Part Number: BOOSTXL-AOA
Hi:
how are you.
we have some problem during our development with your boostxl-aoa and launchxl-cc26x2r1, and SDK version:3.40, we also used SDK 4.10 before, but Passive can't be connected, so we back to use 3.40 version to continual development.
our current issue is:
1. we get good result with your original hardware. also there is some angle jumple, but is acceptable.
2. but when try to test with our antenna sample board which is make by your PCB document, and we just keep antenna A1.1, A1.2, A1.3 this antenna array. the test result is too bad so that we already make 2 times sample PCB board from 2 supplier. for example, we test 45 degree, test result is around 20~30 degree, and angle jumple more big than original board's.
3. could you give us some advice how to compensate it by programming or how to control PCB board quality, or we can't do mass produciton after development finish.
thank you.
