Part Number: TMS320C6748
I2C Slave communication test is performed using the I2C_Slave_lcdkOMAPL138_c674xTestProject project.
I set to non-dma interrupt mode and try to communicate with the other board, but after the I2C_transfer function in the 416th line, it does not move to the next line.
Even if I give Master signal TX / RX from the opponent board, I don't respond, and I want you to tell me if the code is strange or if the test method is wrong.
* \file main_test.c
* \brief The application Demonstrate the I2C master/slave mode functionality.
* I2C data are transferred from master to slave and at the
* same instance data from slave are transferred to master.
* \details
* To demonstrate the example two boards are needed one board
* acts as master and another as slave.
* Following is the Pin connection information:
* MasterI2C_SCL-----SlaveI2C_SCL
* MasterI2C_SDA-----SlaveI2C_SDA
* \Running the example
* 1) Connect the master and slave boards as per above pin connections.
* 2) Two consoles. One for master and another for slave.
* 3) Run slave application binary and then master application binary.
* \Output
* At slave end console:
* All tests have passed.
* At master end console:
* Copyright (C) 2016-2017 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <string.h>
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/cfg/global.h>
#include <xdc/runtime/System.h>
#include <stdio.h>
#include <ti/sysbios/knl/Task.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <xdc/runtime/Error.h>
/* CSL Header files */
#ifdef _TMS320C6X
#include <ti/csl/csl_chip.h>
#endif
/* OSAL Header files */
#include <ti/osal/osal.h>
/* TI-RTOS Header files */
#include <ti/drv/i2c/I2C.h>
#include <ti/drv/i2c/soc/I2C_soc.h>
#include <ti/drv/i2c/src/I2C_osal.h>
#include <ti/drv/i2c/test/src/I2C_log.h>
/* Board Header files */
#include <ti/board/board.h>
* slave address for master/slave board to board test, by default,
* all the AM boards own slave address is set to 0x70 and all the
* Keystone boards own slave address is set to 0x10.
* master own slave address and transaction slave address
#define I2C_TEST_MASTER_OSA_7B 0x20
#define I2C_TEST_MASTER_OSA_10B 0x220
#define I2C_TEST_MASTER_SA_7B 0x44
#define I2C_TEST_MASTER_SA_10B 0x230
* slave own slave address is set to master transaction slave address
#define I2C_TEST_SLAVE_OSA_7B I2C_TEST_MASTER_SA_7B
#define I2C_TEST_SLAVE_OSA_10B I2C_TEST_MASTER_SA_10B
* This address is the own slave address set on the master board,
* it shoud not be the same as the own slave address set on the
* slave board
#define I2C_OWN_SLAVE_ADDR_MASTER 0x60
/* I2C Test definitions */
/* Unit test IDs */
#define I2C_TEST_ID_DMA 0 /* I2C DMA mode test */
#define I2C_TEST_ID_INT 1 /* I2C non-DMA interrupt mode test */
#define I2C_TEST_ID_CB 2 /* I2C callback mode test */
#define I2C_TEST_ID_XA 3 /* I2C 10-bit address mode test */
/* Define the I2C test interface */
typedef struct I2C_Tests_s
bool (*testFunc)(void *);
int16_t testId;
bool master;
bool pollMode;
bool cbMode;
bool dmaMode;
uint32_t timeout;
char testDesc[80];
} I2C_Tests;
typedef struct I2C_XferLen_s
uint32_t wrLen;
uint32_t rdLen;
} I2C_XferLen;
************************** Macros ************************************
#define I2C_MSG_LENGTH 10
#define I2C_MSG_LENGTH2 75
#define I2C_NUM_XFERS 6
I2C_XferLen masterXferLen[I2C_NUM_XFERS] =
I2C_MSG_LENGTH, 0
I2C_MSG_LENGTH2, 0
0, I2C_MSG_LENGTH
0, I2C_MSG_LENGTH2
/* For restart transfer test */
I2C_MSG_LENGTH, I2C_MSG_LENGTH
I2C_MSG_LENGTH2, I2C_MSG_LENGTH2
I2C_XferLen slaveXferLen[I2C_NUM_XFERS] =
0, I2C_MSG_LENGTH
I2C_MSG_LENGTH, 0
************************** Global Variables **************************
#pragma DATA_ALIGN (masterRxBuffer, 128)
unsigned char masterRxBuffer[I2C_MSG_LENGTH2 + 1];
#pragma DATA_ALIGN (slaveRxBuffer, 128)
unsigned char slaveRxBuffer[I2C_MSG_LENGTH2 + 1];
unsigned char masterTxBuffer[I2C_MSG_LENGTH2 + 1] = "Master Txd I2C Master Txd I2C Master Txd I2C Master Txd I2C Master Txd I2C ";
unsigned char slaveTxBuffer[I2C_MSG_LENGTH2 + 1] = "Slave Txd I2C Slave Txd I2C Slave Txd I2C Slave Txd I2C Slave Txd I2C ";
/* Transaction data */
I2C_Transaction transaction;
/* Callback mode variables */
SemaphoreP_Params cbSemParams;
SemaphoreP_Handle cbSem = NULL;
/* Master callback mode function */
void I2C_callbackMaster(I2C_Handle handle, I2C_Transaction *transaction, int16_t transferStatus)
I2C_osalPostLock(cbSem);
/* Slave callback mode function */
void I2C_callbackSlave(I2C_Handle handle, I2C_Transaction *transaction, int16_t transferStatus)
if (transferStatus == I2C_STS_RESTART)
/* Restart condition */
transaction->writeBuf = (void *)slaveTxBuffer;
transaction->writeCount = I2C_MSG_LENGTH2;
else
* ======== I2C init config ========
static void I2C_initConfig(uint32_t instance, I2C_Tests *test)
I2C_HwAttrs i2c_cfg;
uint32_t ownSlaveAddr;
bool master = test->master;
bool pollMode = test->pollMode;
#ifdef I2C_DMA_ENABLE
bool dmaMode = test->dmaMode;
#endif
/* Get the default I2C init configurations */
I2C_socGetInitCfg(instance, &i2c_cfg);
* Set blocking mode (dma mode or non-dma interrupt mode)
* or callback mode
if (pollMode == true)
/* polling mode */
i2c_cfg.enableIntr = false;
else
/* interrupt enabled */
i2c_cfg.enableIntr = true;
if (dmaMode == true)
/* Set the DMA related init config */
#endif
if (master)
if (test->testId == I2C_TEST_ID_XA)
ownSlaveAddr = I2C_TEST_MASTER_OSA_10B;
else
ownSlaveAddr = I2C_TEST_MASTER_OSA_7B;
else
ownSlaveAddr = I2C_TEST_SLAVE_OSA_10B;
else
ownSlaveAddr = I2C_TEST_SLAVE_OSA_7B;
#if defined (evmK2H) || defined (evmK2K) || defined (evmK2E) || defined (evmK2L) || defined (evmK2G) || defined (LCDK_OMAPL138)
i2c_cfg.ownSlaveAddr = ownSlaveAddr;
#else
i2c_cfg.ownSlaveAddr[0] = ownSlaveAddr;
#endif
/* Set the I2C init configurations */
I2C_socSetInitCfg(instance, &i2c_cfg);
bool I2C_verify_data(unsigned char *data1, unsigned char *data2, uint32_t length)
uint32_t i;
bool ret = true;
for (i = 0; i < length; i++)
if (data1[i] != data2[i])
ret = false;
break;
return (ret);
* Utility function which converts a local GEM L2 memory address
* to global memory address.
static uint32_t l2_global_address (uint32_t addr)
if ((addr >= 0x800000) && (addr < 0x1000000))
#ifdef _TMS320C6X
uint32_t coreNum;
/* Get the core number. */
coreNum = CSL_chipReadReg(CSL_CHIP_DNUM);
#if defined(SOC_AM572x) || defined(SOC_AM571x) || defined(SOC_AM574x)
/* Compute the global address. */
return ((1 << 30) | (coreNum << 24) | (addr & 0x00ffffff));
#else
return ((1 << 28) | (coreNum << 24) | (addr & 0x00ffffff));
#endif
#else
return addr;
#endif
else
/* non-L2 address range */
return addr;
static bool I2C_test_mst_slv_xfer(I2C_Handle i2c, I2C_Tests *test, uint32_t wrLen, uint32_t rdLen)
bool transferOK;
uint32_t addrMasterRxBuf, addrSlaveRxBuf;
bool ret = false;
bool cbMode = test->cbMode;
uint32_t timeout = test->timeout;
uint32_t slaveAddr;
if (dmaMode)
addrMasterRxBuf = l2_global_address((uint32_t)masterRxBuffer);
addrSlaveRxBuf = l2_global_address((uint32_t)slaveRxBuffer);
else
addrMasterRxBuf = (uint32_t)masterRxBuffer;
addrSlaveRxBuf = (uint32_t)slaveRxBuffer;
memset(masterRxBuffer, 0, sizeof(masterRxBuffer));
memset(slaveRxBuffer, 0, sizeof(slaveRxBuffer));
if (dmaMode)
CacheP_wbInv((void *)addrMasterRxBuf, (int32_t)sizeof(masterRxBuffer));
CacheP_wbInv((void *)slaveRxBuffer, (int32_t)sizeof(slaveRxBuffer));
/* Initialize slave I2C transaction structure */
I2C_transactionInit(&transaction);
transaction.writeCount = wrLen;
transaction.readCount = rdLen;
transaction.timeout = timeout;
/* 10-bit slave address */
slaveAddr = I2C_TEST_MASTER_SA_10B;
transaction.expandSA = true;
else
/* 7-bit slave address */
slaveAddr = I2C_TEST_MASTER_SA_7B;
transaction.expandSA = false;
if (master == true)
transaction.masterMode = true;
transaction.slaveAddress = slaveAddr;
transaction.writeBuf = (Ptr)masterTxBuffer;
transaction.readBuf = (Ptr)addrMasterRxBuf;
else
transaction.masterMode = false;
transaction.slaveAddress = 0;
transaction.writeBuf = (Ptr)slaveTxBuffer;
transaction.readBuf = (Ptr)addrSlaveRxBuf;
if (rdLen != 0)
/* for restart transfer, slave sends the data in callback mode */
transaction.writeCount = 0;
/* Initiate I2C transfer */
transferOK = I2C_transfer(i2c, &transaction);
if(transferOK)
if (cbMode)
if (I2C_osalPendLock(cbSem, timeout) != SemaphoreP_OK)
goto Err;
if (master == true)
/* master mode, verify master recieved data match with slave sent data */
if (I2C_verify_data(masterRxBuffer, slaveTxBuffer, rdLen) == false)
goto Err;
/* Print contents of master receive buffer */
I2C_log("Master: %s\n", masterRxBuffer);
else
/* slave mode, verify slave recieved data match with master sent data */
if (I2C_verify_data(slaveRxBuffer, masterTxBuffer, rdLen) == false)
goto Err;
/* Print contents of slave receive buffer */
I2C_log("Slave: %s\n", slaveRxBuffer);
else
I2C_log("Unsuccessful slave I2C transfer");
goto Err;
ret = true;
Err:
return (ret);
static bool I2C_test_master_slave(void *arg)
I2C_Handle i2c;
I2C_Params i2cParams;
uint32_t instance, i;
I2C_XferLen *xferLen;
uint32_t testNum;
bool ret = false;
I2C_Tests *test = (I2C_Tests *)arg;
if (cbMode == true)
/* Create call back semaphore */
I2C_osalSemParamsInit(&cbSemParams);
cbSemParams.mode = SemaphoreP_Mode_BINARY;
cbSem = I2C_osalCreateBlockingLock(0, &cbSemParams);
/* Soc configuration structures indexing starts from 0. If the IP
* instances start with 1, to address proper Configuration
* structure index, I2C Instance should be substracted with 1
if (master == true)
instance = BOARD_I2C_MASTER_INSTANCE;
else
instance = BOARD_I2C_SLAVE_INSTANCE;
I2C_initConfig(instance, test);
/* Initialize I2C handle */
I2C_Params_init(&i2cParams);
i2cParams.bitRate =I2C_400kHz;
if (cbMode == true)
i2cParams.transferMode = I2C_MODE_CALLBACK;
if (master == true)
i2cParams.transferCallbackFxn = I2C_callbackMaster;
else
i2cParams.transferCallbackFxn = I2C_callbackSlave;
i2c = I2C_open(instance, &i2cParams);
if (i2c == NULL)
I2C_log("Error initializing I2C\n");
goto Err;
else
I2C_log("I2C initialized\n");
if (cbMode == true)
testNum = I2C_NUM_XFERS;
else
/* do not test restart transfer in non-callback mode */
testNum = I2C_NUM_XFERS - 2;
if (master == true)
xferLen = &masterXferLen[1];
else
xferLen = &slaveXferLen[1];
if (I2C_test_mst_slv_xfer(i2c, test, xferLen->wrLen,
xferLen->rdLen) == false)
goto Err;
if (master == true)
* master sleep for 1 second after each transfer
* to sync with slave transfer
Task_sleep(1000);
ret = true;
Err:
if (i2c)
I2C_close(i2c);
if (cbSem)
I2C_osalDeleteBlockingLock(cbSem);
cbSem = NULL;
return (ret);
void I2C_test_print_test_desc(I2C_Tests *test)
char testId[16] = {0, };
/* Print unit test ID */
sprintf(testId, "%d", test->testId);
I2C_log("\r\n I2C UT %s\r\n", testId);
/* Print test description */
I2C_log("\r\n %s\r\n", test->testDesc);
#define I2C_NUM_TESTS 4
#else
#define I2C_NUM_TESTS 3
#endif
I2C_Tests I2c_tests_master[I2C_NUM_TESTS] =
/* testFunc testID master pollMode cbMode dmaMode timeout testDesc */
{I2C_test_master_slave, I2C_TEST_ID_DMA, true, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test master in dma mode"},
#endif
{I2C_test_master_slave, I2C_TEST_ID_INT, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test master in non-dma interrupt mode"},
{I2C_test_master_slave, I2C_TEST_ID_CB, true, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test master in callback mode"},
{I2C_test_master_slave, I2C_TEST_ID_XA, true, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test master 10-bit address mode"},
I2C_Tests I2c_tests_slave[I2C_NUM_TESTS] =
{I2C_test_master_slave, I2C_TEST_ID_DMA, false, false, false, true, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test slave in dma mode"},
#endif
{I2C_test_master_slave, I2C_TEST_ID_INT, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test slave in non-dma interrupt mode"},
{I2C_test_master_slave, I2C_TEST_ID_CB, false, false, true, false, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test slave in callback mode"},
{I2C_test_master_slave, I2C_TEST_ID_XA, false, false, false, false, SemaphoreP_WAIT_FOREVER, "\r\n I2C master slave test slave 10-bit address mode"},
* ======== slaveTaskFxn ========
* The task is part of separate slave example project.
* To test slave mode example, slave task has to be
* ready for master. Slave I2C sends a message to master
* while receiving message from master.
Void slaveTaskFxn (UArg arg0, UArg arg1)
uint32_t i;
bool testFail = false;
I2C_Tests *test;
I2C_init();
// for (i = 0; i < I2C_NUM_TESTS; i++)
test = &I2c_tests_slave[0];
I2C_test_print_test_desc(test);
if (test->testFunc((void *)test) == true)
I2C_log("\r\n %s have passed\r\n", test->testDesc);
else
I2C_log("\r\n %s have failed\r\n", test->testDesc);
testFail = true;
// break;
if(testFail == true)
UART_printStatus("\n Some tests have failed. \n");
else
UART_printStatus("\n All tests have passed. \n");
I2C_log("Done\n");
Task_exit();
* ======== masterTaskFxn ========
* This task is part of master example project.
* Slave task has to ensure transaction ready.
* Master I2C sends a message to slave and
* receives message from slave.
Void masterTaskFxn (UArg arg0, UArg arg1)
uint32_t i;
I2C_Tests *test;
I2C_init();
test = &I2c_tests_master[i];
else
testFail = true;
break;
else
I2C_log("Done\n");
Task_exit();
* ======== main ========
int main(void)
/* Call board init functions */
Board_initCfg boardCfg;
#if defined (evmK2G)
uint8_t instance;
Board_SoCInfo socInfo;
#endif
#if defined(SOC_AM335x) || defined (SOC_AM437x)
Task_Handle task;
Error_Block eb;
Error_init(&eb);
#if defined (I2C_SLAVE_TASK)
task = Task_create(slaveTaskFxn, NULL, &eb);
#elif defined (I2C_MASTER_TASK)
task = Task_create(masterTaskFxn, NULL, &eb);
#endif /* Task type */
if (task == NULL)
System_printf("Task_create() failed!\n");
BIOS_exit(0);
#endif /* Soc type */
boardCfg = BOARD_INIT_PINMUX_CONFIG |
BOARD_INIT_MODULE_CLOCK |
BOARD_INIT_UART_STDIO;
Board_init(boardCfg);
/* Read the SoC info to get the System clock value */
Board_getSoCInfo(&socInfo);
if(socInfo.sysClock != BOARD_SYS_CLK_DEFAULT)
for (instance = 0; instance < CSL_I2C_CNT; instance++)
/* Update the I2C functional clock based on CPU clock - 1G or 600MHz */
i2c_cfg.funcClk = socInfo.sysClock/I2C_MODULE_CLOCK_DIVIDER;
/* Set the default I2C init configurations */
#endif
/* Start BIOS */
BIOS_start();
return (0);
