Is there any datasheet or design guideline available for PMP10283 Single Stage 200W AC-DC LLC Series Resonant Conv for 120VAC & 230VAC Input
Mausamjeet, thank you for you interest in Texas Instruments. The test report that accompanies the design files for this design represent the "datasheet" for the reference design. Can you advise as to what other information you are looking for such that I can forward to the original design owner so we can better provide you the support you need? Please let us know.
John Fullilove
Hi John,
Thank you for your reply. I want to know the design methodology used in this single stage converter. For example how to pick what inductance and capacitance and transformer turns ratio.for any given specs. I couldn't find them in the documentation available online.
Mausamjeet
Hi Mausamjeet,
You will need to design your resonant tank to cover the wide input voltage. Basically you will need to use small magnetizing inductance (Lm) to resonant inductance ratio (Lr). I.e. Small Lm/Lr ratio. In the meantime, you don't want to make the Lm too small or you will have high circulating current and efficiency will suffer. A little bit overview can be found in my blog: https://e2e.ti.com/blogs_/b/powerhouse/archive/2014/11/04/how-much-can-a-llc-series-resonant-converter-do.
I have also attached the match calculation file I used for PMP10283 for your reference. I no longer have that version mathcad license so I can't do anything to it. Hope you are able to open it.
Sheng-Yang Yu
