Dear Support:
I have followed the directions below:
processors.wiki.ti.com/.../WL18xx_System_Build_Scripts
in creating my build environment to install my WL1837 Cape board onto my BBB and was able to get through it ok. Then I tried to follow the instructions below:
processors.wiki.ti.com/.../WiLink8_WLAN_Demo:_Linux
to test out the functionality of my cape board when plugged into my BBB to make sure it was working ok. See my results below where it is failing from issuing the:
./sta_start.sh
call. Do you know what may be the problem? Please advise.
root@am335x-evm:/usr/sbin/wlconf# ./configure-device.sh
Please provide the following information.
Are you using a TI module? [y/n] : Please enter y or n.
Are you using a TI module? [y/n] : y
What is the chip flavor? [1801/1805/1807/1831/1835/1837 or 0 for unknown] : Please enter 1801/1805/1807/1831/1835/1837 or 0 for unknown.
What is the chip flavor? [1801/1805/1807/1831/1835/1837 or 0 for unknown] : 1837
Should Japanese standards be applied? [y/n] : Please enter y or n
Should Japanese standards be applied? [y/n] : n
How many 2.4GHz antennas are fitted? [1/2] : Please enter 1 or 2 antennas
How many 2.4GHz antennas are fitted? [1/2] : 2
How many 5GHz antennas are fitted? [0/1/2] : Please enter 0, 1 or 2
How many 5GHz antennas are fitted? [0/1/2] : 2
The device has been successfully configured.
TI Module: y
Chip Flavor: 1837
Number of 2.4GHz Antennas Fitted: 2
Number of 5GHz Antennas Fitted: 2
Diversity Support: y
SISO40 Support: y
Japanese Standards Applied: n
Class 2 Permissive Change (C2PC) Applied: n
root@am335x-evm:/usr/sbin/wlconf# [ 608.755085] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 608.776153] wlcore: loaded
[ 608.779071] wlcore: driver version: R8.6_SP1
root@am335x-evm:/usr/sbin/wlconf# cd /usr/share/wl18xx/
root@am335x-evm:/usr/share/wl18xx#
root@am335x-evm:/usr/share/wl18xx# ./load_wlcore.sh
root@am335x-evm:/usr/share/wl18xx# ./sta_start.sh
root@am335x-evm:/usr/share/wl18xx# Successfully initialized wpa_supplicant
[ 672.454126] wlcore: PHY firmware version: Rev 8.2.0.0.233
[ 672.580327] wlcore: firmware booted (Rev 8.9.0.1.55)
[ 672.606457] cfg80211: Calling CRDA for country: US
[ 673.184287] wlcore: ERROR ELP wakeup timeout!
[ 673.188904] ------------[ cut here ]------------
[ 673.193960] WARNING: CPU: 0 PID: 1525 at /home/user/wl8-build/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlcore/main.c:797 wl12xx_queue_recovery_work+0x74/0x7c [wlcore]()
[ 673.211424] Modules linked in: wlcore_sdio(O) wl18xx(O) wlcore(O) mac80211(O) cfg80211(O) musb_dsps musb_hdrc compat(O) snd_soc_evm btwilink bluetooth snd_soc_davinci_mcasp musb_am335x 6lowpan_iphc [last unloaded: wlcore_sdio]
[ 673.232679] CPU: 0 PID: 1525 Comm: crda Tainted: G O 3.14.26-g07d13c6-dirty #1
[ 673.241184] Backtrace:
[ 673.243808] [<c0011268>] (dump_backtrace) from [<c0011404>] (show_stack+0x18/0x1c)
[ 673.251784] r6:0000031d r5:00000009 r4:00000000 r3:00000000
[ 673.257804] [<c00113ec>] (show_stack) from [<c05c6b50>] (dump_stack+0x20/0x28)
[ 673.265436] [<c05c6b30>] (dump_stack) from [<c00381f8>] (warn_slowpath_common+0x6c/0x8c)
[ 673.273937] [<c003818c>] (warn_slowpath_common) from [<c003823c>] (warn_slowpath_null+0x24/0x2c)
[ 673.283183] r8:bf186140 r7:00009194 r6:c08465c8 r5:ffffff92 r4:ccad1360
[ 673.290383] [<c0038218>] (warn_slowpath_null) from [<bf16ab2c>] (wl12xx_queue_recovery_work+0x74/0x7c [wlcore])
[ 673.301189] [<bf16aab8>] (wl12xx_queue_recovery_work [wlcore]) from [<bf1744d0>] (wl1271_ps_elp_wakeup+0xd8/0x1e0 [wlcore])
[ 673.312887] r4:ccad1360 r3:20000093
[ 673.316859] [<bf1743f8>] (wl1271_ps_elp_wakeup [wlcore]) from [<bf16c7fc>] (wlcore_regdomain_config+0x3c/0x70 [wlcore])
[ 673.328187] r10:00000100 r8:00000000 r7:bf0c8e60 r6:0000001f r5:ccad1398 r4:ccad1360
[ 673.336594] [<bf16c7c0>] (wlcore_regdomain_config [wlcore]) from [<bf16c858>] (wl1271_reg_notify+0x28/0x2c [wlcore])
[ 673.347656] r5:bf0c8e60 r4:cdf51ec0
[ 673.351716] [<bf16c830>] (wl1271_reg_notify [wlcore]) from [<bf0a81bc>] (wiphy_update_regulatory+0x2f0/0x528 [cfg80211])
[ 673.363149] r4:bf185e78 r3:bf16c830
[ 673.367181] [<bf0a7ecc>] (wiphy_update_regulatory [cfg80211]) from [<bf0a9e9c>] (set_regdom+0x2a8/0x548 [cfg80211])
[ 673.378152] r10:bf0c8da8 r9:bf0c9040 r8:cdf51ec0 r7:00000001 r6:00000000 r5:bf0c8ccc
[ 673.386429] r4:ccad0000
[ 673.389353] [<bf0a9bf4>] (set_regdom [cfg80211]) from [<bf0b2c04>] (nl80211_set_reg+0xc4/0x26c [cfg80211])
[ 673.399502] r10:00000000 r9:cde43010 r8:cde4312c r7:bf0c66cc r6:cddb23c0 r5:00000000
[ 673.407778] r4:00000006 r3:00000034
[ 673.411697] [<bf0b2b40>] (nl80211_set_reg [cfg80211]) from [<c051b310>] (genl_rcv_msg+0x214/0x370)
[ 673.421119] r10:00000000 r8:bf0c6d04 r7:cde43000 r6:cdc8f540 r5:cc8c3000 r4:bf0c8e74
[ 673.429426] [<c051b0fc>] (genl_rcv_msg) from [<c051a738>] (netlink_rcv_skb+0xb4/0xc8)
[ 673.437658] r10:00000000 r9:00000000 r8:cdf59d0c r7:cdc8f540 r6:c051b0fc r5:cdc8f540
[ 673.445933] r4:cde43000
[ 673.448611] [<c051a684>] (netlink_rcv_skb) from [<c051a8f4>] (genl_rcv+0x30/0x3c)
[ 673.456479] r6:cde43c00 r5:cdc8f540 r4:c087826c r3:c051a8c4
[ 673.462462] [<c051a8c4>] (genl_rcv) from [<c051a0fc>] (netlink_unicast+0x180/0x1ec)
[ 673.470512] r5:00000160 r4:cd93cc00
[ 673.474314] [<c0519f7c>] (netlink_unicast) from [<c051a4c0>] (netlink_sendmsg+0x2ac/0x380)
[ 673.482975] r10:00000000 r8:00000008 r7:cdc8f540 r6:cde43c00 r5:cdf59dd0 r4:cdf59f5c
[ 673.491291] [<c051a214>] (netlink_sendmsg) from [<c04e8fcc>] (sock_sendmsg+0x90/0xb0)
[ 673.499525] r10:cdf59e60 r9:00000000 r8:00000000 r7:cd4019c0 r6:cc90ac00 r5:cdf59dd0
[ 673.507799] r4:c051a214
[ 673.510483] [<c04e8f3c>] (sock_sendmsg) from [<c04e9c7c>] (___sys_sendmsg.part.29+0x28c/0x29c)
[ 673.519531] r6:cdf59e60 r5:00000160 r4:cdf59f5c
[ 673.524442] [<c04e99f0>] (___sys_sendmsg.part.29) from [<c04eb1b4>] (__sys_sendmsg+0x54/0x80)
[ 673.533376] r10:00000000 r9:cdf58000 r8:c000e964 r7:00000128 r6:00000000 r5:bee44c74
[ 673.541652] r4:cd4019c0
[ 673.544359] [<c04eb160>] (__sys_sendmsg) from [<c04eb1f0>] (SyS_sendmsg+0x10/0x14)
[ 673.552293] r6:000ac2a8 r5:000ac008 r4:000ac080
[ 673.557219] [<c04eb1e0>] (SyS_sendmsg) from [<c000e7e0>] (ret_fast_syscall+0x0/0x30)
[ 673.565365] ---[ end trace 164253d119a8b2ef ]---
[ 673.570252] cfg80211: Regulatory domain changed to country: US
[ 673.576400] cfg80211: DFS Master region: FCC
[ 673.580785] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 673.591034] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 673.599461] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 1700 mBm), (N/A)
[ 673.609432] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2300 mBm), (0 s)
[ 673.619400] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2300 mBm), (0 s)
[ 673.627911] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 mBm), (N/A)
[ 673.636328] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 673.647155] wlcore: Hardware recovery in progress. FW ver: Rev 8.9.0.1.55
[ 673.654364] ------------[ cut here ]------------
[ 673.659370] WARNING: CPU: 0 PID: 9 at /home/user/wl8-build/build-utilites/src/compat_wireless/drivers/net/wireless/ti/wlcore/io.h:65 wlcore_set_partition+0xa0/0x50c [wlcore]()
[ 673.675800] Modules linked in: wlcore_sdio(O) wl18xx(O) wlcore(O) mac80211(O) cfg80211(O) musb_dsps musb_hdrc compat(O) snd_soc_evm btwilink bluetooth snd_soc_davinci_mcasp musb_am335x 6lowpan_iphc [last unloaded: wlcore_sdio]
[ 673.697047] CPU: 0 PID: 9 Comm: kworker/u2:1 Tainted: G W O 3.14.26-g07d13c6-dirty #1
[ 673.706100] Workqueue: phy1 wl1271_recovery_work [wlcore]
[ 673.711763] Backtrace:
[ 673.714404] [<c0011268>] (dump_backtrace) from [<c0011404>] (show_stack+0x18/0x1c)
[ 673.722339] r6:00000041 r5:00000009 r4:00000000 r3:c0847ac0
[ 673.728361] [<c00113ec>] (show_stack) from [<c05c6b50>] (dump_stack+0x20/0x28)
[ 673.735985] [<c05c6b30>] (dump_stack) from [<c00381f8>] (warn_slowpath_common+0x6c/0x8c)
[ 673.744513] [<c003818c>] (warn_slowpath_common) from [<c003823c>] (warn_slowpath_null+0x24/0x2c)
[ 673.753719] r8:ccad1398 r7:00000000 r6:bf186140 r5:bf1a6380 r4:ccad1360
[ 673.760914] [<c0038218>] (warn_slowpath_null) from [<bf1706d8>] (wlcore_set_partition+0xa0/0x50c [wlcore])
[ 673.771227] [<bf170638>] (wlcore_set_partition [wlcore]) from [<bf169f2c>] (wl1271_recovery_work+0x70/0x358 [wlcore])
[ 673.782374] r7:cd872500 r6:ccad1360 r5:ccad15f4 r4:ccad15f4
[ 673.788459] [<bf169ebc>] (wl1271_recovery_work [wlcore]) from [<c004ae0c>] (process_one_work+0xfc/0x338)
[ 673.798421] r8:00000000 r7:cd872500 r6:cd86ea00 r5:ccad15f4 r4:cd89ba00
[ 673.805531] [<c004ad10>] (process_one_work) from [<c004b1a0>] (worker_thread+0x11c/0x364)
[ 673.814100] r10:c087e4df r9:cd86ea00 r8:00000001 r7:cd8a2000 r6:cd89ba18 r5:cd86ea10
[ 673.822385] r4:cd89ba00
[ 673.825097] [<c004b084>] (worker_thread) from [<c0050d14>] (kthread+0xc4/0xe0)
[ 673.832666] r10:00000000 r9:00000000 r8:00000000 r7:c004b084 r6:cd89ba00 r5:cd89dec0
[ 673.840944] r4:00000000
[ 673.843625] [<c0050c50>] (kthread) from [<c000e878>] (ret_from_fork+0x14/0x3c)
[ 673.851220] r7:00000000 r6:00000000 r5:c0050c50 r4:cd89dec0
[ 673.857212] ---[ end trace 164253d119a8b2f0 ]---
[ 673.862074] wlcore: down
[ 673.878251] ieee80211 phy1: Hardware restart was requested
Could not read interface p2p-dev-wlan0 flags: No such device
[ 676.710247] wlcore: ERROR timeout waiting for the hardware to complete initialization
Tim
