Other Parts Discussed in Thread: CC-DEBUGGER,
Problem Description:
- After preliminary analysis, we have confirmed that the TX port of the module component did not send data to the main control board, but the module worked normally
- Read out the software of the problem module and then burn it to other modules, which can work normally? ]
- There are two modules with this problem. After one of the modules is burned again, it will recover [hardware normal?
Therefore, we can not judge whether it is a hardware or software problem.
Our initial idea is whether there is a tool that can read the register value of IC without burning [destroy program] to see whether it is consistent with the software configuration.
If there is any other need to confirm, please contact me directly: 13818175226
Thank you for your support
