CCS/TMS320F28377S: Erase selected sectors of flash using DSS
Part Number: TMS320F28377S
Other Parts Discussed in Thread: CCSTUDIO
Here's the snapshot of my script so far:
debugSession = debugServer.openSession( "*","*" );
debugSession.flash.options.setString("FlashEraseSelection", "Selected Sectors Only");
debugSession.flash.options.setNumeric("FlashSPLLIMULT",19);
debugSession.flash.options.setString("FlashSPLLFMULT","0 [0]");
debugSession.flash.options.setString("FlashSYSDIVSEL","0 [/1]");
debugSession.flash.erase();
I noticed in the API document the following note
" look up the exact string for your device using the mySession.flash.options.printOptions() API" , I am not quite sure how to use this function.
How can I specify the sectors I wish to erase?
Rashmy
  • Hi Rashmy,
    Simply add the call to your script. This will print all available options for your device and the associated strings for it.
    debugSession.flash.options.printOptions(".*");
    I attached my output.
    /cfs-file/__key/communityserver-discussions-components-files/81/flash_5F00_options_5F00_f28377.txt
    if you look at the printOptions output, you can see:
    Radio Button Option:
        name: TMS320C28XX.Flash Settings.Erase Settings.
        value: Entire Flash
        choices:
            Entire Flash
            Necessary Sectors Only (for Program Load)
    Boolean Option:
        name: TMS320C28XX.Flash Settings.Erase Settings.Sector A (0x80000 - 0x81FFF)
        value: true
    Boolean Option:
        name: TMS320C28XX.Flash Settings.Erase Settings.Sector B (0x82000 - 0x83FFF)
        value: true
    Boolean Option:
        name: TMS320C28XX.Flash Settings.Erase Settings.Sector C (0x84000 - 0x85FFF)
        value: true
    So an example of erasing just the first two sectors would look like:
    session.flash.options.setString("FlashEraseSelection","Selected Sectors Only");
    session.flash.options.setBoolean("FlashC28Bank0Sector0",true);
    session.flash.options.setBoolean("FlashC28Bank0Sector1",true);
    session.flash.options.setBoolean("FlashC28Bank0Sector2",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector3",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector4",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector5",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector6",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector7",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector8",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector9",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector10",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector11",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector12",false);
    session.flash.options.setBoolean("FlashC28Bank0Sector13",false);
    session.flash.erase();
    ki
  • Thanks for your response, Ki. However I get this error " Target is not connected or does not support current Flash operation. " for the line session.flash.erase(). Does the API not support erase for TMS320F28377S ?
    Rashmy
  • It should work. I tried it with my F28377S LaunchPad. Is your target indeed connected? Can I see the rest of your script?
    ki
  • My target is connected, I tried testing the connection from my target configuration file and it is successful. I am able to flash using CCS IDE. However my script does not work as expected. Here's the rest of my script.
    // Import the DSS packages
    importPackage(Packages.com.ti.debug.engine.scripting)
    importPackage(Packages.com.ti.ccstudio.scripting.environment)
    importPackage(Packages.java.lang)
    // Configurable Parameters
    var deviceCCXMLFile = "../TMS320F28377S.ccxml";
    //var programToLoad = "../DSP_28377_4_jointmodule.out";
    var programToLoad = "../DSP_28377_jointmodule.bin";
    // Create scripting environment object
    var script = ScriptingEnvironment.instance();
    // Create a debug server
    var debugServer = script.getServer( "DebugServer.1" );
    // Set the device ccxml
    debugServer.setConfig( deviceCCXMLFile );
    // Open a debug session
    print(debugSession.flash.options.getString("FlashEraseSelection"));
    //debugSession.flash.options.printOptions(".*");
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector0",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector1",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector2",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector3",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector4",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector5",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector6",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector7",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector8",true);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector9",true);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector10",true);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector11",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector12",false);
    debugSession.flash.options.setBoolean("FlashC28Bank0Sector13",false);
    // Connect to the target
    debugSession.target.connect();
    // Load the program
    debugSession.memory.loadBinaryProgram( programToLoad,0xB0000);
    //debugSession.memory.loadProgram( programToLoad);
    // Run the program
    debugSession.target.run();
    // Disconnect from the target
    debugSession.target.disconnect();
    debugSession.terminate();
    debugServer.stop();
    Please let me know if I am missing something.
    Rashmy
    your target connect call is coming AFTER your call to erase the flash. You need to be connect to the target first before you can try to erase the flash
  • I am able to erase now. Thanks for your help.
