board--DSP: C6416 and the board designed(XD510-USB2.0), can not support CCS3.3 well and its design team suggest us the CCS2.2 or use the XD560plus(may support CCS3.3 well I think). When using the *.lib(such as fastrts64x.lib), the error message happened: error: illegal relocation type 050002 found in section .debug_info, file fastrts64xe.lib. I hopely know whether I can use the fastrts64x.lib(except the rts6400.lib)) in my case.
I have tried to run the mk6x.exe(c:\ti\c6000\cgtools\bin\mk6x.exe), but error still exists. My steps:(1) copy the fastrts62x64x.src in the bin file folder; (2)run the mk6x.exe: mk6x fastrts62x64x.src -mv6400 -l fastrts64xe.lib(3)The message shows divdp.asm is wrong in my command window. I do not know the reason.
TMS320C6000 Optimizing Compiler User’s Guide comments that the Code Composer Studio provides a graphical interface for using the code generation tools.Could I use the *.lib(they run OK in CCS3.3 environment) in CCS2.2 and How can I get the Code Generation Tools Help?
Appreciated if get your suggestions
[:)]Thanks and Best Regards
