Hi all,
I just downloaded CCSv7 and opened a workspace I've worked on recently in CCSv6. I double-checked some of the settings in Project Properties and had to change one or two which wasn't a big deal. Then I did a Clean and Build and the Build process hangs or seemingly stalls out at different percentages through the build. It always gets stopped at a percentage (different number depending on the build) and sits there not changing anything in the Details view of the Build pop-up box. It does always respond immediately when I click Cancel, and it properly cancels the Build operation every time, so I don't think its an error or bug in CCS. I've had a few different build errors related to Project Properties settings that I found and corrected, but there's always been one about gmake not found in PATH: "C:/ti/ccsv7/utils/bin/gmake is not found in PATH." I've checked the location on my computer and it is indeed located in that path, so I don't know what else to look for. I think this error is where the build is getting held up at, so I'm trying to tackle this issue.
Thanks for any help you can give,
