In CCS Theia, I use "Search" it only search workspace file or the file I open.
If I need to search file in SDK, is it possible?
Because, sometimes I need to work in SDK layer, but if variable is not searchaable it is difficut to work.
If you toggle the search details, you have options to add additional search parameters such as searching in specific directories.
You can add the SDK directory to search in.
ki
Glad to help.
Please note that CCS Theia is VS Code based. Hence many of the VS Code help also applies.
For more details on the advanced search, check out:
https://code.visualstudio.com/docs/editor/codebasics#_search-across-files
