Dear Sir,
I am facing an issue while saving my IP address from the online portal. all other settings I can change but while changing static IP it's not retaining in the memory and showing a popup message which is as below.
I am using static IP for the application. So the firmware is as per static not DHCP.
I have not heard back from you. I assume you problem is resolved. I will close this thread for now. If you have new questions you can open a new thread. If your problem is not resolved, you can reply back to this thread to provide your update.
