Other Parts Discussed in Thread: LAUNCHXL-CC13-90
Hi TI Team,
Greetings!!!
We need a pcb layout file for CC1190 Evaluation Module. We already found a link for scheamtic,
but there is no pcb layout recommended guidelines.
Hi TI Team,
Greetings!!!
Hi Lavanya.
We do not have a layout for this module to provide to you. However, CC1190 is used in other reference designs that are available. The following link is the reference design for LAUNCHXL-CC13-90 which you can base your design on.
https://www.ti.com/lit/zip/swrc338
On a general note, you should follow our general recommendations on PCB layout at SWRA640.
HG
Hi Halatulla Gholami,
In this https://www.ti.com/lit/zip/swrc338 reference design there are two schematic file ended up with this EU and US. Some matching network values are different, What should i use.
It depends on what region you will used in. If it is will be used in the US, then you use the US version, and if in Europe, then the EU version. The reason for the two different versions is that different regions have different regulation.
HG
As far as I am aware, the regulation for sub1-GHz ISM band in India and EU is very similar with exception of the frequency range that can be used at the time of my writing. So my recommendation is to use the EU version of the board for India.
HG
