M2-CC3351: Streaming video crashes cc3351 driver
Part Number: M2-CC3351
Other Parts Discussed in Thread: CC3351, SK-AM62-SIP, AM625
Hello All,
I am getting the following driver errors when streaming video for a few minutes (2-15) to the M2-CC3351 wifi module.
We plan to deploy thousands of these Wi-Fi modules starting early next year, so resolving this video streaming issue is critical to our success. We would greatly appreciate your support in addressing it.
Phy0 error logs
These logs happen every time the video stream freezes. Stream reconnects shortly after (2-10 minutes)
Stream freezes in 3-12 minutes after starting.
[  427.253658] cc33xx: ERROR INTERROGATE command failed
[  427.253661] cc33xx: CC33xx driver attempting recovery
[  427.253674] cc33xx: WARNING acx roaming statistics failed: -5
[  429.539487] ieee80211 phy0: Hardware restart was requested
[ 1324.381697] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
CC3351 relevant logs and data for post
TI board, OS image
  1. EVM board
    1. SK-AM62-SIP EVM board
  2. M.2 wifi module
    1. M2-CC3351
  3. Default debain trixie image
    1. tisdk-debian-trixie-am62xxsip-evm-10.01.10.04.wic
  4. Created “uEnv.txt” at BOOT partition and saved the following to it
    1. name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo
  5. uname -r
    1. 6.6.58-k3
GStreamer command being used
gst-launch-1.0 v4l2src device=/dev/video0 ! \ queue ! videoconvert ! \ queue ! jpegenc quality=20 ! \ queue ! rtpjpegpay ! \ queue ! udpsink host=192.168.2.50 port=5000 sync=false
Camera
The same error occurs on any camera tested but the one used here is
  • Arducam 8MP 1080P USB Camera Module for Raspberry Pi, 1/4” CMOS IMX219 Mini UVC USB2.0 Webcam Board with 1.64ft/0.5m USB Cable for Windows, Linux, Android and Mac OS
  • www.amazon.com/.../B07YHK63DS
Ifconfig
root@am62xxsip-evm:~# ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
     ether 08:04:b4:31:12:3f  txqueuelen 1000  (Ethernet)
     RX packets 0  bytes 0 (0.0 B)
     RX errors 0  dropped 0  overruns 0  frame 0
     TX packets 0  bytes 0 (0.0 B)
     TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
     ether ba:80:96:cb:80:e3  txqueuelen 1000  (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
     inet 127.0.0.1  netmask 255.0.0.0
     inet6 ::1  prefixlen 128  scopeid 0x10<host>
     loop  txqueuelen 1000  (Local Loopback)
     RX packets 5192  bytes 714983 (698.2 KiB)
     TX packets 5192  bytes 714983 (698.2 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
     inet 192.168.2.1  netmask 255.255.255.0  broadcast 192.168.2.255
     inet6 fe80::cd5e:fac4:700:5953  prefixlen 64  scopeid 0x20<link>
     ether f8:fb:90:13:6d:56  txqueuelen 1000  (Ethernet)
     RX packets 101  bytes 11827 (11.5 KiB)
     TX packets 234834  bytes 338592220 (322.9 MiB)
lsmod
root@am62xxsip-evm:~# lsmod
Module              Size  Used by
cc33xx            110592  0
rpmsg_ctrl         12288  0
rpmsg_char         20480  1 rpmsg_ctrl
mac80211          569344  1 cc33xx
snd_soc_hdmi_codec 16384  0
libarc4            12288  1 mac80211
uvcvideo          102400  1
videobuf2_vmalloc  12288  17 uvcvideo
uvc                12288  1 uvcvideo
videobuf2_memops   12288  1 videobuf2_vmalloc
videobuf2_v4l2     28672  1 uvcvideo
snd_usb_audio     299008  0
videobuf2_common   57344  4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videodev          249856  3 videobuf2_v4l2,uvcvideo
snd_hwdep          16384  1 snd_usb_audio
snd_usbmidi_lib    32768  1 snd_usb_audio
pru_rproc          20480  0
snd_rawmidi        36864  1 snd_usbmidi_lib
irq_pruss_intc     12288  0
mc                 57344  5 videodev,snd_usb_audio,videobuf2_v4l2,uvcvideo,videobuf2_common
snd_soc_simple_card 16384  0
snd_soc_simple_card_utils 24576  1 snd_soc_simple_card
crct10dif_ce       12288  1
pvrsrvkm         1269760  0
display_connector  12288  0
cc33xx_sdio        12288  0
8021q              28672  0
garp               12288  1 8021q
rtc_ti_k3          12288  1
k3_j72xx_bandgap   12288  0
ti_k3_r5_remoteproc 24576  0
mrp                20480  1 8021q
stp                12288  1 garp
llc                16384  2 stp,garp
cfg80211          397312  2 mac80211,cc33xx
ti_k3_m4_remoteproc 16384  0
rfkill             28672  3 cfg80211
rti_wdt            12288  0
tidss              65536  0
sii902x            20480  0
tps6598x           24576  0
snd_soc_davinci_mcasp 32768  2
snd_soc_tlv320aic3x_i2c 12288  1
snd_soc_tlv320aic3x 73728  1 snd_soc_tlv320aic3x_i2c
snd_soc_ti_udma    12288  1 snd_soc_davinci_mcasp
sa2ul              32768  0
drm_dma_helper     20480  2 tidss
typec              73728  1 tps6598x
snd_soc_ti_edma    12288  1 snd_soc_davinci_mcasp
mcrc64             12288  0
drm_kms_helper    188416  4 sii902x,drm_dma_helper,display_connector,tidss
pruss              16384  1 pru_rproc
snd_soc_ti_sdma    12288  1 snd_soc_davinci_mcasp
at24               16384  0
omap_mailbox       12288  2
omap_hwspinlock    12288  0
fuse              131072  1
drm               548864  7 sii902x,drm_kms_helper,drm_dma_helper,display_connector,pvrsrvkm,tidss
drm_panel_orientation_quirks 28672  1 drm
backlight          20480  1 drm
ip_tables          28672  0
x_tables           36864  1 ip_tables
ipv6              475136  32
AP set up (DHCP, systemd service)
  1. apt update
  2. install wpa supplement
    1. apt install wpasupplicant
    2. systemctl restart wpa_supplicant
    3. systemctl restart NetworkManager
  3. apt install hostapd -y
  4. AP set up
    1. Created hostapd.conf at this location
      1. /etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid=TI-AP-BOARD2
hw_mode=g
channel=6
auth_algs=1
wmm_enabled=0
wpa=2
wpa_passphrase=YourSecurePasswordHere
wpa_key_mgmt=WPA-PSK
rsn_pairwise=CCMP
  1. Modded default hostapd to point to hostapd.conf
    1. Located here:
    2. /etc/default/hostapd
    3. DAEMON_CONF="/etc/hostapd/hostapd.conf"
# Defaults for hostapd initscript
# WARNING: The DAEMON_CONF setting has been deprecated and will be removed
#      in future package releases.
# See /usr/share/doc/hostapd/README.Debian for information about alternative
# methods of managing hostapd.
# Uncomment and set DAEMON_CONF to the absolute path of a hostapd configuration
# file and hostapd will be started during system boot. An example configuration
# file can be found at /usr/share/doc/hostapd/examples/hostapd.conf.gz
# Additional daemon options to be appended to hostapd command:-
#   -d   show more debug messages (-dd for even more)
#   -K   include key data in debug messages
#   -t   include timestamps in some debug messages
# Note that -B (daemon mode) and -P (pidfile) options are automatically
# configured by the init.d script and must not be added to DAEMON_OPTS.
#DAEMON_OPTS=""
  • sudo systemctl unmask hostapd
  • sudo systemctl enable hostapd
  • sudo systemctl start hostapd
  • Next download dhcpcd5
  • sudo apt install dhcpcd5
  • dhcpcd sudo systemctl start dhcpcd
  • Mod this file
    • /etc/dhcpcd.conf
    • Add this to the bottom
interface wlan0
static ip_address=192.168.2.1/24
nohook wpa_supplicant
  • Here is the entire dhcpcd.conf file
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
#clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
duid
# Persist interface configuration when dhcpcd exits.
persistent
# vendorclassid is set to blank to avoid sending the default of
# dhcpcd-<version>:<os>:<machine>:<platform>
vendorclassid
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search
option classless_static_routes
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# Request a hostname from the network
option host_name
# Most distributions have NTP support.
#option ntp_servers
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate SLAAC address using the Hardware Address of the interface
#slaac hwaddr
# OR generate Stable Private IPv6 Addresses based from the DUID
slaac private
interface wlan0
  • apt install dnsmasq -y
  • interface=wlan0
  • dhcp-range=192.168.2.10,192.168.2.100,24h
  • Then enabled dnsmasq
  • systemctl restart dnsmasq
  • systemctl enable dnsmasq
  • systemctl status dnsmasq
At this point we can reboot and see the AP of the TI
On different TI board you can use the following to see AP
  • nmcli dev wifi list
Dmesg logs
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.6.58-k3 (root@b9f9a5302703) (gcc (Debian 13.3.0-8) 13.3.0, GNU ld (GNU Binutils for Debian) 2.43.50.20241126) #1 SMP PREEMPT Thu Dec  5 17:21:53 UTC 2024
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Texas Instruments AM625 SK
[    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
[    0.000000] printk: bootconsole [ns16550a0] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000093600000, size 128 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x0000000093600000..0x000000009b5fffff (131072 KiB) map reusable linux,cma
[    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
[    0.000000] OF: reserved mem: 0x000000009b700000..0x000000009bffffff (9216 KiB) nomap non-reusable framebuffer@9b700000
[    0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
[    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
[    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000
[    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
[    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
[    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000
[    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x000000009bffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
[    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b6fffff]
[    0.000000]   node   0: [mem 0x000000009b700000-0x000000009bffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009bffffff]
[    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] psci: SMC Calling Convention v1.5
[    0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
[    0.000000] pcpu-alloc: s43176 r8192 d30552 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: GIC system register CPU interface
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=ea0a48c4-02 rw rootfstype=ext4 rootwait
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 112896
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x000000008beee000-0x000000008feee000] (64MB)
[    0.000000] Memory: 221168K/458752K available (12480K kernel code, 1272K rwdata, 4184K rodata, 1344K init, 528K bss, 106512K reserved, 131072K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: RCU event tracing is enabled.
[    0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000] Trampoline variant of Tasks RCU enabled.
[    0.000000] Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[    0.000000] GICv3: 256 SPIs implemented
[    0.000000] GICv3: 0 Extended SPIs implemented
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GICv3: GICv3 features: 16 PPIs
[    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
[    0.000000] ITS [mem 0x01820000-0x0182ffff]
[    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
[    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
[    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GICv3: using LPI property table @0x0000000080440000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[    0.008662] Console: colour dummy device 80x25
[    0.013287] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
[    0.023979] pid_max: default: 32768 minimum: 301
[    0.028802] LSM: initializing lsm=capability,selinux,integrity
[    0.034803] SELinux:  Initializing.
[    0.038530] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.046015] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.056347] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.063708] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.071677] rcu: Hierarchical SRCU implementation.
[    0.076586] rcu: Max phase no-delay instances is 1000.
[    0.082277] Platform MSI: msi-controller@1820000 domain created
[    0.088680] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
[    0.098170] EFI services will not be available.
[    0.103184] smp: Bringing up secondary CPUs ...
[    0.108644] Detected VIPT I-cache on CPU1
[    0.108758] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
[    0.108783] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
[    0.108848] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.109734] Detected VIPT I-cache on CPU2
[    0.109818] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
[    0.109838] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000
[    0.109877] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.110623] Detected VIPT I-cache on CPU3
[    0.110696] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
[    0.110708] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000
[    0.110743] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.110831] smp: Brought up 1 node, 4 CPUs
[    0.190585] SMP: Total of 4 processors activated.
[    0.195398] CPU features: detected: 32-bit EL0 Support
[    0.200676] CPU features: detected: CRC32 instructions
[    0.206017] CPU: All CPU(s) started at EL2
[    0.210221] alternatives: applying system-wide alternatives
[    0.217748] devtmpfs: initialized
[    0.230558] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.240585] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.253460] pinctrl core: initialized pinctrl subsystem
[    0.259570] DMI not present or invalid.
[    0.264356] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.271512] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[    0.278856] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.286890] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.295076] audit: initializing netlink subsys (disabled)
[    0.300883] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
[    0.301497] thermal_sys: Registered thermal governor 'step_wise'
[    0.308825] thermal_sys: Registered thermal governor 'power_allocator'
[    0.315034] cpuidle: using governor menu
[    0.325938] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.332987] ASID allocator initialised with 65536 entries
[    0.344914] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
[    0.356451] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    0.368481] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.378531] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    0.390599] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.405599] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    0.417791] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.428948] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    0.441882] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    0.451831] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.461829] /bus@f0000/pinctrl@a40000: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
[    0.473445] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    0.482709] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    0.493631] Modules: 27776 pages in range for non-PLT usage
[    0.493641] Modules: 519296 pages in range for PLT usage
[    0.500401] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.512810] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.519221] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.526161] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.532574] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.539516] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.545923] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.552863] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.561038] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
[    0.570524] iommu: Default domain type: Translated
[    0.575463] iommu: DMA domain TLB invalidation policy: strict mode
[    0.582157] SCSI subsystem initialized
[    0.586253] libata version 3.00 loaded.
[    0.586485] usbcore: registered new interface driver usbfs
[    0.592138] usbcore: registered new interface driver hub
[    0.597611] usbcore: registered new device driver usb
[    0.603413] pps_core: LinuxPPS API ver. 1 registered
[    0.608497] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.617853] PTP clock support registered
[    0.622121] EDAC MC: Ver: 3.0.0
[    0.626052] scmi_core: SCMI protocol bus registered
[    0.631446] FPGA manager framework
[    0.635036] Advanced Linux Sound Architecture Driver Initialized.
[    0.642466] vgaarb: loaded
[    0.645750] clocksource: Switched to clocksource arch_sys_counter
[    0.652388] VFS: Disk quotas dquot_6.6.0
[    0.656446] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.671134] NET: Registered PF_INET protocol family
[    0.676344] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.684608] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[    0.693250] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.701200] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.709157] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.716709] TCP: Hash tables configured (established 4096 bind 4096)
[    0.723366] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.730070] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.737387] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.743746] RPC: Registered named UNIX socket transport module.
[    0.749831] RPC: Registered udp transport module.
[    0.754641] RPC: Registered tcp transport module.
[    0.759450] RPC: Registered tcp-with-tls transport module.
[    0.765059] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.771664] NET: Registered PF_XDP protocol family
[    0.776592] PCI: CLS 0 bytes, default 64
[    0.782472] Initialise system trusted keyrings
[    0.787344] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[    0.794352] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.800683] NFS: Registering the id_resolver key type
[    0.805902] Key type id_resolver registered
[    0.810184] Key type id_legacy registered
[    0.814302] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.821158] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.863027] Key type asymmetric registered
[    0.867237] Asymmetric key parser 'x509' registered
[    0.872297] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.880098] io scheduler mq-deadline registered
[    0.884739] io scheduler kyber registered
[    0.888884] io scheduler bfq registered
[    0.897022] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.903716] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.911490] pinctrl-single a40000.pinctrl: 512 pins, size 2048
[    0.925168] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.945711] loop: module loaded
[    0.950484] megasas: 07.725.01.00-rc1
[    0.958784] tun: Universal TUN/TAP device driver, 1.6
[    0.965274] VFIO - User Level meta-driver version: 0.3
[    0.971887] usbcore: registered new interface driver usb-storage
[    0.978787] i2c_dev: i2c /dev entries driver
[    0.985122] sdhci: Secure Digital Host Controller Interface driver
[    0.991473] sdhci: Copyright(c) Pierre Ossman
[    0.996219] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.002941] ledtrig-cpu: registered to indicate activity on CPUs
[    1.009469] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    1.016881] usbcore: registered new interface driver usbhid
[    1.022586] usbhid: USB HID core driver
[    1.028227] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.037334] optee: probing for conduit method.
[    1.041920] optee: revision 4.4 (8f645256efc0dc66)
[    1.042344] optee: dynamic shared memory is enabled
[    1.053186] random: crng init done
[    1.056803] optee: initialized driver
[    1.062939] Initializing XFRM netlink socket
[    1.067401] NET: Registered PF_PACKET protocol family
[    1.072698] Key type dns_resolver registered
[    1.086533] registered taskstats version 1
[    1.090975] Loading compiled-in X.509 certificates
[    1.113916] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)')
[    1.196842] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    1.209016] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.216452] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.225770] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
[    1.235730] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
[    1.244967] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
[    1.255426] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
[    1.262777] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
[    1.269513] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.278887] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.288788] simple-framebuffer 9b700000.framebuffer: framebuffer at 0x9b700000, 0x8ca000 bytes
[    1.297634] simple-framebuffer 9b700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
[    1.323256] Console: switching to colour frame buffer device 240x75
[    1.344231] simple-framebuffer 9b700000.framebuffer: fb0: simplefb registered!
[    1.353165] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.362503] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.374273] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.386341] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.397391] printk: console [ttyS2] disabled
[    1.402260] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3000000) is a 8250
[    1.411180] printk: console [ttyS2] enabled
[    1.419701] printk: bootconsole [ns16550a0] disabled
[    1.438122] spi-nor spi0.0: s28hs512t (65536 Kbytes)
[    1.443259] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
[    1.450220] Creating 7 MTD partitions on "fc40000.spi.0":
[    1.455615] 0x000000000000-0x000000080000 : "ospi.tiboot3"
[    1.462784] 0x000000080000-0x000000280000 : "ospi.tispl"
[    1.469620] 0x000000280000-0x000000680000 : "ospi.u-boot"
[    1.476476] 0x000000680000-0x0000006c0000 : "ospi.env"
[    1.483082] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
[    1.490282] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
[    1.497094] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
[    1.757422] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.801755] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.814009] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[    1.822118] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
[    1.830254] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.843208] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
[    1.849484] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.856612] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.863301] pps pps0: new PPS source ptp0
[    1.867677] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
[    1.883103] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.894435] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
[    1.906360] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
[    1.921436] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.927041] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.934881] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
[    1.940890] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
[    1.950351] xhci-hcd xhci-hcd.0.auto: irq 253, io mem 0x31100000
[    1.957417] hub 1-0:1.0: USB hub found
[    1.961220] hub 1-0:1.0: 1 port detected
[    1.967465] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
[    1.980697] mmc0: CQHCI version 5.10
[    1.988292] pca953x 1-0022: supply vcc not found, using dummy regulator
[    1.995201] pca953x 1-0022: using AI
[    2.021819] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    2.032420] mmc1: CQHCI version 5.10
[    2.035300] mmc2: CQHCI version 5.10
[    2.036321] clk: Disabling unused clocks
[    2.052395] ALSA device list:
[    2.055483]   No soundcards found.
[    2.081759] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
[    2.082333] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
[    2.094860] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
[    2.097271] Waiting for root device PARTUUID=ea0a48c4-02...
[    2.122244] mmc2: new high speed SDIO card at address 0001
[    2.134015] mmc0: Command Queue Engine enabled
[    2.138487] mmc0: new HS200 MMC card at address 0001
[    2.144257] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
[    2.151964]  mmcblk0: p1 p2
[    2.155588] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
[    2.156027] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
[    2.162022] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
[    2.168022] mmcblk1: mmc1:aaaa SD64G 59.5 GiB
[    2.173300] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
[    2.179381]  mmcblk1: p1 p2
[    2.215284] EXT4-fs (mmcblk1p2): mounted filesystem fb4932ea-803d-4a42-9cd3-da60b6de5c8e r/w with ordered data mode. Quota mode: none.
[    2.217831] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.227490] VFS: Mounted root (ext4 filesystem) on device 179:98.
[    2.242966] devtmpfs: mounted
[    2.247076] Freeing unused kernel memory: 1344K
[    2.251766] Run /sbin/init as init process
[    2.255859]   with arguments:
[    2.255862]     /sbin/init
[    2.255865]   with environment:
[    2.255868]     HOME=/
[    2.255873]     TERM=linux
[    2.548976] systemd[1]: System time advanced to built-in epoch: Thu 2025-03-13 15:25:54 UTC
[    2.616858] NET: Registered PF_INET6 protocol family
[    2.623184] Segment Routing with IPv6
[    2.626979] In-situ OAM (IOAM) with IPv6
[    2.701930] systemd[1]: systemd 257.4-3 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[    2.735486] systemd[1]: Detected architecture arm64.
[    2.768001] systemd[1]: Hostname set to <am62xxsip-evm>.
[    2.828600] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[    3.137713] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[    3.756210] systemd[1]: Queued start job for default target graphical.target.
[    3.804558] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    3.832484] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    3.860617] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    3.887649] systemd[1]: Created slice user.slice - User and Session Slice.
[    3.910407] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[    3.938224] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    3.966213] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
[    3.985665] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2...
[    4.009881] systemd[1]: Expecting device sys-subsystem-net-devices-wlan0.device - /sys/subsystem/net/devices/wlan0...
[    4.038094] systemd[1]: Reached target paths.target - Path Units.
[    4.061951] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[    4.085903] systemd[1]: Reached target slices.target - Slice Units.
[    4.109943] systemd[1]: Reached target swap.target - Swaps.
[    4.135091] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[    4.158618] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    4.183363] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[    4.206724] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    4.230708] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[    4.254950] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
[    4.278034] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    4.291878] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    4.306133] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    4.330406] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    4.359931] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[    4.388079] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    4.433036] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[    4.469036] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    4.478635] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.505975] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
[    4.539262] systemd[1]: Starting ifupdown-wait-online.service - Wait for network to be configured by ifupdown...
[    4.557424] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    4.594124] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    4.611022] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    4.653403] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    4.686712] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    4.702615] systemd[1]: Starting nftables.service - nftables...
[    4.730612] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    4.779086] systemd[1]: Starting systemd-journald.service - Journal Service...
[    4.795597] fuse: init (API version 7.39)
[    4.812005] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    4.845698] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
[    4.874525] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    4.897250] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    4.926634] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    4.954971] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[    4.995168] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    5.024150] systemd-journald[131]: Collecting audit messages is enabled.
[    5.053352] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[    5.062753] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    5.114488] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[    5.139733] systemd[1]: Started systemd-journald.service - Journal Service.
[    5.163023] audit: type=1130 audit(1741879556.624:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.234268] audit: type=1130 audit(1741879556.696:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=ifupdown-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.270234] audit: type=1130 audit(1741879556.732:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.306321] audit: type=1130 audit(1741879556.768:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.326320] audit: type=1131 audit(1741879556.768:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.362289] audit: type=1130 audit(1741879556.824:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.381912] audit: type=1131 audit(1741879556.824:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.418253] audit: type=1130 audit(1741879556.880:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.438477] audit: type=1131 audit(1741879556.880:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.474281] audit: type=1130 audit(1741879556.936:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.494060] audit: type=1131 audit(1741879556.936:12): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.546325] audit: type=1130 audit(1741879557.008:13): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=nftables comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[    5.582284] audit: type=1130 audit(1741879557.044:14): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.622277] audit: type=1130 audit(1741879557.084:15): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-network-generator comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.658829] audit: type=1130 audit(1741879557.120:16): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.698266] audit: type=1130 audit(1741879557.160:17): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-udev-load-credentials comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.996636] systemd-journald[131]: Received client request to flush runtime journal.
[    6.054906] audit: type=1130 audit(1741879557.516:18): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.138243] audit: type=1130 audit(1741879557.600:19): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.178278] audit: type=1130 audit(1741879557.640:20): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    8.044843] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.112975] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.122752] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    8.820964] at24 0-0051: supply vcc not found, using dummy regulator
[    8.821220] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
[    8.851133] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
[    8.968979] tps6598x 0-003f: Unable to find the interrupt, switching to polling
[    9.089021] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
[    9.109731] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.123970] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.145590] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
[    9.145686] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
[    9.152297] 8021q: 802.1Q VLAN Support v1.8
[    9.167191] remoteproc remoteproc0: 5000000.m4fss is available
[    9.176160] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.212094] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.229646] remoteproc remoteproc0: powering up 5000000.m4fss
[    9.236012] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55100
[    9.253908] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node m4f-dma-memory@9cb00000
[    9.264611] virtio_rpmsg_bus virtio0: rpmsg host is online
[    9.264842] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
[    9.274341] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
[    9.278188] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
[    9.284674] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
[    9.299507] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    9.304614] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.313987] platform 78000000.r5f: configured R5F for IPC-only mode
[    9.324473] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.326451] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
[    9.352009] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
[    9.352088] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:15 UTC (15)
[    9.352296] remoteproc remoteproc1: 78000000.r5f is available
[    9.352479] remoteproc remoteproc1: attaching to 78000000.r5f
[    9.353106] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
[    9.354327] virtio_rpmsg_bus virtio1: rpmsg host is online
[    9.354396] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
[    9.354405] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
[    9.355213] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
[    9.355692] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
[    9.356110] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.356146] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.356350] systemd-journald[131]: Time jumped backwards, rotating.
[    9.377805] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.470020] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.497584] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.506245] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.643350] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
[    9.652821] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[    9.666198] sii902x 1-003b: supply iovcc not found, using dummy regulator
[    9.667938] 8021q: adding VLAN 0 to HW filter on device eth0
[    9.675242] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
[    9.692152] mc: Linux media interface: v0.10
[    9.694880] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
[    9.700083] i2c i2c-1: Added multiplexed i2c bus 3
[    9.707088] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[    9.715734] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
[    9.724136] 8021q: adding VLAN 0 to HW filter on device eth1
[    9.728074] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
[    9.743911] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    9.753837] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    9.762443] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
[    9.799814] pvrsrvkm: loading out-of-tree module taints kernel.
[    9.815501] videodev: Linux video capture interface: v2.00
[    9.822614] PVR_K:  221: Device: fd00000.gpu
[    9.835276] PVR_K:  221: Read BVNC 33.15.11.3 from HW device registers
[    9.844708] PVR_K:  221: RGX Device registered with BVNC 33.15.11.3
[    9.861410] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1
[    9.906175] usb 1-1: 3:1: cannot get freq at ep 0x84
[    9.915054] cc33xx_sdio mmc2:0001:2: Using GPIO as IRQ
[   10.036544] remoteproc remoteproc2: 30074000.pru is available
[   10.043616] remoteproc remoteproc3: 30078000.pru is available
[   10.084938] usbcore: registered new interface driver snd-usb-audio
[   10.094812] usb 1-1: Found UVC 1.00 device Arducam_8mp (0c45:6366)
[   10.158252] usbcore: registered new interface driver uvcvideo
[   10.450316] cc33xx_driver cc33xx.5.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
[   10.703032] kauditd_printk_skb: 48 callbacks suppressed
[   10.703058] audit: type=1130 audit(16.848:59): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   10.749129] audit: type=1334 audit(16.892:60): prog-id=29 op=LOAD
[   10.755348] audit: type=1334 audit(16.900:61): prog-id=30 op=LOAD
[   10.761516] audit: type=1334 audit(16.904:62): prog-id=31 op=LOAD
[   11.047214] audit: type=1130 audit(17.192:63): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.283902] audit: type=1130 audit(17.428:64): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.452923] audit: type=1130 audit(17.596:65): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.559858] audit: type=1130 audit(17.704:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.583184] audit: type=1130 audit(17.728:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   11.620958] audit: type=1130 audit(17.764:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=serial-getty@ttyS2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   14.614990] PVR_K:  374: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[   14.629931] PVR_K:  374: Shader binary image 'rgx.sh.33.15.11.3' loaded
[   17.258262] kauditd_printk_skb: 106 callbacks suppressed
[   17.258284] audit: type=1130 audit(23.404:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   17.596008] audit: type=1131 audit(23.740:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.955208] audit: type=1100 audit(27.100:115): pid=372 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:authentication grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
[   20.977232] audit: type=1101 audit(27.108:116): pid=372 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
[   20.998879] audit: type=1103 audit(27.112:117): pid=372 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
[   21.025704] audit: type=1006 audit(27.112:118): pid=372 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=ttyS2 old-ses=4294967295 ses=3 res=1
[   21.039994] audit: type=1300 audit(27.112:118): arch=c00000b7 syscall=64 success=yes exit=1 a0=4 a1=ffffd03081b0 a2=1 a3=0 items=0 ppid=1 pid=372 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS2 ses=3 comm="login" exe="/usr/bin/login" subj=kernel key=(null)
[   21.070359] audit: type=1327 audit(27.112:118): proctitle=2F62696E2F6C6F67696E002D2D
[   21.155606] audit: type=1105 audit(27.300:119): pid=372 uid=0 auid=0 ses=3 subj=kernel msg='op=PAM:session_open grantors=pam_selinux,pam_loginuid,pam_selinux,pam_env,pam_env,pam_limits,pam_mail,pam_keyinit,pam_permit,pam_umask,pam_unix,pam_wtmpdb,pam_systemd acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
[   21.186857] audit: type=1110 audit(27.300:120): pid=372 uid=0 auid=0 ses=3 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
[   41.077583] kauditd_printk_skb: 2 callbacks suppressed
[   41.077601] audit: type=1131 audit(47.220:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   41.177995] audit: type=1334 audit(47.324:124): prog-id=29 op=UNLOAD
[  129.932151] audit: type=1130 audit(136.076:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-networkd-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[  130.259998] audit: type=1130 audit(136.404:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=dnsmasq comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  922.567607] audit: type=1130 audit(928.712:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  922.588611] audit: type=1131 audit(928.712:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1015.097528] audit: type=1101 audit(1021.240:129): pid=486 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_permit acct="root" exe="/usr/sbin/cron" hostname=? addr=? terminal=cron res=success'
[ 1015.117800] audit: type=1103 audit(1021.244:130): pid=486 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/sbin/cron" hostname=? addr=? terminal=cron res=success'
[ 1015.137840] audit: type=1006 audit(1021.244:131): pid=486 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=4 res=1
[ 1015.150991] audit: type=1300 audit(1021.244:131): arch=c00000b7 syscall=64 success=yes exit=1 a0=7 a1=ffffe199a700 a2=1 a3=0 items=0 ppid=252 pid=486 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4 comm="cron" exe="/usr/sbin/cron" subj=kernel key=(null)
[ 1015.176306] audit: type=1327 audit(1021.244:131): proctitle=2F7573722F7362696E2F43524F4E002D66
[ 1015.184992] audit: type=1105 audit(1021.244:132): pid=486 uid=0 auid=0 ses=4 subj=kernel msg='op=PAM:session_open grantors=pam_loginuid,pam_env,pam_env,pam_permit,pam_umask,pam_unix,pam_limits acct="root" exe="/usr/sbin/cron" hostname=? addr=? terminal=cron res=success'
[ 1015.208922] audit: type=1110 audit(1021.248:133): pid=488 uid=0 auid=0 ses=4 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/sbin/cron" hostname=? addr=? terminal=cron res=success'
[ 1015.227305] audit: type=1104 audit(1021.256:134): pid=486 uid=0 auid=0 ses=4 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/sbin/cron" hostname=? addr=? terminal=cron res=success'
[ 1015.245692] audit: type=1106 audit(1021.256:135): pid=486 uid=0 auid=0 ses=4 subj=kernel msg='op=PAM:session_close grantors=pam_loginuid,pam_env,pam_env,pam_permit,pam_umask,pam_unix,pam_limits acct="root" exe="/usr/sbin/cron" hostname=? addr=? terminal=cron res=success'
[ 1371.381767] cc33xx: ERROR INTERROGATE command failed
[ 1371.381769] cc33xx: CC33xx driver attempting recovery
[ 1371.391839] cc33xx: WARNING acx roaming statistics failed: -5
[ 1373.671644] ieee80211 phy0: Hardware restart was requested
All packages here
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                             Version                        Architecture Description
ii  adduser                          3.149                          all      add and remove users and groups
ii  adwaita-icon-theme               48.0-1                         all      default icon theme of GNOME
ii  alsa-utils                       1.2.13-1                       arm64    Utilities for configuring and using ALSA
ii  apt                              2.9.35                         arm64    commandline package manager
ii  apt-listchanges                  4.8                            all      package change history notification tool
ii  apt-utils                        2.9.35                         arm64    package management related utility programs
ii  at-spi2-common                   2.56.1-2                       all      Assistive Technology Service Provider Interface (common files)
ii  base-files                       13.7                           arm64    Debian base system miscellaneous files
ii  base-passwd                      3.6.7                          arm64    Debian base system master password and group files
ii  bash                             5.2.37-1.1+b2                  arm64    GNU Bourne Again SHell
ii  bash-completion                  1:2.16.0-7                     all      programmable completion for the bash shell
ii  bind9-dnsutils                   1:9.20.7-1                     arm64    Clients provided with BIND 9
ii  bind9-host                       1:9.20.7-1                     arm64    DNS Lookup Utility
ii  bind9-libs:arm64                 1:9.20.7-1                     arm64    Shared Libraries used by BIND 9
ii  binutils                         2.44-3                         arm64    GNU assembler, linker and binary utilities
ii  binutils-aarch64-linux-gnu       2.44-3                         arm64    GNU binary utilities, for aarch64-linux-gnu target
ii  binutils-common:arm64            2.44-3                         arm64    Common files for the GNU assembler, linker and binary utilities
ii  bsdextrautils                    2.41-3                         arm64    extra utilities from 4.4BSD-Lite
ii  bsdutils                         1:2.41-3                       arm64    basic utilities from 4.4BSD-Lite
ii  build-essential                  12.12                          arm64    Informational list of build-essential packages
ii  bzip2                            1.0.8-6                        arm64    high-quality block-sorting file compressor - utilities
ii  ca-certificates                  20241223                       all      Common CA certificates
ii  coreutils                        9.5-1+b1                       arm64    GNU core utilities
ii  cpio                             2.15+dfsg-2                    arm64    GNU cpio -- a program to manage archives of files
ii  cpp                              4:14.2.0-1                     arm64    GNU C preprocessor (cpp)
ii  cpp-14                           14.2.0-19                      arm64    GNU C preprocessor
ii  cpp-14-aarch64-linux-gnu         14.2.0-19                      arm64    GNU C preprocessor for aarch64-linux-gnu
ii  cpp-aarch64-linux-gnu            4:14.2.0-1                     arm64    GNU C preprocessor (cpp) for the arm64 architecture
ii  cron                             3.0pl1-196                     arm64    process scheduling daemon
ii  cron-daemon-common               3.0pl1-196                     all      process scheduling daemon's configuration files
ii  cryptodev-linux-dkms             1.14+git20240719+135cbff-1     arm64    Linux Kernel device for cryptographic accelerator access
ii  curl                             8.13.0-1                       arm64    command line tool for transferring data with URL syntax
ii  dash                             0.5.12-12                      arm64    POSIX-compliant shell
ii  dbus                             1.16.2-2                       arm64    simple interprocess messaging system (system message bus)
ii  dbus-bin                         1.16.2-2                       arm64    simple interprocess messaging system (command line utilities)
ii  dbus-daemon                      1.16.2-2                       arm64    simple interprocess messaging system (reference message bus)
ii  dbus-session-bus-common          1.16.2-2                       all      simple interprocess messaging system (session bus configuration)
ii  dbus-system-bus-common           1.16.2-2                       all      simple interprocess messaging system (system bus configuration)
ii  dbus-user-session                1.16.2-2                       arm64    simple interprocess messaging system (systemd --user integration)
ii  dconf-gsettings-backend:arm64    0.40.0-5                       arm64    simple configuration storage system - GSettings back-end
ii  dconf-service                    0.40.0-5                       arm64    simple configuration storage system - D-Bus service
ii  debconf                          1.5.91                         all      Debian configuration management system
ii  debconf-i18n                     1.5.91                         all      full internationalization support for debconf
ii  debian-archive-keyring           2023.4                         all      GnuPG archive keys of the Debian archive
ii  debian-faq                       12.2                           all      Debian Frequently Asked Questions
ii  debianutils                      5.21                           arm64    Miscellaneous utilities specific to Debian
ii  dhcpcd                           1:10.1.0-10                    all      DHCPv4 and DHCPv6 dual-stack client (init.d script & systemd unit)
ii  dhcpcd-base                      1:10.1.0-10                    arm64    DHCPv4 and DHCPv6 dual-stack client (binaries and exit hooks)
ii  dhcpcd5                          1:10.1.0-10                    all      DHCPv4 and DHCPv6 dual-stack client (dummy transitional package)
ii  diffutils                        1:3.10-3                       arm64    File comparison utilities
ii  distro-info-data                 0.63                           all      information about the distributions' releases (data files)
ii  dkms                             3.1.5-2                        all      Dynamic Kernel Module System (DKMS)
ii  dmidecode                        3.6-2                          arm64    SMBIOS/DMI table decoder
ii  dmsetup                          2:1.02.205-1                   arm64    Linux Kernel Device Mapper userspace library
ii  dns-root-data                    2024071801                     all      DNS root hints and DNSSEC trust anchor
ii  dnsmasq                          2.91-1                         all      Small caching DNS proxy and DHCP/TFTP server - system daemon
ii  dnsmasq-base                     2.91-1                         arm64    Small caching DNS proxy and DHCP/TFTP server - executable
ii  doc-debian                       11.3+nmu1                      all      Debian Project documentation and other documents
ii  dpkg                             1.22.18                        arm64    Debian package management system
ii  dpkg-dev                         1.22.18                        all      Debian package development tools
ii  e2fsprogs                        1.47.2-1+b1                    arm64    ext2/ext3/ext4 file system utilities
ii  fdisk                            2.41-3                         arm64    collection of partitioning utilities
ii  file                             1:5.45-3+b1                    arm64    Recognize the type of data in a file using "magic" numbers
ii  findutils                        4.10.0-3                       arm64    utilities for finding files--find, xargs
ii  firmware-cnm-wave                11.00.09-1                     all      Chips&Media codec firmware for TI Platforms
ii  firmware-ti-connectivity         20241210-1                     all      Binary firmware for TI Connectivity Wi-Fi and BT/FM/GPS adapters
ii  firmware-ti-ipc-am62             11.00.09-1                     all      TI IPC firmware for AM62
ii  fontconfig                       2.15.0-2.2                     arm64    generic font configuration library - support binaries
ii  fontconfig-config                2.15.0-2.2                     arm64    generic font configuration library - configuration
ii  fonts-dejavu-core                2.37-8                         all      Vera font family derivate with additional characters
ii  fonts-dejavu-mono                2.37-8                         all      Vera font family derivate with additional characters
ii  g++                              4:14.2.0-1                     arm64    GNU C++ compiler
ii  g++-14                           14.2.0-19                      arm64    GNU C++ compiler
ii  g++-14-aarch64-linux-gnu         14.2.0-19                      arm64    GNU C++ compiler for aarch64-linux-gnu architecture
ii  g++-aarch64-linux-gnu            4:14.2.0-1                     arm64    GNU C++ compiler for the arm64 architecture
ii  gcc                              4:14.2.0-1                     arm64    GNU C compiler
ii  gcc-14                           14.2.0-19                      arm64    GNU C compiler
ii  gcc-14-aarch64-linux-gnu         14.2.0-19                      arm64    GNU C compiler for the aarch64-linux-gnu architecture
ii  gcc-14-base:arm64                14.2.0-19                      arm64    GCC, the GNU Compiler Collection (base package)
ii  gcc-aarch64-linux-gnu            4:14.2.0-1                     arm64    GNU C compiler for the arm64 architecture
ii  gettext-base                     0.23.1-1                       arm64    GNU Internationalization utilities for the base system
ii  glib-networking:arm64            2.80.1-1                       arm64    network-related giomodules for GLib
ii  glib-networking-common           2.80.1-1                       all      network-related giomodules for GLib - data files
ii  glib-networking-services         2.80.1-1                       arm64    network-related giomodules for GLib - D-Bus services
ii  gpg                              2.2.46-6                       arm64    GNU Privacy Guard -- minimalist public key operations
ii  gpgconf                          2.2.46-6                       arm64    GNU privacy guard - core configuration utilities
ii  gpgv                             2.2.46-6                       arm64    GNU privacy guard - signature verification tool
ii  grep                             3.11-4+b1                      arm64    GNU grep, egrep and fgrep
ii  groff-base                       1.23.0-7                       arm64    GNU troff text-formatting system (base system components)
ii  gsettings-desktop-schemas        48.0-1                         all      GSettings desktop-wide schemas
ii  gstreamer1.0-plugins-bad:arm64   1.26.0-1                       arm64    GStreamer plugins from the "bad" set
ii  gstreamer1.0-plugins-base:arm64  1.26.0-1                       arm64    GStreamer plugins from the "base" set
ii  gstreamer1.0-plugins-good:arm64  1.26.0-1                       arm64    GStreamer plugins from the "good" set
ii  gstreamer1.0-tools               1.26.0-3                       arm64    Tools for use with GStreamer
ii  gtk-update-icon-cache            4.18.3+ds-1                    arm64    icon theme caching utility
ii  gzip                             1.13-1                         arm64    GNU compression utilities
ii  hicolor-icon-theme               0.18-2                         all      default fallback theme for FreeDesktop.org icon themes
ii  hostapd                          2:2.10-24                      arm64    access point and authentication server for Wi-Fi and Ethernet
ii  hostname                         3.25                           arm64    utility to set/show the host name or domain name
ii  htop                             3.4.1-3                        arm64    interactive processes viewer
ii  i2c-tools                        4.4-2                          arm64    heterogeneous set of I2C tools for Linux
ii  ifupdown                         0.8.44                         arm64    high level tools to configure network interfaces
ii  inetutils-telnet                 2:2.6-1                        arm64    telnet client
ii  init                             1.68                           arm64    metapackage ensuring an init system is installed
ii  init-system-helpers              1.68                           all      helper tools for all init systems
ii  iproute2                         6.14.0-1                       arm64    networking and traffic control tools
ii  iputils-ping                     3:20240905-1                   arm64    Tools to test the reachability of network hosts
ii  iso-codes                        4.17.0-1                       all      ISO language, territory, currency, script codes and their translations
ii  iw                               6.9-1+b1                       arm64    tool for configuring Linux wireless devices
ii  k3conf                           0.3+git20240725+30a1d5b-1      arm64    Powerful Diagnostic Tool for Texas Instruments K3 based Processors
ii  kmod                             34.2-1                         arm64    tools for managing Linux kernel modules
ii  krb5-locales                     1.21.3-5                       all      internationalization support for MIT Kerberos
ii  less                             668-1                          arm64    pager program similar to more
ii  libaa1:arm64                     1.4p5-51.1+b1                  arm64    ASCII art library
ii  libabsl20240722:arm64            20240722.0-1.5                 arm64    extensions to the C++ standard library
ii  libacl1:arm64                    2.3.2-2+b1                     arm64    access control list - shared library
ii  libaml0t64:arm64                 0.3.0-3                        arm64    Andri's Main Loop library (shared library)
ii  libaom3:arm64                    3.12.0-1                       arm64    AV1 Video Codec Library
ii  libapparmor1:arm64               4.1.0~beta5-6                  arm64    changehat AppArmor library
ii  libapt-pkg6.0t64:arm64           2.9.16                         arm64    package management runtime library
ii  libapt-pkg7.0:arm64              2.9.35                         arm64    package management runtime library
ii  libasan8:arm64                   14.2.0-19                      arm64    AddressSanitizer -- a fast memory error detector
ii  libasound2-data                  1.2.13-1                       all      Configuration files and profiles for ALSA drivers
ii  libasound2-plugins:arm64         1.2.12-2+b1                    arm64    ALSA library additional plugins
ii  libasound2t64:arm64              1.2.13-1+b1                    arm64    shared library for ALSA applications
ii  libass9:arm64                    1:0.17.3-1+b1                  arm64    library for SSA/ASS subtitles rendering
ii  libassuan9:arm64                 3.0.2-2                        arm64    IPC library for the GnuPG components
ii  libasyncns0:arm64                0.8-6+b5                       arm64    Asynchronous name service query library
ii  libatk-bridge2.0-0t64:arm64      2.56.1-2                       arm64    AT-SPI 2 toolkit bridge - shared library
ii  libatk1.0-0t64:arm64             2.56.1-2                       arm64    ATK accessibility toolkit
ii  libatomic1:arm64                 14.2.0-19                      arm64    support library providing __atomic built-in functions
ii  libatopology2t64:arm64           1.2.13-1+b1                    arm64    shared library for handling ALSA topology definitions
ii  libatspi2.0-0t64:arm64           2.56.1-2                       arm64    Assistive Technology Service Provider Interface - shared library
ii  libattr1:arm64                   1:2.5.2-3                      arm64    extended attribute handling - shared library
ii  libaudit-common                  1:4.0.2-2                      all      Dynamic library for security auditing - common files
ii  libaudit1:arm64                  1:4.0.2-2+b2                   arm64    Dynamic library for security auditing
ii  libavahi-client3:arm64           0.8-16                         arm64    Avahi client library
ii  libavahi-common-data:arm64       0.8-16                         arm64    Avahi common data files
ii  libavahi-common3:arm64           0.8-16                         arm64    Avahi common library
ii  libavc1394-0:arm64               0.5.4-5+b2                     arm64    control IEEE 1394 audio/video devices
ii  libavcodec61:arm64               7:7.1.1-1+b1                   arm64    FFmpeg library with de/encoders for audio/video codecs - runtime files
ii  libavfilter10:arm64              7:7.1.1-1+b1                   arm64    FFmpeg library containing media filters - runtime files
ii  libavformat61:arm64              7:7.1.1-1+b1                   arm64    FFmpeg library with (de)muxers for multimedia containers - runtime files
ii  libavtp0:arm64                   0.2.0-2                        arm64    Audio Video Transport Protocol (shared library)
ii  libavutil59:arm64                7:7.1.1-1+b1                   arm64    FFmpeg library with functions for simplifying programming - runtime files
ii  libbinutils:arm64                2.44-3                         arm64    GNU binary utilities (private shared library)
ii  libblas3:arm64                   3.12.1-2                       arm64    Basic Linear Algebra Reference implementations, shared library
ii  libblkid1:arm64                  2.41-3                         arm64    block device ID library
ii  libbluetooth3:arm64              5.79-2                         arm64    Library to use the BlueZ Linux Bluetooth stack
ii  libbluray2:arm64                 1:1.3.4-1+b2                   arm64    Blu-ray disc playback support library (shared library)
ii  libbpf1:arm64                    1:1.5.0-2                      arm64    eBPF helper library (shared library)
ii  libbrotli1:arm64                 1.1.0-2+b7                     arm64    library implementing brotli encoder and decoder (shared libraries)
ii  libbs2b0:arm64                   3.1.0+dfsg-8+b1                arm64    Bauer stereophonic-to-binaural DSP library
ii  libbsd0:arm64                    0.12.2-2                       arm64    utility functions from BSD systems - shared library
ii  libbz2-1.0:arm64                 1.0.8-6                        arm64    high-quality block-sorting file compressor library - runtime
ii  libc-bin                         2.41-6                         arm64    GNU C Library: Binaries
ii  libc-dev-bin                     2.41-6                         arm64    GNU C Library: Development binaries
ii  libc-l10n                        2.41-6                         all      GNU C Library: localization files
ii  libc6:arm64                      2.41-6                         arm64    GNU C Library: Shared libraries
ii  libc6-dev:arm64                  2.41-6                         arm64    GNU C Library: Development Libraries and Header Files
ii  libcaca0:arm64                   0.99.beta20-5                  arm64    colour ASCII art library
ii  libcairo-gobject2:arm64          1.18.4-1+b1                    arm64    Cairo 2D vector graphics library (GObject library)
ii  libcairo2:arm64                  1.18.4-1+b1                    arm64    Cairo 2D vector graphics library
ii  libcap-ng0:arm64                 0.8.5-4+b1                     arm64    alternate POSIX capabilities library
ii  libcap2:arm64                    1:2.75-4                       arm64    POSIX 1003.1e capabilities (library)
ii  libcap2-bin                      1:2.75-4                       arm64    POSIX 1003.1e capabilities (utilities)
ii  libcbor0.10:arm64                0.10.2-2                       arm64    library for parsing and generating CBOR (RFC 7049)
ii  libcc1-0:arm64                   14.2.0-19                      arm64    GCC cc1 plugin for GDB
ii  libcdparanoia0:arm64             3.10.2+debian-14+b1            arm64    audio extraction tool for sampling CDs (library)
ii  libchromaprint1:arm64            1.5.1-7                        arm64    audio fingerprint library
ii  libcjson1:arm64                  1.7.18-3+b1                    arm64    Ultralightweight JSON parser in ANSI C
ii  libclang-common-17-dev:arm64     1:17.0.6-21+b1                 arm64    Clang library - Common development package
ii  libclang-cpp17t64                1:17.0.6-21+b1                 arm64    C++ interface to the Clang library
ii  libclc-17                        1:17.0.6-21                    all      OpenCL C language implementation - platform support
ii  libclc-17-dev                    1:17.0.6-21                    all      OpenCL C language implementation - development files
ii  libcloudproviders0:arm64         0.3.6-2                        arm64    cloud provider library
ii  libcodec2-1.2:arm64              1.2.0-3                        arm64    Codec2 runtime library
ii  libcolord2:arm64                 1.4.7-3                        arm64    system service to manage device colour profiles -- runtime
ii  libcom-err2:arm64                1.47.2-1+b1                    arm64    common error description library
ii  libcpuinfo0:arm64                0.0~git20250203.aaac07e-1      arm64    CPU INFOrmation library (shared object)
ii  libcrypt-dev:arm64               1:4.4.38-1                     arm64    libcrypt development files
ii  libcrypt1:arm64                  1:4.4.38-1                     arm64    libcrypt shared library
ii  libctf-nobfd0:arm64              2.44-3                         arm64    Compact C Type Format library (runtime, no BFD dependency)
ii  libctf0:arm64                    2.44-3                         arm64    Compact C Type Format library (runtime, BFD dependency)
ii  libcups2t64:arm64                2.4.10-2+b1                    arm64    Common UNIX Printing System(tm) - Core library
ii  libcurl3t64-gnutls:arm64         8.13.0-1                       arm64    easy-to-use client-side URL transfer library (GnuTLS flavour)
ii  libcurl4t64:arm64                8.13.0-1                       arm64    easy-to-use client-side URL transfer library (OpenSSL flavour)
ii  libd3dadapter9-mesa:arm64        24.0.1+git20250304+82e6a9293c-1 arm64    state-tracker for Direct3D9
ii  libd3dadapter9-mesa-dev:arm64    24.0.1+git20250304+82e6a9293c-1 arm64    state-tracker for Direct3D9 -- development files
ii  libdatrie1:arm64                 0.2.13-3+b1                    arm64    Double-array trie library
ii  libdav1d7:arm64                  1.5.1-1                        arm64    fast and small AV1 video stream decoder (shared library)
ii  libdb5.3t64:arm64                5.3.28+dfsg2-9                 arm64    Berkeley v5.3 Database Libraries [runtime]
ii  libdbus-1-3:arm64                1.16.2-2                       arm64    simple interprocess messaging system (library)
ii  libdc1394-25:arm64               2.2.6-5                        arm64    high level programming interface for IEEE 1394 digital cameras
ii  libdca0:arm64                    0.0.7-2+b2                     arm64    decoding library for DTS Coherent Acoustics streams
ii  libdconf1:arm64                  0.40.0-5                       arm64    simple configuration storage system - runtime library
ii  libde265-0:arm64                 1.0.15-1+b3                    arm64    Open H.265 video codec implementation
ii  libdebconfclient0:arm64          0.277                          arm64    Debian Configuration Management System (C-implementation library)
ii  libdecor-0-0:arm64               0.2.2-2                        arm64    client-side window decoration library
ii  libdeflate0:arm64                1.23-1+b1                      arm64    fast, whole-buffer DEFLATE-based compression and decompression
ii  libdevmapper1.02.1:arm64         2:1.02.205-1                   arm64    Linux Kernel Device Mapper userspace library
ii  libdirectfb-1.7-7t64:arm64       1.7.7-13                       arm64    direct frame buffer graphics (shared libraries)
ii  libdisplay-info2:arm64           0.2.0-2                        arm64    EDID and DisplayID library (shared library)
ii  libdnnl3.6:arm64                 3.7.1+ds-1                     arm64    oneAPI Deep Neural Network Library (oneDNN) (lib)
ii  libdpkg-perl                     1.22.18                        all      Dpkg perl modules
ii  libdrm-amdgpu1:arm64             2.4.124-2                      arm64    Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-common                    2.4.124-2                      all      Userspace interface to kernel DRM services -- common files
ii  libdrm-dev:arm64                 2.4.124-2                      arm64    Userspace interface to kernel DRM services -- development files
ii  libdrm-etnaviv1:arm64            2.4.124-2                      arm64    Userspace interface to etnaviv-specific kernel DRM services -- runtime
ii  libdrm-freedreno1:arm64          2.4.124-2                      arm64    Userspace interface to msm/kgsl kernel DRM services -- runtime
ii  libdrm-nouveau2:arm64            2.4.124-2                      arm64    Userspace interface to nouveau-specific kernel DRM services -- runtime
ii  libdrm-radeon1:arm64             2.4.124-2                      arm64    Userspace interface to radeon-specific kernel DRM services -- runtime
ii  libdrm-tegra0:arm64              2.4.124-2                      arm64    Userspace interface to tegra-specific kernel DRM services -- runtime
ii  libdrm2:arm64                    2.4.124-2                      arm64    Userspace interface to kernel DRM services -- runtime
ii  libduktape207:arm64              2.7.0-2+b2                     arm64    embeddable Javascript engine, library
ii  libdv4t64:arm64                  1.0.0-17.1+b1                  arm64    software library for DV format digital video (runtime lib)
ii  libdvdnav4:arm64                 6.1.1-3+b1                     arm64    DVD navigation library
ii  libdvdread8t64:arm64             6.1.3-2                        arm64    library for reading DVDs
ii  libdw1t64:arm64                  0.192-4                        arm64    library that provides access to the DWARF debug information
ii  libebur128-1:arm64               1.2.6-1+b2                     arm64    implementation of the EBU R128 loudness standard
ii  libedit2:arm64                   3.1-20250104-1                 arm64    BSD editline and history libraries
ii  libegl-mesa0:arm64               24.0.1+git20250304+82e6a9293c-1 arm64    free implementation of the EGL API -- Mesa vendor library
ii  libegl1:arm64                    1.7.0-1+b2                     arm64    Vendor neutral GL dispatch library -- EGL support
ii  libelf1t64:arm64                 0.192-4                        arm64    library to read and write ELF files
ii  libepoxy0:arm64                  1.5.10-2                       arm64    OpenGL function pointer management library
ii  libevdev2:arm64                  1.13.4+dfsg-1                  arm64    wrapper library for evdev devices
ii  libevent-core-2.1-7t64:arm64     2.1.12-stable-10+b1            arm64    Asynchronous event notification library (core)
ii  libexpat1:arm64                  2.7.1-1                        arm64    XML parsing C library - runtime library
ii  libext2fs2t64:arm64              1.47.2-1+b1                    arm64    ext2/ext3/ext4 file system libraries
ii  libfaad2:arm64                   2.11.2-1                       arm64    freeware Advanced Audio Decoder - runtime files
ii  libfdisk1:arm64                  2.41-3                         arm64    fdisk partitioning library
ii  libffi8:arm64                    3.4.7-1                        arm64    Foreign Function Interface library runtime
ii  libfftw3-double3:arm64           3.3.10-2+b1                    arm64    Library for computing Fast Fourier Transforms - Double precision
ii  libfftw3-single3:arm64           3.3.10-2+b1                    arm64    Library for computing Fast Fourier Transforms - Single precision
ii  libfido2-1:arm64                 1.15.0-1+b1                    arm64    library for generating and verifying FIDO 2.0 objects
ii  libflac12t64:arm64               1.4.3+ds-2.1+b1                arm64    Free Lossless Audio Codec - runtime C library
ii  libflac14:arm64                  1.5.0+ds-2                     arm64    Free Lossless Audio Codec - runtime C library
ii  libflite1:arm64                  2.2-7                          arm64    Small run-time speech synthesis engine - shared libraries
ii  libfluidsynth3:arm64             2.4.4+dfsg-1                   arm64    Real-time MIDI software synthesizer (runtime library)
ii  libfontconfig1:arm64             2.15.0-2.2                     arm64    generic font configuration library - runtime
ii  libfreeaptx0:arm64               0.2.2-1                        arm64    Free implementation of aptX
ii  libfreerdp-server3-3:arm64       3.14.0+dfsg-1                  arm64    Free Remote Desktop Protocol library (server library)
ii  libfreerdp3-3:arm64              3.14.0+dfsg-1                  arm64    Free Remote Desktop Protocol library (core library)
ii  libfreetype6:arm64               2.13.3+dfsg-1                  arm64    FreeType 2 font engine, shared library files
ii  libfribidi0:arm64                1.0.16-1                       arm64    Free Implementation of the Unicode BiDi algorithm
ii  libfstrm0:arm64                  0.6.1-1+b3                     arm64    Frame Streams (fstrm) library
ii  libgbm1:arm64                    24.0.1+git20250304+82e6a9293c-1 arm64    generic buffer management API -- runtime
ii  libgcc-14-dev:arm64              14.2.0-19                      arm64    GCC support library (development files)
ii  libgcc-s1:arm64                  14.2.0-19                      arm64    GCC support library
ii  libgcrypt20:arm64                1.11.0-7                       arm64    LGPL Crypto library - runtime library
ii  libgdbm-compat4t64:arm64         1.24-2                         arm64    GNU dbm database routines (legacy support runtime version)
ii  libgdbm6t64:arm64                1.24-2                         arm64    GNU dbm database routines (runtime version)
ii  libgdk-pixbuf-2.0-0:arm64        2.42.12+dfsg-2                 arm64    GDK Pixbuf library
ii  libgdk-pixbuf2.0-common          2.42.12+dfsg-2                 all      GDK Pixbuf library - data files
ii  libgfortran5:arm64               14.2.0-19                      arm64    Runtime library for GNU Fortran applications
ii  libgif7:arm64                    5.2.2-1+b1                     arm64    library for GIF images (library)
ii  libgl1:arm64                     1.7.0-1+b2                     arm64    Vendor neutral GL dispatch library -- legacy GL support
ii  libgl1-mesa-dri:arm64            24.0.1+git20250304+82e6a9293c-1 arm64    free implementation of the OpenGL API -- DRI modules
ii  libglapi-mesa:arm64              24.0.1+git20250304+82e6a9293c-1 arm64    free implementation of the GL API -- shared library
ii  libgles2:arm64                   1.7.0-1+b2                     arm64    Vendor neutral GL dispatch library -- GLESv2 support
ii  libglib2.0-0t64:arm64            2.84.0-2                       arm64    GLib library of C routines
ii  libglvnd0:arm64                  1.7.0-1+b2                     arm64    Vendor neutral GL dispatch library
ii  libglx-mesa0:arm64               24.0.1+git20250304+82e6a9293c-1 arm64    free implementation of the OpenGL API -- GLX vendor library
ii  libglx0:arm64                    1.7.0-1+b2                     arm64    Vendor neutral GL dispatch library -- GLX support
ii  libgme0:arm64                    0.6.3-7+b2                     arm64    Playback library for video game music files - shared library
ii  libgmp10:arm64                   2:6.3.0+dfsg-3                 arm64    Multiprecision arithmetic library
ii  libgnutls30t64:arm64             3.8.9-2                        arm64    GNU TLS library - main runtime library
ii  libgomp1:arm64                   14.2.0-19                      arm64    GCC OpenMP (GOMP) support library
ii  libgpg-error0:arm64              1.51-4                         arm64    GnuPG development runtime library
ii  libgpm2:arm64                    1.20.7-11+b2                   arm64    General Purpose Mouse - shared library
ii  libgprofng0:arm64                2.44-3                         arm64    GNU Next Generation profiler (runtime library)
ii  libgraphite2-3:arm64             1.3.14-2+b1                    arm64    Font rendering engine for Complex Scripts -- library
ii  libgsm1:arm64                    1.0.22-1+b2                    arm64    Shared libraries for GSM speech compressor
ii  libgssapi-krb5-2:arm64           1.21.3-5                       arm64    MIT Kerberos runtime libraries - krb5 GSS-API Mechanism
ii  libgssdp-1.6-0:arm64             1.6.3-2                        arm64    GObject-based library for SSDP
ii  libgstreamer-gl1.0-0:arm64       1.26.0-1                       arm64    GStreamer GL libraries
ii  libgstreamer-plugins-bad1.0-0:arm64  1.26.0-1                       arm64    GStreamer libraries from the "bad" set
ii  libgstreamer-plugins-base1.0-0:arm64 1.26.0-1                       arm64    GStreamer libraries from the "base" set
ii  libgstreamer1.0-0:arm64          1.26.0-3                       arm64    Core GStreamer libraries and elements
ii  libgtk-3-0t64:arm64              3.24.49-3                      arm64    GTK graphical user interface library
ii  libgtk-3-common                  3.24.49-3                      all      common files for the GTK graphical user interface library
ii  libgudev-1.0-0:arm64             238-6                          arm64    GObject-based wrapper library for libudev
ii  libgupnp-1.6-0:arm64             1.6.8-2                        arm64    GObject-based library for UPnP
ii  libgupnp-igd-1.6-0:arm64         1.6.0-4                        arm64    library to handle UPnP IGD port mapping
ii  libharfbuzz0b:arm64              10.2.0-1+b1                    arm64    OpenType text shaping engine (shared library)
ii  libhogweed6t64:arm64             3.10.1-1                       arm64    low level cryptographic library (public-key cryptos)
ii  libhwasan0:arm64                 14.2.0-19                      arm64    AddressSanitizer -- a fast memory error detector
ii  libhwy1t64:arm64                 1.2.0-2+b2                     arm64    Efficient and performance-portable SIMD wrapper (runtime files)
ii  libi2c0:arm64                    4.4-2                          arm64    userspace I2C programming library
ii  libicu72:arm64                   72.1-6                         arm64    International Components for Unicode
ii  libicu76:arm64                   76.1-3                         arm64    International Components for Unicode
ii  libidn2-0:arm64                  2.3.8-2                        arm64    Internationalized domain names (IDNA2008/TR46) library
ii  libiec61883-0:arm64              1.2.0-7                        arm64    partial implementation of IEC 61883 (shared lib)
ii  libimath-3-1-29t64:arm64         3.1.12-1+b3                    arm64    Utility libraries from ASF used by OpenEXR - runtime
ii  libinput-bin                     1.28.1-1                       arm64    input device management and event handling library - udev quirks
ii  libinput10:arm64                 1.28.1-1                       arm64    input device management and event handling library - shared library
ii  libinstpatch-1.0-2:arm64         1.1.6-1+b2                     arm64    MIDI instrument editing library
ii  libisl23:arm64                   0.27-1                         arm64    manipulating sets and relations of integer points bounded by linear constraints
ii  libitm1:arm64                    14.2.0-19                      arm64    GNU Transactional Memory Library
ii  libjack-jackd2-0:arm64           1.9.22~dfsg-4                  arm64    JACK Audio Connection Kit (libraries)
ii  libjansson4:arm64                2.14-2+b3                      arm64    C library for encoding, decoding and manipulating JSON data
ii  libjbig0:arm64                   2.1-6.1+b2                     arm64    JBIGkit libraries
ii  libjemalloc2:arm64               5.3.0-3                        arm64    general-purpose scalable concurrent malloc(3) implementation
ii  libjpeg62-turbo:arm64            1:2.1.5-3.1                    arm64    libjpeg-turbo JPEG runtime library
ii  libjson-c5:arm64                 0.18+ds-1                      arm64    JSON manipulation library - shared library
ii  libjson-glib-1.0-0:arm64         1.10.6+ds-2                    arm64    GLib JSON manipulation library
ii  libjson-glib-1.0-common          1.10.6+ds-2                    all      GLib JSON manipulation library (common files)
ii  libjxl0.11:arm64                 0.11.1-4                       arm64    JPEG XL Image Coding System - "JXL" (shared libraries)
ii  libjxl0.9:arm64                  0.9.2-10+b1                    arm64    JPEG XL Image Coding System - "JXL" (shared libraries)
ii  libk5crypto3:arm64               1.21.3-5                       arm64    MIT Kerberos runtime libraries - Crypto Library
ii  libkeyutils1:arm64               1.6.3-4                        arm64    Linux Key Management Utilities (library)
ii  libkmod2:arm64                   34.2-1                         arm64    libkmod shared library
ii  libkrb5-3:arm64                  1.21.3-5                       arm64    MIT Kerberos runtime libraries
ii  libkrb5support0:arm64            1.21.3-5                       arm64    MIT Kerberos runtime libraries - Support library
ii  liblapack3:arm64                 3.12.1-2                       arm64    Library of linear algebra routines 3 - shared version
ii  liblastlog2-2:arm64              2.41-3                         arm64    lastlog2 database shared library
ii  liblc3-1:arm64                   1.1.3+dfsg-1                   arm64    Low Complexity Communication Codec (shared library)
ii  liblcms2-2:arm64                 2.16-2                         arm64    Little CMS 2 color management library
ii  libldacbt-enc2:arm64             2.0.2.3+git20200429+ed310a0-5  arm64    LDAC Bluetooth encoder library (shared library)
ii  libldap-2.5-0:arm64              2.5.18+dfsg-3+b1               arm64    OpenLDAP libraries
ii  libldap-common                   2.6.9+dfsg-2                   all      OpenLDAP common files for libraries
ii  libldap2:arm64                   2.6.9+dfsg-2                   arm64    OpenLDAP libraries
ii  liblerc4:arm64                   4.0.0+ds-5                     arm64    Limited Error Raster Compression library
ii  liblilv-0-0:arm64                0.24.26-1                      arm64    library for simple use of LV2 plugins
ii  libllvm17t64:arm64               1:17.0.6-21+b1                 arm64    Modular compiler and toolchain technologies, runtime library
ii  libllvmspirvlib17:arm64          17.0.10-1                      arm64    bi-directional translator for LLVM/SPIRV -- shared library
ii  liblmdb0:arm64                   0.9.31-1+b2                    arm64    Lightning Memory-Mapped Database shared library
ii  liblocale-gettext-perl           1.07-7+b1                      arm64    module using libc functions for internationalization in Perl
ii  liblockfile-bin                  1.17-2                         arm64    support binaries for and cli utilities based on liblockfile
ii  liblrdf0:arm64                   0.6.1-4+b2                     arm64    library to manipulate RDF files describing LADSPA plugins
ii  liblsan0:arm64                   14.2.0-19                      arm64    LeakSanitizer -- a memory leak detector (runtime)
ii  liblsof0                         4.99.4+dfsg-2                  arm64    utility to list open files (shared library)
ii  libltc11:arm64                   1.3.2-1+b2                     arm64    linear timecode library
ii  liblz4-1:arm64                   1.10.0-4                       arm64    Fast LZ compression algorithm library - runtime
ii  liblzma5:arm64                   5.8.1-1                        arm64    XZ-format compression library
ii  libmagic-mgc                     1:5.45-3+b1                    arm64    File type determination library using "magic" numbers (compiled magic file)
ii  libmagic1t64:arm64               1:5.45-3+b1                    arm64    Recognize the type of data in a file using "magic" numbers - library
ii  libmaxminddb0:arm64              1.12.2-1                       arm64    IP geolocation database library
ii  libmbedcrypto16:arm64            3.6.3-1                        arm64    lightweight crypto and SSL/TLS library - crypto library
ii  libmd0:arm64                     1.1.0-2+b1                     arm64    message digest functions from BSD systems - shared library
ii  libmjpegutils-2.1-0t64:arm64     1:2.1.0+debian-8.1+b1          arm64    MJPEG capture/editing/replay and MPEG encoding toolset (library)
ii  libmm-glib0:arm64                1.23.95-2                      arm64    D-Bus service for managing modems - shared libraries
ii  libmnl0:arm64                    1.0.5-3                        arm64    minimalistic Netlink communication library
ii  libmodplug1:arm64                1:0.8.9.0-3+b2                 arm64    shared libraries for mod music based on ModPlug
ii  libmount1:arm64                  2.41-3                         arm64    device mounting library
ii  libmp3lame0:arm64                3.100-6+b3                     arm64    MP3 encoding library
ii  libmpc3:arm64                    1.3.1-1+b3                     arm64    multiple precision complex floating-point library
ii  libmpcdec6:arm64                 2:0.1~r495-3                   arm64    MusePack decoder - library
ii  libmpeg2encpp-2.1-0t64:arm64     1:2.1.0+debian-8.1+b1          arm64    MJPEG capture/editing/replay and MPEG encoding toolset (library)
ii  libmpfr6:arm64                   4.2.2-1                        arm64    multiple precision floating-point computation
ii  libmpg123-0t64:arm64             1.32.10-1                      arm64    MPEG layer 1/2/3 audio decoder (shared library)
ii  libmplex2-2.1-0t64:arm64         1:2.1.0+debian-8.1+b1          arm64    MJPEG capture/editing/replay and MPEG encoding toolset (library)
ii  libmtdev1t64:arm64               1.1.7-1                        arm64    Multitouch Protocol Translation Library - shared library
ii  libmysofa1:arm64                 1.3.3+dfsg-1                   arm64    library to read HRTFs stored in the AES69-2015 SOFA format
ii  libncurses6:arm64                6.5+20250216-2                 arm64    shared libraries for terminal handling
ii  libncursesw6:arm64               6.5+20250216-2                 arm64    shared libraries for terminal handling (wide character support)
ii  libndp0:arm64                    1.9-1+b1                       arm64    Library for Neighbor Discovery Protocol
ii  libneatvnc0:arm64                0.9.1+dfsg-1                   arm64    Fast and neat VNC server library (shared library)
ii  libneon27t64:arm64               0.34.0-1                       arm64    HTTP and WebDAV client library
ii  libnetfilter-conntrack3:arm64    1.1.0-1                        arm64    Netfilter netlink-conntrack library
ii  libnettle8t64:arm64              3.10.1-1                       arm64    low level cryptographic library (symmetric and one-way cryptos)
ii  libnewt0.52:arm64                0.52.25-1                      arm64    Not Erik's Windowing Toolkit - text mode windowing with slang
ii  libnfnetlink0:arm64              1.0.2-3                        arm64    Netfilter netlink library
ii  libnftables1:arm64               1.1.1-1                        arm64    Netfilter nftables high level userspace API library
ii  libnftnl11:arm64                 1.2.8-1                        arm64    Netfilter nftables userspace API library
ii  libnghttp2-14:arm64              1.64.0-1                       arm64    library implementing HTTP/2 protocol (shared library)
ii  libnghttp3-9:arm64               1.8.0-1                        arm64    HTTP/3 library with QUIC and QPACK (library)
ii  libngtcp2-16:arm64               1.11.0-1                       arm64    implementation of QUIC protocol (library)
ii  libngtcp2-crypto-gnutls8:arm64   1.11.0-1                       arm64    implementation of QUIC protocol (library)
ii  libnice10:arm64                  0.1.22-1                       arm64    ICE library (shared library)
ii  libnl-3-200:arm64                3.7.0-2                        arm64    library for dealing with netlink sockets
ii  libnl-genl-3-200:arm64           3.7.0-2                        arm64    library for dealing with netlink sockets - generic netlink
ii  libnl-route-3-200:arm64          3.7.0-2                        arm64    library for dealing with netlink sockets - route interface
ii  libnm0:arm64                     1.52.0-6                       arm64    GObject-based client library for NetworkManager
ii  libnorm1t64:arm64                1.5.9+dfsg-3.1+b2              arm64    NACK-Oriented Reliable Multicast (NORM) library
ii  libnsl2:arm64                    1.3.0-3+b3                     arm64    Public client interface for NIS(YP) and NIS+
ii  libnspr4:arm64                   2:4.36-1                       arm64    NetScape Portable Runtime Library
ii  libnss-systemd:arm64             257.4-3                        arm64    nss module providing dynamic user and group name resolution
ii  libnss3:arm64                    2:3.109-1                      arm64    Network Security Service libraries
ii  libnuma1:arm64                   2.0.18-1+b1                    arm64    Libraries for controlling NUMA policy
ii  libogg0:arm64                    1.3.5-3+b2                     arm64    Ogg bitstream library
ii  libonnx1t64:arm64                1.17.0-3+b1                    arm64    Open Neural Network Exchange (ONNX) (libs)
ii  libonnxruntime1.21:arm64         1.21.0+dfsg-1                  arm64    cross-platform inference and training ML accelerator (shared lib)
ii  libopenal-data                   1:1.24.2-1                     all      Software implementation of the OpenAL audio API (data files)
ii  libopenal1:arm64                 1:1.24.2-1                     arm64    Software implementation of the OpenAL audio API (shared library)
ii  libopencore-amrnb0:arm64         0.1.6-1+b2                     arm64    Adaptive Multi Rate speech codec - shared library
ii  libopencore-amrwb0:arm64         0.1.6-1+b2                     arm64    Adaptive Multi-Rate - Wideband speech codec - shared library
ii  libopenexr-3-1-30:arm64          3.1.13-2                       arm64    runtime files for the OpenEXR image library
ii  libopenh264-7:arm64              2.5.0+dfsg-1                   arm64    OpenH264 Video Codec
ii  libopenh264-8:arm64              2.6.0+dfsg-2                   arm64    OpenH264 Video Codec
ii  libopenjp2-7:arm64               2.5.3-2                        arm64    JPEG 2000 image compression/decompression library
ii  libopenmpt0t64:arm64             0.7.13-1+b1                    arm64    module music library based on OpenMPT -- shared library
ii  libopenni2-0:arm64               2.2.0.33+dfsg-18+b2            arm64    framework for sensor-based 'Natural Interaction'
ii  libopus0:arm64                   1.5.2-2                        arm64    Opus codec runtime library
ii  liborc-0.4-0t64:arm64            1:0.4.41-1                     arm64    Library of Optimized Inner Loops Runtime Compiler
ii  libosmesa6:arm64                 24.0.1+git20250304+82e6a9293c-1 arm64    Mesa Off-screen rendering extension
ii  libp11-kit0:arm64                0.25.5-3                       arm64    library for loading and coordinating access to PKCS#11 modules - runtime
ii  libpam-modules:arm64             1.7.0-3                        arm64    Pluggable Authentication Modules for PAM
ii  libpam-modules-bin               1.7.0-3                        arm64    Pluggable Authentication Modules for PAM - helper binaries
ii  libpam-runtime                   1.7.0-3                        all      Runtime support for the PAM library
ii  libpam-systemd:arm64             257.4-3                        arm64    system and service manager - PAM module
ii  libpam-wtmpdb:arm64              0.72.0-1                       arm64    wtmp database PAM module
ii  libpam0g:arm64                   1.7.0-3                        arm64    Pluggable Authentication Modules library
ii  libpango-1.0-0:arm64             1.56.3-1                       arm64    Layout and rendering of internationalized text
ii  libpangocairo-1.0-0:arm64        1.56.3-1                       arm64    Layout and rendering of internationalized text
ii  libpangoft2-1.0-0:arm64          1.56.3-1                       arm64    Layout and rendering of internationalized text
ii  libparted2t64:arm64              3.6-5                          arm64    disk partition manipulator - shared library
ii  libpci3:arm64                    1:3.13.0-2                     arm64    PCI utilities (shared library)
ii  libpciaccess-dev:arm64           0.17-3+b3                      arm64    Generic PCI access library for X - development files
ii  libpciaccess0:arm64              0.17-3+b3                      arm64    Generic PCI access library for X
ii  libpcre2-8-0:arm64               10.45-1                        arm64    New Perl Compatible Regular Expression Library- 8 bit runtime files
ii  libpcsclite1:arm64               2.3.3-1                        arm64    Middleware to access a smart card using PC/SC (library)
ii  libperl5.40:arm64                5.40.1-2                       arm64    shared Perl library
ii  libpgm-5.3-0t64:arm64            5.3.128~dfsg-2.1+b1            arm64    OpenPGM shared library
ii  libpipeline1:arm64               1.5.8-1                        arm64    Unix process pipeline manipulation library
ii  libpipewire-0.3-0t64:arm64       1.4.1-1                        arm64    libraries for the PipeWire multimedia server
ii  libpixman-1-0:arm64              0.44.0-3                       arm64    pixel-manipulation library for X and cairo
ii  libplacebo349:arm64              7.349.0-3                      arm64    GPU-accelerated video/image rendering primitives (shared library)
ii  libpng16-16t64:arm64             1.6.47-1.1                     arm64    PNG library - runtime (version 1.6)
ii  libpocketsphinx3:arm64           0.8+5prealpha+1-15+b4          arm64    Speech recognition tool - front-end library
ii  libpopt0:arm64                   1.19+dfsg-2                    arm64    lib for parsing cmdline parameters
ii  libpostproc58:arm64              7:7.1.1-1+b1                   arm64    FFmpeg library for post processing - runtime files
ii  libproc2-0:arm64                 2:4.0.4-7                      arm64    library for accessing process information from /proc
ii  libprotobuf-c1:arm64             1.5.1-1                        arm64    Protocol Buffers C shared library (protobuf-c)
ii  libprotobuf32t64:arm64           3.21.12-10+b6                  arm64    protocol buffers C++ library
ii  libproxy1v5:arm64                0.5.9-1                        arm64    automatic proxy configuration management library (shared)
ii  libpru-pssp-dev                  6.4.0+git20240415+f3e3996-1    arm64    Development files for PRU-PSSP v6.1.0
ii  libpsl5t64:arm64                 0.21.2-1.1+b1                  arm64    Library for Public Suffix List (shared libraries)
ii  libpthreadpool0:arm64            0.0~git20240616.560c60d-1      arm64    pthread-based thread pool for C/C++ (shared object)
ii  libpulse0:arm64                  17.0+dfsg1-2+b1                arm64    PulseAudio client libraries
ii  libpython3-stdlib:arm64          3.13.2-2                       arm64    interactive high-level object-oriented language (default python3 version)
ii  libpython3.12-minimal:arm64      3.12.8-1                       arm64    Minimal subset of the Python language (version 3.12)
ii  libpython3.12-stdlib:arm64       3.12.8-1                       arm64    Interactive high-level object-oriented language (standard library, version 3.12)
ii  libpython3.13-minimal:arm64      3.13.2-3                       arm64    Minimal subset of the Python language (version 3.13)
ii  libpython3.13-stdlib:arm64       3.13.2-3                       arm64    Interactive high-level object-oriented language (standard library, version 3.13)
ii  libqrencode4:arm64               4.1.1-2                        arm64    QR Code encoding library
ii  librabbitmq4:arm64               0.15.0-1                       arm64    AMQP client library written in C
ii  libraptor2-0:arm64               2.0.16-6                       arm64    Raptor 2 RDF syntax library
ii  librav1e0.7:arm64                0.7.1-9+b1                     arm64    Fastest and safest AV1 encoder - shared library
ii  libraw1394-11:arm64              2.1.2-2+b2                     arm64    library for direct access to IEEE 1394 bus (aka FireWire)
ii  libre2-11:arm64                  20240702-3+b1                  arm64    efficient, principled regular expression library
ii  libreadline8t64:arm64            8.2-6                          arm64    GNU readline and history libraries, run-time libraries
ii  librist4:arm64                   0.2.11+dfsg-1                  arm64    Reliable Internet Stream Transport -- shared library
ii  librsvg2-2:arm64                 2.60.0+dfsg-1                  arm64    SAX-based renderer library for SVG files (runtime)
ii  librtmp1:arm64                   2.4+20151223.gitfa8646d.1-2+b5 arm64    toolkit for RTMP streams (shared library)
ii  librubberband2:arm64             3.3.0+dfsg-2+b3                arm64    audio time-stretching and pitch-shifting library
ii  libsamplerate0:arm64             0.2.2-4+b2                     arm64    Audio sample rate conversion library
ii  libsasl2-2:arm64                 2.1.28+dfsg1-9                 arm64    Cyrus SASL - authentication abstraction library
ii  libsasl2-modules-db:arm64        2.1.28+dfsg1-9                 arm64    Cyrus SASL - pluggable authentication modules (DB)
ii  libsbc1:arm64                    2.0-1+b2                       arm64    Sub Band CODEC library - runtime
ii  libsdl2-2.0-0:arm64              2.32.4+dfsg-1                  arm64    Simple DirectMedia Layer
ii  libseat1:arm64                   0.9.1-1                        arm64    flexible user, seat and session management library
ii  libseccomp2:arm64                2.6.0-2                        arm64    high level interface to Linux seccomp filter
ii  libselinux1:arm64                3.8.1-1                        arm64    SELinux runtime shared libraries
ii  libsemanage-common               3.8.1-1                        all      Common files for SELinux policy management libraries
ii  libsemanage2:arm64               3.8.1-1                        arm64    SELinux policy management library
ii  libsensors-config                1:3.6.0-10                     all      lm-sensors configuration files
ii  libsensors5:arm64                1:3.6.0-10+b1                  arm64    library to read temperature/voltage/fan sensors
ii  libsepol2:arm64                  3.8.1-1                        arm64    SELinux library for manipulating binary security policies
ii  libserd-0-0:arm64                0.32.4-1                       arm64    lightweight RDF syntax library
ii  libsframe1:arm64                 2.44-3                         arm64    Library to handle the SFrame format (runtime library)
ii  libsharpyuv0:arm64               1.5.0-0.1                      arm64    Library for sharp RGB to YUV conversion
ii  libshine3:arm64                  3.1.1-2+b2                     arm64    Fixed-point MP3 encoding library - runtime files
ii  libshout3:arm64                  2.4.6-1+b3                     arm64    MP3/Ogg Vorbis broadcast streaming library
ii  libslang2:arm64                  2.3.3-5+b2                     arm64    S-Lang programming library - runtime version
ii  libsmartcols1:arm64              2.41-3                         arm64    smart column output alignment library
ii  libsnappy1v5:arm64               1.2.2-1                        arm64    fast compression/decompression library
ii  libsndfile1:arm64                1.2.2-2+b1                     arm64    Library for reading/writing audio files
ii  libsodium23:arm64                1.0.18-1+b2                    arm64    Network communication, cryptography and signaturing library
ii  libsord-0-0:arm64                0.16.18-1                      arm64    library for storing RDF data in memory
ii  libsoundtouch1:arm64             2.3.3+ds-1+b1                  arm64    Sound stretching library
ii  libsoup-3.0-0:arm64              3.6.5-1                        arm64    HTTP library implementation in C -- Shared library
ii  libsoup-3.0-common               3.6.5-1                        all      HTTP library implementation in C -- Common files
ii  libsoxr0:arm64                   0.1.3-4+b2                     arm64    High quality 1D sample-rate conversion library
ii  libspa-0.2-modules:arm64         1.4.1-1                        arm64    libraries for the PipeWire multimedia server Simple Plugin API - modules
ii  libspandsp2t64:arm64             0.0.6+dfsg-2.2                 arm64    Telephony signal processing library
ii  libspeex1:arm64                  1.2.1-3                        arm64    Speex codec library (runtime library)
ii  libspeexdsp1:arm64               1.2.1-3                        arm64    DSP library derived from speex
ii  libsphinxbase3t64:arm64          0.8+5prealpha+1-21+b1          arm64    Speech recognition tool - shared library
ii  libsqlite3-0:arm64               3.46.1-2                       arm64    SQLite 3 shared library
ii  libsratom-0-0:arm64              0.6.18-1                       arm64    library for serialising LV2 atoms to/from Turtle
ii  libsrt1.5-gnutls:arm64           1.5.4-1                        arm64    Secure Reliable Transport UDP streaming library (GnuTLS flavour)
ii  libsrtp2-1:arm64                 2.5.0-3+b2                     arm64    Secure RTP (SRTP) and UST Reference Implementations - shared library
ii  libss2:arm64                     1.47.2-1+b1                    arm64    command-line interface parsing library
ii  libssh-4:arm64                   0.11.1-1                       arm64    tiny C SSH library (OpenSSL flavor)
ii  libssh2-1t64:arm64               1.11.1-1                       arm64    SSH2 client-side library
ii  libssl3t64:arm64                 3.4.1-1                        arm64    Secure Sockets Layer toolkit - shared libraries
ii  libstdc++-14-dev:arm64           14.2.0-19                      arm64    GNU Standard C++ Library v3 (development files)
ii  libstdc++6:arm64                 14.2.0-19                      arm64    GNU Standard C++ Library v3
ii  libsvtav1enc2:arm64              2.3.0+dfsg-1                   arm64    Scalable Video Technology for AV1 (libsvtav1enc shared library)
ii  libswresample5:arm64             7:7.1.1-1+b1                   arm64    FFmpeg library for audio resampling, rematrixing etc. - runtime files
ii  libswscale8:arm64                7:7.1.1-1+b1                   arm64    FFmpeg library for image scaling and various conversions - runtime files
ii  libsystemd-shared:arm64          257.4-3                        arm64    systemd shared private library
ii  libsystemd0:arm64                257.4-3                        arm64    systemd utility library
ii  libtag1v5:arm64                  1.13.1-2                       arm64    audio meta-data library
ii  libtag1v5-vanilla:arm64          1.13.1-2                       arm64    audio meta-data library - vanilla flavour
ii  libtag2:arm64                    2.0.2-2                        arm64    audio meta-data library
ii  libtasn1-6:arm64                 4.20.0-2                       arm64    Manage ASN.1 structures (runtime)
ii  libteamdctl0:arm64               1.31-1+b2                      arm64    library for communication with `teamd` process
ii  libtext-charwidth-perl:arm64     0.04-11+b4                     arm64    get display widths of characters on the terminal
ii  libtext-iconv-perl:arm64         1.7-8+b4                       arm64    module to convert between character sets in Perl
ii  libtext-wrapi18n-perl            0.06-10                        all      internationalized substitute of Text::Wrap
ii  libthai-data                     0.1.29-2                       all      Data files for Thai language support library
ii  libthai0:arm64                   0.1.29-2+b1                    arm64    Thai language support library
ii  libtheora0:arm64                 1.2.0~alpha1+dfsg-6            arm64    Theora Video Compression Codec (shared library - libtheora)
ii  libtheoradec1:arm64              1.2.0~alpha1+dfsg-6            arm64    Theora Video Compression Codec (shared library - libtheoradec)
ii  libtheoraenc1:arm64              1.2.0~alpha1+dfsg-6            arm64    Theora Video Compression Codec (shared library - libtheoraenc)
ii  libti-rpmsg-char:arm64           0.6.6+git20240226+55a6f40-1    arm64    RPMSG-char Utility Library
ii  libti-rpmsg-char-dev             0.6.6+git20240226+55a6f40-1    arm64    RPMSG-char Utility Library
ii  libtiff6:arm64                   4.7.0-2                        arm64    Tag Image File Format (TIFF) library
ii  libtinfo6:arm64                  6.5+20250216-2                 arm64    shared low-level terminfo library for terminal handling
ii  libtirpc-common                  1.3.6+ds-1                     all      transport-independent RPC library - common files
ii  libtirpc3t64:arm64               1.3.6+ds-1                     arm64    transport-independent RPC library
ii  libtsan2:arm64                   14.2.0-19                      arm64    ThreadSanitizer -- a Valgrind-based detector of data races (runtime)
ii  libturbojpeg0:arm64              1:2.1.5-3.1                    arm64    TurboJPEG runtime library - SIMD optimized
ii  libtwolame0:arm64                0.4.0-2+b2                     arm64    MPEG Audio Layer 2 encoding library
ii  libubsan1:arm64                  14.2.0-19                      arm64    UBSan -- undefined behaviour sanitizer (runtime)
ii  libuchardet0:arm64               0.0.8-1+b2                     arm64    universal charset detection library - shared library
ii  libudev1:arm64                   257.4-3                        arm64    libudev shared library
ii  libudfread0:arm64                1.1.2-1+b2                     arm64    UDF reader library
ii  libunibreak6:arm64               6.1-2+b1                       arm64    line breaking library for Unicode (shared library)
ii  libunistring5:arm64              1.3-2                          arm64    Unicode string library for C
ii  libunwind8:arm64                 1.8.1-0.1                      arm64    library to determine the call-chain of a program - runtime
ii  liburcu8t64:arm64                0.15.1-1                       arm64    userspace RCU (read-copy-update) library
ii  liburiparser1:arm64              0.9.8+dfsg-2                   arm64    URI parsing library compliant with RFC 3986
ii  libusb-1.0-0:arm64               2:1.0.28-1                     arm64    userspace USB programming library
ii  libuuid1:arm64                   2.41-3                         arm64    Universally Unique ID library
ii  libuv1t64:arm64                  1.50.0-2                       arm64    asynchronous event notification library - runtime library
ii  libv4l-0t64:arm64                1.28.1-1                       arm64    Collection of video4linux support libraries
ii  libv4lconvert0t64:arm64          1.28.1-1                       arm64    Video4linux frame format conversion library
ii  libva-drm2:arm64                 2.22.0-3                       arm64    Video Acceleration (VA) API for Linux -- DRM runtime
ii  libva-x11-2:arm64                2.22.0-3                       arm64    Video Acceleration (VA) API for Linux -- X11 runtime
ii  libva2:arm64                     2.22.0-3                       arm64    Video Acceleration (VA) API for Linux -- runtime
ii  libvdpau1:arm64                  1.5-3+b1                       arm64    Video Decode and Presentation API for Unix (libraries)
ii  libvidstab1.1:arm64              1.1.0-2+b2                     arm64    video stabilization library (shared library)
ii  libvisual-0.4-0:arm64            0.4.2-2+b2                     arm64    audio visualization framework
ii  libvo-aacenc0:arm64              0.1.3-3                        arm64    VisualOn AAC encoder library
ii  libvo-amrwbenc0:arm64            0.1.3-2+b2                     arm64    VisualOn AMR-WB encoder library
ii  libvorbis0a:arm64                1.3.7-2+b1                     arm64    decoder library for Vorbis General Audio Compression Codec
ii  libvorbisenc2:arm64              1.3.7-2+b1                     arm64    encoder library for Vorbis General Audio Compression Codec
ii  libvorbisfile3:arm64             1.3.7-2+b1                     arm64    high-level API for Vorbis General Audio Compression Codec
ii  libvpx9:arm64                    1.15.0-2                       arm64    VP8 and VP9 video codec (shared library)
ii  libvulkan1:arm64                 1.4.309.0-1                    arm64    Vulkan loader library
ii  libwacom-common                  2.14.0-1                       all      Wacom model feature query library (common files)
ii  libwacom9:arm64                  2.14.0-1                       arm64    Wacom model feature query library
ii  libwavpack1:arm64                5.8.1-1                        arm64    audio codec (lossy and lossless) - library
ii  libwayland-client0:arm64         1.23.1-3                       arm64    wayland compositor infrastructure - client library
ii  libwayland-cursor0:arm64         1.23.1-3                       arm64    wayland compositor infrastructure - cursor library
ii  libwayland-egl1:arm64            1.23.1-3                       arm64    wayland compositor infrastructure - EGL library
ii  libwayland-server0:arm64         1.23.1-3                       arm64    wayland compositor infrastructure - server library
ii  libwebp7:arm64                   1.5.0-0.1                      arm64    Lossy compression of digital photographic images (shared library)
ii  libwebpmux3:arm64                1.5.0-0.1                      arm64    Lossy compression of digital photographic images (libwebpmux library)
ii  libwebrtc-audio-processing-1-3:arm64 1.3-3+b1                       arm64    WebRTC Audio Processing library
ii  libwebrtc-audio-processing1:arm64 0.3-1+b2                       arm64    AudioProcessing module from the WebRTC project.
ii  libweston-14-0:arm64             14.0.1-3                       arm64    reference implementation of a wayland compositor (shared libs)
ii  libwildmidi2:arm64               0.4.3-1+b3                     arm64    software MIDI player library
ii  libwinpr3-3:arm64                3.14.0+dfsg-1                  arm64    Windows Portable Runtime library
ii  libwrap0:arm64                   7.6.q-36                       arm64    Wietse Venema's TCP wrappers library
ii  libwtmpdb0:arm64                 0.72.0-1                       arm64    wtmp database shared library
ii  libx11-6:arm64                   2:1.8.12-1                     arm64    X11 client-side library
ii  libx11-data                      2:1.8.12-1                     all      X11 client-side library
ii  libx11-xcb1:arm64                2:1.8.12-1                     arm64    Xlib/XCB interface library
ii  libx264-164:arm64                2:0.164.3108+git31e19f9-2+b1   arm64    x264 video coding library
ii  libx265-209:arm64                3.6-3+b1                       arm64    H.265/HEVC video stream encoder (shared library)
ii  libx265-215:arm64                4.1-2                          arm64    H.265/HEVC video stream encoder (shared library)
ii  libxau6:arm64                    1:1.0.11-1                     arm64    X11 authorisation library
ii  libxcb-composite0:arm64          1.17.0-2+b1                    arm64    X C Binding, composite extension
ii  libxcb-dri2-0:arm64              1.17.0-2+b1                    arm64    X C Binding, dri2 extension
ii  libxcb-dri3-0:arm64              1.17.0-2+b1                    arm64    X C Binding, dri3 extension
ii  libxcb-glx0:arm64                1.17.0-2+b1                    arm64    X C Binding, glx extension
ii  libxcb-present0:arm64            1.17.0-2+b1                    arm64    X C Binding, present extension
ii  libxcb-randr0:arm64              1.17.0-2+b1                    arm64    X C Binding, randr extension
ii  libxcb-render0:arm64             1.17.0-2+b1                    arm64    X C Binding, render extension
ii  libxcb-shm0:arm64                1.17.0-2+b1                    arm64    X C Binding, shm extension
ii  libxcb-sync1:arm64               1.17.0-2+b1                    arm64    X C Binding, sync extension
ii  libxcb-xfixes0:arm64             1.17.0-2+b1                    arm64    X C Binding, xfixes extension
ii  libxcb-xkb1:arm64                1.17.0-2+b1                    arm64    X C Binding, XKEYBOARD extension
ii  libxcb1:arm64                    1.17.0-2+b1                    arm64    X C Binding
ii  libxcomposite1:arm64             1:0.4.6-1                      arm64    X11 Composite extension library
ii  libxcursor1:arm64                1:1.2.3-1                      arm64    X cursor management library
ii  libxdamage1:arm64                1:1.1.6-1+b2                   arm64    X11 damaged region extension library
ii  libxdmcp6:arm64                  1:1.1.5-1                      arm64    X11 Display Manager Control Protocol library
ii  libxext6:arm64                   2:1.3.4-1+b3                   arm64    X11 miscellaneous extension library
ii  libxfixes3:arm64                 1:6.0.0-2+b4                   arm64    X11 miscellaneous 'fixes' extension library
ii  libxi6:arm64                     2:1.8.2-1                      arm64    X11 Input extension library
ii  libxinerama1:arm64               2:1.1.4-3+b4                   arm64    X11 Xinerama extension library
ii  libxkbcommon-x11-0:arm64         1.7.0-2                        arm64    library to create keymaps with the XKB X11 protocol
ii  libxkbcommon0:arm64              1.7.0-2                        arm64    library interface to the XKB compiler - shared library
ii  libxkbfile1:arm64                1:1.1.0-1+b4                   arm64    X11 keyboard file manipulation library
ii  libxml2:arm64                    2.12.7+dfsg+really2.9.14-0.4   arm64    GNOME XML library
ii  libxnnpack0.20241108:arm64       0.0~git20241108.4ea82e5-1      arm64    High-efficiency floating-point neural network inference operators (libs)
ii  libxrandr2:arm64                 2:1.5.4-1+b3                   arm64    X11 RandR extension library
ii  libxrender1:arm64                1:0.9.12-1                     arm64    X Rendering Extension client library
ii  libxshmfence1:arm64              1.3.3-1                        arm64    X shared memory fences - shared library
ii  libxslt1.1:arm64                 1.1.35-1.2                     arm64    XSLT 1.0 processing library - runtime library
ii  libxss1:arm64                    1:1.2.3-1+b3                   arm64    X11 Screen Saver extension library
ii  libxtables12:arm64               1.8.11-2                       arm64    netfilter xtables library
ii  libxtst6:arm64                   2:1.2.5-1                      arm64    X11 Testing -- Record extension library
ii  libxvidcore4:arm64               2:1.3.7-1+b2                   arm64    Open source MPEG-4 video codec (library)
ii  libxxf86vm1:arm64                1:1.1.4-1+b4                   arm64    X11 XFree86 video mode extension library
ii  libxxhash0:arm64                 0.8.3-2                        arm64    shared library for xxhash
ii  libyajl2:arm64                   2.1.0-5+b2                     arm64    Yet Another JSON Library
ii  libz3-4:arm64                    4.13.3-1                       arm64    theorem prover from Microsoft Research - runtime libraries
ii  libzbar0t64:arm64                0.23.93-7                      arm64    QR code / bar code scanner and decoder (library)
ii  libzimg2:arm64                   3.0.5+ds1-1+b2                 arm64    scaling, colorspace, depth conversion library (shared library)
ii  libzix-0-0:arm64                 0.6.2-1                        arm64    library of portability wrappers and data structures (shared library)
ii  libzmq5:arm64                    4.3.5-1+b3                     arm64    lightweight messaging kernel (shared library)
ii  libzstd1:arm64                   1.5.7+dfsg-1                   arm64    fast lossless compression algorithm
ii  libzvbi-common                   0.2.44-1                       all      Vertical Blanking Interval decoder (VBI) - common files
ii  libzvbi0t64:arm64                0.2.44-1                       arm64    Vertical Blanking Interval decoder (VBI) - runtime files
ii  libzxing3:arm64                  2.3.0-3                        arm64    C++ port of ZXing library (library files)
ii  linux-headers-6.6.58-k3          6.6.58-1                       arm64    Linux kernel headers for 6.6.58-k3 on arm64
ii  linux-image-6.6.58-k3            6.6.58-1                       arm64    Linux kernel, version 6.6.58-k3
ii  linux-libc-dev:arm64             6.12.17-k3-rt                  arm64    Linux support headers for userspace development
ii  locales                          2.41-6                         all      GNU C Library: National Language (locale) data [support]
ii  login                            1:4.16.0-2+really2.41-3        arm64    system login tools
ii  login.defs                       1:4.17.3-3                     all      system user management configuration
ii  logrotate                        3.22.0-1+b2                    arm64    Log rotation utility
ii  logsave                          1.47.2-1+b1                    arm64    save the output of a command in a log file
ii  lsb-release                      12.1-1                         all      Linux Standard Base version reporting utility (minimal implementation)
ii  lsof                             4.99.4+dfsg-2                  arm64    utility to list open files
ii  make                             4.4.1-1                        arm64    utility for directing compilation
ii  man-db                           2.13.0-1                       arm64    tools for reading manual pages
ii  manpages                         6.9.1-1                        all      Manual pages about using a GNU/Linux system
ii  mawk                             1.3.4.20250131-1               arm64    Pattern scanning and text processing language
ii  media-types                      13.0.0                         all      List of standard media types and their usual file extension
ii  mesa-opencl-icd:arm64            24.0.1+git20250304+82e6a9293c-1 arm64    free implementation of the OpenCL API -- ICD runtime
ii  mesa-va-drivers:arm64            24.0.1+git20250304+82e6a9293c-1 arm64    Mesa VA-API video acceleration drivers
ii  mesa-vdpau-drivers:arm64         24.0.1+git20250304+82e6a9293c-1 arm64    Mesa VDPAU video acceleration drivers
ii  mesa-vulkan-drivers:arm64        24.0.1+git20250304+82e6a9293c-1 arm64    Mesa Vulkan graphics drivers
ii  mount                            2.41-3                         arm64    tools for mounting and manipulating filesystems
ii  nano                             8.3-1                          arm64    small, friendly text editor inspired by Pico
ii  ncurses-base                     6.5+20250216-2                 all      basic terminal type definitions
ii  ncurses-bin                      6.5+20250216-2                 arm64    terminal-related programs and man pages
ii  ncurses-term                     6.5+20250216-2                 all      additional terminal type definitions
ii  neofetch                         7.1.0-4                        all      Shows Linux System Information with Distribution Logo
ii  net-tools                        2.10-1.1+b1                    arm64    NET-3 networking toolkit
ii  netbase                          6.5                            all      Basic TCP/IP networking system
ii  netcat-traditional               1.10-50                        arm64    TCP/IP swiss army knife
ii  network-manager                  1.52.0-6                       arm64    network management framework (daemon and userspace tools)
ii  network-manager-l10n             1.52.0-6                       all      network management framework (translation files)
ii  nftables                         1.1.1-1                        arm64    Program to control packet filtering rules by Netfilter project
ii  ocl-icd-libopencl1:arm64         2.3.2-1+b2                     arm64    Generic OpenCL ICD Loader
ii  openssh-client                   1:9.9p2-2                      arm64    secure shell (SSH) client, for secure access to remote machines
ii  openssh-server                   1:9.9p2-2                      arm64    secure shell (SSH) server, for secure access from remote machines
ii  openssh-sftp-server              1:9.9p2-2                      arm64    secure shell (SSH) sftp server module, for SFTP access from remote machines
ii  openssl                          3.4.1-1                        arm64    Secure Sockets Layer toolkit - cryptographic utility
ii  openssl-provider-legacy          3.4.1-1                        arm64    Secure Sockets Layer toolkit - cryptographic utility
ii  parted                           3.6-5                          arm64    disk partition manipulator
ii  passwd                           1:4.17.3-3                     arm64    change and administer password and group data
ii  patch                            2.7.6-7+b1                     arm64    Apply a diff file to an original
ii  pci.ids                          0.0~2025.03.09-1               all      PCI ID Repository
ii  pciutils                         1:3.13.0-2                     arm64    PCI utilities
ii  perl                             5.40.1-2                       arm64    Larry Wall's Practical Extraction and Report Language
ii  perl-base                        5.40.1-2                       arm64    minimal Perl system
ii  perl-modules-5.40                5.40.1-2                       all      Core Perl modules
ii  procps                           2:4.0.4-7                      arm64    /proc file system utilities
ii  pru-pssp                         6.4.0+git20240415+f3e3996-1    arm64    Programmable Real-time Unit (PRU) Software Support Package v6.1.0
ii  python-apt-common                2.9.9                          all      Python interface to libapt-pkg (locales)
ii  python3                          3.13.2-2                       arm64    interactive high-level object-oriented language (default python3 version)
ii  python3-apt                      2.9.9+b1                       arm64    Python 3 interface to libapt-pkg
ii  python3-autocommand              2.2.2-3                        all      library to generate argparse parsers from function signatures
ii  python3-certifi                  2025.1.31+ds-1                 all      root certificates for validating SSL certs and verifying TLS hosts (python3)
ii  python3-chardet                  5.2.0+dfsg-2                   all      Universal Character Encoding Detector (Python3)
ii  python3-charset-normalizer       3.4.1-1+b1                     arm64    charset, encoding and language detection (Python 3)
ii  python3-debconf                  1.5.91                         all      interact with debconf from Python 3
ii  python3-debian                   1.0.1                          all      Python 3 modules to work with Debian-related data formats
ii  python3-debianbts                4.1.1                          all      Python interface to Debian's Bug Tracking System
ii  python3-idna                     3.10-1                         all      Python IDNA2008 (RFC 5891) handling (Python 3)
ii  python3-inflect                  7.3.1-2                        all      Generate plurals, singular nouns, ordinals, indefinite articles (Python 3)
ii  python3-jaraco.context           6.0.1-1                        all      jaraco contextlib extensions
ii  python3-jaraco.functools         4.1.0-1                        all      additional functools in the spirit of stdlib's functools
ii  python3-minimal                  3.13.2-2                       arm64    minimal subset of the Python language (default python3 version)
ii  python3-more-itertools           10.6.0-1                       all      library with routines for operating on iterables, beyond itertools (Python 3)
ii  python3-pkg-resources            75.8.0-1                       all      Package Discovery and Resource Access using pkg_resources
ii  python3-reportbug                13.1.0                         all      Python modules for interacting with bug tracking systems
ii  python3-requests                 2.32.3+dfsg-4                  all      elegant and simple HTTP library for Python3, built for human beings
ii  python3-typeguard                4.4.2-1                        all      Run-time type checker for Python
ii  python3-typing-extensions        4.13.0-1                       all      Backported and Experimental Type Hints for Python
ii  python3-urllib3                  2.3.0-2                        all      HTTP library with thread-safe connection pooling for Python3
ii  python3.12                       3.12.8-1                       arm64    Interactive high-level object-oriented language (version 3.12)
ii  python3.12-minimal               3.12.8-1                       arm64    Minimal subset of the Python language (version 3.12)
ii  python3.13                       3.13.2-3                       arm64    Interactive high-level object-oriented language (version 3.13)
ii  python3.13-minimal               3.13.2-3                       arm64    Minimal subset of the Python language (version 3.13)
ii  readline-common                  8.2-6                          all      GNU readline and history libraries, common files
ii  reportbug                        13.1.0                         all      reports bugs in the Debian distribution
ii  rpcsvc-proto                     1.4.3-1+b1                     arm64    RPC protocol compiler and definitions
ii  runit-helper                     2.16.4                         all      dh-runit implementation detail
ii  seatd                            0.9.1-1                        arm64    minimal user, seat and session management daemon
ii  sed                              4.9-2+b1                       arm64    GNU stream editor for filtering/transforming text
ii  sensible-utils                   0.0.24                         all      Utilities for sensible alternative selection
ii  shared-mime-info                 2.4-5+b2                       arm64    FreeDesktop.org shared MIME database and spec
ii  sq                               1.3.1-1                        arm64    OpenPGP command-line tool from Sequoia
ii  sqv                              1.3.0-1                        arm64    Simple OpenPGP signature verification program
ii  sudo                             1.9.16p2-1                     arm64    Provide limited super user privileges to specific users
ii  systemd                          257.4-3                        arm64    system and service manager
ii  systemd-sysv                     257.4-3                        arm64    system and service manager - SysV compatibility symlinks
ii  systemd-timesyncd                257.4-3                        arm64    minimalistic service to synchronize local time with NTP servers
ii  sysvinit-utils                   3.14-4                         arm64    System-V-like utilities
ii  tar                              1.35+dfsg-3.1                  arm64    GNU version of the tar archiving utility
hi  ti-img-rogue-driver-am62-dkms    24.1.6554834+git20240717+0884dea-1 all      Imagination Rogue Kernel Mode Driver for Texas Instruments AM62
hi  ti-img-rogue-firmware-am62       24.1.6554834+git20240613+ba93a3e-1 arm64    Rogue GPU firmware for AM62
hi  ti-img-rogue-tools-am62          24.1.6554834+git20240613+ba93a3e-1 arm64    Rogue GPU tools for AM62
hi  ti-img-rogue-umlibs-am62         24.1.6554834+git20240613+ba93a3e-1 arm64    Rogue GPU userspace libraries for AM62
ii  timgm6mb-soundfont               1.3-5                          all      TimGM6mb SoundFont from MuseScore 1.3
ii  tmux                             3.5a-3                         arm64    terminal multiplexer
ii  traceroute                       1:2.1.6-1                      arm64    Traces the route taken by packets over an IPv4/IPv6 network
ii  tzdata                           2025b-1                        all      time zone and daylight-saving time data
ii  ucf                              3.0051                         all      Update Configuration File(s): preserve user changes to config files
ii  udev                             257.4-3                        arm64    /dev/ and hotplug management daemon
ii  util-linux                       2.41-3                         arm64    miscellaneous system utilities
ii  util-linux-extra                 2.41-3                         arm64    interactive login tools
ii  vim                              2:9.1.1230-1                   arm64    Vi IMproved - enhanced vi editor
ii  vim-common                       2:9.1.1230-1                   all      Vi IMproved - Common files
ii  vim-runtime                      2:9.1.1230-1                   all      Vi IMproved - Runtime files
ii  vim-tiny                         2:9.1.1230-1                   arm64    Vi IMproved - enhanced vi editor - compact version
ii  wamerican                        2020.12.07-4                   all      American English dictionary words for /usr/share/dict
ii  weston                           14.0.1-3                       arm64    reference implementation of a wayland compositor
ii  wget                             1.25.0-2                       arm64    retrieves files from the web
ii  whiptail                         0.52.25-1                      arm64    Displays user-friendly dialog boxes from shell scripts
ii  wireless-regdb                   2025.02.20-1                   all      wireless regulatory database for Linux
ii  wpasupplicant                    2:2.10-24                      arm64    client support for WPA and WPA2 (IEEE 802.11i)
ii  wtmpdb                           0.72.0-1                       arm64    utility to display login/logout/reboot information
ii  x11-common                       1:7.7+24                       all      X Window System (X.Org) infrastructure
ii  xkb-data                         2.42-1                         all      X Keyboard Extension (XKB) configuration data
ii  xz-utils                         5.8.1-1                        arm64    XZ-format compression utilities
ii  zlib1g:arm64                     1:1.3.dfsg+really1.3.1-1+b1    arm64    compression library - runtime
  • Here's some additional context: the access point is set up so that another identical TI board can connect to it, receive the Wi-Fi video stream, and then forward it to a computer via a USB-to-Ethernet gadget interface. To recreate the error one needs to set up the TI board with the AP set up as shown above and apt update and upgrade before installing the needed packages. I will say that when upgrading, I needed to prevent upgrading the following packages, otherwise 'apt upgrade' would never finish.
    sudo apt-mark hold ti-img-rogue-driver-am62-dkms ti-img-rogue-firmware-am62 ti-img-rogue-tools-am62 ti-img-rogue-umlibs-am62
    Additionally, when running 'apt upgrade', I was prompted regarding the sshd_config and selected "Keep the local version currently installed"
  • Hi David,
    We have seen issues with video streaming before and believe we have made improvements around this. However it will require some updates to the linux kernel and the cc33xx firmware binaries.
    Can you first apply the following patch to your kernel build? https://github.com/TexasInstruments-Sandbox/cc33xx-linux-mpu-ports/tree/main/ti-linux-6.6.y
    Then, download the CC33xx SDK 1.0.0.8 and take all the binaries from cc33xx/cc33xx_rootfs/lib/firmware/ti-connectivity/ and install them into the same directory on your target (rootfs/lib/firmware/ti-connectivity). https://www.ti.com/tool/download/CC33XX-LINUX-MPU/1.0.0.8
  • Hi Sabeeh,
    Thank you for your speedy response! In order to patch my kernel build, can this be done with the SDK (here: https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/11_00_09_04/exports/docs/devices/AM62X/linux/Overview.html)  for Debian as well, or should I use bdebstrap (https://github.com/TexasInstruments/ti-bdebstrap)? I ask because currently, I am using the default Debian image. Happy to proceed either way.
  • Hi David,
    I'm personally more familiar with the Processor SDK and I know it's much simpler to add the patch into the SDK. I have not yet understood how to patch properly with the Debian as I assume patching and building is much more complex.
  • Hi Sabeeh,
    Sounds good will proceed with SDK. The Processor SDK seems yocto focused. Say we build the kernel in the SDK will that work for Debian as well? Thank you again for the responsiveness.
  • Hello Sabeeh,
    Thank you again for looking into this; it is very much appreciated.
    I noticed with the latest SDK 11x, there is no mention of the board we are using (am62xxsip) anywhere in the SDK directories. But the previous SDK release 10x does mention our board. Additionally, on the am62sip downloads page here: https://www.ti.com/tool/SK-AM62-SIP
    There is no mention of the am62sip default images. I tried using the latest am62xxevm default image, and that did not boot. In order to get access to the am62sip default images, I needed to go back one version, as seen in this link: https://www.ti.com/tool/download/PROCESSOR-SDK-LINUX-AM62X/10.01.10.04
    So as of now the newest am62sip default image and SDK installer are not available. Do you know when they might be updated?
    In the meantime, I am going to have to use the 10x version of the SDK and try the patches you mentioned. Since the patch mentioned was made last week, I do worry that it will not be compatible with the 10x SDK, which came out in December.
    I noticed in the snapshots page the am62sip latest snapshot is from December 2024 while am62xx is up to date. Is the am62sip still being supported going forward? If it is not we would like to know soon so that we may adjust before custom board designs are finalized.
    snapshot CI/CD link:
    software-dl.ti.com/.../
  • Hi David,
    SDK 10.x versions use kernel 6.6, and the patch I linked above is also for the same kernel version. See the directory folder which hints at the name. So the patch will apply directly to AM62x Processor SDK 10.x.
    I'm not sure why the SIP images are not available on SDK 11.x. I will ask around and try to find out for you. But for now, I encourage you to use the SDK 10.x and apply the mentioned patch.
  • Hi Sabeeh,
    Okay, sounds good. Thank you for asking around! We appreciate it since it is just early enough to change course if needed.
    I am able to build bootable Debian images when using the SDK for SIP 10X. I just needed to first download the default Debian image, then copy the rootfs to my PC, then when running "sudo bin/create-sdcard.sh" in the SDK I enter the path to the copied rootfs.
    I am testing modifying the kernel and still pointing to the Debian rootfs to see if we can patch the kernel and keep Debian. In your view, is this the correct way to modify the kernel when using Debian on am62xxsip platforms?
    Will update on the patch performance soon. Thank you again for taking the time.
  • Hi Sabeeh,
    I was wondering if you have any word on the when SIP images will be updated?
  • Hello Sabeeh,
    Just checking in wondering if there was an updated regarding AM62SIP default images and SDK being updated from 10x to 11x. Sorry to bother.
  • Hi David,
    Yes I am trying to follow up on this information.
    For now I still recommend the one from SDK 10 since you are trying to bring up cc33xx. SDK 11 uses kernel 6.12 which requires a diffeernt from patch from the same Github repo.
  • Hi David,
    I am hearing that the SIP image should be the same as the default am62x image. Can you please give it a try? If you are having issues, then I suggest creating a new ticket for that.
  • Hi Sabeeh,
    I tried flashing both default and Debian images for the am62 and neither one booted fully.
    I get the following results on the terminal
    � U-Boot SPL 2025.01-gcd91d7360181 (Apr 03 2025 - 12:56:46 +0530)
    SYSFW ABI: 4.0 (firmware rev 0x000b '11.0.7--v11.00.07 (Fancy Rat)')
    Changed A53 CPU frequency to 1250000000Hz (T grade) in DT SPL initial stack usage: 13424 bytes
    I will make a separate ticket regarding this.
    For the patch in the SDK does one need to simply put the patch into this dir "board-support/ti-linux-kernel-6.6.58+git-ti/patches"
    Thank you again for your continued support
  • Hi Sabeeh,
    Thank you for your continued support. Also, I noticed you made this patch!
    So far, I have found a way to use the SDK10x to customize the kernel for a Debian or Yocto rootfs. Please let me know if you see anything wrong here or if you have any insights or tips related. I plan to use this method and apply the patch as you mentioned a while ago.
    I will apply the patch to the ti-linux-kernel-6.6.58+git-ti branch
    Here are the rest of the steps I have been using to customize the kernel for debian rootfs with SDK10x
    Host is Ubuntu 22.04
    Assume you run these cmds one at a time.
    • Set the cross-compile environment once per shell
    export ARCH=arm64
    export CROSS_COMPILE=$HOME/Desktop/5-7-10x-SDK/linux-devkit/\
    sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-
    • Go into the TI ARM64 kernel tree
    cd ~/Desktop/5-7-10x-SDK/board-support/ti-linux-kernel-6.6.58+git-ti
    • Start from a clean tree
    make mrproper
    • Load TI’s baseline + prune fragment
    make defconfig ti_arm64_prune.config
    • Open the *correct* (ARM64) menuconfig
      • Here is where you can mod the kernel to your liking
    make menuconfig
    • Freeze this config as the new SDK defconfig
    make savedefconfig
    cp defconfig arch/arm64/configs/defconfig   # overwrite generic defconfig
    • Back to the SDK root and rebuild everything
    make clean            # (one time) clears previous top-level artifacts
    make all -j$(nproc)   # full SDK build (kernel + modules + dtbs) with your config
    make linux_stage                 # copies results → built-images
    • Create the SD card image
    You will be asked to provide paths or go with defaults. Select (2) provide paths every time.
    Path 1 and 2: /home/davidsober/Desktop/5-7-10x-SDK/board-support/built-images
    Path 3 (Debian)
    /home/davidsober/Desktop/extracted-debian-rootfs/10x-trixie-rootfs
    • For debian rootfs you need to extract the rootfs of a debian default image that matches the sdk verison you are using (kernel versions need to match)
    Path 3 (Yocto default):
    /home/davidsober/Desktop/5-7-10x-SDK/filesystem/am62xxsip-evm/tisdk-base-image-am62xxsip-evm.rootfs.tar.xz
    • Copy kernel Image, DTBs, and kernel fitImage to newly created SD card image rootfs/boot
    unplug and replug SD card
    BOOT=/media/$USER/rootfs/boot    # ext4 partition already mounted
    sudo cp ~/Desktop/5-7-10x-SDK/board-support/built-images/Image  $BOOT/
    sudo cp -r ~/Desktop/5-7-10x-SDK/board-support/built-images/dtb/ti  $BOOT/dtb/
    sudo cp /home/davidsober/Desktop/5-7-10x-SDK/board-support/built-images/fitImage \
         /media/davidsober/rootfs/boot/fitImage
  • Hi Sabeeh,
    After following the instructions here:
    As well as using my steps above to create a bootable SD card with Debian rootfs, I am unable to see the wlan0 when running 'ifconfig' even after adding "name_overlays=ti/k3-am625-sk-m2-cc3350.dtbo" to uEnv.txt in the boot partition. This uEnv.txt is the only way I have been able to enable the wifi on default debian images.
    I was wondering if you had a different method of applying the patch. I used: git am /home/davidsober/Downloads/drivers-cc33xx-update-to-1.0.0.8.patch   -   while in the ti-linux-kernel directory.
  • Hi Sabeeh,
    I was wondering since you are the author of the patch, how did the patch perform on am62sip evm boards? Were you able to stream video of say 480p at 30fps over the m.2 cc3351 wifi module for an hour or greater without a driver reset error?
    Right now, I am working to enable wlan0 on this custom image as mentioned in my previous response.
  • Hello Sabeeh,
    Just checking in. I was able to apply the patch as mentioned but now wlan0 does not show up when running ifconfig after booting. I already added uEnv.txt and "name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo" to it. Is there possibly another way to get wlan0 to show up on the SIP board besides uEnv.txt? and besides writing the "name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo" in uboots command line?
    Kind regards,
    David
  • Hi David,
    I haven't tested the patch on Am62SIP, specifically, but I have tested on boards like AM62x-SK (which is the same CPU as SIP) and AM62A. We have done camera streaming demos on AM62A: https://www.youtube.com/watch?v=c-AiSWsC65g
    Could you please attach the entire output of "dmesg"? I will review the output and provide feedback.
  • Hello Sabeeh,
    That is good to know. Apologies. I realized I applied the patch incorrectly before by using "git am."
    Here is the new way I patched the kernel.
    Patch method
    • cd /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel-6.6.58+git-ti
    • make new branch and checkout to it
    • patch -p1 < ~/Downloads/drivers-cc33xx-update-to-1.0.0.8.patch
    • Git add and commit
    I then copied the patched kernel to the rootfs of my target SD card.
    Default Debian Trixie 10x
    • Flashed tisdk-debian-trixie-am62xxsip-evm-10.01.10.04.wic to SD card
    • Booted ran ifconfig see no wlan0 (expected result met)
    • Save dmesg
    • Created uEnx.txt with “name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo” in BOOT partition
      • Sync
    • Booted
    • Ifconfig shows wlan0 (as expected)
    • cd to SDK root dir and ran the following
    sudo cp ~/Desktop/5-19-processor-SDK-SIP/board-support/built-images/Image  $BOOT/
    sudo cp -r ~/Desktop/5-19-processor-SDK-SIP/board-support/built-images/dtb/ti  $BOOT/dtb/
    sudo cp /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/fitImage \
    sync
    • Boot
    • Ifconfig shows that wlan0 has disappeared
    The method used to update the kernel and dtbs will break wlan0 interface and thus prevent us from testing the patch.
    I had an identical result when testing the default arago Arago image for 10x release
    I also tried using the "make linux_install" tool from the SDK but this resulted in an image that could not boot
    Here were my steps for that
    Used create-sdcard.sh and selected prebulit image and selected tisdk-default-image-am62xxsip-evm.rootfs.tar.xz
    • Built image.
    • See the following in rootfs/boot
    davidsober@davidsober-AORUS-16X-ASG /media/davidsober/rootfs/boot $ ll
    total 30068
    drwxr-xr-x 3 root root 4096 Mar  9  2018 dtb
    drwxr-xr-x 3 root root 4096 Mar  9  2018 EFI
    lrwxrwxrwx 1 root root   44 Mar  9  2018 fitImage -> fitImage-6.6.58-ti-01497-ga7758da17c28-dirty
    -rw-r--r-- 1 root root  9700402 Mar  9  2018 fitImage-6.6.58-ti-01497-ga7758da17c28-dirty
    lrwxrwxrwx 1 root root   41 Mar  9  2018 Image -> Image-6.6.58-ti-01497-ga7758da17c28-dirty
    -rw-r--r-- 1 root root 21029376 Mar  9  2018 Image-6.6.58-ti-01497-ga7758da17c28-dirty
    In sdk root dir i run
    First cross compile
    export ARCH=arm64
    Run
    • sudo DESTDIR=/media/$USER/rootfs make linux_install
    Result
    davidsober@davidsober-AORUS-16X-ASG ~/Desktop/5-19-processor-SDK-SIP $ sudo DESTDIR=/media/$USER/rootfs make linux_install
    [sudo] password for davidsober:
    mkdir -p /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/dtb/ti
    cp /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/u-boot-build/a53/tispl.bin /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/tispl.bin
    cp /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/u-boot-build/a53/u-boot.img /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/u-boot.img
    cp /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/u-boot-build/r5/tiboot3*.bin /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/
    cp /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel*/arch/arm64/boot/Image /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images
    Installing the Linux Kernel DTBs
    install -d /media/davidsober/rootfs/boot/dtb/ti
    install /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/fitImage /media/davidsober/rootfs/boot
    install /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/built-images/Image /media/davidsober/rootfs/boot
    install /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel*/vmlinux /media/davidsober/rootfs/boot
    install /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel*/System.map /media/davidsober/rootfs/boot
    make -C /home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel* ARCH=arm64 CROSS_COMPILE=/home/davidsober/Desktop/5-19-processor-SDK-SIP/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux- INSTALL_MOD_PATH=/media/davidsober/rootfs INSTALL_MOD_STRIP=1 modules_install
    make[1]: Entering directory '/home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel-6.6.58+git-ti'
      SYMLINK /media/davidsober/rootfs/lib/modules/6.6.58-ga6e2a57116f3/build
      INSTALL /media/davidsober/rootfs/lib/modules/6.6.58-ga6e2a57116f3/modules.order
      INSTALL /media/davidsober/rootfs/lib/modules/6.6.58-ga6e2a57116f3/modules.builtin
      INSTALL /media/davidsober/rootfs/lib/modules/6.6.58-ga6e2a57116f3/modules.builtin.modinfo
      DEPMOD  /media/davidsober/rootfs/lib/modules/6.6.58-ga6e2a57116f3
    make[1]: Leaving directory '/home/davidsober/Desktop/5-19-processor-SDK-SIP/board-support/ti-linux-kernel-6.6.58+git-ti'
    Result in rootfs/boot target
    total 244484
    -rwxr-xr-x 1 root root  16360950 May 22 12:40 fitImage
    -rwxr-xr-x 1 root root  37501440 May 22 12:40 Image
    -rwxr-xr-x 1 root root   5376619 May 22 12:40 System.map
    -rwxr-xr-x 1 root root 160301176 May 22 12:40 vmlinux
    These look updated
    sync
    Boot
    • Not booting
    In a previous reply, I showed how I built the Kernel and copied it to a default Debian rootfs and was able to boot and verify that the changes I made in "make menuconfig" were in fact present on the board.
    The issue is, I was unable to get wlan0 to show up using that method as well
    Long story short:
    Copying the kernel, dtbs from linux SDK... or firmware from cc33xxSDK cc33xx/cc33xx_rootfs/lib/firmware/ti-connectivity/ to target (rootfs/lib/firmware/ti-connectivity). will, for some reason, prevent wlan0 from showing up when running "ifconfig" after booting. (This includes having uEnv.txt with "name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo" in boot partition)
    - The only conclusion I have is: I must be copying these files wrongly. I just use 'cp'
    How did you copy the kernel Image and dtb from the SDK to the target rootfs and still retain wlan0 interface? With that information, I could properly test the patch.
  • Hello Sabeeh,
    I was just checking in. Perhaps I will ask the following in a separate question. I was wondering if your steps for patching the kernel and building the SD card were massively different from mine, shown above. I ask because when I modify the kernel image with cp or the cc33xx firmware with cp I can no longer see the wlan0 interface when I run "ifconfig." Without this interface, I am unable to provide useful dmesg logs as you have requested.
    Regarding steps for building the kernel may be a different question, and so I will ask that separately, but it would be interesting to see how you were able to update the kernel image and cc33xx firmware without losing the wlan0 interface.
    Thank you for taking the time and consideration throughout all these replies.
    David
  • Hi David,
    I think one of the steps you are missing is to install the kernel modules as well. Have you already done this?
  • Hi David,
    In addition, there is no link between wlan0 showing up and dmesg. I would like to examine the full logs anyways so if you can please share the output of 'dmesg' command after the linux kernel boots then that can help me debug your scenario.
  • Hi Sabeeh, Thank you for responding.
    Consolidating questions from other threads here.
    No, I do not think so. How can I do this? I thought I was doing this by copying the binaries from C33xx SDK 1.0.0.8  cc33xx/cc33xx_rootfs/lib/firmware/ti-connectivity/ and pasting them into the same directory as my target (rootfs/lib/firmware/ti-connectivity) using 'cp'
    q1: I am using this command to patch the kernel is this correct?
    q2: After you have finished patching and building everything with "make all" and are now building an SD card. When running bin/create-sdcard.sh in the SDK, you are asked three sub questions. Are your answers the following?
    a. Enter path for Boot Partition: SDK/board-support/built-images
    b. Enter path for kernel image and device tree files: SDK/board-support/built-images
    c. Enter path for Rootfs Partition: SDK/filesystem/am62xxsip-evm/tisdk-default-image-am62xxsip-evm.rootfs.tar.xz
    If those are not your 3 answers, can I ask what your answers are? I ask because I need to make sure we are on the same page for this step.
    Apologies for the long response below. I included dmesg logs from before and after I copied the ti-connectivity firmware from cc33xxsdk to the target rootfs, as you asked.
    At this point we have patched the kernel and ran 'make all.' and build the SD card.
    In boot/ partition, i added a file ‘uEnv.txt’
    And save the following into it: “name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo”
    I boot and can see wlan0
    I will paste dmesg from before and after copying the firmware. Here is how I did that
    Copy all files from ti-connectivitiy directory to target
    • cd /home/davidsober/Desktop/cc33xx_SDK/cc33xx_linux_package_1_0_0_8/cc33xx/cc33xx_rootfs/lib/firmware/ti-connectivity
    • cp * /media/davidsober/rootfs/lib/firmware/ti-connectivity
    Now after booting wlan0 is gone again (issue reproduced)
    dmesg
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.6.58-ti-01497-ga7758da17c28-dirty (oe-user@oe-host) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Wed Nov 27 13:23:15 UTC 2024
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM625 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000094000000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x0000000094000000..0x000000009bffffff (131072 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x000000009bffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009bffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009bffffff]
    [    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
    [    0.000000] pcpu-alloc: s43176 r8192 d30552 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=b8ea592a-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 112896
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x000000008beee000-0x000000008feee000] (64MB)
    [    0.000000] Memory: 229212K/458752K available (12480K kernel code, 1272K rwdata, 4184K rodata, 2496K init, 528K bss, 98468K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000]     Trampoline variant of Tasks RCU enabled.
    [    0.000000]     Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080440000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008596] Console: colour dummy device 80x25
    [    0.013205] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023890] pid_max: default: 32768 minimum: 301
    [    0.028697] LSM: initializing lsm=capability,selinux,integrity
    [    0.034689] SELinux:  Initializing.
    [    0.038389] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.045874] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.055871] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.063205] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.071143] rcu: Hierarchical SRCU implementation.
    [    0.076051] rcu:     Max phase no-delay instances is 1000.
    [    0.081692] Platform MSI: msi-controller@1820000 domain created
    [    0.088036] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.097482] EFI services will not be available.
    [    0.102441] smp: Bringing up secondary CPUs ...
    [    0.107793] Detected VIPT I-cache on CPU1
    [    0.107887] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.107906] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
    [    0.107961] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.108743] Detected VIPT I-cache on CPU2
    [    0.108809] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.108823] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000
    [    0.108860] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.109534] Detected VIPT I-cache on CPU3
    [    0.109589] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.109603] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000
    [    0.109632] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.109709] smp: Brought up 1 node, 4 CPUs
    [    0.189444] SMP: Total of 4 processors activated.
    [    0.194258] CPU features: detected: 32-bit EL0 Support
    [    0.199533] CPU features: detected: CRC32 instructions
    [    0.204854] CPU: All CPU(s) started at EL2
    [    0.209052] alternatives: applying system-wide alternatives
    [    0.216272] devtmpfs: initialized
    [    0.228492] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.238504] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.250295] pinctrl core: initialized pinctrl subsystem
    [    0.256255] DMI not present or invalid.
    [    0.260916] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.267899] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.275201] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.283195] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.291365] audit: initializing netlink subsys (disabled)
    [    0.297117] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
    [    0.297649] thermal_sys: Registered thermal governor 'step_wise'
    [    0.305053] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.311251] cpuidle: using governor menu
    [    0.322121] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.329155] ASID allocator initialised with 65536 entries
    [    0.340494] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.352006] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.364038] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.374076] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    0.386142] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.400788] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.412948] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.424032] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    0.436906] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.446850] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.456838] /bus@f0000/pinctrl@a40000: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
    [    0.468284] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.477534] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.488309] Modules: 27488 pages in range for non-PLT usage
    [    0.488321] Modules: 519008 pages in range for PLT usage
    [    0.494895] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.507302] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.513712] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.520652] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.527059] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.533999] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.540407] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.547347] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.555270] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.564617] iommu: Default domain type: Translated
    [    0.569555] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.576201] SCSI subsystem initialized
    [    0.580214] libata version 3.00 loaded.
    [    0.580433] usbcore: registered new interface driver usbfs
    [    0.586082] usbcore: registered new interface driver hub
    [    0.591550] usbcore: registered new device driver usb
    [    0.597245] pps_core: LinuxPPS API ver. 1 registered
    [    0.602328] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.611679] PTP clock support registered
    [    0.615915] EDAC MC: Ver: 3.0.0
    [    0.619725] scmi_core: SCMI protocol bus registered
    [    0.625052] FPGA manager framework
    [    0.628627] Advanced Linux Sound Architecture Driver Initialized.
    [    0.635915] vgaarb: loaded
    [    0.639126] clocksource: Switched to clocksource arch_sys_counter
    [    0.645680] VFS: Disk quotas dquot_6.6.0
    [    0.649733] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.663923] NET: Registered PF_INET protocol family
    [    0.669100] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.677254] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
    [    0.685880] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.693821] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.701771] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.709292] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.715926] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.722626] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.729915] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.736179] RPC: Registered named UNIX socket transport module.
    [    0.742256] RPC: Registered udp transport module.
    [    0.747066] RPC: Registered tcp transport module.
    [    0.751875] RPC: Registered tcp-with-tls transport module.
    [    0.757483] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.764075] NET: Registered PF_XDP protocol family
    [    0.768993] PCI: CLS 0 bytes, default 64
    [    0.774562] Initialise system trusted keyrings
    [    0.779383] workingset: timestamp_bits=46 max_order=17 bucket_order=0
    [    0.786350] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.792646] NFS: Registering the id_resolver key type
    [    0.797859] Key type id_resolver registered
    [    0.802138] Key type id_legacy registered
    [    0.806255] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.813112] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.854830] Key type asymmetric registered
    [    0.859034] Asymmetric key parser 'x509' registered
    [    0.864087] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.871838] io scheduler mq-deadline registered
    [    0.876479] io scheduler kyber registered
    [    0.880616] io scheduler bfq registered
    [    0.888146] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.894746] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.902313] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.915163] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.934125] loop: module loaded
    [    0.938603] megasas: 07.725.01.00-rc1
    [    0.946312] tun: Universal TUN/TAP device driver, 1.6
    [    0.952637] VFIO - User Level meta-driver version: 0.3
    [    0.959076] usbcore: registered new interface driver usb-storage
    [    0.965932] i2c_dev: i2c /dev entries driver
    [    0.972053] sdhci: Secure Digital Host Controller Interface driver
    [    0.978398] sdhci: Copyright(c) Pierre Ossman
    [    0.983083] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.989679] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.996153] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.003488] usbcore: registered new interface driver usbhid
    [    1.009203] usbhid: USB HID core driver
    [    1.014620] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    1.023615] optee: probing for conduit method.
    [    1.028193] optee: revision 4.4 (8f645256efc0dc66)
    [    1.028557] optee: dynamic shared memory is enabled
    [    1.039289] random: crng init done
    [    1.042875] optee: initialized driver
    [    1.048602] Initializing XFRM netlink socket
    [    1.053042] NET: Registered PF_PACKET protocol family
    [    1.058311] Key type dns_resolver registered
    [    1.071667] registered taskstats version 1
    [    1.076047] Loading compiled-in X.509 certificates
    [    1.097019] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)')
    [    1.173532] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.185674] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.193368] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.202651] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.212614] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.221843] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.232245] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.239906] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.245918] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.255258] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.265695] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.274672] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.286124] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.297690] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.308363] printk: console [ttyS2] disabled
    [    1.313166] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3000000) is a 8250
    [    1.322065] printk: console [ttyS2] enabled
    [    1.330570] printk: bootconsole [ns16550a0] disabled
    [    1.346985] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.352113] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.359076] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.364470] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.371427] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.378060] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.384742] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.391143] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.398091] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.404738] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.661396] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.707131] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.719157] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.727260] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.735383] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.748351] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.754619] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.761745] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.768301] pps pps0: new PPS source ptp0
    [    1.772619] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.786964] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.797799] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.809714] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    1.824382] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.829959] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.837771] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.843780] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
    [    1.853223] xhci-hcd xhci-hcd.0.auto: irq 253, io mem 0x31100000
    [    1.860127] hub 1-0:1.0: USB hub found
    [    1.863922] hub 1-0:1.0: 1 port detected
    [    1.869836] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.882752] mmc0: CQHCI version 5.10
    [    1.889548] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.896354] pca953x 1-0022: using AI
    [    1.923711] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.936748] mmc1: CQHCI version 5.10
    [    1.937098] clk: Disabling unused clocks
    [    1.942534] mmc2: CQHCI version 5.10
    [    1.956271] ALSA device list:
    [    1.959335]   No soundcards found.
    [    1.979715] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.989730] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    1.997924] Waiting for root device PARTUUID=b8ea592a-02...
    [    2.002366] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
    [    2.017728] mmc0: Command Queue Engine enabled
    [    2.022196] mmc0: new HS200 MMC card at address 0001
    [    2.023643] mmc2: new high speed SDIO card at address 0001
    [    2.027941] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.038799]  mmcblk0: p1 p2
    [    2.042295] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.048426] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.054377] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.057093] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
    [    2.068107] mmcblk1: mmc1:aaaa SD64G 59.5 GiB
    [    2.075432]  mmcblk1: p1 p2
    [    2.239833] EXT4-fs (mmcblk1p2): recovery complete
    [    2.245719] EXT4-fs (mmcblk1p2): mounted filesystem 5ebcf8d5-7f01-42f7-8ce3-decfba78fec0 r/w with ordered data mode. Quota mode: none.
    [    2.257893] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.267182] devtmpfs: mounted
    [    2.271855] Freeing unused kernel memory: 2496K
    [    2.276487] Run /sbin/init as init process
    [    2.280579]   with arguments:
    [    2.280583]     /sbin/init
    [    2.280586]   with environment:
    [    2.280588]     HOME=/
    [    2.280591]     TERM=linux
    [    2.493613] systemd[1]: System time before build time, advancing clock.
    [    2.543929] NET: Registered PF_INET6 protocol family
    [    2.550045] Segment Routing with IPv6
    [    2.553808] In-situ OAM (IOAM) with IPv6
    [    2.594774] systemd[1]: systemd 255.13^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.626700] systemd[1]: Detected architecture arm64.
    [    2.643998] systemd[1]: Hostname set to <am62xxsip-evm>.
    [    2.652126] systemd[1]: Initializing machine ID from random generator.
    [    2.943657] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    3.050872] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.163009] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.242936] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.281749] systemd[1]: Created slice Slice /system/getty.
    [    3.305948] systemd[1]: Created slice Slice /system/modprobe.
    [    3.329896] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.353158] systemd[1]: Created slice User and Session Slice.
    [    3.375686] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.399525] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.423335] systemd[1]: Expecting device /dev/dri/card1...
    [    3.439224] systemd[1]: Expecting device /dev/ttyS2...
    [    3.455364] systemd[1]: Reached target Path Units.
    [    3.471261] systemd[1]: Reached target Remote File Systems.
    [    3.491259] systemd[1]: Reached target Slice Units.
    [    3.507276] systemd[1]: Reached target Swaps.
    [    3.566474] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.587497] systemd[1]: Reached target RPC Port Mapper.
    [    3.614477] systemd[1]: Listening on Process Core Dump Socket.
    [    3.635789] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.660676] systemd[1]: Listening on Journal Audit Socket.
    [    3.684484] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.708531] systemd[1]: Listening on Journal Socket.
    [    3.724644] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.765725] systemd[1]: Listening on udev Control Socket.
    [    3.788424] systemd[1]: Listening on udev Kernel Socket.
    [    3.812413] systemd[1]: Listening on User Database Manager Socket.
    [    3.871620] systemd[1]: Mounting Huge Pages File System...
    [    3.892345] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.920744] systemd[1]: Mounting Kernel Debug File System...
    [    3.936022] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.955652] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.978385] systemd[1]: Starting Create List of Static Device Nodes...
    [    4.030219] systemd[1]: Starting Load Kernel Module configfs...
    [    4.053056] systemd[1]: Starting Load Kernel Module drm...
    [    4.081223] systemd[1]: Starting Load Kernel Module fuse...
    [    4.111396] systemd[1]: Starting Start psplash boot splash screen...
    [    4.128303] fuse: init (API version 7.39)
    [    4.144741] systemd[1]: Starting RPC Bind...
    [    4.163747] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    4.186277] systemd[1]: Starting Journal Service...
    [    4.215605] systemd[1]: Starting Load Kernel Modules...
    [    4.241974] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.269823] cryptodev: loading out-of-tree module taints kernel.
    [    4.277854] cryptodev: driver 1.14 loaded.
    [    4.282885] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.301343] systemd-journald[128]: Collecting audit messages is enabled.
    [    4.318101] systemd[1]: Starting Coldplug All udev Devices...
    [    4.355886] systemd[1]: Started RPC Bind.
    [    4.364333] EXT4-fs (mmcblk1p2): re-mounted 5ebcf8d5-7f01-42f7-8ce3-decfba78fec0 r/w. Quota mode: none.
    [    4.378693] systemd[1]: Mounted Huge Pages File System.
    [    4.400334] systemd[1]: Started Journal Service.
    [    4.798434] systemd-journald[128]: Received client request to flush runtime journal.
    [    5.038589] audit: type=1334 audit(1728487094.540:2): prog-id=6 op=LOAD
    [    5.045353] audit: type=1334 audit(1728487094.548:3): prog-id=7 op=LOAD
    [    5.052126] audit: type=1334 audit(1728487094.556:4): prog-id=8 op=LOAD
    [    5.386428] audit: type=1334 audit(1728487094.888:5): prog-id=9 op=LOAD
    [    5.393134] audit: type=1334 audit(1728487094.896:6): prog-id=10 op=LOAD
    [    5.688357] audit: type=1334 audit(1728487095.192:7): prog-id=11 op=LOAD
    [    5.712795] audit: type=1334 audit(1728487095.216:8): prog-id=12 op=LOAD
    [    7.259646] at24 0-0051: supply vcc not found, using dummy regulator
    [    7.283023] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    7.289693] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
    [    7.301844] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    7.334411] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.343568] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.383955] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.392617] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.414012] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    7.427315] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    7.434208] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    7.444152] remoteproc remoteproc0: 5000000.m4fss is available
    [    7.449857] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.458445] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.467631] remoteproc remoteproc0: powering up 5000000.m4fss
    [    7.474311] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.475221] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55100
    [    7.482817] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.496321] rproc-virtio rproc-virtio.1.auto: assigned reserved memory node m4f-dma-memory@9cb00000
    [    7.510493] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.518494] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    7.525749] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.525777] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.543285] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    7.548880] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.548918] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.566152] rproc-virtio rproc-virtio.1.auto: registered virtio0 (type 7)
    [    7.573364] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
    [    7.580634] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.589837] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.614019] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.619462] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    7.623513] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.625747] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    7.626224] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:13 UTC (13)
    [    7.635724] platform 78000000.r5f: configured R5F for IPC-only mode
    [    7.643190] systemd-journald[128]: Time jumped backwards, rotating.
    [    7.648239] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
    [    7.658191] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.663814] remoteproc remoteproc1: 78000000.r5f is available
    [    7.668846] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.677221] remoteproc remoteproc1: attaching to 78000000.r5f
    [    7.706513] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
    [    7.709341] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.717587] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    7.724179] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    7.730258] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    7.737673] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    7.744427] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    7.745819] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.752522] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.778783] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.796927] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.805445] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.814993] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    7.822515] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    7.834977] i2c i2c-1: Added multiplexed i2c bus 3
    [    7.845242] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.853731] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.864595] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    7.873308] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    7.880665] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    7.901327] PVR_K:  202: Device: fd00000.gpu
    [    7.907117] PVR_K:  202: Read BVNC 33.15.11.3 from HW device registers
    [    7.914013] PVR_K:  202: RGX Device registered with BVNC 33.15.11.3
    [    7.921530] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1
    [    8.055504] cc33xx_sdio mmc2:0001:2: Using GPIO as IRQ
    [    8.135526] remoteproc remoteproc2: 30074000.pru is available
    [    8.145206] remoteproc remoteproc3: 30078000.pru is available
    [    8.424958] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.456683] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.463408] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    8.613823] cc33xx_driver cc33xx.5.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
    [    9.368622] audit: type=1334 audit(15.240:9): prog-id=13 op=LOAD
    [    9.517121] dbus-broker-lau[583]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    9.740586] audit: type=1334 audit(15.612:10): prog-id=14 op=LOAD
    [    9.751380] audit: type=1334 audit(15.620:11): prog-id=15 op=LOAD
    [    9.757750] audit: type=1334 audit(15.620:12): prog-id=16 op=LOAD
    [    9.919928] audit: type=1334 audit(15.792:13): prog-id=17 op=LOAD
    [   10.266642] Bluetooth: Core ver 2.22
    [   10.270660] NET: Registered PF_BLUETOOTH protocol family
    [   10.270675] Bluetooth: HCI device and connection manager initialized
    [   10.270700] Bluetooth: HCI socket layer initialized
    [   10.270712] Bluetooth: L2CAP socket layer initialized
    [   10.270736] Bluetooth: SCO socket layer initialized
    [   10.488807] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   10.504932] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   10.561343] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [   10.594472] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   16.898642] PVR_K:  652: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
    [   16.952781] PVR_K:  652: Shader binary image 'rgx.sh.33.15.11.3' loaded
    [   17.510555] audit: type=1701 audit(23.380:14): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=652 comm="ti-apps-launche" exe="/usr/bin/ti-apps-launcher" sig=6 res=1
    [   17.773458] audit: type=1334 audit(23.644:15): prog-id=18 op=LOAD
    [   17.779673] audit: type=1334 audit(23.652:16): prog-id=19 op=LOAD
    [   17.785841] audit: type=1334 audit(23.656:17): prog-id=20 op=LOAD
    [   20.193765] audit: type=1006 audit(26.064:18): pid=1120 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   20.208040] audit: type=1300 audit(26.064:18): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffeac5ae58 a2=1 a3=1 items=0 ppid=1 pid=1120 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   20.235876] audit: type=1327 audit(26.064:18): proctitle="(systemd)"
    [   20.308454] audit: type=1334 audit(26.180:19): prog-id=21 op=LOAD
    [   20.315930] audit: type=1300 audit(26.180:19): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffe4c078c8 a2=90 a3=0 items=0 ppid=1 pid=1120 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   20.342437] audit: type=1327 audit(26.180:19): proctitle="(systemd)"
    Now apply steps to update firmware
    Now wlan0 is gone again (issue reproduced)
    Here is dmesg
    [    0.008593] Console: colour dummy device 80x25
    [    0.013200] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023885] pid_max: default: 32768 minimum: 301
    [    0.028692] LSM: initializing lsm=capability,selinux,integrity
    [    0.034684] SELinux:  Initializing.
    [    0.038381] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.045865] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.055859] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.063197] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.071138] rcu: Hierarchical SRCU implementation.
    [    0.076046] rcu:     Max phase no-delay instances is 1000.
    [    0.081689] Platform MSI: msi-controller@1820000 domain created
    [    0.088022] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.097466] EFI services will not be available.
    [    0.102416] smp: Bringing up secondary CPUs ...
    [    0.107764] Detected VIPT I-cache on CPU1
    [    0.107855] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.107874] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
    [    0.107931] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.108709] Detected VIPT I-cache on CPU2
    [    0.108774] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.108788] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000
    [    0.108823] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.109492] Detected VIPT I-cache on CPU3
    [    0.109546] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.109559] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000
    [    0.109589] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.109666] smp: Brought up 1 node, 4 CPUs
    [    0.189403] SMP: Total of 4 processors activated.
    [    0.194216] CPU features: detected: 32-bit EL0 Support
    [    0.199490] CPU features: detected: CRC32 instructions
    [    0.204810] CPU: All CPU(s) started at EL2
    [    0.209009] alternatives: applying system-wide alternatives
    [    0.216238] devtmpfs: initialized
    [    0.228456] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.238470] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.250248] pinctrl core: initialized pinctrl subsystem
    [    0.256231] DMI not present or invalid.
    [    0.260888] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.267867] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.275167] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.283161] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.291330] audit: initializing netlink subsys (disabled)
    [    0.297081] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
    [    0.297608] thermal_sys: Registered thermal governor 'step_wise'
    [    0.305015] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.311213] cpuidle: using governor menu
    [    0.322086] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.329122] ASID allocator initialised with 65536 entries
    [    0.340433] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.351947] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.363977] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.374012] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    0.386077] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.400723] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.412885] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.423971] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    0.436841] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.446785] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.456775] /bus@f0000/pinctrl@a40000: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
    [    0.468228] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.477476] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.488272] Modules: 27488 pages in range for non-PLT usage
    [    0.488284] Modules: 519008 pages in range for PLT usage
    [    0.494846] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.507257] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.513668] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.520608] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.527015] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.533954] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.540362] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.547302] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.555229] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.564582] iommu: Default domain type: Translated
    [    0.569520] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.576173] SCSI subsystem initialized
    [    0.580186] libata version 3.00 loaded.
    [    0.580400] usbcore: registered new interface driver usbfs
    [    0.586046] usbcore: registered new interface driver hub
    [    0.591512] usbcore: registered new device driver usb
    [    0.597220] pps_core: LinuxPPS API ver. 1 registered
    [    0.602305] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.611656] PTP clock support registered
    [    0.615904] EDAC MC: Ver: 3.0.0
    [    0.619722] scmi_core: SCMI protocol bus registered
    [    0.625057] FPGA manager framework
    [    0.628634] Advanced Linux Sound Architecture Driver Initialized.
    [    0.635920] vgaarb: loaded
    [    0.639140] clocksource: Switched to clocksource arch_sys_counter
    [    0.645697] VFS: Disk quotas dquot_6.6.0
    [    0.649747] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.663948] NET: Registered PF_INET protocol family
    [    0.669130] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.677302] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
    [    0.685922] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.693863] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.701814] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.709338] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.715976] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.722674] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.729962] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.736214] RPC: Registered named UNIX socket transport module.
    [    0.742293] RPC: Registered udp transport module.
    [    0.747103] RPC: Registered tcp transport module.
    [    0.751912] RPC: Registered tcp-with-tls transport module.
    [    0.757520] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.764112] NET: Registered PF_XDP protocol family
    [    0.769031] PCI: CLS 0 bytes, default 64
    [    0.774619] Initialise system trusted keyrings
    [    0.779451] workingset: timestamp_bits=46 max_order=17 bucket_order=0
    [    0.786416] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.792706] NFS: Registering the id_resolver key type
    [    0.797913] Key type id_resolver registered
    [    0.802191] Key type id_legacy registered
    [    0.806309] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.813165] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.854907] Key type asymmetric registered
    [    0.859112] Asymmetric key parser 'x509' registered
    [    0.864164] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.871908] io scheduler mq-deadline registered
    [    0.876550] io scheduler kyber registered
    [    0.880685] io scheduler bfq registered
    [    0.888217] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.894804] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.902357] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.915237] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.934148] loop: module loaded
    [    0.938616] megasas: 07.725.01.00-rc1
    [    0.946339] tun: Universal TUN/TAP device driver, 1.6
    [    0.952639] VFIO - User Level meta-driver version: 0.3
    [    0.959069] usbcore: registered new interface driver usb-storage
    [    0.965880] i2c_dev: i2c /dev entries driver
    [    0.972024] sdhci: Secure Digital Host Controller Interface driver
    [    0.978370] sdhci: Copyright(c) Pierre Ossman
    [    0.983053] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.989651] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.996127] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.003458] usbcore: registered new interface driver usbhid
    [    1.009173] usbhid: USB HID core driver
    [    1.014580] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    1.023579] optee: probing for conduit method.
    [    1.028155] optee: revision 4.4 (8f645256efc0dc66)
    [    1.028516] optee: dynamic shared memory is enabled
    [    1.039258] random: crng init done
    [    1.042844] optee: initialized driver
    [    1.048569] Initializing XFRM netlink socket
    [    1.053006] NET: Registered PF_PACKET protocol family
    [    1.058268] Key type dns_resolver registered
    [    1.071642] registered taskstats version 1
    [    1.076021] Loading compiled-in X.509 certificates
    [    1.096927] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)')
    [    1.173616] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.185757] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.192915] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.202184] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.212124] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.221348] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.231742] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.239233] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.245564] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.254860] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.265147] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.274195] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.285665] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.297188] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.307855] printk: console [ttyS2] disabled
    [    1.312653] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3000000) is a 8250
    [    1.321563] printk: console [ttyS2] enabled
    [    1.330058] printk: bootconsole [ns16550a0] disabled
    [    1.346994] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.352110] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.359071] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.364465] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.371442] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.378083] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.384799] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.391237] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.398204] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.404819] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.661631] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.707146] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.719173] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.727275] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.735398] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.748369] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.754640] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.761766] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.768335] pps pps0: new PPS source ptp0
    [    1.772691] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.787050] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.797873] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.809770] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    1.824312] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.829893] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.837706] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.843712] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
    [    1.853156] xhci-hcd xhci-hcd.0.auto: irq 253, io mem 0x31100000
    [    1.860079] hub 1-0:1.0: USB hub found
    [    1.863878] hub 1-0:1.0: 1 port detected
    [    1.869819] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.882728] mmc0: CQHCI version 5.10
    [    1.889345] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    1.896190] pca953x 1-0022: using AI
    [    1.925761] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    1.936064] mmc1: CQHCI version 5.10
    [    1.938182] mmc2: CQHCI version 5.10
    [    1.940054] clk: Disabling unused clocks
    [    1.955891] ALSA device list:
    [    1.958870]   No soundcards found.
    [    1.984017] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    1.984036] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    1.999403] Waiting for root device PARTUUID=b8ea592a-02...
    [    2.004202] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
    [    2.018026] mmc0: Command Queue Engine enabled
    [    2.022494] mmc0: new HS200 MMC card at address 0001
    [    2.025248] mmc2: new high speed SDIO card at address 0001
    [    2.028207] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.039123]  mmcblk0: p1 p2
    [    2.042633] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.048795] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.049213] mmc1: new ultra high speed SDR104 SDXC card at address aaaa
    [    2.054741] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.061057] mmcblk1: mmc1:aaaa SD64G 59.5 GiB
    [    2.073908]  mmcblk1: p1 p2
    [    2.178601] EXT4-fs (mmcblk1p2): recovery complete
    [    2.184657] EXT4-fs (mmcblk1p2): mounted filesystem 5ebcf8d5-7f01-42f7-8ce3-decfba78fec0 r/w with ordered data mode. Quota mode: none.
    [    2.196857] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.206323] devtmpfs: mounted
    [    2.210995] Freeing unused kernel memory: 2496K
    [    2.215781] Run /sbin/init as init process
    [    2.219880]   with arguments:
    [    2.219884]     /sbin/init
    [    2.219887]   with environment:
    [    2.219889]     HOME=/
    [    2.219892]     TERM=linux
    [    2.443701] systemd[1]: System time before build time, advancing clock.
    [    2.495953] NET: Registered PF_INET6 protocol family
    [    2.502091] Segment Routing with IPv6
    [    2.505812] In-situ OAM (IOAM) with IPv6
    [    2.550026] systemd[1]: systemd 255.13^ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -TPM2 -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
    [    2.582002] systemd[1]: Detected architecture arm64.
    [    2.600021] systemd[1]: Hostname set to <am62xxsip-evm>.
    [    2.821858] systemd[1]: Configuration file /usr/lib/systemd/system/ti-apps-launcher.service is marked executable. Please remove executable permission bits. Proceeding anyway.
    [    2.929298] systemd[1]: /usr/lib/systemd/system/bt-enable.service:9: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.040836] systemd[1]: /etc/systemd/system/sync-clocks.service:11: Standard output type syslog is obsolete, automatically updating to journal. Please update your unit file, and consider removing the setting altogether.
    [    3.120856] systemd[1]: Queued start job for default target Graphical Interface.
    [    3.161781] systemd[1]: Created slice Slice /system/getty.
    [    3.185964] systemd[1]: Created slice Slice /system/modprobe.
    [    3.209955] systemd[1]: Created slice Slice /system/serial-getty.
    [    3.233215] systemd[1]: Created slice User and Session Slice.
    [    3.255690] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [    3.279535] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    3.303364] systemd[1]: Expecting device /dev/dri/card1...
    [    3.323239] systemd[1]: Expecting device /dev/ttyS2...
    [    3.339397] systemd[1]: Reached target Path Units.
    [    3.355287] systemd[1]: Reached target Remote File Systems.
    [    3.375250] systemd[1]: Reached target Slice Units.
    [    3.391284] systemd[1]: Reached target Swaps.
    [    3.446191] systemd[1]: Listening on RPCbind Server Activation Socket.
    [    3.467554] systemd[1]: Reached target RPC Port Mapper.
    [    3.494459] systemd[1]: Listening on Process Core Dump Socket.
    [    3.515824] systemd[1]: Listening on initctl Compatibility Named Pipe.
    [    3.540711] systemd[1]: Listening on Journal Audit Socket.
    [    3.564162] systemd[1]: Listening on Journal Socket (/dev/log).
    [    3.588137] systemd[1]: Listening on Journal Socket.
    [    3.608292] systemd[1]: Listening on Network Service Netlink Socket.
    [    3.636773] systemd[1]: Listening on udev Control Socket.
    [    3.660075] systemd[1]: Listening on udev Kernel Socket.
    [    3.684032] systemd[1]: Listening on User Database Manager Socket.
    [    3.739603] systemd[1]: Mounting Huge Pages File System...
    [    3.760274] systemd[1]: Mounting POSIX Message Queue File System...
    [    3.788814] systemd[1]: Mounting Kernel Debug File System...
    [    3.811905] systemd[1]: Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    3.830855] systemd[1]: Mounting Temporary Directory /tmp...
    [    3.854334] systemd[1]: Starting Create List of Static Device Nodes...
    [    3.881901] systemd[1]: Starting Load Kernel Module configfs...
    [    3.905191] systemd[1]: Starting Load Kernel Module drm...
    [    3.933399] systemd[1]: Starting Load Kernel Module fuse...
    [    3.958197] systemd[1]: Starting Start psplash boot splash screen...
    [    3.997610] systemd[1]: Starting RPC Bind...
    [    4.011888] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
    [    4.035234] systemd[1]: Starting Journal Service...
    [    4.040951] fuse: init (API version 7.39)
    [    4.104356] systemd[1]: Starting Load Kernel Modules...
    [    4.115875] systemd[1]: Starting Generate network units from Kernel command line...
    [    4.147753] systemd[1]: Starting Remount Root and Kernel File Systems...
    [    4.184983] systemd[1]: Starting Coldplug All udev Devices...
    [    4.200432] cryptodev: loading out-of-tree module taints kernel.
    [    4.207433] systemd-journald[131]: Collecting audit messages is enabled.
    [    4.223712] cryptodev: driver 1.14 loaded.
    [    4.225995] systemd[1]: Started RPC Bind.
    [    4.256469] systemd[1]: Mounted Huge Pages File System.
    [    4.259485] EXT4-fs (mmcblk1p2): re-mounted 5ebcf8d5-7f01-42f7-8ce3-decfba78fec0 r/w. Quota mode: none.
    [    4.290232] systemd[1]: Started Journal Service.
    [    4.697103] systemd-journald[131]: Received client request to flush runtime journal.
    [    5.002457] audit: type=1334 audit(1728487094.552:2): prog-id=6 op=LOAD
    [    5.009170] audit: type=1334 audit(1728487094.560:3): prog-id=7 op=LOAD
    [    5.267240] audit: type=1334 audit(1728487094.816:4): prog-id=8 op=LOAD
    [    5.315753] audit: type=1334 audit(1728487094.868:5): prog-id=9 op=LOAD
    [    5.367941] audit: type=1334 audit(1728487094.920:6): prog-id=10 op=LOAD
    [    5.374815] audit: type=1334 audit(1728487094.928:7): prog-id=11 op=LOAD
    [    5.381726] audit: type=1334 audit(1728487094.936:8): prog-id=12 op=LOAD
    [    6.143255] audit: type=1334 audit(1749156916.572:9): prog-id=13 op=LOAD
    [    6.450222] dbus-broker-lau[303]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    6.803324] audit: type=1334 audit(1749156917.232:10): prog-id=14 op=LOAD
    [    6.812659] audit: type=1334 audit(1749156917.232:11): prog-id=15 op=LOAD
    [    6.831318] audit: type=1334 audit(1749156917.232:12): prog-id=16 op=LOAD
    [    7.145920] audit: type=1334 audit(1749156917.576:13): prog-id=17 op=LOAD
    [    7.212296] Bluetooth: Core ver 2.22
    [    7.219059] NET: Registered PF_BLUETOOTH protocol family
    [    7.227310] Bluetooth: HCI device and connection manager initialized
    [    7.237053] Bluetooth: HCI socket layer initialized
    [    7.242152] Bluetooth: L2CAP socket layer initialized
    [    7.247326] Bluetooth: SCO socket layer initialized
    [    7.588499] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    7.615582] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    7.622269] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    7.635786] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    7.670175] at24 0-0051: supply vcc not found, using dummy regulator
    [    7.704638] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
    [    7.721831] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    7.730649] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.741659] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.752632] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.761757] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.776254] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.784999] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.810328] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.818924] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.844838] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    7.860701] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.868235] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [    7.869299] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.883290] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [    7.891562] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.903940] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.905555] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    7.911434] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.911467] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.916419] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.951709] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    7.953747] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    7.970408] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    7.971047] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [    7.976803] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:14 UTC (14)
    [    7.981647] remoteproc remoteproc0: 5000000.m4fss is available
    [    7.985983] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    7.986451] systemd-journald[131]: Time jumped backwards, rotating.
    [    8.013850] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.015574] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [    8.028021] remoteproc remoteproc0: powering up 5000000.m4fss
    [    8.038786] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.042682] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55100
    [    8.050323] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.068222] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node m4f-dma-memory@9cb00000
    [    8.075758] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.078232] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    8.078585] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.078838] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    8.087827] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.091697] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
    [    8.111122] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.114291] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
    [    8.127194] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.223832] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    8.247562] platform 78000000.r5f: configured R5F for IPC-only mode
    [    8.256623] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
    [    8.271360] remoteproc remoteproc1: 78000000.r5f is available
    [    8.277422] remoteproc remoteproc1: attaching to 78000000.r5f
    [    8.284298] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
    [    8.285342] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    8.285406] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    8.285415] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    8.286054] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    8.286257] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    8.314617] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.314658] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.334422] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.334468] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.346370] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.385690] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.584578] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    8.591906] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    8.605596] i2c i2c-1: Added multiplexed i2c bus 3
    [    8.629332] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.639037] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.653851] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    8.654704] PVR_K:  190: Device: fd00000.gpu
    [    8.662085] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    8.669118] PVR_K:  190: Read BVNC 33.15.11.3 from HW device registers
    [    8.673726] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    8.679920] PVR_K:  190: RGX Device registered with BVNC 33.15.11.3
    [    8.692329] [drm] Initialized pvr 24.1.6554834 20170530 for fd00000.gpu on minor 1
    [    8.731239] cc33xx_sdio mmc2:0001:2: Using GPIO as IRQ
    [    9.130971] remoteproc remoteproc2: 30074000.pru is available
    [    9.160175] remoteproc remoteproc3: 30078000.pru is available
    [    9.695301] cc33xx_driver cc33xx.5.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
    [    9.730478] cc33xx: ERROR ti-connectivity/cc33xx-conf.bin configuration binary size is wrong, expected 1353 got 1136
    [    9.741323] cc33xx: WARNING falling back to default config
    [   11.282548] cc33xx: ERROR FW is stuck, triggering recovery
    [   12.112071] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
    [   13.295157] cc33xx: WARNING download INI params to FW command sending failed: -5
    [   13.302683] cc33xx: ERROR FW download failed
    [   14.984582] audit: type=1006 audit(21.504:14): pid=1095 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
    [   14.997549] audit: type=1300 audit(21.504:14): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffc033b7a8 a2=1 a3=1 items=0 ppid=1 pid=1095 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd-executor" subj=kernel key=(null)
    [   15.024548] audit: type=1327 audit(21.504:14): proctitle="(systemd)"
    [   15.112267] audit: type=1334 audit(21.632:15): prog-id=18 op=LOAD
    [   15.118463] audit: type=1300 audit(21.632:15): arch=c00000b7 syscall=280 success=yes exit=8 a0=5 a1=ffffee5e8e18 a2=90 a3=0 items=0 ppid=1 pid=1095 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   15.144721] audit: type=1327 audit(21.632:15): proctitle="(systemd)"
    [   15.151288] audit: type=1334 audit(21.632:16): prog-id=18 op=UNLOAD
    [   15.157800] audit: type=1300 audit(21.632:16): arch=c00000b7 syscall=57 success=yes exit=0 a0=8 a1=1 a2=0 a3=ffffad3d0c60 items=0 ppid=1 pid=1095 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="systemd" exe="/usr/lib/systemd/systemd" subj=kernel key=(null)
    [   15.183920] audit: type=1327 audit(21.632:16): proctitle="(systemd)"
    [   15.190502] audit: type=1334 audit(21.632:17): prog-id=19 op=LOAD
    [   16.337162] PVR_K:  675: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
    [   16.352103] PVR_K:  675: Shader binary image 'rgx.sh.33.15.11.3' loaded
    [   20.343362] kauditd_printk_skb: 9 callbacks suppressed
    [   20.343382] audit: type=1334 audit(26.864:23): prog-id=22 op=UNLOAD
    [   20.355230] audit: type=1334 audit(26.864:24): prog-id=21 op=UNLOAD
    [   20.361544] audit: type=1334 audit(26.864:25): prog-id=20 op=UNLOAD
    [   36.051862] audit: type=1334 audit(1749158689.273:26): prog-id=23 op=LOAD
    [   36.247494] audit: type=1334 audit(1749158689.469:27): prog-id=23 op=UNLOAD
  • Hello David,
    You simply can not only copy the binaries from the newer 1.0.0.8 SDK. You must also apply the kernel patch and then re-build and re-install the kernel. Apply the patch as you have done before and then re-install the kernel and the kernel modules.
    The steps to building and installing the kernel and modules are documented here:
    https://software-dl.ti.com/processor-sdk-linux/esd/AM62X/10_01_10_04/exports/docs/linux/Foundational_Components_Kernel_Users_Guide.html
  • Hi Sabeeh.
    Thank you, now wlan0 works after patching, building, etc. Unfortunately, the reset bug still persists. I am testing this on Debian will test on Arago tomorrow, although I am not sure that will make a difference. After streaming video 480p at 30 fps with the following command, I get the same error within 10 minutes.
    command to stream
    gst-launch-1.0 -e \
      v4l2src device=/dev/video0 ! \
        image/jpeg,width=640,height=480,framerate=30/1 ! \
      rtpjpegpay ! \
      udpsink host="192.168.2.1" port="5000" sync=false
    dmesg log
    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    [    0.000000] Linux version 6.6.58-ga7758da17c28-dirty (davidsober@davidsober-AORUS-16X-ASG) (aarch64-oe-linux-gcc (GCC) 13.3.0, GNU ld (GNU Binutils) 2.42.0.20240723) #1 SMP PREEMPT Tue Jun 17 13:27:31 PDT 2025
    [    0.000000] KASLR disabled due to lack of seed
    [    0.000000] Machine model: Texas Instruments AM625 SK
    [    0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '')
    [    0.000000] printk: bootconsole [ns16550a0] enabled
    [    0.000000] efi: UEFI not found.
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000093600000, size 128 MiB
    [    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x0000000093600000..0x000000009b5fffff (131072 KiB) map reusable linux,cma
    [    0.000000] OF: reserved mem: 0x0000000080000000..0x000000008007ffff (512 KiB) nomap non-reusable tfa@80000000
    [    0.000000] OF: reserved mem: 0x000000009b700000..0x000000009bffffff (9216 KiB) nomap non-reusable framebuffer@9b700000
    [    0.000000] OF: reserved mem: 0x000000009c700000..0x000000009c7fffff (1024 KiB) map non-reusable ramoops@9c700000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009c800000, size 3 MiB
    [    0.000000] OF: reserved mem: initialized node ipc-memories@9c800000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009c800000..0x000000009cafffff (3072 KiB) nomap non-reusable ipc-memories@9c800000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cb00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-dma-memory@9cb00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009cb00000..0x000000009cbfffff (1024 KiB) nomap non-reusable m4f-dma-memory@9cb00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009cc00000, size 14 MiB
    [    0.000000] OF: reserved mem: initialized node m4f-memory@9cc00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009cc00000..0x000000009d9fffff (14336 KiB) nomap non-reusable m4f-memory@9cc00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009da00000, size 1 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-dma-memory@9da00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009da00000..0x000000009dafffff (1024 KiB) nomap non-reusable r5f-dma-memory@9da00000
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009db00000, size 12 MiB
    [    0.000000] OF: reserved mem: initialized node r5f-memory@9db00000, compatible id shared-dma-pool
    [    0.000000] OF: reserved mem: 0x000000009db00000..0x000000009e6fffff (12288 KiB) nomap non-reusable r5f-memory@9db00000
    [    0.000000] OF: reserved mem: 0x000000009e800000..0x000000009fffffff (24576 KiB) nomap non-reusable optee@9e800000
    [    0.000000] Zone ranges:
    [    0.000000]   DMA      [mem 0x0000000080000000-0x000000009bffffff]
    [    0.000000]   DMA32    empty
    [    0.000000]   Normal   empty
    [    0.000000] Movable zone start for each node
    [    0.000000] Early memory node ranges
    [    0.000000]   node   0: [mem 0x0000000080000000-0x000000008007ffff]
    [    0.000000]   node   0: [mem 0x0000000080080000-0x000000009b6fffff]
    [    0.000000]   node   0: [mem 0x000000009b700000-0x000000009bffffff]
    [    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000009bffffff]
    [    0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
    [    0.000000] psci: probing for conduit method from DT.
    [    0.000000] psci: PSCIv1.1 detected in firmware.
    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    [    0.000000] psci: Trusted OS migration not required
    [    0.000000] psci: SMC Calling Convention v1.5
    [    0.000000] percpu: Embedded 20 pages/cpu s43176 r8192 d30552 u81920
    [    0.000000] pcpu-alloc: s43176 r8192 d30552 u81920 alloc=20*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Detected VIPT I-cache on CPU0
    [    0.000000] CPU features: detected: GIC system register CPU interface
    [    0.000000] CPU features: detected: ARM erratum 845719
    [    0.000000] alternatives: applying boot alternatives
    [    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=spi-nand0:512k(ospi_nand.tiboot3),2m(ospi_nand.tispl),4m(ospi_nand.u-boot),256k(ospi_nand.env),256k(ospi_nand.env.backup),98048k@32m(ospi_nand.rootfs),256k@130816k(ospi_nand.phypattern) root=PARTUUID=ea0a48c4-02 rw rootfstype=ext4 rootwait
    [    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 112896
    [    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
    [    0.000000] software IO TLB: area num 4.
    [    0.000000] software IO TLB: mapped [mem 0x000000008beee000-0x000000008feee000] (64MB)
    [    0.000000] Memory: 220008K/458752K available (12480K kernel code, 1272K rwdata, 4184K rodata, 2496K init, 528K bss, 107672K reserved, 131072K cma-reserved)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu:     RCU event tracing is enabled.
    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
    [    0.000000]     Trampoline variant of Tasks RCU enabled.
    [    0.000000]     Tracing variant of Tasks RCU enabled.
    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    [    0.000000] GICv3: 256 SPIs implemented
    [    0.000000] GICv3: 0 Extended SPIs implemented
    [    0.000000] Root IRQ handler: gic_handle_irq
    [    0.000000] GICv3: GICv3 features: 16 PPIs
    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000
    [    0.000000] ITS [mem 0x01820000-0x0182ffff]
    [    0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS
    [    0.000000] ITS@0x0000000001820000: Devices Table too large, reduce ids 20->19
    [    0.000000] ITS@0x0000000001820000: allocated 524288 Devices @80c00000 (flat, esz 8, psz 64K, shr 0)
    [    0.000000] ITS: using cache flushing for cmd queue
    [    0.000000] GICv3: using LPI property table @0x0000000080440000
    [    0.000000] GIC: using cache flushing for LPI property table
    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x0000000080450000
    [    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
    [    0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0x3ffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
    [    0.000001] sched_clock: 58 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
    [    0.008666] Console: colour dummy device 80x25
    [    0.013289] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000)
    [    0.023979] pid_max: default: 32768 minimum: 301
    [    0.028802] LSM: initializing lsm=capability,selinux,integrity
    [    0.034801] SELinux:  Initializing.
    [    0.038531] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.046014] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
    [    0.056359] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.063730] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
    [    0.071693] rcu: Hierarchical SRCU implementation.
    [    0.076609] rcu:     Max phase no-delay instances is 1000.
    [    0.082311] Platform MSI: msi-controller@1820000 domain created
    [    0.088733] PCI/MSI: /bus@f0000/interrupt-controller@1800000/msi-controller@1820000 domain created
    [    0.098221] EFI services will not be available.
    [    0.103260] smp: Bringing up secondary CPUs ...
    [    0.108664] Detected VIPT I-cache on CPU1
    [    0.108783] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000
    [    0.108802] GICv3: CPU1: using allocated LPI pending table @0x0000000080460000
    [    0.108872] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    [    0.109778] Detected VIPT I-cache on CPU2
    [    0.109859] GICv3: CPU2: found redistributor 2 region 0:0x00000000018c0000
    [    0.109879] GICv3: CPU2: using allocated LPI pending table @0x0000000080470000
    [    0.109922] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
    [    0.110696] Detected VIPT I-cache on CPU3
    [    0.110758] GICv3: CPU3: found redistributor 3 region 0:0x00000000018e0000
    [    0.110775] GICv3: CPU3: using allocated LPI pending table @0x0000000080480000
    [    0.110809] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
    [    0.110892] smp: Brought up 1 node, 4 CPUs
    [    0.190637] SMP: Total of 4 processors activated.
    [    0.195452] CPU features: detected: 32-bit EL0 Support
    [    0.200726] CPU features: detected: CRC32 instructions
    [    0.206058] CPU: All CPU(s) started at EL2
    [    0.210261] alternatives: applying system-wide alternatives
    [    0.217734] devtmpfs: initialized
    [    0.230792] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
    [    0.240821] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
    [    0.253696] pinctrl core: initialized pinctrl subsystem
    [    0.259775] DMI not present or invalid.
    [    0.264555] NET: Registered PF_NETLINK/PF_ROUTE protocol family
    [    0.271716] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
    [    0.279073] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
    [    0.287099] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
    [    0.295291] audit: initializing netlink subsys (disabled)
    [    0.301092] audit: type=2000 audit(0.184:1): state=initialized audit_enabled=0 res=1
    [    0.301702] thermal_sys: Registered thermal governor 'step_wise'
    [    0.309028] thermal_sys: Registered thermal governor 'power_allocator'
    [    0.315239] cpuidle: using governor menu
    [    0.326141] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
    [    0.333191] ASID allocator initialised with 65536 entries
    [    0.345114] /bus@f0000/interrupt-controller@1800000: Fixed dependency cycle(s) with /bus@f0000/interrupt-controller@1800000
    [    0.356645] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.368677] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.378725] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    0.390799] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.405816] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    0.417995] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.429163] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    0.442089] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    0.452044] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.462037] /bus@f0000/pinctrl@a40000: Fixed dependency cycle(s) with /bus@f0000/pinctrl@a40000/cpsw-cpts
    [    0.473614] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    0.482873] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    0.493805] Modules: 27488 pages in range for non-PLT usage
    [    0.493818] Modules: 519008 pages in range for PLT usage
    [    0.500580] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
    [    0.513007] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
    [    0.519417] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
    [    0.526357] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
    [    0.532765] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
    [    0.539704] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
    [    0.546113] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
    [    0.553052] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
    [    0.561214] k3-chipinfo 43000014.chipid: Family:AM62X rev:SR1.0 JTAGID[0x0bb7e02f] Detected
    [    0.570724] iommu: Default domain type: Translated
    [    0.575656] iommu: DMA domain TLB invalidation policy: strict mode
    [    0.582359] SCSI subsystem initialized
    [    0.586428] libata version 3.00 loaded.
    [    0.586654] usbcore: registered new interface driver usbfs
    [    0.592302] usbcore: registered new interface driver hub
    [    0.597772] usbcore: registered new device driver usb
    [    0.603575] pps_core: LinuxPPS API ver. 1 registered
    [    0.608664] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.618021] PTP clock support registered
    [    0.622294] EDAC MC: Ver: 3.0.0
    [    0.626133] scmi_core: SCMI protocol bus registered
    [    0.631556] FPGA manager framework
    [    0.635163] Advanced Linux Sound Architecture Driver Initialized.
    [    0.642552] vgaarb: loaded
    [    0.645825] clocksource: Switched to clocksource arch_sys_counter
    [    0.652447] VFS: Disk quotas dquot_6.6.0
    [    0.656522] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
    [    0.671337] NET: Registered PF_INET protocol family
    [    0.676550] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
    [    0.684819] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
    [    0.693475] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
    [    0.701425] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
    [    0.709376] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
    [    0.716924] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.723579] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.730286] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
    [    0.737605] NET: Registered PF_UNIX/PF_LOCAL protocol family
    [    0.743964] RPC: Registered named UNIX socket transport module.
    [    0.750041] RPC: Registered udp transport module.
    [    0.754854] RPC: Registered tcp transport module.
    [    0.759662] RPC: Registered tcp-with-tls transport module.
    [    0.765270] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.771872] NET: Registered PF_XDP protocol family
    [    0.776799] PCI: CLS 0 bytes, default 64
    [    0.782681] Initialise system trusted keyrings
    [    0.787577] workingset: timestamp_bits=46 max_order=17 bucket_order=0
    [    0.794597] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.800932] NFS: Registering the id_resolver key type
    [    0.806160] Key type id_resolver registered
    [    0.810438] Key type id_legacy registered
    [    0.814555] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
    [    0.821421] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
    [    0.863349] Key type asymmetric registered
    [    0.867562] Asymmetric key parser 'x509' registered
    [    0.872625] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
    [    0.880422] io scheduler mq-deadline registered
    [    0.885064] io scheduler kyber registered
    [    0.889206] io scheduler bfq registered
    [    0.897322] pinctrl-single 4084000.pinctrl: 34 pins, size 136
    [    0.904022] pinctrl-single f4000.pinctrl: 171 pins, size 684
    [    0.911760] pinctrl-single a40000.pinctrl: 512 pins, size 2048
    [    0.925464] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
    [    0.946255] loop: module loaded
    [    0.951041] megasas: 07.725.01.00-rc1
    [    0.959387] tun: Universal TUN/TAP device driver, 1.6
    [    0.965917] VFIO - User Level meta-driver version: 0.3
    [    0.972546] usbcore: registered new interface driver usb-storage
    [    0.979451] i2c_dev: i2c /dev entries driver
    [    0.985804] sdhci: Secure Digital Host Controller Interface driver
    [    0.992181] sdhci: Copyright(c) Pierre Ossman
    [    0.996910] sdhci-pltfm: SDHCI platform and OF driver helper
    [    1.003630] ledtrig-cpu: registered to indicate activity on CPUs
    [    1.010158] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
    [    1.017636] usbcore: registered new interface driver usbhid
    [    1.023349] usbhid: USB HID core driver
    [    1.029016] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
    [    1.038147] optee: probing for conduit method.
    [    1.042745] optee: revision 4.4 (8f645256efc0dc66)
    [    1.043167] optee: dynamic shared memory is enabled
    [    1.054132] random: crng init done
    [    1.057735] optee: initialized driver
    [    1.063859] Initializing XFRM netlink socket
    [    1.068335] NET: Registered PF_PACKET protocol family
    [    1.073610] Key type dns_resolver registered
    [    1.087695] registered taskstats version 1
    [    1.092150] Loading compiled-in X.509 certificates
    [    1.114352] ti-sci 44043000.system-controller: ABI: 4.0 (firmware rev 0x000a '10.1.8--v10.01.08 (Fiery Fox)')
    [    1.196879] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.209068] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
    [    1.216515] /connector-hdmi: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.225827] /bus@f0000/dss@30200000: Fixed dependency cycle(s) with /bus@f0000/i2c@20010000/bridge-hdmi@3b
    [    1.235779] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /connector-hdmi
    [    1.245014] /bus@f0000/i2c@20010000/bridge-hdmi@3b: Fixed dependency cycle(s) with /bus@f0000/dss@30200000
    [    1.255510] omap_i2c 20010000.i2c: bus 1 rev0.12 at 100 kHz
    [    1.262840] omap_i2c 20020000.i2c: bus 2 rev0.12 at 400 kHz
    [    1.268887] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
    [    1.278211] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
    [    1.288283] simple-framebuffer 9b700000.framebuffer: framebuffer at 0x9b700000, 0x8ca000 bytes
    [    1.297140] simple-framebuffer 9b700000.framebuffer: format=a8r8g8b8, mode=1920x1200x32, linelength=7680
    [    1.322782] Console: switching to colour frame buffer device 240x75
    [    1.343729] simple-framebuffer 9b700000.framebuffer: fb0: simplefb registered!
    [    1.352668] ti-udma 485c0100.dma-controller: Number of rings: 82
    [    1.362100] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
    [    1.373941] ti-udma 485c0000.dma-controller: Number of rings: 150
    [    1.386124] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
    [    1.397091] printk: console [ttyS2] disabled
    [    1.401990] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 238, base_baud = 3000000) is a 8250
    [    1.410975] printk: console [ttyS2] enabled
    [    1.419462] printk: bootconsole [ns16550a0] disabled
    [    1.446219] spi-nor spi0.0: s28hs512t (65536 Kbytes)
    [    1.451351] 7 fixed-partitions partitions found on MTD device fc40000.spi.0
    [    1.458314] Creating 7 MTD partitions on "fc40000.spi.0":
    [    1.463708] 0x000000000000-0x000000080000 : "ospi.tiboot3"
    [    1.470934] 0x000000080000-0x000000280000 : "ospi.tispl"
    [    1.477678] 0x000000280000-0x000000680000 : "ospi.u-boot"
    [    1.484652] 0x000000680000-0x0000006c0000 : "ospi.env"
    [    1.491237] 0x0000006c0000-0x000000700000 : "ospi.env.backup"
    [    1.498418] 0x000000800000-0x000003fc0000 : "ospi.rootfs"
    [    1.505244] 0x000003fc0000-0x000004000000 : "ospi.phypattern"
    [    1.762510] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
    [    1.805835] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
    [    1.818187] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
    [    1.826296] davinci_mdio 8000f00.mdio: phy[1]: device 8000f00.mdio:01, driver TI DP83867
    [    1.834430] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
    [    1.847458] am65-cpsw-nuss 8000000.ethernet: Use random MAC address
    [    1.853738] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
    [    1.860867] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
    [    1.867518] pps pps0: new PPS source ptp0
    [    1.871913] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:1
    [    1.887383] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
    [    1.898774] /bus@f0000/i2c@20000000/tps6598x@3f/connector: Fixed dependency cycle(s) with /bus@f0000/dwc3-usb@f900000/usb@31000000
    [    1.910716] /bus@f0000/dwc3-usb@f900000/usb@31000000: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/tps6598x@3f/connector
    [    1.928533] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.934106] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.941932] xhci-hcd xhci-hcd.0.auto: USB3 root hub has no ports
    [    1.947940] xhci-hcd xhci-hcd.0.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020000010
    [    1.957398] xhci-hcd xhci-hcd.0.auto: irq 253, io mem 0x31100000
    [    1.964586] hub 1-0:1.0: USB hub found
    [    1.968403] hub 1-0:1.0: 1 port detected
    [    1.974670] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 1200000 KHz, changing to: 1250000 KHz
    [    1.987916] mmc0: CQHCI version 5.10
    [    1.995573] pca953x 1-0022: supply vcc not found, using dummy regulator
    [    2.002408] pca953x 1-0022: using AI
    [    2.030434] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
    [    2.044696] mmc1: CQHCI version 5.10
    [    2.044987] clk: Disabling unused clocks
    [    2.049498] mmc2: CQHCI version 5.10
    [    2.061133] ALSA device list:
    [    2.064209]   No soundcards found.
    [    2.094406] mmc1: SDHCI controller on fa00000.mmc [fa00000.mmc] using ADMA 64-bit
    [    2.096433] mmc2: SDHCI controller on fa20000.mmc [fa20000.mmc] using ADMA 64-bit
    [    2.110066] Waiting for root device PARTUUID=ea0a48c4-02...
    [    2.114512] sdhci-am654 fa20000.mmc: card claims to support voltages below defined range
    [    2.136216] mmc2: new high speed SDIO card at address 0001
    [    2.145894] mmc0: Command Queue Engine enabled
    [    2.150372] mmc0: new HS200 MMC card at address 0001
    [    2.156275] mmcblk0: mmc0:0001 G1M15L 29.6 GiB
    [    2.162748]  mmcblk0: p1 p2
    [    2.166416] mmcblk0boot0: mmc0:0001 G1M15L 31.5 MiB
    [    2.172741] mmcblk0boot1: mmc0:0001 G1M15L 31.5 MiB
    [    2.178855] mmcblk0rpmb: mmc0:0001 G1M15L 4.00 MiB, chardev (239:0)
    [    2.205801] mmc1: new ultra high speed SDR104 SDHC card at address aaaa
    [    2.213409] mmcblk1: mmc1:aaaa SL32G 29.7 GiB
    [    2.223144]  mmcblk1: p1 p2
    [    2.229862] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    2.376955] EXT4-fs (mmcblk1p2): recovery complete
    [    2.397254] EXT4-fs (mmcblk1p2): mounted filesystem fb4932ea-803d-4a42-9cd3-da60b6de5c8e r/w with ordered data mode. Quota mode: none.
    [    2.409483] VFS: Mounted root (ext4 filesystem) on device 179:98.
    [    2.421623] devtmpfs: mounted
    [    2.426649] Freeing unused kernel memory: 2496K
    [    2.431313] Run /sbin/init as init process
    [    2.435411]   with arguments:
    [    2.435414]     /sbin/init
    [    2.435417]   with environment:
    [    2.435420]     HOME=/
    [    2.435423]     TERM=linux
    [    2.721049] systemd[1]: System time advanced to timestamp on /usr/lib/clock-epoch: Tue 2025-06-17 23:47:41 UTC
    [    2.848813] NET: Registered PF_INET6 protocol family
    [    2.855198] Segment Routing with IPv6
    [    2.858970] In-situ OAM (IOAM) with IPv6
    [    2.965966] systemd[1]: systemd 257~rc3-1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
    [    2.999736] systemd[1]: Detected architecture arm64.
    [    3.034160] systemd[1]: Hostname set to <am62xxsip-evm>.
    [    3.094812] systemd[1]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
    [    3.410233] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
    [    4.113260] systemd[1]: Queued start job for default target graphical.target.
    [    4.172533] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
    [    4.200561] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
    [    4.228633] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
    [    4.255751] systemd[1]: Created slice user.slice - User and Session Slice.
    [    4.278522] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
    [    4.310323] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
    [    4.338266] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
    [    4.357709] systemd[1]: Expecting device dev-ttyS2.device - /dev/ttyS2...
    [    4.382185] systemd[1]: Reached target paths.target - Path Units.
    [    4.406034] systemd[1]: Reached target remote-fs.target - Remote File Systems.
    [    4.429975] systemd[1]: Reached target slices.target - Slice Units.
    [    4.454005] systemd[1]: Reached target swap.target - Swaps.
    [    4.481225] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
    [    4.506720] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
    [    4.531487] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
    [    4.554827] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
    [    4.578750] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
    [    4.603007] systemd[1]: Listening on systemd-networkd.socket - Network Service Netlink Socket.
    [    4.626131] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [    4.639985] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [    4.654247] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
    [    4.678538] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
    [    4.710132] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
    [    4.740546] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
    [    4.792935] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
    [    4.825779] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
    [    4.835355] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
    [    4.864738] systemd[1]: Mounting tmp.mount - Temporary Directory /tmp...
    [    4.911572] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
    [    4.949630] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
    [    4.981786] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
    [    4.997035] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
    [    5.036332] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
    [    5.069391] systemd[1]: Starting nftables.service - nftables...
    [    5.090723] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
    [    5.143385] systemd[1]: Starting systemd-journald.service - Journal Service...
    [    5.180538] fuse: init (API version 7.39)
    [    5.186142] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
    [    5.201772] systemd[1]: Starting systemd-network-generator.service - Generate network units from Kernel command line...
    [    5.230611] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [    5.259252] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
    [    5.290644] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
    [    5.319468] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
    [    5.382057] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
    [    5.411371] systemd-journald[128]: Collecting audit messages is enabled.
    [    5.423740] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
    [    5.451844] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
    [    5.479700] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
    [    5.503451] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
    [    5.527801] systemd[1]: Started systemd-journald.service - Journal Service.
    [    5.551139] audit: type=1130 audit(1750204064.796:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.610366] audit: type=1130 audit(1750204064.856:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.646916] audit: type=1130 audit(1750204064.892:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.666915] audit: type=1131 audit(1750204064.892:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@configfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.706355] audit: type=1130 audit(1750204064.952:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.725967] audit: type=1131 audit(1750204064.952:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@drm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.762471] audit: type=1130 audit(1750204065.008:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.782657] audit: type=1131 audit(1750204065.008:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@efi_pstore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.818387] audit: type=1130 audit(1750204065.064:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    5.838129] audit: type=1131 audit(1750204065.064:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=modprobe@fuse comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [    6.265765] systemd-journald[128]: Received client request to flush runtime journal.
    [    6.277416] systemd-journald[128]: File /var/log/journal/fe90a065fd6b49ac81ea7e4068e318de/system.journal corrupted or uncleanly shut down, renaming and replacing.
    [    8.428618] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [    8.476250] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [    8.483163] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
    [    8.497110] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [    8.506002] cfg80211: failed to load regulatory.db
    [    8.648279] at24 0-0051: supply vcc not found, using dummy regulator
    [    8.680983] omap-mailbox 29000000.mailbox: omap mailbox rev 0x66fc9100
    [    8.681078] at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
    [    8.779430] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.788025] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.799856] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.814127] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.815952] tps6598x 0-003f: Unable to find the interrupt, switching to polling
    [    8.843750] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.854898] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.856506] k3-m4-rproc 5000000.m4fss: assigned reserved memory node m4f-dma-memory@9cb00000
    [    8.875285] k3-m4-rproc 5000000.m4fss: configured M4 for remoteproc mode
    [    8.885931] k3-m4-rproc 5000000.m4fss: local reset is deasserted for device
    [    8.903026] rtc-ti-k3 2b1f0000.rtc: registered as rtc0
    [    8.903638] remoteproc remoteproc0: 5000000.m4fss is available
    [    8.905100] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.905142] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.925767] rtc-ti-k3 2b1f0000.rtc: setting system clock to 1970-01-01T00:00:15 UTC (15)
    [    8.929218] systemd-journald[128]: Time jumped backwards, rotating.
    [    8.937285] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.960907] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    8.976262] remoteproc remoteproc0: powering up 5000000.m4fss
    [    8.984130] remoteproc remoteproc0: Booting fw image am62-mcu-m4f0_0-fw, size 55100
    [    8.994682] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    8.998182] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
    [    9.003304] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.019169] rproc-virtio rproc-virtio.2.auto: assigned reserved memory node m4f-dma-memory@9cb00000
    [    9.031115] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    9.038971] virtio_rpmsg_bus virtio0: rpmsg host is online
    [    9.039754] virtio_rpmsg_bus virtio0: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.040016] virtio_rpmsg_bus virtio0: creating channel rpmsg_chrdev addr 0xe
    [    9.041935] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.048922] rproc-virtio rproc-virtio.2.auto: registered virtio0 (type 7)
    [    9.054085] platform 78000000.r5f: configured R5F for IPC-only mode
    [    9.059264] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    9.059305] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.065916] remoteproc remoteproc0: remote processor 5000000.m4fss is now up
    [    9.071198] platform 78000000.r5f: assigned reserved memory node r5f-dma-memory@9da00000
    [    9.118088] remoteproc remoteproc1: 78000000.r5f is available
    [    9.127810] remoteproc remoteproc1: attaching to 78000000.r5f
    [    9.140214] rproc-virtio rproc-virtio.3.auto: assigned reserved memory node r5f-dma-memory@9da00000
    [    9.142272] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    9.150467] virtio_rpmsg_bus virtio1: rpmsg host is online
    [    9.150982] virtio_rpmsg_bus virtio1: creating channel ti.ipc4.ping-pong addr 0xd
    [    9.151219] virtio_rpmsg_bus virtio1: creating channel rpmsg_chrdev addr 0xe
    [    9.157807] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.163419] rproc-virtio rproc-virtio.3.auto: registered virtio1 (type 7)
    [    9.172989] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    9.177894] remoteproc remoteproc1: remote processor 78000000.r5f is now attached
    [    9.209187] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.220413] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    9.229052] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.267327] sii902x 1-003b: supply iovcc not found, using dummy regulator
    [    9.274816] sii902x 1-003b: supply cvcc12 not found, using dummy regulator
    [    9.287044] i2c i2c-1: Added multiplexed i2c bus 3
    [    9.294539] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@0/ports
    [    9.303327] OF: graph: no port node found in /bus@f0000/dss@30200000/oldi-txes/oldi@1/ports
    [    9.313929] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
    [    9.322050] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    9.334423] tidss 30200000.dss: [drm] Cannot find any crtc or sizes
    [    9.615465] mc: Linux media interface: v0.10
    [    9.627249] remoteproc remoteproc2: 30074000.pru is available
    [    9.641313] remoteproc remoteproc3: 30078000.pru is available
    [    9.678655] videodev: Linux video capture interface: v2.00
    [    9.785794] usb 1-1: 3:1: cannot get freq at ep 0x84
    [    9.797605] cc33xx_sdio mmc2:0001:2: Using GPIO as IRQ
    [    9.963260] usbcore: registered new interface driver snd-usb-audio
    [    9.970412] usb 1-1: Found UVC 1.00 device Arducam_8mp (0c45:6366)
    [   10.017369] usbcore: registered new interface driver uvcvideo
    [   10.084197] cc33xx_driver cc33xx.5.auto: Direct firmware load for ti-connectivity/cc33xx-nvs.bin failed with error -2
    [   10.710221] kauditd_printk_skb: 44 callbacks suppressed
    [   10.710240] audit: type=1130 audit(17.284:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   10.794547] audit: type=1130 audit(17.368:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.027211] audit: type=1130 audit(17.600:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=resize_rootfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.067329] audit: type=1130 audit(17.640:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.435475] audit: type=1334 audit(18.008:52): prog-id=28 op=LOAD
    [   11.441836] audit: type=1334 audit(18.012:53): prog-id=29 op=LOAD
    [   11.448105] audit: type=1334 audit(18.020:54): prog-id=30 op=LOAD
    [   11.731284] audit: type=1130 audit(18.304:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   11.911368] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=POLL)
    [   11.920883] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
    [   11.976603] am65-cpsw-nuss 8000000.ethernet eth1: PHY [8000f00.mdio:01] driver [TI DP83867] (irq=POLL)
    [   11.986122] am65-cpsw-nuss 8000000.ethernet eth1: configuring for phy/rgmii-rxid link mode
    [   12.039109] audit: type=1130 audit(18.612:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   12.075229] audit: type=1130 audit(18.648:57): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   15.737698] kauditd_printk_skb: 107 callbacks suppressed
    [   15.737717] audit: type=1131 audit(22.308:103): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=weston comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
    [   16.082567] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control rx/tx
    [   16.676653] audit: type=1100 audit(23.248:104): pid=326 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:authentication grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
    [   16.698706] audit: type=1101 audit(23.248:105): pid=326 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:accounting grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
    [   16.720357] audit: type=1103 audit(23.272:106): pid=326 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
    [   16.741689] audit: type=1006 audit(23.272:107): pid=326 uid=0 subj=kernel old-auid=4294967295 auid=0 tty=ttyS2 old-ses=4294967295 ses=2 res=1
    [   16.754519] audit: type=1300 audit(23.272:107): arch=c00000b7 syscall=64 success=yes exit=1 a0=4 a1=ffffcaf87020 a2=1 a3=1 items=0 ppid=1 pid=326 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=ttyS2 ses=2 comm="login" exe="/usr/bin/login" subj=kernel key=(null)
    [   16.779413] audit: type=1327 audit(23.272:107): proctitle=2F62696E2F6C6F67696E002D2D
    [   16.871728] audit: type=1105 audit(23.444:108): pid=326 uid=0 auid=0 ses=2 subj=kernel msg='op=PAM:session_open grantors=pam_selinux,pam_loginuid,pam_selinux,pam_env,pam_env,pam_limits,pam_mail,pam_keyinit,pam_permit,pam_umask,pam_unix,pam_wtmpdb,pam_systemd acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
    [   16.903003] audit: type=1110 audit(23.444:109): pid=326 uid=0 auid=0 ses=2 subj=kernel msg='op=PAM:setcred grantors=pam_permit acct="root" exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=/dev/ttyS2 res=success'
    [   16.922848] audit: type=1112 audit(23.444:110): pid=326 uid=0 auid=0 ses=2 subj=kernel msg='op=login id=0 exe="/usr/bin/login" hostname=am62xxsip-evm addr=? terminal=ttyS2 res=success'
    [   17.468640] wlan0: authenticate with f8:fb:90:13:6c:52
    [   17.509774] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [   17.518305] wlan0: authenticated
    [   17.525904] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [   17.533310] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x411 status=0 aid=1)
    [   17.545711] cc33xx: HE Disabled
    [   17.549632] wlan0: associated
    [   21.577139] wlan0: deauthenticated from f8:fb:90:13:6c:52 (Reason: 15=4WAY_HANDSHAKE_TIMEOUT)
    [   22.046470] kauditd_printk_skb: 1 callbacks suppressed
    [   22.046487] audit: type=1131 audit(28.620:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   24.131666] audit: type=1130 audit(30.704:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   26.174643] wlan0: authenticate with f8:fb:90:13:6c:52
    [   26.215357] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [   26.226422] wlan0: authenticated
    [   26.233903] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [   26.240820] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x411 status=0 aid=1)
    [   26.253158] cc33xx: HE Disabled
    [   26.257071] wlan0: associated
    [   26.306828] cc33xx: Association complete.
    [   34.141717] audit: type=1131 audit(40.712:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   41.764617] audit: type=1131 audit(48.336:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   41.866077] audit: type=1334 audit(48.440:116): prog-id=28 op=UNLOAD
    [   46.398331] wlan0: deauthenticated from f8:fb:90:13:6c:52 (Reason: 3=DEAUTH_LEAVING)
    [   46.581681] audit: type=1130 audit(1750206159.319:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=e2scrub_all comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   46.601541] audit: type=1131 audit(1750206159.319:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=e2scrub_all comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   46.742273] audit: type=1130 audit(1750206159.483:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=dpkg-db-backup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   46.762161] audit: type=1131 audit(1750206159.483:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=dpkg-db-backup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   51.034527] wlan0: authenticate with f8:fb:90:13:6c:52
    [   51.075227] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [   51.116440] wlan0: send auth to f8:fb:90:13:6c:52 (try 2/3)
    [   51.246642] wlan0: send auth to f8:fb:90:13:6c:52 (try 3/3)
    [   52.081837] wlan0: authentication with f8:fb:90:13:6c:52 timed out
    [   62.449462] audit: type=1130 audit(1750206175.187:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   72.465591] audit: type=1131 audit(1750206185.203:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   75.004135] wlan0: authenticate with f8:fb:90:13:6c:52
    [   75.044751] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [   75.053213] wlan0: authenticated
    [   75.057886] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [   75.065025] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x411 status=0 aid=1)
    [   75.077518] cc33xx: HE Disabled
    [   75.081434] wlan0: associated
    [   75.142891] cc33xx: Association complete.
    [   75.719811] audit: type=1130 audit(1750206188.459:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [   85.737819] audit: type=1131 audit(1750206198.475:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  179.282687] cc33xx: ERROR INTERROGATE command failed
    [  179.282694] cc33xx: CC33xx driver attempting recovery
    [  179.292747] cc33xx: WARNING acx roaming statistics failed: -5
    [  179.298576] wlan0: Connection to AP f8:fb:90:13:6c:52 lost
    [  179.304909] wlan0: failed to remove key (0, f8:fb:90:13:6c:52) from hardware (-11)
    [  179.313293] wlan0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-11)
    [  181.659012] ieee80211 phy0: Hardware restart was requested
    [  181.659179] ------------[ cut here ]------------
    [  181.669135] WARNING: CPU: 3 PID: 304 at drivers/net/wireless/ti/cc33xx/scan.c:360 cc33xx_scan+0x238/0x264 [cc33xx]
    [  181.679538] Modules linked in: cc33xx mac80211 libarc4 uvcvideo videobuf2_vmalloc uvc videobuf2_memops videobuf2_v4l2 snd_usb_audio videobuf2_common snd_hwdep snd_soc_hdmi_codec rpmsg_ctrl videodev snd_usbmidi_lib cc33xx_sdio snd_rawmidi rpmsg_char pru_rproc mc irq_pruss_intc snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils display_connector k3_j72xx_bandgap ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc rti_wdt tps6598x tidss snd_soc_davinci_mcasp mcrc64 typec snd_soc_ti_udma sii902x pruss sa2ul drm_dma_helper snd_soc_ti_edma snd_soc_tlv320aic3x_i2c omap_hwspinlock snd_soc_ti_sdma snd_soc_tlv320aic3x drm_kms_helper omap_mailbox at24 cfg80211 rfkill fuse drm drm_panel_orientation_quirks backlight ip_tables x_tables ipv6
    [  181.744473] CPU: 3 PID: 304 Comm: wpa_supplicant Not tainted 6.6.58-ga7758da17c28-dirty #1
    [  181.752728] Hardware name: Texas Instruments AM625 SK (DT)
    [  181.758201] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [  181.767060] pc : cc33xx_scan+0x238/0x264 [cc33xx]
    [  181.771815] lr : cc33xx_scan+0x9c/0x264 [cc33xx]
    [  181.776459] sp : ffff80008216b650
    [  181.779765] x29: ffff80008216b660 x28: 0000000000000096 x27: ffff800079986d60
    [  181.786893] x26: ffff000008604c00 x25: 0000000000000000 x24: ffff000008d31de8
    [  181.794018] x23: ffff000008d319c0 x22: 000000000000013c x21: ffff000008604c70
    [  181.803048] x20: ffff000008cd0c00 x19: ffff00000841a060 x18: 0000000000000000
    [  181.810172] x17: 8a4be11043e11405 x16: 48510a8096c22150 x15: 0000000000000001
    [  181.817302] x14: d0a5a735a3535385 x13: 0000000000000158 x12: 0000000000000002
    [  181.824426] x11: 0000000000000000 x10: 00000000000009b0 x9 : 0000000000000000
    [  181.831550] x8 : ffff000008cd0e00 x7 : 0000000000000000 x6 : 000000000000003f
    [  181.838672] x5 : ffff000008cd0c00 x4 : ffff80008216b5d0 x3 : 0000000000000000
    [  181.845796] x2 : 0000000000000002 x1 : 00000000000000ff x0 : 00000000000000ff
    [  181.852924] Call trace:
    [  181.855365]  cc33xx_scan+0x238/0x264 [cc33xx]
    [  181.859766]  cc33xx_op_hw_scan+0xcc/0xd4 [cc33xx]
    [  181.864489]  __ieee80211_start_scan+0x39c/0x5b8 [mac80211]
    [  181.870120]  ieee80211_request_scan+0x38/0x60 [mac80211]
    [  181.875502]  ieee80211_scan+0x84/0xf8 [mac80211]
    [  181.880224]  cfg80211_scan+0x17c/0x1b4 [cfg80211]
    [  181.886954]  nl80211_trigger_scan+0x468/0x614 [cfg80211]
    [  181.892363]  genl_family_rcv_msg_doit+0xd4/0x140
    [  181.896983]  genl_rcv_msg+0x210/0x288
    [  181.900636]  netlink_rcv_skb+0x60/0x130
    [  181.904462]  genl_rcv+0x38/0x50
    [  181.907595]  netlink_unicast+0x300/0x36c
    [  181.911509]  netlink_sendmsg+0x1bc/0x438
    [  181.915422]  __sock_sendmsg+0x54/0x60
    [  181.919082]  ____sys_sendmsg+0x24c/0x268
    [  181.923004]  ___sys_sendmsg+0xb0/0x108
    [  181.926746]  __sys_sendmsg+0x88/0xe8
    [  181.930312]  __arm64_sys_sendmsg+0x24/0x30
    [  181.934398]  invoke_syscall+0x48/0x114
    [  181.938140]  el0_svc_common.constprop.0+0xc0/0xe0
    [  181.942834]  do_el0_svc+0x1c/0x28
    [  181.946141]  el0_svc+0x2c/0x84
    [  181.949189]  el0t_64_sync_handler+0x120/0x12c
    [  181.953538]  el0t_64_sync+0x190/0x194
    [  181.957201] ---[ end trace 0000000000000000 ]---
    [  181.961960] ------------[ cut here ]------------
    [  181.966666] ieee80211_restart_work called with hardware scan in progress
    [  181.973541] WARNING: CPU: 2 PID: 73 at net/mac80211/main.c:352 ieee80211_restart_work+0x168/0x170 [mac80211]
    [  181.985445] Modules linked in: cc33xx mac80211 libarc4 uvcvideo videobuf2_vmalloc uvc videobuf2_memops videobuf2_v4l2 snd_usb_audio videobuf2_common snd_hwdep snd_soc_hdmi_codec rpmsg_ctrl videodev snd_usbmidi_lib cc33xx_sdio snd_rawmidi rpmsg_char pru_rproc mc irq_pruss_intc snd_soc_simple_card crct10dif_ce snd_soc_simple_card_utils display_connector k3_j72xx_bandgap ti_k3_r5_remoteproc rtc_ti_k3 ti_k3_m4_remoteproc rti_wdt tps6598x tidss snd_soc_davinci_mcasp mcrc64 typec snd_soc_ti_udma sii902x pruss sa2ul drm_dma_helper snd_soc_ti_edma snd_soc_tlv320aic3x_i2c omap_hwspinlock snd_soc_ti_sdma snd_soc_tlv320aic3x drm_kms_helper omap_mailbox at24 cfg80211 rfkill fuse drm drm_panel_orientation_quirks backlight ip_tables x_tables ipv6
    [  182.050382] CPU: 2 PID: 73 Comm: kworker/2:2 Tainted: G        W          6.6.58-ga7758da17c28-dirty #1
    [  182.059765] Hardware name: Texas Instruments AM625 SK (DT)
    [  182.065244] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  182.072190] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [  182.079141] pc : ieee80211_restart_work+0x168/0x170 [mac80211]
    [  182.085095] lr : ieee80211_restart_work+0x168/0x170 [mac80211]
    [  182.092896] sp : ffff8000819ebd80
    [  182.096200] x29: ffff8000819ebd80 x28: 0000000000000000 x27: 0000000000000000
    [  182.103327] x26: 0000000000000000 x25: ffff0000017deac0 x24: ffff000000412605
    [  182.110454] x23: ffff000008418900 x22: ffff000008419f50 x21: ffff000008418750
    [  182.117579] x20: ffff000008419f50 x19: ffff0000017dea80 x18: 0000000000000006
    [  182.124703] x17: 0000000000000000 x16: 0000000000000000 x15: ffff8000819eb7a0
    [  182.131827] x14: 0000000000000000 x13: 0000000000000092 x12: 0000000000000002
    [  182.138951] x11: 0000000000000000 x10: 00000000000009b0 x9 : ffff8000819ebbf0
    [  182.146077] x8 : ffff000001401850 x7 : ffff00001359e280 x6 : 0000000000000000
    [  182.153201] x5 : 0000000000000000 x4 : 0000000000000002 x3 : 0000000000000008
    [  182.160325] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff000001400e40
    [  182.167450] Call trace:
    [  182.169890]  ieee80211_restart_work+0x168/0x170 [mac80211]
    [  182.175523]  process_one_work+0x138/0x248
    [  182.179545]  worker_thread+0x320/0x438
    [  182.183290]  kthread+0x110/0x114
    [  182.186514]  ret_from_fork+0x10/0x20
    [  182.190084] ---[ end trace 0000000000000000 ]---
    [  188.998012] audit: type=1130 audit(1750206301.739:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=wtmpdb-rotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  189.018587] audit: type=1131 audit(1750206301.739:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=wtmpdb-rotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  191.663556] wlan0: authenticate with f8:fb:90:13:6c:52
    [  191.704152] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [  191.768862] wlan0: authenticated
    [  191.774723] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [  191.781779] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x411 status=0 aid=1)
    [  191.794296] cc33xx: HE Disabled
    [  191.798232] wlan0: associated
    [  194.282895] wlan0: deauthenticating from f8:fb:90:13:6c:52 by local choice (Reason: 3=DEAUTH_LEAVING)
    [  194.515885] audit: type=1130 audit(1750206307.259:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  203.059715] wlan0: authenticate with f8:fb:90:13:6c:52
    [  203.100577] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [  203.109321] wlan0: authenticated
    [  203.114844] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [  203.124476] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x411 status=0 aid=1)
    [  203.136936] cc33xx: HE Disabled
    [  203.140875] wlan0: associated
    [  203.196186] cc33xx: Association complete.
    [  204.526340] audit: type=1131 audit(1750206317.267:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  275.830538] cc33xx: Beacon loss detected. roles:0x1
    [  277.984719] cc33xx: Beacon loss detected. roles:0x1
    [  279.713452] cc33xx: Beacon loss detected. roles:0x1
    [  280.818636] cc33xx: Connection loss work (role_id: 0).
    [  280.823814] wlan0: Connection to AP f8:fb:90:13:6c:52 lost
    [  281.330626] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
    [  281.453919] cc33xx: Beacon loss detected. roles:0x1
    [  281.842621] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
    [  282.354626] cc33xx: WARNING Unable to flush all TX buffers, timed out (timeout 500 ms
    [  297.453049] audit: type=1130 audit(1750206410.195:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  307.469961] audit: type=1131 audit(1750206420.211:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  487.327317] audit: type=1130 audit(1750206600.067:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=apt-daily-upgrade comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    [  487.347510] audit: type=1131 audit(1750206600.067:132): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=kernel msg='unit=apt-daily-upgrade comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
    How do you get the wlan0 interface to appear?
    I write a file named uEnv.txt containing "name_overlays=ti/k3-am625-sk-m2-cc3301.dtbo" in BOOT partition. But do you do this differently?
    Here was my missing step: sudo make ARCH=arm64 INSTALL_MOD_PATH=/media/$USER/rootfs modules_install
    For future readers' clarity, here are the steps I have used so far.
    1. Export variables.
    • export SDK_INSTALL_DIR=/home/davidsober/Desktop/5-30-SDK
    • export CROSS_COMPILE_64="${SDK_INSTALL_DIR}/linux-devkit/sysroots/x86_64-arago-linux/usr/bin/aarch64-oe-linux/aarch64-oe-linux-"
    • export SYSROOT_64="${SDK_INSTALL_DIR}/linux-devkit/sysroots/aarch64-oe-linux"
    • export CC_64="${CROSS_COMPILE_64}gcc --sysroot=${SYSROOT_64}"
    • export CROSS_COMPILE_32="${SDK_INSTALL_DIR}/k3r5-devkit/sysroots/x86_64-arago-linux/usr/bin/arm-oe-eabi/arm-oe-eabi-"
    2. Go to kernel tree root and clean
    • cd /home/davidsober/Desktop/5-30-SDK/board-support/ti-linux-kernel-6.6.58+git-ti
    • make ARCH=arm64 CROSS_COMPILE="$CROSS_COMPILE_64" distclean
    3. Apply patch and run defconfig
    • patch -p1 < ~/Downloads/drivers-cc33xx-update-to-1.0.0.8.patch
    • make ARCH=arm64 CROSS_COMPILE="$CROSS_COMPILE_64" defconfig ti_arm64_prune.config
    4. Build Kernel, device tree binaries, and modules. Copy them to the target.
    • make -j$(nproc) ARCH=arm64 CROSS_COMPILE="$CROSS_COMPILE_64" Image dtbs modules
    • sudo cp arch/arm64/boot/Image \
      arch/arm64/boot/dts/ti/k3-am625-sk.dtb \
      /media/$USER/rootfs/boot/
    • sudo cp arch/arm64/boot/dts/ti/k3-am625-sk.dtb \
      /media/$USER/rootfs/boot/dtb/ti/
    • sudo rm /media/$USER/rootfs/boot/k3-am625-sk.dtb
    5. Install modules to target.
    • sudo make ARCH=arm64 INSTALL_MOD_PATH=/media/$USER/rootfs modules_install
    6. Copy firmware from cc33xx_SDK to the target firmware directory.
    • cd /home/davidsober/Desktop/cc33xx_SDK/cc33xx_linux_package_1_0_0_8/cc33xx/cc33xx_rootfs/lib/firmware/ti-connectivity
    • cp * /media/davidsober/rootfs/lib/firmware/ti-connectivity
    Thanks for taking a look at this. I know this was not the desired result but I am sure we will get to the bottom of this eventually. Hopefully this issue is at least known to the developers before they release SDK 11.1 for am62sip in July.
  • Hi Sabeeh,
    Just checking in and quick update. I tested on Arago as well and got a very similar result.
    On Debian the error I get is:
    On Arago it is:
    [  374.321803] cc33xx: WARNING CONFIGURE command NOK
    [  374.326539] cc33xx: WARNING failed to set group addr table: -5
    [  374.332401] cc33xx: CC33xx driver attempting recovery
    So a command fails because the CC3351 becomes unresponsive. This happens after streaming video for a short duration of time. Usually withing 5 minutes but I have seen streams go as far as 40 minutes before the error occurs.
    The only difference is I used wpa to connect to an ap instead of nmcli.
    The process was slightly different for Arago. I started the stream after patching and updating the firmware. I used the following command to connect to the AP am62sip board.
    wpa_passphrase "TI-AP-BOARD2" "YourSecurePasswordHere" \ | wpa_supplicant -B -i wlan0 -D nl80211 -c /dev/stdin
    After 1:30 minutes, the stream froze, but I did not get an immediate kernel error. Just a freeze. Then I ran the above command to reconnect, and then the error log began on dmesg. I am starting to think there is a buffer issue on the cc3351 firmware. Here is a snippet of the error log on dmesg.
    [   56.817840] audit: type=1334 audit(1750286582.215:19): prog-id=20 op=LOAD
    [   87.455775] wlan0: authenticate with f8:fb:90:13:6c:52
    [   87.497293] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [   87.505485] wlan0: authenticated
    [   87.511984] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [   87.522326] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x11 status=0 aid=1)
    [   87.534614] cc33xx: HE Disabled
    [   87.539222] wlan0: associated
    [   87.617777] cc33xx: Association complete.
    [   87.740395] kauditd_printk_skb: 5 callbacks suppressed
    [   87.740414] audit: type=1334 audit(1750286613.233:21): prog-id=21 op=LOAD
    [   87.752512] audit: type=1334 audit(1750286613.237:22): prog-id=22 op=LOAD
    [   87.759412] audit: type=1334 audit(1750286613.245:23): prog-id=23 op=LOAD
    [  100.632033] audit: type=1701 audit(1750286626.125:24): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=1127 comm="ti-apps-launche" exe="/usr/bin/ti-apps-launcher" sig=6 res=1
    [  100.692685] audit: type=1334 audit(1750286626.185:25): prog-id=24 op=LOAD
    [  100.699584] audit: type=1334 audit(1750286626.189:26): prog-id=25 op=LOAD
    [  100.706429] audit: type=1334 audit(1750286626.197:27): prog-id=26 op=LOAD
    [  102.856059] audit: type=1334 audit(1750286628.349:28): prog-id=26 op=UNLOAD
    [  102.863099] audit: type=1334 audit(1750286628.349:29): prog-id=25 op=UNLOAD
    [  102.870175] audit: type=1334 audit(1750286628.349:30): prog-id=24 op=UNLOAD
    [  118.000151] audit: type=1334 audit(1750286643.493:31): prog-id=23 op=UNLOAD
    [  118.007210] audit: type=1334 audit(1750286643.493:32): prog-id=22 op=UNLOAD
    [  118.014203] audit: type=1334 audit(1750286643.493:33): prog-id=21 op=UNLOAD
    [  372.345032] audit: type=1334 audit(1750286897.835:34): prog-id=27 op=LOAD
    [  372.353000] audit: type=1334 audit(1750286897.843:35): prog-id=28 op=LOAD
    [  372.365276] audit: type=1334 audit(1750286897.855:36): prog-id=29 op=LOAD
    [  374.332419] wlan0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-11)
    [  374.365805] wlan0: Connection to AP f8:fb:90:13:6c:52 lost
    [  374.371532] wlan0: failed to remove key (0, f8:fb:90:13:6c:52) from hardware (-11)
    [  376.698114] ieee80211 phy0: Hardware restart was requested
    [  376.698234] ------------[ cut here ]------------
    [  376.708227] WARNING: CPU: 2 PID: 1178 at drivers/net/wireless/ti/cc33xx/scan.c:360 cc33xx_scan+0x238/0x264 [cc33xx]
    [  376.718709] Modules linked in: cc33xx mac80211 libarc4 snd_soc_hdmi_codec rpmsg_ctrl rpmsg_char irq_pruss_intc pru_rproc uvcvideo crct10dif_ce videobuf2_vmalloc snd_usb_audio snd_soc_simple_card uvc snd_soc_simple_card_utils videobuf2_memops snd_hwdep videobuf2_v4l2 snd_usbmidi_lib videobuf2_common snd_rawmidi videodev display_connector cc33xx_sdio mc k3_j72xx_bandgap ti_k3_r5_remoteproc rtc_ti_k3 rti_wdt ti_k3_m4_remoteproc snd_soc_davinci_mcasp tidss snd_soc_ti_udma sii902x sa2ul snd_soc_ti_edma drm_dma_helper mcrc64 pruss snd_soc_ti_sdma tps6598x drm_kms_helper omap_hwspinlock omap_mailbox typec at24 snd_soc_tlv320aic3x_i2c snd_soc_tlv320aic3x overlay cfg80211 bluetooth ecdh_generic ecc rfkill fuse drm drm_panel_orientation_quirks backlight ipv6
    [  376.785025] CPU: 2 PID: 1178 Comm: wpa_supplicant Not tainted 6.6.58-ga7758da17c28-dirty #1
    [  376.793359] Hardware name: Texas Instruments AM625 SK (DT)
    [  376.798831] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [  376.805778] pc : cc33xx_scan+0x238/0x264 [cc33xx]
    [  376.810511] lr : cc33xx_scan+0x9c/0x264 [cc33xx]
    [  376.815146] sp : ffff8000817eb650
    [  376.818449] x29: ffff8000817eb660 x28: 000000000000000d x27: ffff8000799f9d60
    [  376.825573] x26: ffff000003a0d800 x25: 0000000000000000 x24: ffff00000b4c5de8
    [  376.832697] x23: ffff00000b4c59c0 x22: 000000000000013c x21: ffff000003a0d870
    [  376.839820] x20: ffff000003dd3200 x19: ffff00000b532060 x18: 0000000000000000
    [  376.846943] x17: 0000000000000000 x16: 0000000000000000 x15: 0000000000000000
    [  376.854066] x14: 0000000000000000 x13: 0000000000000086 x12: 0000000000000002
    [  376.861189] x11: 0000000000000000 x10: 00000000000009b0 x9 : 0000000000000000
    [  376.868312] x8 : ffff000003dd3400 x7 : 0000000000000000 x6 : 000000000000003f
    [  376.875434] x5 : ffff000003dd3200 x4 : ffff8000817eb5d0 x3 : 0000000000000000
    [  376.882557] x2 : 0000000000000002 x1 : 00000000000000ff x0 : 00000000000000ff
    [  376.889681] Call trace:
    [  376.892117]  cc33xx_scan+0x238/0x264 [cc33xx]
    [  376.896494]  cc33xx_op_hw_scan+0xcc/0xd4 [cc33xx]
    [  376.901214]  __ieee80211_start_scan+0x39c/0x5b8 [mac80211]
    [  376.906831]  ieee80211_request_scan+0x38/0x60 [mac80211]
    [  376.912207]  ieee80211_scan+0x84/0xf8 [mac80211]
    [  376.916891]  cfg80211_scan+0x17c/0x1b4 [cfg80211]
    [  376.921697]  nl80211_trigger_scan+0x468/0x614 [cfg80211]
    [  376.927059]  genl_family_rcv_msg_doit+0xd4/0x140
    [  376.931674]  genl_rcv_msg+0x210/0x288
    [  376.935327]  netlink_rcv_skb+0x60/0x130
    [  376.939153]  genl_rcv+0x38/0x50
    [  376.942285]  netlink_unicast+0x300/0x36c
    [  376.946198]  netlink_sendmsg+0x1bc/0x438
    [  376.950110]  __sock_sendmsg+0x54/0x60
    [  376.953768]  ____sys_sendmsg+0x24c/0x268
    [  376.957683]  ___sys_sendmsg+0xb0/0x108
    [  376.961423]  __sys_sendmsg+0x88/0xe8
    [  376.964987]  __arm64_sys_sendmsg+0x24/0x30
    [  376.969072]  invoke_syscall+0x48/0x114
    [  376.972816]  el0_svc_common.constprop.0+0xc0/0xe0
    [  376.977510]  do_el0_svc+0x1c/0x28
    [  376.980816]  el0_svc+0x2c/0x84
    [  376.983864]  el0t_64_sync_handler+0x120/0x12c
    [  376.988211]  el0t_64_sync+0x190/0x194
    [  376.991866] ---[ end trace 0000000000000000 ]---
    [  376.997497] ------------[ cut here ]------------
    [  377.002162] ieee80211_restart_work called with hardware scan in progress
    [  377.008966] WARNING: CPU: 1 PID: 66 at net/mac80211/main.c:352 ieee80211_restart_work+0x168/0x170 [mac80211]
    [  377.018949] Modules linked in: cc33xx mac80211 libarc4 snd_soc_hdmi_codec rpmsg_ctrl rpmsg_char irq_pruss_intc pru_rproc uvcvideo crct10dif_ce videobuf2_vmalloc snd_usb_audio snd_soc_simple_card uvc snd_soc_simple_card_utils videobuf2_memops snd_hwdep videobuf2_v4l2 snd_usbmidi_lib videobuf2_common snd_rawmidi videodev display_connector cc33xx_sdio mc k3_j72xx_bandgap ti_k3_r5_remoteproc rtc_ti_k3 rti_wdt ti_k3_m4_remoteproc snd_soc_davinci_mcasp tidss snd_soc_ti_udma sii902x sa2ul snd_soc_ti_edma drm_dma_helper mcrc64 pruss snd_soc_ti_sdma tps6598x drm_kms_helper omap_hwspinlock omap_mailbox typec at24 snd_soc_tlv320aic3x_i2c snd_soc_tlv320aic3x overlay cfg80211 bluetooth ecdh_generic ecc rfkill fuse drm drm_panel_orientation_quirks backlight ipv6
    [  377.085270] CPU: 1 PID: 66 Comm: kworker/1:2 Tainted: G        W          6.6.58-ga7758da17c28-dirty #1
    [  377.094648] Hardware name: Texas Instruments AM625 SK (DT)
    [  377.100121] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [  377.107023] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [  377.113971] pc : ieee80211_restart_work+0x168/0x170 [mac80211]
    [  377.119874] lr : ieee80211_restart_work+0x168/0x170 [mac80211]
    [  377.125773] sp : ffff80008198bd80
    [  377.129074] x29: ffff80008198bd80 x28: 0000000000000000 x27: 0000000000000000
    [  377.136198] x26: 0000000000000000 x25: ffff000001761100 x24: ffff000000412405
    [  377.143321] x23: ffff00000b530900 x22: ffff00000b531f50 x21: ffff00000b530750
    [  377.150445] x20: ffff00000b531f50 x19: ffff0000017610c0 x18: 0000000000000006
    [  377.157568] x17: ffff7fff92474000 x16: ffff800080008000 x15: ffff80008198b7a0
    [  377.164691] x14: 0000000000000000 x13: ffff8000812ef178 x12: 00000000000006cc
    [  377.171815] x11: 00000000000002b6 x10: 00000057c77ad800 x9 : 00000057c77af449
    [  377.178938] x8 : ffff00001358a280 x7 : 0000000000000000 x6 : 0000000000000002
    [  377.186061] x5 : 000000067d067682 x4 : 0000000000000400 x3 : ffff00001358ac68
    [  377.193183] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff0000005f9c80
    [  377.200308] Call trace:
    [  377.202745]  ieee80211_restart_work+0x168/0x170 [mac80211]
    [  377.208298]  process_one_work+0x138/0x248
    [  377.212308]  worker_thread+0x320/0x438
    [  377.216049]  kthread+0x110/0x114
    [  377.219270]  ret_from_fork+0x10/0x20
    [  377.222839] ---[ end trace 0000000000000000 ]---
    [  382.445146] wlan0: authenticate with f8:fb:90:13:6c:52
    [  382.492686] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [  382.515760] wlan0: authenticate with f8:fb:90:13:6c:52
    [  382.520997] wlan0: send auth to f8:fb:90:13:6c:52 (try 1/3)
    [  382.549494] wlan0: authenticated
    [  382.553810] wlan0: associate with f8:fb:90:13:6c:52 (try 1/3)
    [  382.561010] wlan0: RX AssocResp from f8:fb:90:13:6c:52 (capab=0x11 status=0 aid=1)
    [  382.573390] cc33xx: HE Disabled
    [  382.578018] wlan0: associated
    [  382.627491] cc33xx: Association complete.
    [  438.182015] audit: type=1334 audit(1750286963.675:37): prog-id=29 op=UNLOAD
    [  438.189046] audit: type=1334 audit(1750286963.675:38): prog-id=28 op=UNLOAD
    [  438.196053] audit: type=1334 audit(1750286963.675:39): prog-id=27 op=UNLOAD
    [  443.182788] audit: type=1334 audit(1750286968.675:40): prog-id=30 op=LOAD
    [  443.189674] audit: type=1334 audit(1750286968.683:41): prog-id=31 op=LOAD
    [  443.196716] audit: type=1334 audit(1750286968.687:42): prog-id=32 op=LOAD
    [  473.441853] audit: type=1334 audit(1750286998.935:43): prog-id=32 op=UNLOAD
    [  473.448918] audit: type=1334 audit(1750286998.935:44): prog-id=31 op=UNLOAD
    [  473.455921] audit: type=1334 audit(1750286998.935:45): prog-id=30 op=UNLOAD
    [  491.353238] audit: type=1334 audit(1750287016.843:46): prog-id=33 op=LOAD
    [  491.360174] audit: type=1334 audit(1750287016.855:47): prog-id=34 op=LOAD
    [  491.367027] audit: type=1334 audit(1750287016.859:48): prog-id=35 op=LOAD
  • What resolution and framerate were you using during video streaming testing? I tested lower resolutions and frame rates and got better results but I wonder what you used for your testing.
    Also did you use MJPEG or YUY2 format or other?
    Thank you and best regards
  • Hi Sabeeh,
    Just checking in. Can you please share your format for video when streaming and resolution plus frames per second chosen?
  • Hello Sabeeh,
    Just checking in. Was wondering if you had any time to review this issue.
    Thanks.
  • Hi David,
    Glad you were able to update the driver and firmware. Let me try to find out those resolution and framerate details for you.
  • Hi David,
    We used a raw sensor in the project with 2MP at 30FPS. We also tested 2MP USB camera with MPEG encoding at 30FPS. In both cases we encoded the stream using H264.
  • It would also be helpful to collect FW logs so that we can understand if there is a bug within the CC33xx-firmware.
  • Hi Sabeeh,
    Thanks for taking the time to review this.
    - Which sensor did you use? We used many different sensors but need IMX219 to work for the product.
    - when you saw "raw sensor" this means csi correct?
    - We will try H264 encoding with the stream.
    - For FW logs are we able to collect them with just the m.2 cc3351 connected to am62sip or do we need to follow your guide here?: https://e2e.ti.com/support/wireless-connectivity/wi-fi-group/wifi/f/wi-fi-forum/1401313/cc33xx-software-cc33xx-software-cc3301-custom-board-error-while-rebooting-collecting-firmware-logs?
    We are going to follow the guide as well and we have the Beaglebone.
  • Also for the FW logs you are looking for us to provide a .pcap or .pcapng file right?
    - additionally I worry the logs on the beaglebone board will be different than am62sip because they would have different firmware. Will make sure they are the same. But this is a concern.
  • Hi Sabeeh,
    I tried streaming on the newest OS release by TI, and the issue is still present. seems worse (happens sooner than 10x release)
    Streaming 480p at 30fps resulted in the same bug on both RT and non RT armbian releases
    Here are the logs for the RT release (tisdk-debian-trixie-rt-am62xxsip-evm-11.01-Armbian-25.08.img)
    I will get FW logs asap.
    [  427.879876] wlan0: associated
    [  427.952043] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by bc:9a:8e:ac:3b:d4
    [  427.973662] cc33xx: Association complete.
    [ 1218.427541] wlan0: deauthenticating from bc:9a:8e:ac:3b:d4 by local choice (Reason: 3=DEAUTH_LEAVING)
    [ 1367.485075] wlan0: regulatory prevented using AP config, downgraded
    [ 1367.522593] wlan0: authenticate with bc:9a:8e:ac:3b:dc (local address=f8:fb:90:13:6d:56)
    [ 1367.522616] wlan0: send auth to bc:9a:8e:ac:3b:dc (try 1/3)
    [ 1368.537413] wlan0: send auth to bc:9a:8e:ac:3b:dc (try 2/3)
    [ 1369.497256] wlan0: send auth to bc:9a:8e:ac:3b:dc (try 3/3)
    [ 1370.521094] wlan0: authentication with bc:9a:8e:ac:3b:dc timed out
    [ 1370.888390] wlan0: regulatory prevented using AP config, downgraded
    [ 1370.919601] wlan0: authenticate with bc:9a:8e:ac:3b:d8 (local address=f8:fb:90:13:6d:56)
    [ 1370.919622] wlan0: send auth to bc:9a:8e:ac:3b:d8 (try 1/3)
    [ 1371.544947] wlan0: send auth to bc:9a:8e:ac:3b:d8 (try 2/3)
    [ 1372.504787] wlan0: send auth to bc:9a:8e:ac:3b:d8 (try 3/3)
    [ 1373.528603] wlan0: authentication with bc:9a:8e:ac:3b:d8 timed out
    [ 1374.162339] wlan0: authenticate with bc:9a:8e:ac:3b:d4 (local address=f8:fb:90:13:6d:56)
    [ 1374.162367] wlan0: send auth to bc:9a:8e:ac:3b:d4 (try 1/3)
    [ 1374.168276] wlan0: authenticated
    [ 1374.170587] wlan0: associate with bc:9a:8e:ac:3b:d4 (try 1/3)
    [ 1374.189381] wlan0: associate with bc:9a:8e:ac:3b:d4 (try 2/3)
    [ 1374.261287] wlan0: associate with bc:9a:8e:ac:3b:d4 (try 3/3)
    [ 1374.295976] wlan0: association with bc:9a:8e:ac:3b:d4 timed out
    [ 1378.033329] wlan0: regulatory prevented using AP config, downgraded
    [ 1378.071897] wlan0: authenticate with bc:9a:8e:ac:3b:dc (local address=f8:fb:90:13:6d:56)
    [ 1378.071925] wlan0: send auth to bc:9a:8e:ac:3b:dc (try 1/3)
    [ 1379.543643] wlan0: send auth to bc:9a:8e:ac:3b:dc (try 2/3)
    [ 1380.503496] wlan0: send auth to bc:9a:8e:ac:3b:dc (try 3/3)
    [ 1381.527318] wlan0: authentication with bc:9a:8e:ac:3b:dc timed out
    [ 1428.689414] am65-cpsw-nuss 8000000.ethernet end1: Link is Up - 1Gbps/Full - flow control rx/tx
    [ 1779.439971] wlan0: authenticate with f8:fb:90:14:da:bc (local address=f8:fb:90:13:6d:56)
    [ 1779.440000] wlan0: send auth to f8:fb:90:14:da:bc (try 1/3)
    [ 1779.447807] wlan0: authenticated
    [ 1779.448828] wlan0: associate with f8:fb:90:14:da:bc (try 1/3)
    [ 1779.454954] wlan0: RX AssocResp from f8:fb:90:14:da:bc (capab=0x11 status=0 aid=1)
    [ 1779.459553] cc33xx: HE Disabled
    [ 1779.461284] wlan0: associated
    [ 1779.530822] cc33xx: Association complete.
    [ 1868.975719] cc33xx: ERROR INTERROGATE command failed
    [ 1868.975724] cc33xx: CC33xx driver attempting recovery
    [ 1868.975739] cc33xx: WARNING acx roaming statistics failed: -5
    [ 1868.975832] wlan0: Connection to AP f8:fb:90:14:da:bc lost
    [ 1869.038715] wlan0: failed to remove key (0, f8:fb:90:14:da:bc) from hardware (-11)
    [ 1869.039118] wlan0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-11)
    [ 1871.258639] ieee80211 phy0: Hardware restart was requested
    [ 1871.258787] ------------[ cut here ]------------
    [ 1871.258795] WARNING: CPU: 0 PID: 925 at drivers/net/wireless/ti/cc33xx/scan.c:519 cc33xx_scan+0x234/0x26c [cc33xx]
    [ 1871.258844] Modules linked in: cc33xx mac80211 libarc4 cfg80211 rfkill pru_rproc irq_pruss_intc uvcvideo videobuf2_vmalloc uvc crct10dif_ce snd_soc_simple_card videobuf2_v4l2 snd_soc_simple_card_utils videobuf2_memops snd_usb_audio videobuf2_common snd_hwdep videodev snd_usbmidi_lib snd_rawmidi mc pvrsrvkm(O) cc33xx_sdio k3_j72xx_bandgap rtc_ti_k3 rti_wdt sa2ul authenc snd_soc_tlv320aic3x_i2c crypto_null tps6598x snd_soc_tlv320aic3x mcrc64 pruss typec at24 omap_hwspinlock fuse ipv6
    [ 1871.258958] CPU: 0 UID: 0 PID: 925 Comm: wpa_supplicant Tainted: G           O       6.12.35-current-rt-k3 #1
    [ 1871.258968] Tainted: [O]=OOT_MODULE
    [ 1871.258972] Hardware name: Texas Instruments AM6254xxl SK (DT)
    [ 1871.258976] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [ 1871.258983] pc : cc33xx_scan+0x234/0x26c [cc33xx]
    [ 1871.259006] lr : cc33xx_scan+0x94/0x26c [cc33xx]
    [ 1871.259024] sp : ffff0000104d76a0
    [ 1871.259027] x29: ffff0000104d76b0 x28: 0000000000000001 x27: ffff000008dc89a0
    [ 1871.259036] x26: ffff00000b3aa242 x25: 0000000000000000 x24: ffff00000b3aa278
    [ 1871.259045] x23: ffff00000b3a9de8 x22: 000000000000013c x21: ffff00000b343870
    [ 1871.259053] x20: ffff00000be0f000 x19: ffff000008dca4e0 x18: 0000000000000001
    [ 1871.259062] x17: 0000000000000004 x16: 0000000000000001 x15: 000007c4755ba260
    [ 1871.259070] x14: ffff00000b0b1f00 x13: ffff800080cec6b0 x12: 0000000000000001
    [ 1871.259078] x11: 000001b3afb4db6a x10: 0000000000000a00 x9 : 0000000000000000
    [ 1871.259086] x8 : ffff00000be0f200 x7 : 0000000000000000 x6 : 000000000000003f
    [ 1871.259095] x5 : 0000000000000040 x4 : 0000000000000000 x3 : 0000000000000004
    [ 1871.259103] x2 : 0000000000000002 x1 : 00000000000000ff x0 : 00000000000000ff
    [ 1871.259112] Call trace:
    [ 1871.259115]  cc33xx_scan+0x234/0x26c [cc33xx]
    [ 1871.259136]  cc33xx_op_hw_scan+0xc4/0xcc [cc33xx]
    [ 1871.259154]  __ieee80211_start_scan+0x3e8/0x5fc [mac80211]
    [ 1871.259334]  ieee80211_request_scan+0xc/0x14 [mac80211]
    [ 1871.259424]  ieee80211_scan+0x88/0xcc [mac80211]
    [ 1871.259514]  cfg80211_scan+0x144/0x178 [cfg80211]
    [ 1871.259664]  nl80211_trigger_scan+0x390/0x68c [cfg80211]
    [ 1871.259739]  genl_family_rcv_msg_doit+0xac/0x10c
    [ 1871.259758]  genl_rcv_msg+0x1bc/0x264
    [ 1871.259765]  netlink_rcv_skb+0x38/0xf0
    [ 1871.259771]  genl_rcv+0x34/0x48
    [ 1871.259777]  netlink_unicast+0x1fc/0x320
    [ 1871.259784]  netlink_sendmsg+0x184/0x390
    [ 1871.259790]  __sock_sendmsg+0x4c/0x58
    [ 1871.259802]  ____sys_sendmsg+0x220/0x238
    [ 1871.259809]  ___sys_sendmsg+0x6c/0xa8
    [ 1871.259817]  __sys_sendmsg+0x54/0x9c
    [ 1871.259826]  __arm64_sys_sendmsg+0x20/0x28
    [ 1871.259834]  el0_svc_common.constprop.0+0x58/0x128
    [ 1871.259845]  do_el0_svc+0x1c/0x24
    [ 1871.259851]  el0_svc+0x24/0xf0
    [ 1871.259864]  el0t_64_sync_handler+0x134/0x150
    [ 1871.259870]  el0t_64_sync+0x14c/0x150
    [ 1871.259878] ---[ end trace 0000000000000000 ]---
    [ 1871.261051] ------------[ cut here ]------------
    [ 1871.261069] ieee80211_restart_work called with hardware scan in progress
    [ 1871.261188] WARNING: CPU: 2 PID: 85 at net/mac80211/main.c:477 ieee80211_restart_work+0x168/0x170 [mac80211]
    [ 1871.261387] Modules linked in: cc33xx mac80211 libarc4 cfg80211 rfkill pru_rproc irq_pruss_intc uvcvideo videobuf2_vmalloc uvc crct10dif_ce snd_soc_simple_card videobuf2_v4l2 snd_soc_simple_card_utils videobuf2_memops snd_usb_audio videobuf2_common snd_hwdep videodev snd_usbmidi_lib snd_rawmidi mc pvrsrvkm(O) cc33xx_sdio k3_j72xx_bandgap rtc_ti_k3 rti_wdt sa2ul authenc snd_soc_tlv320aic3x_i2c crypto_null tps6598x snd_soc_tlv320aic3x mcrc64 pruss typec at24 omap_hwspinlock fuse ipv6
    [ 1871.261498] CPU: 2 UID: 0 PID: 85 Comm: kworker/2:2 Tainted: G        W  O       6.12.35-current-rt-k3 #1
    [ 1871.261513] Tainted: [W]=WARN, [O]=OOT_MODULE
    [ 1871.261517] Hardware name: Texas Instruments AM6254xxl SK (DT)
    [ 1871.261522] Workqueue: events_freezable ieee80211_restart_work [mac80211]
    [ 1871.261619] pstate: 80000005 (Nzcv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--)
    [ 1871.261628] pc : ieee80211_restart_work+0x168/0x170 [mac80211]
    [ 1871.261715] lr : ieee80211_restart_work+0x168/0x170 [mac80211]
    [ 1871.261805] sp : ffff0000049d7d70
    [ 1871.261808] x29: ffff0000049d7d70 x28: 0000000000000000 x27: ffff80008159c380
    [ 1871.261817] x26: 0000000000000000 x25: 0000000000000000 x24: ffff000008dc89a0
    [ 1871.261826] x23: ffff000008dc8b68 x22: ffff000008dca368 x21: ffff000001c1c600
    [ 1871.261834] x20: ffff000008dca368 x19: ffff000008dc89a0 x18: fffffffffffec6a0
    [ 1871.261843] x17: ffff7fff9ed0a000 x16: ffff00001ff73980 x15: fffffffffffec6e8
    [ 1871.261852] x14: ffff8000814778d8 x13: ffff800081477958 x12: 00000000000007a4
    [ 1871.261860] x11: 000000000000028c x10: ffff8000814cf958 x9 : ffff800081477958
    [ 1871.261869] x8 : 00000000ffffefff x7 : ffff8000814cf958 x6 : 0000000000000000
    [ 1871.261877] x5 : ffff00001ff6b6d0 x4 : 0000000000000000 x3 : 0000000000000027
    [ 1871.261885] x2 : 0000000000000027 x1 : ffff00000473adc0 x0 : 0000000100000000
    [ 1871.261895] Call trace:
    [ 1871.261899]  ieee80211_restart_work+0x168/0x170 [mac80211]
    [ 1871.261988]  process_one_work+0x148/0x28c
    [ 1871.262004]  worker_thread+0x2d0/0x3d0
    [ 1871.262010]  kthread+0x114/0x118
    [ 1871.262020]  ret_from_fork+0x10/0x20
    [ 1871.262030] ---[ end trace 0000000000000000 ]---
    [ 1879.347788] wlan0: authenticate with f8:fb:90:14:da:bc (local address=f8:fb:90:13:6d:56)
    [ 1879.347818] wlan0: send auth to f8:fb:90:14:da:bc (try 1/3)
    [ 1879.407551] wlan0: authenticated
    [ 1879.409133] wlan0: associate with f8:fb:90:14:da:bc (try 1/3)
    [ 1879.411262] wlan0: RX AssocResp from f8:fb:90:14:da:bc (capab=0x11 status=0 aid=1)
    [ 1879.416528] cc33xx: HE Disabled
    [ 1879.418294] wlan0: associated
    [ 1879.463864] cc33xx: Association complete.
    [ 1908.517761] systemd-journald[367]: Received client request to flush runtime journal.
    [ 1908.878423] systemd-journald[367]: Received client request to relinquish /var/log/journal/5a103e5d9ac14d3aa38c0b6dd7287e4b access.
  • Edit apologies for this reply regarding the link. Read the response too quickly
  • Hello David,
    The documentation for the logger user guide comes included in the simplelink wifi toolbox. Please install it from the below link. After installation, you will then find the "docs" folder in C:/ti/simplelink_wifi_toolbox_x.x.x./docs
    https://www.ti.com/tool/download/SIMPLELINK-WIFI-TOOLBOX
  • Thanks. Yes did this. Will order the JTAG tool required for this.
  • How can i modify the firmware for the cc3351 It appears someone is able to do it in this post here:  CC3301: R7 fw stuck issue.
    I ask because they mentioned a workaround to crashing, and we could try this.
  • Hi David,
    You don't need the JTAG debugger in order to collect FW logs, just a UART-USB translator like an FTDI chip.
    Please dont follow all of the advice in that thread. That customer is using the RTOS SDK so the process is different.
    To change out the firmware in linux applications, you simply need to replace the binaries on your target filesystem in /lib/firmware/ti-connectivity. However, recall that updating the firmware also requires updating the driver and building the kernel and kernel modules as well. Similar steps as you have done before earlier in the thread.
  • Hi Sabeeh,
    I see. Will get the logs around tomorrow once the USB-UART converter comes in.
    Understood regarding that thread.
    Right, I recall we can change out the compiled firmware binaries like earlier. But I was wondering if there is a way to modify the source code for the firmware. This way, I could also attempt some workarounds. Appreciate the responses.
  • Here are the LOGs
    OS used: tisdk-debian-trixie-rt-am62xxsip-evm-11.01-Armbian-25.08.img
    Used gstreamer to stream USB camera with IMX219 sensor at 480p @30fps
    1st log: started recording at boot, stopped recording just after first firmware reset bug occurred
    • Including dmesg output as well.
    https://drive.google.com/drive/folders/1WwIp0rmuU3zAd081QKT4VlSPDDhq3KW5?usp=sharing
    2nd log: started recording when gstreamer started, stopped recording just after first firmware reset bug occurred
    https://drive.google.com/drive/folders/1oxnA7_Jpn6W9UeUdizSZGWVLHKDOpb_0?usp=sharing
    Please let me know if these Google Drive links have any issues. I did not want to paste the entire output here as it would be very long.
  • Hi Sabeeh. I was wondering if these links work for you and / or if I should provide additional instructions on reproducing this issue on your side.
  • Hello David,
    Yes I am able to access thank you. However I don't see a FW crash in the log.
    Also, to debug issues like we need to be using the latest CC33xx SDK. The firmware that comes default in the Processor SDK is very old and we have addressed many items.
    As you've done before, can you please update the driver and firmware to latest CC33xx SDK? I just published a patch to update the ti-linux-kernel-6.12 here:
    https://github.com/TexasInstruments-Sandbox/cc33xx-linux-mpu-ports/tree/khan/ti6.12-1.0.2.10/ti-linux-6.12.y
    Simply apply this patch to the kernel in the AM62 Processor SDK, and then replace the firmware binaries with those found here:
    https://www.ti.com/tool/download/CC33XX-LINUX-MPU/1.0.2.10
    Lastly, it would help to use the logger.bin custom parser when using this firmware. That way you won't see the 'dropped bytes' in the firmware log. Luckily I was able to parse the log using the offline parser from the *.bin, so thanks for providing the .bin.
    https://dr-download.ti.com/software-development/driver-or-library/MD-UoRUAALCjn/1.0.2.10/logger.bin
  • Hello Sabeeh,
    Thank you again for your continued support.
    I used the latest patch above with the latest processor and cc33xx SDKs on a default armbian image: tisdk-debian-trixie-am62xxsip-evm-11.01-Armbian-25.08.img
    Sadly, the "ERROR INTERROGATE command failed" error still occurred. I will just call it that for now, since that is the first message that shows up in dmesg when this error occurs. I will provide more info. I included the custom parser, and yes, it is much easier to read now.
    Logs are here: https://drive.google.com/drive/folders/1x-PFODA0Sm5_45bRGnmdzaRdP2NRvrWl?usp=sharing
    Here are some quick steps to reproduce the error for yourself, in case that may help:
    Steps to reproduce the issue
    link to uSD images: https://drive.google.com/drive/folders/1Q4yPUitO4cy31YrnEtQI46YFS_NVp-Vy?usp=sharing
    1. Download, unzip, and flash SD images from the above link
    2. Connect power cables and log in to both AM62SIP boards
      1. Username and password are both: root
    3. run ./start_controller_gst.sh and ./start_drone_gst.sh on each board
      1. The CC3351 error will occur within <15 minutes of streaming
    and some added context in case you go this route.
    Context:
    For some context, our setup involves streaming video between two AM62SIP boards and having one board route the video to a laptop over USB-C. To reproduce the error quickly, it is only necessary to have two AM62SIP EVM boards, a USB camera, and 2 m2-cc3351.
    The AP AM62SIP board in our use case will route received video frames to a small web server also on the AP board. The STA AM62SIP sends the frames with GStreamer over UDP to the AP AM62SIP.
    SD image information
    • AP board will only run a Flask server at reboot (you can see this in crontab) to host the images.
    • STA board is running the latest version of Debian (11.01.05.03)
    • AP board is running an older version of Debian (10.01.10.04)
  • Hi Sabeeh.
    We are testing CSI camera streaming and I was wondering what camera sensor you used during your testing? We need the imx219 to work but we are also testing ov5640 since that has a built-in ISP.
  • Hi Sabeeh,
    We are now using IMX219 over CSI instead of USB. However, the steps to reproduce above are more convenient since any USB camera can reproduce the issue.
    We will test streaming raw Bayer images to see if the "ERROR INTERROGATE command failed" bug continues in that case.
    I posted a software ISP solution that worked for us here:  SK-AM62-SIP: IMX219 Bayer to RGB ISP question
    But as mentioned, any USB camera should reproduce the issue.
    Is it at all possible for me to have some access to the cc3351 fw source code? This way, I can attempt to find workarounds. I am not sure if it is closed source or not.
  • Hi Sabeeh,
    Just checking in. Do the steps listed above help reproduce the error?
    I see that the CC3351 firmware source code is possibly in https://www.ti.com/tool/CC33XX-SOFTWARE
    I will look into this software package more.
    This link seems not to contain an SDK for firmware development for CC3351. If such an SDK exists, could you kindly point me to it so I can attempt some workarounds?
  • Just checking in. We are wondering if you had a chance to reproduce this issue with the steps provided above. We will reattempt H264 encoding as you mentioned above.
    Also, could you kindly share the GStreamer command you used when testing your raw IMX219 sensor on am62sip over m2-cc3351?
    This would greatly help in narrowing down differences in testing.
    For example, we recently implemented our own ISP since the am62sip does not have a hardware or software ISP solution.
    - This leads us to wonder how you handled ISP during testing with this board?
    - We have handled ISP with GStreamer in the past and wonder if this is the approach you used at Texas Instruments as well.
  • Hello Sabeeh,
    Hope all is well. We are wondering if there are any updates regarding the items mentioned
    Thank you again for taking the time.
