Code Composer Version 6.1.0.00104 Not able to Debug
I have been attempting to simple run the debugger in Code Composer Version 6.1.0.00104, but keep getting a message.
"You are required to terminate existing debugger session to perform the current action. Do you want to continue."
I have changed work spaces and removed the older version of Code Composer 6.0.1 in attempt to resolve the issue, but no luck. There isn't any other debugger sessions going on, and this seems like a new issue. I just recently updated my Code Composer and now having issues.
I would appreciate any help offered. Thanks.
    Did you update from CCS 6.0.1 to 6.1.0 from within CCS? We have had a couple of similar reports however we have not been able to reproduce this locally in order to investigate the root cause. If you are still able to reproduce this consistently with your project, would you mind zipping up your workspace and sending it to us so can try to reproduce the issue?
    To resolve the issue, try opening a new clean workspace and importing your project into it. If that does not help, unfortunately a complete uninstall and reinstall of CCS 6.1.0 may be necessary. You can download the installer from http://processors.wiki.ti.com/index.php/Download_CCS .
