On my CCS 5.3 installation:
Open project..
Introduce a compilation error.
Build.
Problems window shows the error.
Remove the compilation error.
Build again, without problems.
Problems window still shows the old error.
Bug or local problem?
Open project..
Build.
Hi Davor,
would you be willing to send us your project (offline is also fine - my ID is a link you can use for a conversation/friend request)? I have not be able to reproduce this with a couple quick tests. Have you tried a fresh workspace or deleting the projects .metadata?
Lisa
Hi Lisa,
I just tried it with a fresh workspace and created an empty project (with main.c). And, I couldn't reproduce it! But then I remembered that I always use Console Verbosity Level = Super Quet. (Preferences -> Code Composer Studio -> Build). And the new workspace has the default value of Normal.
So, this problem seems to appear only if Console Verbosity Level is set to Super Quiet.
Hi Davor,
I do seem to be able to reproduce this when in super quiet mode. I have noticed a clean clears the problem view and at the moment is a work around for you.
I have filed this as bug SDSCM00046140
You should be able to follow it here
Lisa
