Other Parts Discussed in Thread: MOTORWARE, CCSTUDIO
Dear TI support,
I am an hardware engineer, and not quite used to TI microcontrollers.
I found this board really interesting. However documentation about software looks to me not enough.
There is a software package with some source of the TIDA-00643 product.
There is some source.
The only document is important notice for reference designs.
Not a hex or bin file and way to flash it to the microcontroller. That's defintely not profesional.
Here a code example, package, with binaries, people want to try the evaluations boards before go into deeper ...
In the tiduak1.pdf file I got some informations, There is motorware software to install.
So I read this and I got the same problem on many persons that is not fix.
I got same problem, packages installed, and nothing found in directories.
That's quite a fail from TI.
I like TI products, when it's come to microcontrollers and there is software in line or so, I run away from TI, ... I know why again.
This board unfortunatly is not available for sell, with fitted software.
I can be stubborn to find a solution, here you need a lot of that to get things working.
The Hardware documentation is one of the best of the world. Software in my mind is quite bad. There is hell of links everywhere and and documentations a bit here, a bit here, and obviously nothing works from start.
So what I do know ? I try install CCstudio ... and get into more loss of time fail ?
