I have got a problem using the Coil Designer.
When using the WEBBENCH Coil Designer configured for LDC2114 or LDC2112 every configuration I've tested (and also the standard configuration) is producing strange and useless output, at least for Altium.
Please see the picture below, this is what I get for the default parameters of LDC2114. The leftmost tracks of the coil are moved to the right outside of the board.
Do you have a idea of what is going wrong here?
Steffen,
Thank you for your patience. We have identified the problem and are working on fixing it. We'll notify you when the fix is released and available to use.
Shrikrishna,
Texas Instruments.
Steffen,
Once again, thank you for your patience. This problem has been fixed and released and ready for you to use. Please try out exporting your coil using the Coil Designer tool and let us know if you still find any problem.
Shrikrishna,
Texas Instruments.
Shrikrishna,
thank you very much. It seems to work properly now.
Steffen
