Code Composer V6 and Gitlab - unable to pull
Other Parts Discussed in Thread: CCSTUDIO
Hi. My Code Composer version is 6.1.0.00104. I am running Windows 7 Professional Service Pack 1. I am using Code Composer to import projects from Gitlab. Everything was working fine until recently. If I try to "Pull" from the remote repository, I receive the error message: Session.connect: java.io.IOException: End of IO stream read. I am using SSH to connect to the project repository. More information is shown below. Thanks.
Anthony
!SESSION 2016-05-16 11:44:34.290 -----------------------------------------------
eclipse.buildId=4.4.1.M20140925-0400
java.version=1.7.0_60
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
This is a continuation of log file C:\Users\josh-install\workspace_v6_1\.metadata\.bak_0.log
Created Time: 2016-05-16 13:53:15.907
!ENTRY org.eclipse.egit.ui 4 0 2016-05-16 13:53:15.907
!MESSAGE Session.connect: java.io.IOException: End of IO Stream Read
!STACK 0
org.eclipse.jgit.api.errors.TransportException Session.connect: java.io.IOException: End of IO Stream Read
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:139)
at org.eclipse.jgit.api.PullCommand.call(PullCommand.java:253)
at org.eclipse.egit.core.op.PullOperation$1.run(PullOperation.java:97)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
at org.eclipse.egit.core.op.PullOperation.execute(PullOperation.java:128)
at org.eclipse.egit.ui.internal.pull.PullOperationUI.execute(PullOperationUI.java:139)
at org.eclipse.egit.ui.internal.pull.PullOperationUI$1.runInWorkspace(PullOperationUI.java:114)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.jgit.errors.TransportException Session.connect: java.io.IOException: End of IO Stream Read
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:159)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:121)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:248)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:147)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1111)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:130)
... 8 more
Caused by: com.jcraft.jsch.JSchException: Session.connect: java.io.IOException: End of IO Stream Read
at com.jcraft.jsch.Session.connect(Session.java:557)
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:116)
... 15 more
