Part Number: IWR1642BOOST
Hi there is a problem with CCS.
I am wondering how to solve this problem
**** Clean-only build of configuration Debug for project vitalSigns_16xx_dss **** "C:\\ti\\ccs930\\ccs\\utils\\bin\\gmake" -k -j 12 clean -O DEL /F "vitalSigns_16xx_dss.hex" "configPkg\linker.cmd" "configPkg\compiler.opt" "vitalSigns_16xx_dss.xe674" DEL /F "dss_config_edma_util.oe674" "dss_data_path.oe674" "dss_main.oe674" "dss_vitalSignsDemo_utilsFunc.oe674" DEL /F "dss_config_edma_util.d" "dss_data_path.d" "dss_main.d" "dss_vitalSignsDemo_utilsFunc.d" RMDIR /S/Q "configPkg\" C:\new\vitalSigns_16xx_dss\Debug\vitalSigns_16xx_dss.hex을(를) 찾을 수 없습니다. C:\new\vitalSigns_16xx_dss\Debug\configPkg\linker.cmd을(를) 찾을 수 없습니다. C:\new\vitalSigns_16xx_dss\Debug\vitalSigns_16xx_dss.xe674을(를) 찾을 수 없습니다. C:\new\vitalSigns_16xx_dss\Debug\dss_config_edma_util.oe674을(를) 찾을 수 없습니다. C:\new\vitalSigns_16xx_dss\Debug\dss_config_edma_util.d을(를) 찾을 수 없습니다. Finished clean **** Build Finished **** **** Build of configuration Debug for project vitalSigns_16xx_dss **** "C:\\ti\\ccs930\\ccs\\utils\\bin\\gmake" -k -j 12 all -O rm -f C:/new/vitalSigns_16xx_dss/vitalSigns_16xx_dss.bin makefile:188: recipe for target 'pre-build' failed process_begin: CreateProcess(NULL, rm -f C:/new/vitalSigns_16xx_dss/vitalSigns_16xx_dss.bin, ...) failed. make (e=2): 지정된 파일을 찾을 수 없습니다. gmake[1]: [pre-build] Error 2 (ignored) Building file: "../dss_mmw.cfg" Invoking: XDCtools "C:/ti/ccs930/xdctools_3_50_04_43_core/xs" --xdcpath="C:/ti/bios_6_53_02_00/packages;" xdc.tools.configuro -o configPkg -t ti.targets.elf.C674 -p ti.platforms.c6x:AWR16XX:false:600 -r debug -c "C:/ti/ccs930/ccs/tools/compiler/ti-cgt-c6000_8.3.5" "../dss_mmw.cfg" subdir_rules.mk:19: recipe for target 'build-1788522337-inproc' failed C:/Users/Baeks/AppData/Local/Temp/make2968-1.sh: Can't open C:/Users/Baeks/AppData/Local/Temp/make2968-1.sh: No such file or directory C:/ti/ccs930/xdctools_3_50_04_43_core/packages/xdc/bld/xdc_rules.mak:307: *** Error: Specified build configuration file '' is not found. Stop. js: "C:/ti/ccs930/xdctools_3_50_04_43_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted. gmake[2]: *** [build-1788522337-inproc] Error 1 gmake[1]: *** [build-1788522337] Error 2 gmake[1]: Target 'main-build' not remade because of errors. subdir_rules.mk:16: recipe for target 'build-1788522337' failed makefile:155: recipe for target 'all' failed gmake: *** [all] Error 2 **** Build Finished ****
