hellow sir,
i am working msp430f2252 using ccsv7. here i getting problem in ccs.
for
Description Resource Path Location Type
gmake: *** [main.obj] Error 1 apl C/C++ Problem
gmake: Target 'all' not remade because of errors. projectName C/C++ Problem.
i write piece of code and joining every piece of code it will generate this error ..
my work is pending for this error.
so pls solve or give solution immediately.
Thanking You
siranjeevi.m
Please save the full output seen in the CCS build console to a text file and attach it here. That should provide more details about the errors you are seeing.
siranjeevi mahadevan said:"Type gmake: Target 'all' not remade because of errors.
There are usually prior errors preceding this final error message. Please take a look at the CCS build console and carefully look for error messages - they will also be summarized in the CCS Problems view.
If you need further help in understanding the errors, we would need to see the full build output (not just this final message).
The sample codes provided by TI are all included in MSP430Ware.
hi,
i have found my problem in this line
#pragma vector=USCIAB0TX_VECTOR
if i delete this line no error
otherwise to generate Type gmake:Target all not remade because of error.
can you explain about #pragma and remain vector usage detail of this
thanking you
siranjeevi
From a compiler perspective, you can find details about this pragma, its usage and syntax in the MSP430 Compiler Users Guide, section 5.12.30.
To better understand how it is used I would suggest taking a look at some of the examples provided in MSP430Ware. You can import some of those example projects into CCS and compare them with your project to identify and address any differences.
