Other Parts Discussed in Thread: TEST2
Tool/software: Linux
I am trying to build the wpa-supplicant-wl18xx Arago recipe with WiFi MESH support turned on. The current recipe uses the correct R8.7_SP3 branch, but not the correct config file for wpa_supplicant. In the Build Scripts mentioned here:
processors.wiki.ti.com/.../WL18xx_System_Build_Scripts
The wpa_supplicant build uses the android.config for the build, but the Yocto recipe uses something else. I created a bbappend file to apply the android.config to the wpa-supplicant-wl18xx build. When I do that, I get:
| NOTE: make -j 8
| ../src/drivers/driver_nl80211.c:17:10: fatal error: netlink/genl/genl.h: No such file or directory
| #include <netlink/genl/genl.h>
| compilation terminated.
However libnl-3.2.29 is being built as a dependency. The TI System Build Scripts use this git repo (git://github.com/tgraf/libnl.git) whereas Arago downloads from https://github.com/thom311/
I am building for the BeagleBone Black and the StreamUnlimited WiFi Cape. Wifi Station mode is working great. Now I just need Mesh to work.
I'm using Arago with processor-sdk-04.02.00.09.
Has anyone managed to build Yocto/Arago including WiFi mesh?
Matt
