I tried to lower the power for BLE for CC2564 module (i entered commands to put it in continuous advertising) then i entered different power levels from 1 to 15 as mentionned in the HCI_VS_LE_Output_Power command.
The problem is that I see no difference in RSSI when scanning when I enter power levels 2 to 15. Power Level 1 is higher that the others.
Can I know what transmission power corresponds to what power Level? is there any sort of a table as it is the case for Bluetooth classic command? (HCI_VS_DRPb_Set_Power_Vector)
Is power level 1 corresponds to a transmission of 10 dBm and what other power levels correspond to?
Thank you.
