PSPICE-FOR-TI: PSPICE install error code [LMC-02955]
Part Number: PSPICE-FOR-TI
HI Teams
I get a problem with installing PSPICE for TI tool....
Laptop borken and reinstall the Windows11.
I use my account reinstall the tool and stock in finall step every time. waiting more than 1 hour and process just idle....
[BTW] The backup latop only 3 min can success this process...... I can also provide the normall install log for you.
"Starting process: D:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install"
shows the error code :
Error install-log attached (My on-board laptop)
下午 04:13:15 2023年12月29日 : parameter count = 1
下午 04:13:15 2023年12月29日 : -wrapper
下午 04:13:15 2023年12月29日 : Module Name: TIPSpice.exe
下午 04:13:15 2023年12月29日 : Server OS = False
下午 04:13:15 2023年12月29日 : Operating system version : 10.0.0.0
下午 04:13:15 2023年12月29日 : Checking for proxy
下午 04:13:15 2023年12月29日 : {
	"LibUpdate_DeltaZip": "https://software-dl.ti.com/pspice/esd/models/library/delta.zip",
	"LibUpdate_VersionTxt": "https://software-dl.ti.com/pspice/esd/models/library/Pspice_Lib_Version.txt",
	"LibUpdate_UpdateDelta": "https://software-dl.ti.com/pspice/esd/models/library/UpdateDelta.json",
	"LibUpdate_UpdateConfig": "https://software-dl.ti.com/pspice/esd/models/library/UpdateConfigure.json",
	"LibUpdate_LibMetadata": "https://software-dl.ti.com/pspice/esd/models/library/library.json",
	"LibFirstInstall_LibraryZip": "https://software-dl.ti.com/pspice/esd/models/library/library.zip",
	"LibFirstInstall_LatestVersion": "23.10.001",
	"Installer_DownloadXML": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpiceForTIXML.xml",
	"Installer_BasePath": "https://software-dl.ti.com/pspice/esd/installer",
	"Installer_DownloadSetup": "https://software-dl.ti.com/pspice/esd/installer/setup/PSpice-For-TI_setup.exe",
	"Licensing_URL": "https://cdsplicwc.cadence.com/chws/b2c/v1",
	"SoftwareUpdate_Expiry": {
		"Timestamp": "01:15:2099 15:07:19 GMT",
		"RegularMessage": {
			"PreHyperLink": "A new software update is available. Click Install to start the download. By installing the update, you accept the ",
			"HyperLink": "license agreement",
			"PostHyperLink": "."
		"ForceMessage": {
			"PreHyperLink": "Latest updates must be installed to run the software. Click Install to start the download. By installing the update, you accept the",
			"PostHyperLink": ".  Click Cancel to exit."
	"UTM_Keyword": {
		"TIPSpice_Install": "HQS=pspiceforti",
		"Full_Install": "HQS=pspiceforti"
	"TI_URLs_Version": [
		"17_4_2020_S006",
		"17_4_2020_S009",
		"23_1_2024_P001"
下午 04:13:15 2023年12月29日 : Checking if Licensing URL is accessible
下午 04:13:22 2023年12月29日 : Initializing
下午 04:13:22 2023年12月29日 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
下午 04:13:22 2023年12月29日 : Response Content length = 1766
下午 04:13:22 2023年12月29日 : C:\Users\cheney.wen\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
下午 04:13:22 2023年12月29日 : Reading Json URL File
下午 04:13:22 2023年12月29日 : setting media download server URL from Json File
下午 04:13:22 2023年12月29日 : setting Dll path from Json File
下午 04:13:22 2023年12月29日 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
下午 04:13:22 2023年12月29日 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
下午 04:13:24 2023年12月29日 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system:
下午 04:13:24 2023年12月29日 : LaunchTIPSpiceDlgs()
下午 04:13:24 2023年12月29日 : Checking for compnts.dat
下午 04:13:31 2023年12月29日 : error_code cdsVblRegisterInstallation: VblSuccess
下午 04:13:31 2023年12月29日 : error_code cdsVblRequestLicense: VblSuccess
下午 04:13:34 2023年12月29日 : Set Installation and Home Directory()
下午 04:13:34 2023年12月29日 : Setting default Installation directory : C:\Cadence\PSpiceTI
下午 04:13:34 2023年12月29日 : Reading CDS_HOME environment variable
下午 04:13:34 2023年12月29日 : CDS_HOME is present and set to C:\cds_spb_home. No need to set CDS_HOME
下午 04:13:39 2023年12月29日 : Checking for memory space
下午 04:13:39 2023年12月29日 : Memory space available
下午 04:13:39 2023年12月29日 : Target Dir: D:\Cadence\PSpiceTI
下午 04:13:39 2023年12月29日 : Working Dir: C:\cds_spb_home
下午 04:13:39 2023年12月29日 : Silent ini file created
下午 04:13:44 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
下午 04:13:44 2023年12月29日 : Starting download of data1.cab   Attempt no 1 DataSize is 31794546
下午 04:13:45 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
下午 04:13:45 2023年12月29日 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
下午 04:13:45 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
下午 04:13:46 2023年12月29日 : Completing download of 0x0409.ini
下午 04:13:47 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
下午 04:13:47 2023年12月29日 : Completing download of data1.cab
下午 04:13:49 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
下午 04:13:49 2023年12月29日 : Starting download of data2.cab   Attempt no 1 DataSize is 170127360
下午 04:13:49 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
下午 04:13:49 2023年12月29日 : Starting download of data1.hdr   Attempt no 1 DataSize is 5038454
下午 04:13:50 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
下午 04:13:50 2023年12月29日 : Completing download of data1.hdr
下午 04:13:52 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
下午 04:13:52 2023年12月29日 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
下午 04:14:18 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
下午 04:14:19 2023年12月29日 : Completing download of data2.cab
下午 04:14:23 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
下午 04:14:23 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
下午 04:14:23 2023年12月29日 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
下午 04:14:23 2023年12月29日 : Completing download of data3.cab
下午 04:14:28 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
下午 04:14:28 2023年12月29日 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
下午 04:14:54 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
下午 04:14:54 2023年12月29日 : Completing download of data4.cab
下午 04:14:57 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
下午 04:14:57 2023年12月29日 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
下午 04:15:02 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
下午 04:15:02 2023年12月29日 : Completing download of data5.cab
下午 04:15:07 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
下午 04:15:07 2023年12月29日 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
下午 04:15:27 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
下午 04:15:28 2023年12月29日 : Completing download of data6.cab
下午 04:15:32 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
下午 04:15:32 2023年12月29日 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
下午 04:15:41 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
下午 04:15:41 2023年12月29日 : Completing download of data7.cab
下午 04:15:46 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
下午 04:15:46 2023年12月29日 : Starting download of data9.cab   Attempt no 1 DataSize is 83923568
下午 04:16:02 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
下午 04:16:02 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
下午 04:16:02 2023年12月29日 : Completing download of data9.cab
下午 04:16:02 2023年12月29日 : Completing download of data8.cab
下午 04:16:07 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
下午 04:16:07 2023年12月29日 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637496
下午 04:16:07 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
下午 04:16:07 2023年12月29日 : Completing download of ISSetup.dll
下午 04:16:08 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
下午 04:16:08 2023年12月29日 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954488
下午 04:16:08 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
下午 04:16:08 2023年12月29日 : Completing download of installsetup.exe
下午 04:16:09 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
下午 04:16:09 2023年12月29日 : Starting download of layout.bin   Attempt no 1 DataSize is 994
下午 04:16:09 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
下午 04:16:09 2023年12月29日 : Completing download of layout.bin
下午 04:16:11 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
下午 04:16:11 2023年12月29日 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
下午 04:16:11 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
下午 04:16:11 2023年12月29日 : Completing download of pspInstall.pdf
下午 04:16:12 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
下午 04:16:12 2023年12月29日 : Starting download of setup.bmp   Attempt no 1 DataSize is 414056
下午 04:16:12 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
下午 04:16:12 2023年12月29日 : Completing download of setup.bmp
下午 04:16:13 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
下午 04:16:13 2023年12月29日 : Starting download of setup.ini   Attempt no 1 DataSize is 2430
下午 04:16:13 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
下午 04:16:13 2023年12月29日 : Completing download of setup.ini
下午 04:16:15 2023年12月29日 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
下午 04:16:15 2023年12月29日 : Starting download of setup.inx   Attempt no 1 DataSize is 575660
下午 04:16:15 2023年12月29日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
下午 04:16:15 2023年12月29日 : Completing download of setup.inx
下午 04:16:15 2023年12月29日 : 853674 853674
下午 04:16:15 2023年12月29日 : Setup exe path: D:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
下午 04:16:15 2023年12月29日 : Allegro Installation Start pid: 1668
下午 04:16:21 2023年12月29日 : NumberOfComponentsToBeInstalled = 40106
下午 04:16:21 2023年12月29日 : Updated NumberOfComponentsToBeInstalled = 40913.08
下午 04:16:21 2023年12月29日 : Updated NumberOfComponentsInstalled = 402
下午 04:18:44 2023年12月29日 : Feature transfer complete..disabling close button
下午 04:18:44 2023年12月29日 : Installing: Runtime packages and redistributables
下午 04:18:45 2023年12月29日 : Installing: Configuring documentation
下午 04:18:45 2023年12月29日 : Installing: Configuring file associations
下午 04:18:46 2023年12月29日 : Installing: Setting permissions for files and folders
下午 04:18:48 2023年12月29日 : Installing: Creating Registries
下午 04:18:48 2023年12月29日 : Installing: Finishing Installation
下午 04:19:03 2023年12月29日 : Running Library Configuration Executable
下午 04:19:03 2023年12月29日 : Starting process: D:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
下午 04:37:51 2023年12月29日 : Exiting Installation Installing Dialog
Can you help me how to slove this?
Successful log below (from the backip laptop)
上午 08:31:17 2023年12月21日 : parameter count = 1
上午 08:31:17 2023年12月21日 : -wrapper
上午 08:31:17 2023年12月21日 : Module Name: TIPSpice.exe
上午 08:31:17 2023年12月21日 : Server OS = False
上午 08:31:17 2023年12月21日 : Operating system version : 10.0.0.0
上午 08:31:17 2023年12月21日 : Checking for proxy
上午 08:31:25 2023年12月21日 : {
		"RegularMessage": {
		"ForceMessage": {
	"UTM_Keyword": {
		"17_4_2020_S006",
		"17_4_2020_S009",
		"23_1_2024_P001"
上午 08:31:25 2023年12月21日 : Checking if Licensing URL is accessible
上午 08:31:32 2023年12月21日 : Initializing
上午 08:31:32 2023年12月21日 : Downloading URLs file from : https://pcb.cadence.com/startPages/PSpiceTI_data/TI_URLs.txt
上午 08:31:32 2023年12月21日 : Response Content length = 1766
上午 08:31:32 2023年12月21日 : C:\Users\cheney.wen\AppData\Roaming\Cadence\PspiceTIInstall\TI_URLs.txt bytes downloaded = 1766
上午 08:31:32 2023年12月21日 : Reading Json URL File
上午 08:31:32 2023年12月21日 : setting media download server URL from Json File
上午 08:31:32 2023年12月21日 : setting Dll path from Json File
上午 08:31:32 2023年12月21日 : Chws URL is: https://cdsplicwc.cadence.com/chws/b2c/v1
上午 08:31:32 2023年12月21日 : DownloadServerPath is: https://software-dl.ti.com/pspice/esd/installer
上午 08:31:35 2023年12月21日 : ReleaseVersion in XML: 17.40.009 InstalledVersion on system:
上午 08:31:35 2023年12月21日 : LaunchTIPSpiceDlgs()
上午 08:31:35 2023年12月21日 : Checking for compnts.dat
上午 08:33:15 2023年12月21日 : error_code cdsVblRegisterInstallation: VblSuccess
上午 08:33:15 2023年12月21日 : error_code cdsVblRequestLicense: VblSuccess
上午 08:33:24 2023年12月21日 : Set Installation and Home Directory()
上午 08:33:24 2023年12月21日 : Setting default Installation directory : C:\Cadence\PSpiceTI
上午 08:33:24 2023年12月21日 : Reading CDS_HOME environment variable
上午 08:33:24 2023年12月21日 : CDS_HOME is not present or is empty. Need to set CDS_HOME.
上午 08:33:24 2023年12月21日 : First time installation. CDS_HOME will be set to default HOME directory.
上午 08:33:24 2023年12月21日 : Checking if CDS_HOME directory exists and whether user has permission to create it.
上午 08:33:24 2023年12月21日 : Creating directory : C:\cds_spb_home
上午 08:33:33 2023年12月21日 : Checking for memory space
上午 08:33:33 2023年12月21日 : Memory space available
上午 08:33:33 2023年12月21日 : Target Dir: D:\Cadence\PSpiceTI
上午 08:33:33 2023年12月21日 : Working Dir: C:\cds_spb_home
上午 08:33:33 2023年12月21日 : Silent ini file created
上午 08:33:39 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data1.cab?tracked=1 Status is OK
上午 08:33:39 2023年12月21日 : Starting download of data1.cab   Attempt no 1 DataSize is 31794546
上午 08:33:41 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/0x0409.ini?tracked=1 Status is OK
上午 08:33:41 2023年12月21日 : Starting download of 0x0409.ini   Attempt no 1 DataSize is 22480
上午 08:33:41 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/0x0409.ini
上午 08:33:42 2023年12月21日 : Completing download of 0x0409.ini
上午 08:33:44 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data1.hdr?tracked=1 Status is OK
上午 08:33:44 2023年12月21日 : Starting download of data1.hdr   Attempt no 1 DataSize is 5038454
上午 08:33:50 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.hdr
上午 08:33:50 2023年12月21日 : Completing download of data1.hdr
上午 08:33:53 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data2.cab?tracked=1 Status is OK
上午 08:33:53 2023年12月21日 : Starting download of data2.cab   Attempt no 1 DataSize is 170127360
上午 08:34:55 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data1.cab
上午 08:34:55 2023年12月21日 : Completing download of data1.cab
上午 08:35:01 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data3.cab?tracked=1 Status is OK
上午 08:35:01 2023年12月21日 : Starting download of data3.cab   Attempt no 1 DataSize is 209715200
上午 08:36:17 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data2.cab
上午 08:36:17 2023年12月21日 : Completing download of data2.cab
上午 08:36:22 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data4.cab?tracked=1 Status is OK
上午 08:36:22 2023年12月21日 : Starting download of data4.cab   Attempt no 1 DataSize is 209715200
上午 08:37:41 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data3.cab
上午 08:37:41 2023年12月21日 : Completing download of data3.cab
上午 08:37:45 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data5.cab?tracked=1 Status is OK
上午 08:37:45 2023年12月21日 : Starting download of data5.cab   Attempt no 1 DataSize is 209715200
上午 08:39:10 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data5.cab
上午 08:39:11 2023年12月21日 : Completing download of data5.cab
上午 08:39:17 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data6.cab?tracked=1 Status is OK
上午 08:39:17 2023年12月21日 : Starting download of data6.cab   Attempt no 1 DataSize is 209715200
上午 08:42:04 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data4.cab
上午 08:42:04 2023年12月21日 : Completing download of data4.cab
上午 08:42:10 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data7.cab?tracked=1 Status is OK
上午 08:42:10 2023年12月21日 : Starting download of data7.cab   Attempt no 1 DataSize is 209715200
上午 08:43:47 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data6.cab
上午 08:43:47 2023年12月21日 : Completing download of data6.cab
上午 08:43:57 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data8.cab?tracked=1 Status is OK
上午 08:43:57 2023年12月21日 : Starting download of data8.cab   Attempt no 1 DataSize is 209715200
上午 08:46:07 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data8.cab
上午 08:46:08 2023年12月21日 : Completing download of data8.cab
上午 08:46:12 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/data9.cab?tracked=1 Status is OK
上午 08:46:12 2023年12月21日 : Starting download of data9.cab   Attempt no 1 DataSize is 83923568
上午 08:46:39 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data9.cab
上午 08:46:39 2023年12月21日 : Completing download of data9.cab
上午 08:46:41 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/installsetup.exe?tracked=1 Status is OK
上午 08:46:41 2023年12月21日 : Starting download of installsetup.exe   Attempt no 1 DataSize is 954488
上午 08:46:42 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/installsetup.exe
上午 08:46:42 2023年12月21日 : Completing download of installsetup.exe
上午 08:46:44 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/ISSetup.dll?tracked=1 Status is OK
上午 08:46:44 2023年12月21日 : Starting download of ISSetup.dll   Attempt no 1 DataSize is 1637496
上午 08:46:45 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/ISSetup.dll
上午 08:46:45 2023年12月21日 : Completing download of ISSetup.dll
上午 08:46:49 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/layout.bin?tracked=1 Status is OK
上午 08:46:49 2023年12月21日 : Starting download of layout.bin   Attempt no 1 DataSize is 994
上午 08:46:49 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/layout.bin
上午 08:46:49 2023年12月21日 : Completing download of layout.bin
上午 08:46:50 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/pspInstall.pdf Status is OK
上午 08:46:50 2023年12月21日 : Starting download of pspInstall.pdf   Attempt no 1 DataSize is 85357
上午 08:46:51 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/pspInstall.pdf
上午 08:46:51 2023年12月21日 : Completing download of pspInstall.pdf
上午 08:46:54 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/setup.bmp?tracked=1 Status is OK
上午 08:46:54 2023年12月21日 : Starting download of setup.bmp   Attempt no 1 DataSize is 414056
上午 08:46:55 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.bmp
上午 08:46:55 2023年12月21日 : Completing download of setup.bmp
上午 08:46:59 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/setup.ini?tracked=1 Status is OK
上午 08:46:59 2023年12月21日 : Starting download of setup.ini   Attempt no 1 DataSize is 2430
上午 08:46:59 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.ini
上午 08:46:59 2023年12月21日 : Completing download of setup.ini
上午 08:47:02 2023年12月21日 : https://downloads.ti.com/pspice/esd/installer/software/setup.inx?tracked=1 Status is OK
上午 08:47:02 2023年12月21日 : Starting download of setup.inx   Attempt no 1 DataSize is 575660
上午 08:47:02 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/setup.inx
上午 08:47:02 2023年12月21日 : Completing download of setup.inx
上午 08:47:29 2023年12月21日 : File download completed without any errors. Url = https://software-dl.ti.com/pspice/esd/installer/software/data7.cab
上午 08:47:30 2023年12月21日 : Completing download of data7.cab
上午 08:47:30 2023年12月21日 : 918488 918488
上午 08:47:30 2023年12月21日 : Setup exe path: D:\Cadence\PSpiceTI\PSpiceTI/software/\installsetup.exe
上午 08:47:31 2023年12月21日 : Allegro Installation Start pid: 5096
上午 08:47:38 2023年12月21日 : NumberOfComponentsToBeInstalled = 40106
上午 08:47:38 2023年12月21日 : Updated NumberOfComponentsToBeInstalled = 40913.08
上午 08:47:38 2023年12月21日 : Updated NumberOfComponentsInstalled = 402
上午 08:50:01 2023年12月21日 : Feature transfer complete..disabling close button
上午 08:50:01 2023年12月21日 : Installing: Runtime packages and redistributables
上午 08:50:22 2023年12月21日 : Installing: Configuring documentation
上午 08:50:23 2023年12月21日 : Installing: Configuring file associations
上午 08:50:24 2023年12月21日 : Installing: Setting permissions for files and folders
上午 08:50:26 2023年12月21日 : Installing: Creating Registries
上午 08:50:26 2023年12月21日 : Installing: SQL Lite ODBC Driver
上午 08:50:33 2023年12月21日 : Installing: Finishing Installation
上午 08:50:48 2023年12月21日 : Running Library Configuration Executable
上午 08:50:48 2023年12月21日 : Starting process: D:\Cadence\PSpiceTI\tools\bin\orLibraryDownLoad.exe with argument: -mode full_install
上午 08:53:35 2023年12月21日 : orLibraryDownLoad.exe returned : 0
上午 08:53:35 2023年12月21日 : Library Installation completed successfully.
上午 08:53:35 2023年12月21日 : Downloading License file
上午 08:53:42 2023年12月21日 : error_code cdsVblDownloadLicense: VblSuccess
上午 08:53:42 2023年12月21日 : Downloading License file finish
上午 08:53:42 2023年12月21日 : Removing generic credentials.
上午 08:53:42 2023年12月21日 : PrepareUninstallation
上午 08:53:42 2023年12月21日 : strLocalPath: C:\Users\cheney.wen\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe
上午 08:53:42 2023年12月21日 : strLocalConfigPath: C:\Users\cheney.wen\AppData\Roaming\Cadence\PSpiceTIInstall\TIPSpice.exe.config
上午 08:53:42 2023年12月21日 : strCachedLocForFV174Installer: "C:\Users\cheney.wen\AppData\Roaming\InstallShield Installation Information\{xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx}\Uninstall.exe" -runfromtemp -l0x0409  Uninstall -removeonly
上午 08:53:42 2023年12月21日 : ClearRunOnceIfNotNeeded()
上午 08:53:42 2023年12月21日 : installSetupValue =
