Hi Team,
I have a customer who created a project initially on CCS 7.4.0.00015 on their Windows 7 system. They are trying to import their project on to their new Windows 10 system but are running into some issues.
Could you help provide some insights on if CCS 7.4.0.00015 is supported on Windows 10? And what would be the best way for our customer to proceed?
Please see our customer's description below:
In the import dialog window, we click on browse and select our project directory. Afterwards, we don’t see any projects in the dialog window.
This process works on the windows 7 system.
Thanks for the help and best regards,
Jerry
Alexander Sacharov said:Then I copied the installed system from VM W7x64 to W10 C:/ti.
How did you do that?
What did you get?
Please zip amd post your ccs_setup_9.0.1.00004_install.log
Hi Jerry,
I have solved this problem via install with login in W10 as Administrator. I tried to start the installation of CCS9 and it started fine now without any messages. Pleas check whether it works for you.
Alexander
