I want to implement M-BUS using CC1310 transceiver's, and want to know the frames of M-BUS sent from the device side towards the collector.Also,the responses for the same.
I am not able to understand the frames of Wireless M-BUS from the stack of stackforce.It is different from the theory of the Wireless M-BUS???????????????????
We have the following Application Notes about the wM-Bus implementation on the CC1310:
SWRA522 (CC13xx Combined wM-Bus C-Mode and T-Mode): https://www.ti.com/lit/swra522
SWRA512 (CC13xx wM-Bus S-Mode): https://www.ti.com/lit/swra512
Zack
I am using the satck giving by the stackforce for the wireless m-bus , but the information which i have gathered about the wireless m-bus is different from the m-bus frames of the stack. I am not able to understand the development of m-bus frames from the stack.
The wmbus from stackforce is compliant and supports OMSv.4.1.2, as stated in the release note.
If you need support using the stack I suggest you contact SF directly.
BR
Siri
