Hello everybody! I wan't build modules to industry remote control with 70 channels to use. The parameters who i have now:
RX: channels in step 25khz, symbolrate 4.8kb, deviation 4kz, rx bw 39khz. TX:power 10dbm
with this parameters the range distance is not good, about 70meters.
What I should change to increase the range with actual channel spacing 25khz? These modules may work in the same place even 30 modules in the same place( cranes );
Thank you!
