Other Parts Discussed in Thread: CC2640, CC2640R2F
I am trying to flash firmware onto a cc2640r2fq1 chip on a pcb i designed through the debugger of a cc2640 launchpad. i get the following error:
>Initiate access to target: COM5 using 2-pin cJTAG.
>No response from device. Device may not be in bootloader mode. Reset device and try again.
If problem persists, check connection and baud rate.
>Connecting over serial bootloader failed: No response from device. Device may not be in bootloader mode. Reset device and try again.
>Failed to create device object.
Any ideas what i could be doing wrong, and also what is the correct firmware to flash onto the chip and where can i find it as i dont think i have the right files?
