CCS Advanced Event Triggering
Other Parts Discussed in Thread: TMS320C6413
I read the Wiki page on advanced event triggering and also Application Report SPRA387.  On my TMS320C6413 target system, under Code Composer v3.1, if you go to Tools->Advanced Event Triggering, I get a SeqPEdit popup window which says "Unable to Connect to Target".  Does this indicate that the 6413 does not support this feature?
If anybody has an idea about what this means, I'd appreciate hearing from you.
Thank You and Best Regards,
Stephen Fedigan
http://processors.wiki.ti.com/index.php/Advanced_Event_Triggering
  • Stephen,
    It is probably missing the necessary configuration files to know that the device supports AET.  C6413 should have cTools which is the device feature that enables AET.  Looking through my CCSv3.3 install I see an AET config file for 6413.  I am going to attach it.  You would drop it in \cc\bin\aet_config
    <?xml version="1.0"?>
    <!-- This file defines the on-chip debug resources for a 6416.  It is required.
         Don't make any changes unless you know what you're doing, and make a backup first. -->
    <CTOOLS version="1.1.0.0" Copyright="Copyright (c) 2005-2007 Texas Instruments">
        <ENTITY_NAME>cTools2000</ENTITY_NAME>
        <NUM_CTOOLS>0</NUM_CTOOLS>
        <HW_MAJOR_V>2</HW_MAJOR_V>
        <HW_MINOR_V>1</HW_MINOR_V>
        <DB_MAJOR_V>1</DB_MAJOR_V>
        <DB_MINOR_V>0</DB_MINOR_V>
        <ACTION>
          <GLOBAL_ID>90</GLOBAL_ID>
          <TYPE>4</TYPE>
          <ID>1</ID>
          <UI_DISPLAYABLE>YES</UI_DISPLAYABLE>
          <TEXT>Go To State</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>109</GLOBAL_ID>
          <TYPE>1</TYPE>
          <ID>21</ID>
          <TEXT>Halt CPU</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>110</GLOBAL_ID>
          <TYPE>9</TYPE>
          <ID>22</ID>
          <TEXT>Drive Pin</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>102</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>14</ID>
          <UI_DISPLAYABLE>NO</UI_DISPLAYABLE>
          <TEXT>Start Timer</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>103</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>15</ID>
          <TEXT>Stop Timer</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>104</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>16</ID>
          <TEXT>Start Counter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>105</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>17</ID>
          <TEXT>Stop Counter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>106</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>18</ID>
          <TEXT>Reload Counter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>107</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>19</ID>
          <TEXT>Reload Timer</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>111</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>23</ID>
          <TEXT>Increment Counter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>112</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>24</ID>
          <TEXT>Decrement Counter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>113</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>26</ID>
          <TEXT>Initialize Counter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>114</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>27</ID>
          <TEXT>Initialize Timer</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>115</GLOBAL_ID>
          <TYPE>11</TYPE>
          <ID>28</ID>
          <TEXT>Disable cTOOL</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>91</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>2</ID>
          <TEXT>Start Trace</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>92</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>3</ID>
          <TEXT>End Trace</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>118</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>30</ID>
          <TEXT>Trace End Trigger</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>93</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>4</ID>
          <TEXT>Trigger Receiver</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>119</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>4</ID>
          <TEXT>Trigger Transmitter</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>94</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>5</ID>
          <TEXT>Store Sample</TEXT>
        </ACTION>
        <ACTION>
          <GLOBAL_ID>95</GLOBAL_ID>
          <TYPE>5</TYPE>
          <ID>6</ID>
          <TEXT>Don't Store Sample</TEXT>
        </ACTION>
        <!-- EQ -->
        <OPERATOR>
          <GLOBAL_ID>79</GLOBAL_ID>
          <TYPE>1</TYPE>
          <ID>1</ID>
        </OPERATOR>
        <!-- LT -->
        <OPERATOR>
          <GLOBAL_ID>80</GLOBAL_ID>
          <TYPE>1</TYPE>
          <ID>2</ID>
        </OPERATOR>
        <!-- GT -->
        <OPERATOR>
          <GLOBAL_ID>81</GLOBAL_ID>
          <TYPE>1</TYPE>
          <ID>3</ID>
        </OPERATOR>
        <!-- LE -->
        <OPERATOR>
          <GLOBAL_ID>82</GLOBAL_ID>
          <TYPE>1</TYPE>
          <ID>4</ID>
        </OPERATOR>
        <!-- GE -->
        <OPERATOR>
          <GLOBAL_ID>83</GLOBAL_ID>
          <TYPE>1</TYPE>
          <ID>5</ID>
        </OPERATOR>
        <!-- RANGE -->
        <OPERATOR>
          <GLOBAL_ID>84</GLOBAL_ID>
          <TYPE>2</TYPE>
          <ID>6</ID>
        </OPERATOR>
        <!-- AND -->
        <OPERATOR>
          <GLOBAL_ID>85</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>7</ID>
        </OPERATOR>
        <!-- OR -->
        <OPERATOR>
          <GLOBAL_ID>86</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>8</ID>
        </OPERATOR>
        <!-- NOT -->
        <OPERATOR>
          <GLOBAL_ID>87</GLOBAL_ID>
          <TYPE>3</TYPE>
          <ID>9</ID>
        </OPERATOR>
        <INPUT>
          <GLOBAL_ID>0</GLOBAL_ID>
          <CLASS>0</CLASS>
          <CATEGORY>0</CATEGORY>
          <TYPE>0</TYPE>
          <ID>0</ID>
          <SIZEINBITS>0</SIZEINBITS>
          <COUNTABLE>YES</COUNTABLE>
          <TEXT>None</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>1</GLOBAL_ID>
          <CLASS>1</CLASS>
          <CATEGORY>1</CATEGORY>
          <TYPE>1</TYPE>
          <ID>1</ID>
          <SIZEINBITS>32</SIZEINBITS>
          <COUNTABLE>NO</COUNTABLE>
          <TEXT>PA</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>6</GLOBAL_ID>
          <CLASS>1</CLASS>
          <CATEGORY>2</CATEGORY>
          <TYPE>1</TYPE>
          <ID>6</ID>
          <TEXT>WA</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>7</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>1</TYPE>
          <ID>7</ID>
          <TEXT>WD</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>8</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>1</TYPE>
          <ID>8</ID>
          <TEXT>RA</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>9</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>1</TYPE>
          <ID>9</ID>
          <TEXT>RD</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>62</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>60</ID>
          <TEXT>Program Address</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>66</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>64</ID>
          <TEXT>Write Address</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>67</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>65</ID>
          <TEXT>Write Data</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>68</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>66</ID>
          <TEXT>Read Address</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>69</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>67</ID>
          <TEXT>Read Data</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>117</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>74</ID>
          <TEXT>PC TAG</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>59</GLOBAL_ID>
          <CLASS>1</CLASS>
          <TYPE>5</TYPE>
          <ID>59</ID>
          <TEXT>Time Stamp</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>72</GLOBAL_ID>
          <CLASS>2</CLASS>
          <CATEGORY>6</CATEGORY>
          <TYPE>7</TYPE>
          <ID>70</ID>
          <SIZEINBITS>1</SIZEINBITS>
          <TEXT>State0</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>73</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>7</TYPE>
          <ID>71</ID>
          <TEXT>State1</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>74</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>7</TYPE>
          <ID>72</ID>
          <TEXT>State2</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>75</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>7</TYPE>
          <ID>73</ID>
          <TEXT>State3</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>56</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>3</TYPE>
          <ID>56</ID>
          <TEXT>RTDXXmitComplete</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>55</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>3</TYPE>
          <ID>55</ID>
          <TEXT>RTDXRcvComplete</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>14</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>2</TYPE>
          <ID>14</ID>
          <TEXT>InterruptAcknowledge</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>23</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>2</TYPE>
          <ID>23</ID>
          <TEXT>L1DStall</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>33</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>2</TYPE>
          <ID>33</ID>
          <TEXT>L1IReadMissStall</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>36</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>2</TYPE>
          <ID>36</ID>
          <TEXT>PipelineStall</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>57</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>4</TYPE>
          <ID>57</ID>
          <TEXT>ET0</TEXT>
        </INPUT>
        <INPUT>
          <GLOBAL_ID>58</GLOBAL_ID>
          <CLASS>2</CLASS>
          <TYPE>4</TYPE>
          <ID>58</ID>
          <TEXT>ET1</TEXT>
        </INPUT>
    </CTOOLS>
    If that doesn't work you get an eval copy of CCSv4 here: http://processors.wiki.ti.com/index.php/Category:Code_Composer_Studio_v4
    John
  • Hi John,
    I appreciate the advice.  I added the file to the appropriate directory, restarted the program, and got the same message.  I'll try CCS v4.0 now and see what the result is.
    Thank You,
    Steve
