Other Parts Discussed in Thread: CC1352P
Hello everybody,
We are using CC1190 with a 868MHz transceiver for a battery powered device. We're having some cases where CC1190 in power down mode starts consuming power. We have many boards our clients returned us because they started to consume the batteries in a few days while they should last for minimum 2 years. All the boards present the same problem. CC1190 is in power down mode (PA_EN and LNA_EN are set to 0) but it consume several mA. The consumption is not the same for all the boards. If I remove the external inductor that power the output stage we can see the regular consumption of 50uA. So it seems something strange happened that damaged the output stage. How is it possible? Any ideas?
Thanks in advance
