I've the same problem as this one:
[https://e2e.ti.com/support/development_tools/code_composer_studio/f/81/t/420045]
Is 45 minutes ( or longer) normal for Installation?
Than during installation, it hangs at unzipping eclipse_core_4.3.0.rtm_4_candidate.zip
If unzip it from command line, it lasts not a second!??
I cannot insert a file, there is a View-Tag in HTML ( also for the link above)??
The important lines are below:
How can I set the proxy to the exe? Why is no error-message in "interactive" time?
regards,
S.Netz
Windows 7 64 Bit SP1
ccs_setup_6.1.0.00104.exe
05/05/2015 11:51:57(GMT) - checkAV - CCS_INFO: av message child process exited abnormally
05/05/2015 11:52:01(GMT) - checkAVAgain - CCS_INFO: av message child process exited abnormally
05/05/2015 14:00:42(GMT) - checkProgramFiles - CCS_INFO: checking c:\program files (x86)
05/05/2015 14:00:42(GMT) - Util::httpCopy - http::config now: -accept */* -proxyfilter http::ProxyRequired -proxyhost {} -proxyport {} -urlencoding utf-8 -useragent {Tcl http client package 2.5.2}
05/05/2015 14:00:42(GMT) - Util::httpCopy - Downloading C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/apps_6.1.0.json from software-dl.ti.com/.../apps_6.1.0.json
05/05/2015 14:00:43(GMT) - Util::httpCopy - Could not get file software-dl.ti.com/.../apps_6.1.0.json:couldn't open socket: connection refused
05/05/2015 14:07:06(GMT) - extract - cmd = "C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/util/unzip.exe" -q -o -d "C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59" "D:/Install/CCS6.1.0.00104_win32/CCS6.1.0.00104_win32/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip"
05/05/2015 14:07:06(GMT) - extract - successfully unzipped D:/Install/CCS6.1.0.00104_win32/CCS6.1.0.00104_win32/baserepo/eclipse_core_4.3.0.rtm_4_candidate.zip
05/05/2015 14:07:06(GMT) - findLauncher - launcher version = 1.3.0.v20130327-1440
05/05/2015 14:07:06(GMT) - installEclipse - CCS_INFO: eclipsec.exe does not exist
05/05/2015 14:07:06(GMT) - installEclipse - using c:/ti/ccsv6/eclipse/jre/bin/java.exe
05/05/2015 14:07:06(GMT) - installEclipse - "c:/ti/ccsv6/eclipse/jre/bin/java.exe" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/eclipse/cfg" "-Dosgi.instance.area=C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/eclipse/ws" -jar "C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/D:/Install/CCS6.1.0.00104_win32/CCS6.1.0.00104_win32/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "c:/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "c:/ti/ccsv6/eclipse/" -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
05/05/2015 14:07:06(GMT) - runEclipseApp - running cmd "c:/ti/ccsv6/eclipse/jre/bin/java.exe" -Xmx512m -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultConnectTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 "-Dosgi.configuration.area=C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/eclipse/cfg" "-Dosgi.instance.area=C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/eclipse/ws" -jar "C:/Users/admin/AppData/Local/Temp/ccs_f1980d13-02ce-45b9-7d30-eea9fe6afd59/eclipse/plugins/org.eclipse.equinox.launcher_1.3.0.v20130327-1440.jar" -application org.eclipse.equinox.p2.director -repository "file:/D:/Install/CCS6.1.0.00104_win32/CCS6.1.0.00104_win32/baserepo/eclipserepo" -installIU org.eclipse.platform.ide,org.eclipse.help.feature.group,org.eclipse.equinox.p2.discovery.feature.feature.group,org.eclipse.equinox.p2.user.ui.feature.group,org.eclipse.cdt.feature.group,org.eclipse.cdt.debug.ui.memory.feature.group,org.eclipse.tm.terminal.sdk.feature.group,org.eclipse.epp.mpc.feature.group,org.eclipse.egit.feature.group,gnu.io.rxtx.feature.group,org.eclipse.cdt.build.crossgcc.feature.group,org.eclipse.rse.feature.group,org.eclipse.cdt.launch.remote.feature.group -destination "c:/ti/ccsv6/eclipse/" -profile epp.package.cpp -profileProperties org.eclipse.update.install.features=true -bundlepool "c:/ti/ccsv6/eclipse/" -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
