CCS:Error while trying to change/inject a value in memory while the target/application is running in Debug perspective
new to CCS...
i'm trying to change/inject a value in memory while the target/application is running in Debug perspective...tried menu item View->Memory Browser...but I get
this "yellow triangle with exclamation in the middle" about can't access....
I've used one old emulator(SeeHau from NoHau, Campbell , Calif.) to debug and it had a GUI called "Fast Breakpoint" that you enter the memory address and
the value and hit enter...no problem....worked great with the emulator running with no breakpoints....
pass this on to a CSS Guru...this is what I'm trying to do...we redesigned the board to use a TI DSP chip...TMS320C28346...
