CCS: CCS v8 installation fails -- Java
I have downloaded both the CCS8.1.0.00011 and CCS8.2.0.00007 installers -- the web version AND the offline ones. I am running Ubuntu 16.04:
aero@drone3:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=16.04
DISTRIB_CODENAME=xenial
DISTRIB_DESCRIPTION="Ubuntu 16.04.5 LTS"
aero@drone3:~$ uname -a
Linux drone3 4.4.76-aero-1.2 #1 SMP PREEMPT Thu Dec 21 09:55:38 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
It looks like both CCS packages for installation come with or download the following file: jre-8u112-linux-x64.zip
The problem is that when the installer attempts to extract this file using p7zip, (7za) there is an error at the end, which apparently the installer checks for and decides to abort (v8.2) with an error mentioning something about "logger:loglist" or keeps re-trying again and again (v8.1). I even tried to use a later version of 7za downloaded from the official website to see if the problem was the outdated extractor (circa 2010), but the same error occurred, which leads me to the conclusion that the archive is corrupt, perhaps.
So, with this issue, I'm at a loss as to how to install CCS v8 successfully currently and do not have a workaround available to install it on the affected system. I have attached a copy of the log of how the 8.1 installer shows the error message after extraction.
Please provide a workaround or solution :)
10/22/2018 21:16:10(GMT) - extract - cmd = "/tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/util/7za" x "/tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/downloads/jre-8u112-linux-x64.zip" -o"/opt/ti/ccsv8/eclipse" -y
10/22/2018 21:16:10(GMT) - extract - changed permissions on /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/7zaexe.sh
10/22/2018 21:16:16(GMT) - extract - Found file /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/7zaexe.sh
10/22/2018 21:16:16(GMT) - extract - reading /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/7zaexe.sh
10/22/2018 21:16:16(GMT) - extract - #!/bin/sh
10/22/2018 21:16:16(GMT) - extract - "/tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/util/7za" x "/tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/downloads/jre-8u112-linux-x64.zip" -o"/opt/ti/ccsv8/eclipse" -y
10/22/2018 21:16:16(GMT) - extract - found file /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/util/7za
10/22/2018 21:16:16(GMT) - extract - found directory /opt/ti/ccsv8/eclipse
10/22/2018 21:16:16(GMT) - extract - found file /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/downloads/jre-8u112-linux-x64.zip
10/22/2018 21:16:16(GMT) - extract - couldn't unzip /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/downloads/jre-8u112-linux-x64.zip:
7-Zip (A) [64] 9.20  Copyright (c) 1999-2010 Igor Pavlov  2010-11-18
p7zip Version 9.20 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,4 CPUs)
Processing archive: /tmp/ccs_356f8e4a-4c35-4a1a-67f4-8892bf2df511/downloads/jre-8u112-linux-x64.zip
Extracting  jre
Extracting  jre/Welcome.html
Extracting  jre/bin
Extracting  jre/bin/jjs
Extracting  jre/bin/policytool
Extracting  jre/bin/unpack200
Extracting  jre/bin/keytool
Extracting  jre/bin/orbd
Extracting  jre/bin/servertool
Extracting  jre/bin/rmiregistry
Extracting  jre/bin/jcontrol
Extracting  jre/bin/rmid
Extracting  jre/bin/tnameserv
Extracting  jre/bin/javaws
Extracting  jre/bin/pack200
Extracting  jre/bin/ControlPanel
Extracting  jre/plugin
Extracting  jre/plugin/desktop
Extracting  jre/plugin/desktop/sun_java.desktop
Extracting  jre/plugin/desktop/sun_java.png
Extracting  jre/README
Extracting  jre/THIRDPARTYLICENSEREADME-JAVAFX.txt
Extracting  jre/THIRDPARTYLICENSEREADME.txt
Extracting  jre/man
Extracting  jre/man/ja
Extracting  jre/man/man1
Extracting  jre/man/man1/jjs.1
Extracting  jre/man/man1/rmiregistry.1
Extracting  jre/man/man1/keytool.1
Extracting  jre/man/man1/unpack200.1
Extracting  jre/man/man1/pack200.1
Extracting  jre/man/man1/java.1
Extracting  jre/man/man1/rmid.1
Extracting  jre/man/man1/servertool.1
Extracting  jre/man/man1/orbd.1
Extracting  jre/man/man1/tnameserv.1
Extracting  jre/man/man1/policytool.1
Extracting  jre/man/man1/javaws.1
Extracting  jre/man/ja_JP.UTF-8
Extracting  jre/man/ja_JP.UTF-8/man1
Extracting  jre/man/ja_JP.UTF-8/man1/jjs.1
Extracting  jre/man/ja_JP.UTF-8/man1/rmiregistry.1
Extracting  jre/man/ja_JP.UTF-8/man1/keytool.1
Extracting  jre/man/ja_JP.UTF-8/man1/unpack200.1
Extracting  jre/man/ja_JP.UTF-8/man1/pack200.1
Extracting  jre/man/ja_JP.UTF-8/man1/java.1
Extracting  jre/man/ja_JP.UTF-8/man1/rmid.1
Extracting  jre/man/ja_JP.UTF-8/man1/servertool.1
Extracting  jre/man/ja_JP.UTF-8/man1/orbd.1
Extracting  jre/man/ja_JP.UTF-8/man1/tnameserv.1
Extracting  jre/man/ja_JP.UTF-8/man1/policytool.1
Extracting  jre/man/ja_JP.UTF-8/man1/javaws.1
Extracting  jre/release
Extracting  jre/lib
Extracting  jre/lib/logging.properties
Extracting  jre/lib/fontconfig.RedHat.6.bfc
Extracting  jre/lib/management-agent.jar
Extracting  jre/lib/fontconfig.Turbo.bfc
Extracting  jre/lib/fontconfig.RedHat.6.properties.src
Extracting  jre/lib/applet
Extracting  jre/lib/charsets.jar
Extracting  jre/lib/fontconfig.SuSE.10.properties.src
Extracting  jre/lib/oblique-fonts
Extracting  jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf
Extracting  jre/lib/oblique-fonts/fonts.dir
Extracting  jre/lib/oblique-fonts/LucidaSansOblique.ttf
Extracting  jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf
Extracting  jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf
Extracting  jre/lib/meta-index
Extracting  jre/lib/psfont.properties.ja
Extracting  jre/lib/fontconfig.RedHat.5.bfc
Extracting  jre/lib/hijrah-config-umalqura.properties
Extracting  jre/lib/jexec
Extracting  jre/lib/locale
Extracting  jre/lib/locale/zh_HK.BIG5HK
Extracting  jre/lib/locale/zh_HK.BIG5HK/LC_MESSAGES
Extracting  jre/lib/locale/zh_HK.BIG5HK/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/it
Extracting  jre/lib/locale/it/LC_MESSAGES
Extracting  jre/lib/locale/it/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/ko.UTF-8
Extracting  jre/lib/locale/ko.UTF-8/LC_MESSAGES
Extracting  jre/lib/locale/ko.UTF-8/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/sv
Extracting  jre/lib/locale/sv/LC_MESSAGES
Extracting  jre/lib/locale/sv/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/ko/LC_MESSAGES
Extracting  jre/lib/locale/ko/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/de
Extracting  jre/lib/locale/de/LC_MESSAGES
Extracting  jre/lib/locale/de/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/zh_TW.BIG5
Extracting  jre/lib/locale/zh_TW.BIG5/LC_MESSAGES
Extracting  jre/lib/locale/zh_TW.BIG5/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/ja
Extracting  jre/lib/locale/ja/LC_MESSAGES
Extracting  jre/lib/locale/ja/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/zh.GBK
Extracting  jre/lib/locale/zh.GBK/LC_MESSAGES
Extracting  jre/lib/locale/zh.GBK/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/fr
Extracting  jre/lib/locale/fr/LC_MESSAGES
Extracting  jre/lib/locale/fr/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/es
Extracting  jre/lib/locale/es/LC_MESSAGES
Extracting  jre/lib/locale/es/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/zh_TW/LC_MESSAGES
Extracting  jre/lib/locale/zh_TW/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/zh/LC_MESSAGES
Extracting  jre/lib/locale/zh/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/locale/pt_BR
Extracting  jre/lib/locale/pt_BR/LC_MESSAGES
Extracting  jre/lib/locale/pt_BR/LC_MESSAGES/sunw_java_plugin.mo
Extracting  jre/lib/jvm.hprof.txt
Extracting  jre/lib/net.properties
Extracting  jre/lib/fonts
Extracting  jre/lib/fonts/LucidaTypewriterBold.ttf
Extracting  jre/lib/fonts/LucidaBrightDemiItalic.ttf
Extracting  jre/lib/fonts/LucidaTypewriterRegular.ttf
Extracting  jre/lib/fonts/LucidaBrightItalic.ttf
Extracting  jre/lib/fonts/LucidaBrightDemiBold.ttf
Extracting  jre/lib/fonts/LucidaSansRegular.ttf
Extracting  jre/lib/fonts/fonts.dir
Extracting  jre/lib/fonts/LucidaSansDemiBold.ttf
Extracting  jre/lib/fonts/LucidaBrightRegular.ttf
Extracting  jre/lib/plugin.jar
Extracting  jre/lib/classlist
Extracting  jre/lib/resources.jar
Extracting  jre/lib/javaws.jar
Extracting  jre/lib/fontconfig.properties.src
Extracting  jre/lib/jfxswt.jar
Extracting  jre/lib/cmm
Extracting  jre/lib/cmm/sRGB.pf
Extracting  jre/lib/cmm/CIEXYZ.pf
Extracting  jre/lib/cmm/LINEAR_RGB.pf
Extracting  jre/lib/cmm/GRAY.pf
Extracting  jre/lib/cmm/PYCC.pf
Extracting  jre/lib/jsse.jar
Extracting  jre/lib/rt.jar
Extracting  jre/lib/sound.properties
Extracting  jre/lib/desktop
Extracting  jre/lib/desktop/mime
Extracting  jre/lib/desktop/mime/packages
Extracting  jre/lib/desktop/mime/packages/x-java-archive.xml
Extracting  jre/lib/desktop/mime/packages/x-java-jnlp-file.xml
Extracting  jre/lib/desktop/icons
Extracting  jre/lib/desktop/icons/LowContrast
Extracting  jre/lib/desktop/icons/LowContrast/16x16
Extracting  jre/lib/desktop/icons/LowContrast/16x16/mimetypes
Extracting  jre/lib/desktop/icons/LowContrast/16x16/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/LowContrast/16x16/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/LowContrast/16x16/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/LowContrast/16x16/apps
Extracting  jre/lib/desktop/icons/LowContrast/16x16/apps/sun-java.png
Extracting  jre/lib/desktop/icons/LowContrast/16x16/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/LowContrast/16x16/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/LowContrast/48x48
Extracting  jre/lib/desktop/icons/LowContrast/48x48/mimetypes
Extracting  jre/lib/desktop/icons/LowContrast/48x48/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/LowContrast/48x48/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/LowContrast/48x48/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/LowContrast/48x48/apps
Extracting  jre/lib/desktop/icons/LowContrast/48x48/apps/sun-java.png
Extracting  jre/lib/desktop/icons/LowContrast/48x48/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/LowContrast/48x48/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/hicolor
Extracting  jre/lib/desktop/icons/hicolor/16x16
Extracting  jre/lib/desktop/icons/hicolor/16x16/mimetypes
Extracting  jre/lib/desktop/icons/hicolor/16x16/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/hicolor/16x16/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/hicolor/16x16/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/hicolor/16x16/apps
Extracting  jre/lib/desktop/icons/hicolor/16x16/apps/sun-java.png
Extracting  jre/lib/desktop/icons/hicolor/16x16/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/hicolor/16x16/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/hicolor/48x48
Extracting  jre/lib/desktop/icons/hicolor/48x48/mimetypes
Extracting  jre/lib/desktop/icons/hicolor/48x48/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/hicolor/48x48/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/hicolor/48x48/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/hicolor/48x48/apps
Extracting  jre/lib/desktop/icons/hicolor/48x48/apps/sun-java.png
Extracting  jre/lib/desktop/icons/hicolor/48x48/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/hicolor/48x48/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/HighContrast
Extracting  jre/lib/desktop/icons/HighContrast/16x16
Extracting  jre/lib/desktop/icons/HighContrast/16x16/mimetypes
Extracting  jre/lib/desktop/icons/HighContrast/16x16/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/HighContrast/16x16/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/HighContrast/16x16/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/HighContrast/16x16/apps
Extracting  jre/lib/desktop/icons/HighContrast/16x16/apps/sun-java.png
Extracting  jre/lib/desktop/icons/HighContrast/16x16/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/HighContrast/16x16/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/HighContrast/48x48
Extracting  jre/lib/desktop/icons/HighContrast/48x48/mimetypes
Extracting  jre/lib/desktop/icons/HighContrast/48x48/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/HighContrast/48x48/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/HighContrast/48x48/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/HighContrast/48x48/apps
Extracting  jre/lib/desktop/icons/HighContrast/48x48/apps/sun-java.png
Extracting  jre/lib/desktop/icons/HighContrast/48x48/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/HighContrast/48x48/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/HighContrastInverse
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/mimetypes
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/apps
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/apps/sun-java.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/16x16/apps/sun-javaws.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/mimetypes
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/mimetypes/gnome-mime-application-x-java-jnlp-file.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/mimetypes/gnome-mime-text-x-java.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/mimetypes/gnome-mime-application-x-java-archive.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/apps
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/apps/sun-java.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/apps/sun-jcontrol.png
Extracting  jre/lib/desktop/icons/HighContrastInverse/48x48/apps/sun-javaws.png
Extracting  jre/lib/desktop/applications
Extracting  jre/lib/desktop/applications/sun-java.desktop
Extracting  jre/lib/desktop/applications/sun_java.desktop
Extracting  jre/lib/desktop/applications/sun-javaws.desktop
Extracting  jre/lib/flavormap.properties
Extracting  jre/lib/calendars.properties
Extracting  jre/lib/fontconfig.SuSE.11.bfc
Extracting  jre/lib/fontconfig.bfc
Extracting  jre/lib/jfr.jar
Extracting  jre/lib/currency.data
Extracting  jre/lib/fontconfig.Turbo.properties.src
Extracting  jre/lib/content-types.properties
Extracting  jre/lib/security
Extracting  jre/lib/security/US_export_policy.jar
Extracting  jre/lib/security/local_policy.jar
Extracting  jre/lib/security/java.policy
Extracting  jre/lib/security/blacklist
Extracting  jre/lib/security/javaws.policy
Extracting  jre/lib/security/trusted.libraries
Extracting  jre/lib/security/blacklisted.certs
Extracting  jre/lib/security/java.security
Extracting  jre/lib/security/cacerts
Extracting  jre/lib/ext
Extracting  jre/lib/ext/localedata.jar
Extracting  jre/lib/ext/nashorn.jar
Extracting  jre/lib/ext/meta-index
Extracting  jre/lib/ext/jfxrt.jar
Extracting  jre/lib/ext/sunec.jar
Extracting  jre/lib/ext/sunpkcs11.jar
Extracting  jre/lib/ext/jaccess.jar
Extracting  jre/lib/ext/zipfs.jar
Extracting  jre/lib/ext/cldrdata.jar
Extracting  jre/lib/ext/sunjce_provider.jar
Extracting  jre/lib/ext/dnsns.jar
Extracting  jre/lib/javafx.properties
Extracting  jre/lib/images
Extracting  jre/lib/images/icons
Extracting  jre/lib/images/icons/sun-java_HighContrast.png
Extracting  jre/lib/images/icons/sun-java_LowContrast.png
Extracting  jre/lib/images/icons/sun-java.png
Extracting  jre/lib/images/icons/sun-java_HighContrastInverse.png
Extracting  jre/lib/images/cursors
Extracting  jre/lib/images/cursors/motif_MoveDrop32x32.gif
Extracting  jre/lib/images/cursors/motif_CopyNoDrop32x32.gif
Extracting  jre/lib/images/cursors/motif_CopyDrop32x32.gif
Extracting  jre/lib/images/cursors/motif_LinkNoDrop32x32.gif
Extracting  jre/lib/images/cursors/cursors.properties
Extracting  jre/lib/images/cursors/motif_LinkDrop32x32.gif
Extracting  jre/lib/images/cursors/motif_MoveNoDrop32x32.gif
Extracting  jre/lib/images/cursors/invalid32x32.gif
Extracting  jre/lib/fontconfig.SuSE.10.bfc
Extracting  jre/lib/fontconfig.RedHat.5.properties.src
Extracting  jre/lib/tzdb.dat
Extracting  jre/lib/fontconfig.SuSE.11.properties.src
Extracting  jre/lib/jce.jar
Extracting  jre/lib/management/snmp.acl.template
Extracting  jre/lib/management/jmxremote.access
Extracting  jre/lib/management/jmxremote.password.template
Extracting  jre/lib/management/management.properties
Extracting  jre/lib/jfr/profile.jfc
Extracting  jre/lib/jfr/default.jfc
Extracting  jre/lib/psfontj2d.properties
Extracting  jre/lib/deploy
Extracting  jre/lib/deploy/splash_11@2x-lic.gif
Extracting  jre/lib/deploy/MixedCodeMainDialog.ui
Extracting  jre/lib/deploy/cautionshield.icns
Extracting  jre/lib/deploy/messages_zh_HK.properties
Extracting  jre/lib/deploy/splash_11-lic.gif
Extracting  jre/lib/deploy/messages_pt_BR.properties
Extracting  jre/lib/deploy/messages.properties
Extracting  jre/lib/deploy/splash@2x.gif
Extracting  jre/lib/deploy/messages_de.properties
Extracting  jre/lib/deploy/splash.gif
Extracting  jre/lib/deploy/java-icon.ico
Extracting  jre/lib/deploy/ffjcext.zip
Extracting  jre/lib/deploy/messages_fr.properties
Extracting  jre/lib/deploy/messages_es.properties
Extracting  jre/lib/deploy/messages_it.properties
Extracting  jre/lib/deploy/MixedCodeMainDialogJs.ui
Extracting  jre/lib/deploy/messages_zh_CN.properties
Extracting  jre/lib/deploy/mixcode_s.png
Extracting  jre/lib/deploy/messages_sv.properties
Extracting  jre/lib/deploy/messages_ko.properties
Extracting  jre/lib/deploy/messages_zh_TW.properties
Extracting  jre/lib/deploy/messages_ja.properties
Extracting  jre/lib/amd64
Extracting  jre/lib/amd64/libjava.so
Extracting  jre/lib/amd64/libinstrument.so
Extracting  jre/lib/amd64/libverify.so
Extracting  jre/lib/amd64/libavplugin-ffmpeg-56.so
Extracting  jre/lib/amd64/libbci.so
Extracting  jre/lib/amd64/libglass.so
Extracting  jre/lib/amd64/libnio.so
Extracting  jre/lib/amd64/libawt_xawt.so
Extracting  jre/lib/amd64/libdecora_sse.so
Extracting  jre/lib/amd64/libresource.so
Extracting  jre/lib/amd64/libjaas_unix.so
Extracting  jre/lib/amd64/libmanagement.so
Extracting  jre/lib/amd64/libjfr.so
Extracting  jre/lib/amd64/libmlib_image.so
Extracting  jre/lib/amd64/libjavafx_font_freetype.so
Extracting  jre/lib/amd64/libjfxwebkit.so
Extracting  jre/lib/amd64/libsunec.so
Extracting  jre/lib/amd64/libjavafx_font_t2k.so
Extracting  jre/lib/amd64/libzip.so
Extracting  jre/lib/amd64/libdeploy.so
Extracting  jre/lib/amd64/libjdwp.so
Extracting  jre/lib/amd64/libt2k.so
Extracting  jre/lib/amd64/libdcpr.so
Extracting  jre/lib/amd64/libavplugin-54.so
Extracting  jre/lib/amd64/libsctp.so
Extracting  jre/lib/amd64/libprism_sw.so
Extracting  jre/lib/amd64/libjavafx_font.so
Extracting  jre/lib/amd64/libjsoundalsa.so
Extracting  jre/lib/amd64/libnet.so
Extracting  jre/lib/amd64/libprism_es2.so
Extracting  jre/lib/amd64/libjfxmedia.so
Extracting  jre/lib/amd64/libawt_headless.so
Extracting  jre/lib/amd64/libkcms.so
Extracting  jre/lib/amd64/libjsound.so
Extracting  jre/lib/amd64/libavplugin-53.so
Extracting  jre/lib/amd64/libunpack.so
Extracting  jre/lib/amd64/libfxplugins.so
Extracting  jre/lib/amd64/jli
Extracting  jre/lib/amd64/jli/libjli.so
Extracting  jre/lib/amd64/libavplugin-55.so
Extracting  jre/lib/amd64/libj2pkcs11.so
Extracting  jre/lib/amd64/libgstreamer-lite.so
Extracting  jre/lib/amd64/libnpjp2.so
Extracting  jre/lib/amd64/libjavafx_font_pango.so
Extracting  jre/lib/amd64/libj2pcsc.so
Extracting  jre/lib/amd64/libawt.so
Extracting  jre/lib/amd64/libjpeg.so
Extracting  jre/lib/amd64/server
Extracting  jre/lib/amd64/server/libjvm.so
Extracting  jre/lib/amd64/server/Xusage.txt
Extracting  jre/lib/amd64/server/libjsig.so
Extracting  jre/lib/amd64/libjava_crw_demo.so
Extracting  jre/lib/amd64/liblcms.so
Extracting  jre/lib/amd64/libj2gss.so
Extracting  jre/lib/amd64/libjsdt.so
Extracting  jre/lib/amd64/jvm.cfg
Extracting  jre/lib/amd64/libsplashscreen.so
Extracting  jre/lib/amd64/libavplugin-56.so
Extracting  jre/lib/amd64/libjawt.so
Extracting  jre/lib/amd64/libhprof.so
Extracting  jre/lib/amd64/libfontmanager.so
Extracting  jre/lib/amd64/libjavafx_iio.so
Extracting  jre/lib/amd64/libdt_socket.so
Extracting  jre/lib/amd64/libnpt.so
Extracting  jre/lib/amd64/libjsig.so
Extracting  jre/lib/amd64/libprism_common.so
Extracting  jre/lib/deploy.jar
Extracting  jre/LICENSE
Extracting  jre/COPYRIGHT
ERROR: E_FAIL
child process exited abnormally
trying to extract manually with v8.2 installer:
aero@drone3:/tmp/ccs_a2475ec4-4c8b-45c8-4ee3-7ca715b6c374$ sudo "/tmp/ccs_a2475ec4-4c8b-45c8-4ee3-7ca715b6c374/util/7za" x "/tmp/ccs_a2475ec4-4c8b-45c8-4ee3-7ca715b6c374/downloads/jre-8u112-linux-x64.zip" -o"/opt/ti/ccsv8/eclipse" -y
7-Zip (a) [32] 16.02 : Copyright (c) 1999-2016 Igor Pavlov : 2016-05-21
p7zip Version 16.02 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,32 bits,4 CPUs Intel(R) Atom(TM) x7-Z8750  CPU @ 1.60GHz (406C4),ASM,AES-NI)
Scanning the drive for archives:
1 file, 73825824 bytes (71 MiB)
Extracting archive: /tmp/ccs_a2475ec4-4c8b-45c8-4ee3-7ca715b6c374/downloads/jre-8u112-linux-x64.zip
Path = /tmp/ccs_a2475ec4-4c8b-45c8-4ee3-7ca715b6c374/downloads/jre-8u112-linux-x64.zip
Type = zip
Physical Size = 73825824
ERROR: E_FAIL
Archives with Errors: 1
  • So after a bit more digging, and re-creating an archive with the exact same JRE files, the issue persisted. It turns out that for whatever reason the extraction error is encountered when writing to a mounted vfat partition on a microSD card. Attempting to install to a different linux-native (ext4) partition resolved the issue.
    My workaround will be to copy the installation to the microSD card after the fact and then use a symbolic link to match the original installation path.
    This thread can be closed.
  • Glad to hear you resolved the issue and thank you for sharing your findings!
    ki
  • Thanks for posting. I have run into the same problem with CCS 8.2 and 7zip failing to unzip the downloaded Zip file. I am still unable to install it.
    These are the last log entries in the install log:
    11/22/2018 08:18:45(GMT) - handler - reading file13
    p7zip Version 9.20 (locale=en_AU.UTF-8,Utf16=on,HugeFiles=on,2 CPUs)
    Processing archive: /tmp/ccs_c90c2be0-a70b-497c-6ab9-ae6551b2d803/baserepo/eclipse_core_4.5.1.custom-160121.zip
    Error: Can not open file as archive
    11/22/2018 08:18:45(GMT) - extract - Failed to extract so checking the error_msg
    It looks like you may be having problems downloading files. Could you please try the offline installer?
    Danish
