Other Parts Discussed in Thread: TAS2562,
I am writing the xml configuration file to use the tas2562 with the cc8530. Is there a way to us an interrupt with the cc8530 in autonomous mode. My main concern is a UVLO fault of the TAS2562 is latching, and without any way to signal to thee CC8530 a fault has occurred there will be no way to clear the fault. In the case of a latching fault the CC8530 would just need to send the same configuration sequence for a transition from off to sr-switch, so it could pretty much treat a fault signal the same as being powered on. Does anyone have any ideas of how to remedy this?
Thank you,
Austin
