Hi!,
Which simplelink API should be used to set the device in transceiver mode and read the beacon info of the local routers ?
Thanks in advance.
to start the device in transceiver mode use:
Switch from any role to STA:
sl_WlanSetMode(ROLE_STA);
sl_Stop(0);
sl_Start(NULL,NULL,NULL);
(or configuring via sysconfig) and calling,
SlWlanNetworkEntry_t netEntries[10];
_u8 i;
_i16 resultsCount = sl_WlanGetNetworkList(0,10,&netEntries[0]);
for(i=0; i< resultsCount; i++)
printf("%d. ", i + 1);
printf("SSID: %.32s ", Entries[i].Ssid);
printf("BSSID: %x:%x:%x:%x:%x:%x ", Entries[i].Bssid[0], Entries[i].Bssid[1], Entries[i].Bssid[2], Entries[i].Bssid[3], Entries[i].Bssid[4], Entries[i].Bssid[5]);
printf("Channel: %d ", Entries[i].Channel);
printf("RSSI: %d ", Entries[i].Rssi);
printf("Security type: %d ", SL_WLAN_SCAN_RESULT_SEC_TYPE_BITMAP(Entries[i].SecurityInfo));
printf("Group Cipher: %d ", SL_WLAN_SCAN_RESULT_GROUP_CIPHER(Entries[i].SecurityInfo));
printf("Unicast Cipher bitmap: %d ", SL_WLAN_SCAN_RESULT_UNICAST_CIPHER_BITMAP(Entries[i].SecurityInfo));
printf("Key Mgmt suites bitmap: %d ", SL_WLAN_SCAN_RESULT_KEY_MGMT_SUITES_BITMAP(Entries[i].SecurityInfo));
printf("Hidden SSID: %d ", SL_WLAN_SCAN_RESULT_HIDDEN_SSID(Entries[i].SecurityInfo));
printf("PMF Enable: %d ", SL_WLAN_SCAN_RESULT_PMF_ENABLE(Entries[i].SecurityInfo));
printf("PMF Required: %d\r\n", SL_WLAN_SCAN_RESULT_PMF_REQUIRED(Entries[i].SecurityInfo));
in order to read the beacon info of the local routers.
take a look at these functions in: https://dev.ti.com/tirex/explore/node?node=A__AO6Uh7Oii5BBfYbgEZ9fGg__com.ti.SIMPLELINK_CC32XX_SDK__fc2e6sr__LATEST
and especially take a look at the network terminal example it has this already implemented in the wlan_cmd.c ( https://dev.ti.com/tirex/explore/node?node=A__AE3.OYy11PdaL9VvsDX6Rg__com.ti.SIMPLELINK_CC32XX_SDK__fc2e6sr__LATEST)
best regards,
Avi
