Mar 3 00:47:15 icg kernel: [ 0.000000] Booting Linux on physical CPU 0x0 Mar 3 00:47:15 icg kernel: [ 0.000000] Linux version 4.9.0-12-armmp-icg (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18) ) #1 SMP Debian 4.9.210-1+icg2 (2020-03-02) Mar 3 00:47:15 icg kernel: [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d Mar 3 00:47:15 icg kernel: [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache Mar 3 00:47:15 icg kernel: [ 0.000000] OF: fdt:Machine model: TI AM335x ICG P3 Mar 3 00:47:15 icg kernel: [ 0.000000] efi: Getting EFI parameters from FDT: Mar 3 00:47:15 icg kernel: [ 0.000000] efi: UEFI not found. Mar 3 00:47:15 icg kernel: [ 0.000000] cma: Reserved 16 MiB at 0x9e000000 Mar 3 00:47:15 icg kernel: [ 0.000000] Memory policy: Data cache writeback Mar 3 00:47:15 icg kernel: [ 0.000000] On node 0 totalpages: 130560 Mar 3 00:47:15 icg kernel: [ 0.000000] free_area_init_node: node 0, pgdat c0eece00, node_mem_map df971000 Mar 3 00:47:15 icg kernel: [ 0.000000] Normal zone: 1148 pages used for memmap Mar 3 00:47:15 icg kernel: [ 0.000000] Normal zone: 0 pages reserved Mar 3 00:47:15 icg kernel: [ 0.000000] Normal zone: 130560 pages, LIFO batch:31 Mar 3 00:47:15 icg kernel: [ 0.000000] CPU: All CPU(s) started in SVC mode. Mar 3 00:47:15 icg kernel: [ 0.000000] AM335X ES2.1 (neon) Mar 3 00:47:15 icg kernel: [ 0.000000] percpu: Embedded 14 pages/cpu s27596 r8192 d21556 u57344 Mar 3 00:47:15 icg kernel: [ 0.000000] pcpu-alloc: s27596 r8192 d21556 u57344 alloc=14*4096 Mar 3 00:47:15 icg kernel: [ 0.000000] pcpu-alloc: [0] 0 Mar 3 00:47:15 icg kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129412 Mar 3 00:47:15 icg kernel: [ 0.000000] Kernel command line: console=ttyO0,115200n8 musb_hdrc.use_dma=n root=/dev/mmcblk2p2 ro rootfstype=ext4 rootwait Mar 3 00:47:15 icg kernel: [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) Mar 3 00:47:15 icg kernel: [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Mar 3 00:47:15 icg kernel: [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Mar 3 00:47:15 icg kernel: [ 0.000000] Memory: 485860K/522240K available (8192K kernel code, 1061K rwdata, 2352K rodata, 2048K init, 335K bss, 19996K reserved, 16384K cma-reserved, 0K highmem) Mar 3 00:47:15 icg kernel: [ 0.000000] Virtual kernel memory layout: Mar 3 00:47:15 icg kernel: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) Mar 3 00:47:15 icg kernel: [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) Mar 3 00:47:15 icg kernel: [ 0.000000] vmalloc : 0xe0000000 - 0xff800000 ( 504 MB) Mar 3 00:47:15 icg kernel: [ 0.000000] lowmem : 0xc0000000 - 0xdfe00000 ( 510 MB) Mar 3 00:47:15 icg kernel: [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) Mar 3 00:47:15 icg kernel: [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) Mar 3 00:47:15 icg kernel: [ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB) Mar 3 00:47:15 icg kernel: [ 0.000000] .init : 0xc0c00000 - 0xc0e00000 (2048 kB) Mar 3 00:47:15 icg kernel: [ 0.000000] .data : 0xc0e00000 - 0xc0f094fc (1062 kB) Mar 3 00:47:15 icg kernel: [ 0.000000] .bss : 0xc0f0b000 - 0xc0f5efc4 ( 336 kB) Mar 3 00:47:15 icg kernel: [ 0.000000] Hierarchical RCU implementation. Mar 3 00:47:15 icg kernel: [ 0.000000] Build-time adjustment of leaf fanout to 32. Mar 3 00:47:15 icg kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1. Mar 3 00:47:15 icg kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1 Mar 3 00:47:15 icg kernel: [ 0.000000] NR_IRQS:16 nr_irqs:16 16 Mar 3 00:47:15 icg kernel: [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts Mar 3 00:47:15 icg kernel: [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz Mar 3 00:47:15 icg kernel: [ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns Mar 3 00:47:15 icg kernel: [ 0.000042] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns Mar 3 00:47:15 icg kernel: [ 0.000057] OMAP clocksource: timer1 at 24000000 Hz Mar 3 00:47:15 icg kernel: [ 0.004720] clocksource_probe: no matching clocksources found Mar 3 00:47:15 icg kernel: [ 0.005354] Console: colour dummy device 80x30 Mar 3 00:47:15 icg kernel: [ 0.005398] Calibrating delay loop... 796.26 BogoMIPS (lpj=1990656) Mar 3 00:47:15 icg kernel: [ 0.028646] pid_max: default: 32768 minimum: 301 Mar 3 00:47:15 icg kernel: [ 0.028976] Security Framework initialized Mar 3 00:47:15 icg kernel: [ 0.028993] Yama: disabled by default; enable with sysctl kernel.yama.* Mar 3 00:47:15 icg kernel: [ 0.029039] AppArmor: AppArmor disabled by boot time parameter Mar 3 00:47:15 icg kernel: [ 0.029136] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) Mar 3 00:47:15 icg kernel: [ 0.029152] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) Mar 3 00:47:15 icg kernel: [ 0.030464] CPU: Testing write buffer coherency: ok Mar 3 00:47:15 icg kernel: [ 0.030543] CPU0: Spectre v2: using BPIALL workaround Mar 3 00:47:15 icg kernel: [ 0.030557] ftrace: allocating 28151 entries in 83 pages Mar 3 00:47:15 icg kernel: [ 0.161714] CPU0: thread -1, cpu 0, socket -1, mpidr 0 Mar 3 00:47:15 icg kernel: [ 0.161797] Setting up static identity map for 0x80100000 - 0x80100098 Mar 3 00:47:15 icg kernel: [ 0.168267] EFI services will not be available. Mar 3 00:47:15 icg kernel: [ 0.168972] Brought up 1 CPUs Mar 3 00:47:15 icg kernel: [ 0.168992] SMP: Total of 1 processors activated (796.26 BogoMIPS). Mar 3 00:47:15 icg kernel: [ 0.169003] CPU: All CPU(s) started in SVC mode. Mar 3 00:47:15 icg kernel: [ 0.170889] devtmpfs: initialized Mar 3 00:47:15 icg kernel: [ 0.185870] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 Mar 3 00:47:15 icg kernel: [ 0.186411] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 9556302231375000 ns Mar 3 00:47:15 icg kernel: [ 0.186444] futex hash table entries: 256 (order: 2, 16384 bytes) Mar 3 00:47:15 icg kernel: [ 0.187849] pinctrl core: initialized pinctrl subsystem Mar 3 00:47:15 icg kernel: [ 0.190480] NET: Registered protocol family 16 Mar 3 00:47:15 icg kernel: [ 0.193382] DMA: preallocated 256 KiB pool for atomic coherent allocations Mar 3 00:47:15 icg kernel: [ 0.216295] omap_hwmod: debugss: _wait_target_disable failed Mar 3 00:47:15 icg kernel: [ 0.277213] gpio gpiochip0: (gpio): added GPIO chardev (254:0) Mar 3 00:47:15 icg kernel: [ 0.277772] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio) Mar 3 00:47:15 icg kernel: [ 0.279894] OMAP GPIO hardware version 0.1 Mar 3 00:47:15 icg kernel: [ 0.281047] gpio gpiochip1: (gpio): added GPIO chardev (254:1) Mar 3 00:47:15 icg kernel: [ 0.281559] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio) Mar 3 00:47:15 icg kernel: [ 0.284418] gpio gpiochip2: (gpio): added GPIO chardev (254:2) Mar 3 00:47:15 icg kernel: [ 0.285025] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio) Mar 3 00:47:15 icg kernel: [ 0.287784] gpio gpiochip3: (gpio): added GPIO chardev (254:3) Mar 3 00:47:15 icg kernel: [ 0.288289] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio) Mar 3 00:47:15 icg kernel: [ 0.305537] No ATAGs? Mar 3 00:47:15 icg kernel: [ 0.305566] hw-breakpoint: debug architecture 0x4 unsupported. Mar 3 00:47:15 icg kernel: [ 0.307464] Serial: AMBA PL011 UART driver Mar 3 00:47:15 icg kernel: [ 0.330233] edma 49000000.edma: TI EDMA DMA engine driver Mar 3 00:47:15 icg kernel: [ 0.330849] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator0[0]' Mar 3 00:47:15 icg kernel: [ 0.331325] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator2[0]' - status (0) Mar 3 00:47:15 icg kernel: [ 0.331814] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator3[0]' - status (0) Mar 3 00:47:15 icg kernel: [ 0.336033] vgaarb: loaded Mar 3 00:47:15 icg kernel: [ 0.337093] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe Mar 3 00:47:15 icg kernel: [ 0.337162] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe Mar 3 00:47:15 icg kernel: [ 0.337754] media: Linux media interface: v0.10 Mar 3 00:47:15 icg kernel: [ 0.337835] Linux video capture interface: v2.00 Mar 3 00:47:15 icg kernel: [ 0.337943] pps_core: LinuxPPS API ver. 1 registered Mar 3 00:47:15 icg kernel: [ 0.337953] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> Mar 3 00:47:15 icg kernel: [ 0.337982] PTP clock support registered Mar 3 00:47:15 icg kernel: [ 0.338785] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 Mar 3 00:47:15 icg kernel: [ 0.341009] clocksource: Switched to clocksource timer1 Mar 3 00:47:15 icg kernel: [ 0.410916] VFS: Disk quotas dquot_6.6.0 Mar 3 00:47:15 icg kernel: [ 0.411178] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) Mar 3 00:47:15 icg kernel: [ 0.427683] NET: Registered protocol family 2 Mar 3 00:47:15 icg kernel: [ 0.428761] TCP established hash table entries: 4096 (order: 2, 16384 bytes) Mar 3 00:47:15 icg kernel: [ 0.428823] TCP bind hash table entries: 4096 (order: 3, 32768 bytes) Mar 3 00:47:15 icg kernel: [ 0.428897] TCP: Hash tables configured (established 4096 bind 4096) Mar 3 00:47:15 icg kernel: [ 0.428976] UDP hash table entries: 256 (order: 1, 8192 bytes) Mar 3 00:47:15 icg kernel: [ 0.429003] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) Mar 3 00:47:15 icg kernel: [ 0.429228] NET: Registered protocol family 1 Mar 3 00:47:15 icg kernel: [ 0.429278] PCI: CLS 0 bytes, default 64 Mar 3 00:47:15 icg kernel: [ 0.430386] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available Mar 3 00:47:15 icg kernel: [ 0.433701] audit: initializing netlink subsys (disabled) Mar 3 00:47:15 icg kernel: [ 0.433853] audit: type=2000 audit(0.335:1): initialized Mar 3 00:47:15 icg kernel: [ 0.435473] workingset: timestamp_bits=14 max_order=17 bucket_order=3 Mar 3 00:47:15 icg kernel: [ 0.435664] zbud: loaded Mar 3 00:47:15 icg kernel: [ 0.449004] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) Mar 3 00:47:15 icg kernel: [ 0.449307] io scheduler noop registered Mar 3 00:47:15 icg kernel: [ 0.449322] io scheduler deadline registered Mar 3 00:47:15 icg kernel: [ 0.449426] io scheduler cfq registered (default) Mar 3 00:47:15 icg kernel: [ 0.451647] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 Mar 3 00:47:15 icg kernel: [ 0.462356] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled Mar 3 00:47:15 icg kernel: [ 0.465070] Serial: AMBA driver Mar 3 00:47:15 icg kernel: [ 0.466153] omap_uart 44e09000.serial: no wakeirq for uart0 Mar 3 00:47:15 icg kernel: [ 0.466177] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@44e09000[0]' Mar 3 00:47:15 icg kernel: [ 0.466432] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a OMAP UART0 Mar 3 00:47:15 icg kernel: [ 1.107539] console [ttyO0] enabled Mar 3 00:47:15 icg kernel: [ 1.111991] omap_uart 48022000.serial: no wakeirq for uart1 Mar 3 00:47:15 icg kernel: [ 1.117911] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@48022000[0]' Mar 3 00:47:15 icg kernel: [ 1.118105] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 159, base_baud = 3000000) is a OMAP UART1 Mar 3 00:47:15 icg kernel: [ 1.128544] omap_uart 48024000.serial: no wakeirq for uart2 Mar 3 00:47:15 icg kernel: [ 1.134450] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@48024000[0]' Mar 3 00:47:15 icg kernel: [ 1.134627] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 160, base_baud = 3000000) is a OMAP UART2 Mar 3 00:47:15 icg kernel: [ 1.145062] omap_uart 481a6000.serial: no wakeirq for uart3 Mar 3 00:47:15 icg kernel: [ 1.150994] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@481a6000[0]' Mar 3 00:47:15 icg kernel: [ 1.151166] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 161, base_baud = 3000000) is a OMAP UART3 Mar 3 00:47:15 icg kernel: [ 1.161453] pinctrl-single 44e10800.pinmux: mux offset out of range: 0xfffff8f0 (0x238) Mar 3 00:47:15 icg kernel: [ 1.169900] pinctrl-single 44e10800.pinmux: could not add functions for pinmux_uart4_pins 4294965488x Mar 3 00:47:15 icg kernel: [ 1.179723] omap_uart 481a8000.serial: no wakeirq for uart4 Mar 3 00:47:15 icg kernel: [ 1.185602] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@481a8000[0]' Mar 3 00:47:15 icg kernel: [ 1.185771] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 162, base_baud = 3000000) is a OMAP UART4 Mar 3 00:47:15 icg kernel: [ 1.196237] omap_uart 481aa000.serial: no wakeirq for uart5 Mar 3 00:47:15 icg kernel: [ 1.202127] of_get_named_gpiod_flags: can't parse 'rts-gpio' property of node '/ocp/serial@481aa000[0]' Mar 3 00:47:15 icg kernel: [ 1.202300] 481aa000.serial: ttyO5 at MMIO 0x481aa000 (irq = 163, base_baud = 3000000) is a OMAP UART5 Mar 3 00:47:15 icg kernel: [ 1.216585] libphy: Fixed MDIO Bus: probed Mar 3 00:47:15 icg kernel: [ 1.222357] mousedev: PS/2 mouse device common for all mice Mar 3 00:47:15 icg kernel: [ 1.230231] omap_rtc 44e3e000.rtc: already running Mar 3 00:47:15 icg kernel: [ 1.235937] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 Mar 3 00:47:15 icg kernel: [ 1.248615] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd Mar 3 00:47:15 icg kernel: [ 1.248628] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.248662] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) Mar 3 00:47:15 icg kernel: [ 1.248687] omap_hsmmc 48060000.mmc: Got CD GPIO Mar 3 00:47:15 icg kernel: [ 1.253634] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp Mar 3 00:47:15 icg kernel: [ 1.253642] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.253653] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' Mar 3 00:47:15 icg kernel: [ 1.253662] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' Mar 3 00:47:15 icg kernel: [ 1.253670] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.253681] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed Mar 3 00:47:15 icg kernel: [ 1.254544] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd Mar 3 00:47:15 icg kernel: [ 1.254555] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.254567] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.254576] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.254584] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.254593] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed Mar 3 00:47:15 icg kernel: [ 1.254605] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp Mar 3 00:47:15 icg kernel: [ 1.254611] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.254620] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.254627] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.254635] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.254642] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed Mar 3 00:47:15 icg kernel: [ 1.255306] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd Mar 3 00:47:15 icg kernel: [ 1.255316] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.255327] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@47810000[0]' Mar 3 00:47:15 icg kernel: [ 1.255335] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@47810000[0]' Mar 3 00:47:15 icg kernel: [ 1.255343] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.255351] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed Mar 3 00:47:15 icg kernel: [ 1.255361] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp Mar 3 00:47:15 icg kernel: [ 1.255367] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.255376] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@47810000[0]' Mar 3 00:47:15 icg kernel: [ 1.255384] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@47810000[0]' Mar 3 00:47:15 icg kernel: [ 1.255391] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.255398] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed Mar 3 00:47:15 icg kernel: [ 1.376761] ledtrig-cpu: registered to indicate activity on CPUs Mar 3 00:47:15 icg kernel: [ 1.387086] remoteproc0: wkup_m3 is available Mar 3 00:47:15 icg kernel: [ 1.391813] remoteproc0: Note: remoteproc is still under development and considered experimental. Mar 3 00:47:15 icg kernel: [ 1.401228] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. Mar 3 00:47:15 icg kernel: [ 1.412467] omap_hsmmc 47810000.mmc: card claims to support voltages below defined range Mar 3 00:47:15 icg kernel: [ 1.422097] NET: Registered protocol family 10 Mar 3 00:47:15 icg kernel: [ 1.427164] remoteproc0: firmware: failed to load am335x-pm-firmware.elf (-2) Mar 3 00:47:15 icg kernel: [ 1.434855] remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2 Mar 3 00:47:15 icg kernel: [ 1.445523] mip6: Mobile IPv6 Mar 3 00:47:15 icg kernel: [ 1.448845] NET: Registered protocol family 17 Mar 3 00:47:15 icg kernel: [ 1.453640] mpls_gso: MPLS GSO support Mar 3 00:47:15 icg kernel: [ 1.457848] omap_voltage_late_init: Voltage driver support not added Mar 3 00:47:15 icg kernel: [ 1.464674] sr_dev_init: No voltage domain specified for smartreflex0. Cannot initialize Mar 3 00:47:15 icg kernel: [ 1.473241] sr_dev_init: No voltage domain specified for smartreflex1. Cannot initialize Mar 3 00:47:15 icg kernel: [ 1.482072] ThumbEE CPU extension supported. Mar 3 00:47:15 icg kernel: [ 1.486668] Registering SWP/SWPB emulation handler Mar 3 00:47:15 icg kernel: [ 1.491751] SmartReflex Class3 initialized Mar 3 00:47:15 icg kernel: [ 1.497316] registered taskstats version 1 Mar 3 00:47:15 icg kernel: [ 1.501835] zswap: loaded using pool lzo/zbud Mar 3 00:47:15 icg kernel: [ 1.508087] Key type encrypted registered Mar 3 00:47:15 icg kernel: [ 1.512590] ima: No TPM chip found, activating TPM-bypass! Mar 3 00:47:15 icg kernel: [ 1.518475] ima: Allocated hash algorithm: sha256 Mar 3 00:47:15 icg kernel: [ 1.525739] random: fast init done Mar 3 00:47:15 icg kernel: [ 1.531823] mmc0: new high speed SDIO card at address 0001 Mar 3 00:47:15 icg kernel: [ 1.556378] tps65910 0-002d: No interrupt support, no core IRQ Mar 3 00:47:15 icg kernel: [ 1.564876] vrtc: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.572688] vio: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.578066] vdd1: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.583906] vdd2: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.591447] vdig1: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.596869] vdig2: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.602263] vpll: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.607555] vdac: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.612931] vaux1: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.618360] vaux2: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.623834] vaux33: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.629345] vmmc: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.634625] vbb: supplied by vbat Mar 3 00:47:15 icg kernel: [ 1.641458] bq32k 0-0068: rtc core: registered bq32k as rtc1 Mar 3 00:47:15 icg kernel: [ 1.647803] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz Mar 3 00:47:15 icg kernel: [ 1.655089] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 400 kHz Mar 3 00:47:15 icg kernel: [ 1.662052] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd Mar 3 00:47:15 icg kernel: [ 1.662065] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.662101] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) Mar 3 00:47:15 icg kernel: [ 1.662125] omap_hsmmc 48060000.mmc: Got CD GPIO Mar 3 00:47:15 icg kernel: [ 1.667069] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp Mar 3 00:47:15 icg kernel: [ 1.667077] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.667088] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' Mar 3 00:47:15 icg kernel: [ 1.667097] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' Mar 3 00:47:15 icg kernel: [ 1.667106] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.667116] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed Mar 3 00:47:15 icg kernel: [ 1.707495] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd Mar 3 00:47:15 icg kernel: [ 1.707510] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.707526] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.707534] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.707543] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.707553] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed Mar 3 00:47:15 icg kernel: [ 1.707565] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp Mar 3 00:47:15 icg kernel: [ 1.707571] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.707580] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.707588] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]' Mar 3 00:47:15 icg kernel: [ 1.707595] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 1.707603] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed Mar 3 00:47:15 icg kernel: [ 1.747043] bq32k 0-0068: setting system clock to 2020-03-03 00:47:04 UTC (1583196424) Mar 3 00:47:15 icg kernel: [ 1.755471] sr_init: No PMIC hook to init smartreflex Mar 3 00:47:15 icg kernel: [ 1.764106] sr_init: platform driver register failed for SR Mar 3 00:47:15 icg kernel: [ 1.770472] PM: Hibernation image not present or could not be loaded. Mar 3 00:47:15 icg kernel: [ 1.770606] wlan-en-regulator: disabling Mar 3 00:47:15 icg kernel: [ 1.775898] Waiting for root device /dev/mmcblk2p2... Mar 3 00:47:15 icg kernel: [ 1.826106] mmc2: new high speed MMC card at address 0001 Mar 3 00:47:15 icg kernel: [ 1.833084] mmcblk2: mmc2:0001 P1XXXX 3.60 GiB Mar 3 00:47:15 icg kernel: [ 1.838572] mmcblk2boot0: mmc2:0001 P1XXXX partition 1 16.0 MiB Mar 3 00:47:15 icg kernel: [ 1.845403] mmcblk2boot1: mmc2:0001 P1XXXX partition 2 16.0 MiB Mar 3 00:47:15 icg kernel: [ 1.853286] mmcblk2: p1 p2 Mar 3 00:47:15 icg kernel: [ 1.900767] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null) Mar 3 00:47:15 icg kernel: [ 1.909580] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. Mar 3 00:47:15 icg kernel: [ 1.919800] Freeing unused kernel memory: 2048K Mar 3 00:47:15 icg kernel: [ 2.281412] ip_tables: (C) 2000-2006 Netfilter Core Team Mar 3 00:47:15 icg kernel: [ 2.302564] random: systemd: uninitialized urandom read (16 bytes read) Mar 3 00:47:15 icg kernel: [ 2.313066] random: systemd: uninitialized urandom read (16 bytes read) Mar 3 00:47:15 icg kernel: [ 2.648633] random: systemd-cryptse: uninitialized urandom read (16 bytes read) Mar 3 00:47:15 icg kernel: [ 4.704348] EXT4-fs (mmcblk2p2): re-mounted. Opts: (null) Mar 3 00:47:15 icg kernel: [ 7.102362] cpufreq: cpufreq_online: CPU0: Running at unlisted freq: 800000 KHz Mar 3 00:47:15 icg kernel: [ 7.182080] cpu cpu0: dev_pm_opp_set_rate: failed to find current OPP for freq 800000000 (-34) Mar 3 00:47:15 icg kernel: [ 7.276548] cpufreq: cpufreq_online: CPU0: Unlisted initial frequency changed to: 720000 KHz Mar 3 00:47:15 icg kernel: [ 7.441877] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec Mar 3 00:47:15 icg kernel: [ 7.491811] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write Mar 3 00:47:15 icg kernel: [ 8.130713] davinci-mcasp 4803c000.mcasp: Missing SND_EDMA_SOC Mar 3 00:47:15 icg kernel: [ 8.185121] davinci-mcasp: probe of 4803c000.mcasp failed with error -22 Mar 3 00:47:15 icg kernel: [ 8.192860] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 Mar 3 00:47:15 icg kernel: [ 8.673587] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 Mar 3 00:47:15 icg kernel: [ 9.111321] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 Mar 3 00:47:15 icg kernel: [ 9.159509] omap-aes 53500000.aes: will run requests pump with realtime priority Mar 3 00:47:15 icg kernel: [ 9.416682] cpsw 4a100000.ethernet: Detected MACID = d0:5f:b8:d3:60:fa Mar 3 00:47:15 icg kernel: [ 9.799832] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer reset Mar 3 00:47:15 icg kernel: [ 9.799854] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 9.799871] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' Mar 3 00:47:15 icg kernel: [ 9.799883] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' Mar 3 00:47:15 icg kernel: [ 9.799893] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 9.799904] am335x-phy-driver 47401300.usb-phy: lookup for GPIO reset failed Mar 3 00:47:15 icg kernel: [ 9.799915] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer vbus-detect Mar 3 00:47:15 icg kernel: [ 9.799923] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 9.799934] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' Mar 3 00:47:15 icg kernel: [ 9.799943] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' Mar 3 00:47:15 icg kernel: [ 9.799952] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 9.799960] am335x-phy-driver 47401300.usb-phy: lookup for GPIO vbus-detect failed Mar 3 00:47:15 icg kernel: [ 9.800054] 47401300.usb-phy supply vcc not found, using dummy regulator Mar 3 00:47:15 icg kernel: [ 9.947429] usbcore: registered new interface driver usbfs Mar 3 00:47:15 icg kernel: [ 10.002118] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer reset Mar 3 00:47:15 icg kernel: [ 10.002140] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 10.002159] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' Mar 3 00:47:15 icg kernel: [ 10.002171] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' Mar 3 00:47:15 icg kernel: [ 10.002181] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 10.002192] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO reset failed Mar 3 00:47:15 icg kernel: [ 10.002204] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer vbus-detect Mar 3 00:47:15 icg kernel: [ 10.002212] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup Mar 3 00:47:15 icg kernel: [ 10.002222] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' Mar 3 00:47:15 icg kernel: [ 10.002231] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' Mar 3 00:47:15 icg kernel: [ 10.002239] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup Mar 3 00:47:15 icg kernel: [ 10.002248] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO vbus-detect failed Mar 3 00:47:15 icg kernel: [ 10.002345] 47401b00.usb-phy supply vcc not found, using dummy regulator Mar 3 00:47:15 icg kernel: [ 10.019218] usbcore: registered new interface driver hub Mar 3 00:47:15 icg kernel: [ 10.087166] usbcore: registered new device driver usb Mar 3 00:47:15 icg kernel: [ 10.361199] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 Mar 3 00:47:15 icg kernel: [ 10.367713] davinci_mdio 4a101000.mdio: detected phy mask fffffffc Mar 3 00:47:15 icg kernel: [ 10.427870] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver Mar 3 00:47:15 icg kernel: [ 10.520852] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1 Mar 3 00:47:15 icg kernel: [ 10.639198] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 Mar 3 00:47:15 icg kernel: [ 10.646504] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 Mar 3 00:47:15 icg kernel: [ 10.654128] usb usb1: Product: MUSB HDRC host driver Mar 3 00:47:15 icg kernel: [ 10.659359] usb usb1: Manufacturer: Linux 4.9.0-12-armmp-icg musb-hcd Mar 3 00:47:15 icg kernel: [ 10.666131] usb usb1: SerialNumber: musb-hdrc.2.auto Mar 3 00:47:15 icg kernel: [ 10.780706] libphy: 4a101000.mdio: probed Mar 3 00:47:15 icg kernel: [ 10.785101] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver RTL8211F Gigabit Ethernet Mar 3 00:47:15 icg kernel: [ 10.795196] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver RTL8211F Gigabit Ethernet Mar 3 00:47:15 icg kernel: [ 11.058499] hub 1-0:1.0: USB hub found Mar 3 00:47:15 icg kernel: [ 11.111435] hub 1-0:1.0: 1 port detected Mar 3 00:47:15 icg kernel: [ 11.205896] wl18xx_driver wl18xx.0.auto: firmware: direct-loading firmware ti-connectivity/wl1271-nvs.bin Mar 3 00:47:15 icg kernel: [ 11.256380] wl18xx_driver wl18xx.0.auto: firmware: failed to load ti-connectivity/wl18xx-conf.bin (-2) Mar 3 00:47:15 icg kernel: [ 11.266317] wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl18xx-conf.bin failed with error -2 Mar 3 00:47:15 icg kernel: [ 11.277581] wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2 Mar 3 00:47:15 icg kernel: [ 11.286813] wlcore: WARNING falling back to default config Mar 3 00:47:15 icg kernel: [ 11.561363] usb 1-1: new high-speed USB device number 2 using musb-hdrc Mar 3 00:47:15 icg kernel: [ 11.717890] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610 Mar 3 00:47:15 icg kernel: [ 11.725070] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 Mar 3 00:47:15 icg kernel: [ 11.732615] usb 1-1: Product: USB2.0 Hub Mar 3 00:47:15 icg kernel: [ 11.768002] hub 1-1:1.0: USB hub found Mar 3 00:47:15 icg kernel: [ 11.779475] hub 1-1:1.0: 4 ports detected Mar 3 00:47:15 icg kernel: [ 11.800768] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11) Mar 3 00:47:15 icg kernel: [ 11.831481] wlcore: WARNING Detected unconfigured mac address in nvs, derive from fuse instead. Mar 3 00:47:15 icg kernel: [ 11.831481] Mar 3 00:47:15 icg kernel: [ 11.842215] wlcore: WARNING This default nvs file can be removed from the file system Mar 3 00:47:15 icg kernel: [ 11.842215] Mar 3 00:47:15 icg kernel: [ 11.998740] wlcore: loaded Mar 3 00:47:19 icg kernel: [ 16.741269] usb 1-1.2: new high-speed USB device number 3 using musb-hdrc Mar 3 00:47:19 icg kernel: [ 16.941775] usb 1-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 255, changing to 11 Mar 3 00:47:19 icg kernel: [ 17.051380] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0051 Mar 3 00:47:19 icg kernel: [ 17.058702] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:47:19 icg kernel: [ 17.066437] usb 1-1.2: Product: U-Boot 2010.12 Mar 3 00:47:19 icg kernel: [ 17.071140] usb 1-1.2: Manufacturer: Das U-Boot Mar 3 00:47:19 icg kernel: [ 17.075887] usb 1-1.2: SerialNumber: 0000000 Mar 3 00:47:20 icg kernel: [ 17.463435] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device Mar 3 00:47:20 icg kernel: [ 17.531341] usbcore: registered new interface driver cdc_acm Mar 3 00:47:20 icg kernel: [ 17.537355] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters Mar 3 00:47:20 icg kernel: [ 17.701124] random: crng init done Mar 3 00:47:20 icg kernel: [ 17.704724] random: 7 urandom warning(s) missed due to ratelimiting Mar 3 00:47:24 icg kernel: [ 21.782507] usb 1-1.2: USB disconnect, device number 3 Mar 3 00:47:26 icg kernel: [ 24.157048] usb 1-1.2: new high-speed USB device number 4 using musb-hdrc Mar 3 00:47:27 icg kernel: [ 24.308430] usb 1-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 255, changing to 11 Mar 3 00:47:27 icg kernel: [ 24.368271] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0051 Mar 3 00:47:27 icg kernel: [ 24.375626] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:47:27 icg kernel: [ 24.383355] usb 1-1.2: Product: U-Boot 2010.12 Mar 3 00:47:27 icg kernel: [ 24.388042] usb 1-1.2: Manufacturer: Das U-Boot Mar 3 00:47:27 icg kernel: [ 24.392816] usb 1-1.2: SerialNumber: 0000000 Mar 3 00:47:27 icg kernel: [ 24.477023] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device Mar 3 00:47:31 icg kernel: [ 29.197479] usb 1-1.2: USB disconnect, device number 4 Mar 3 00:47:33 icg kernel: [ 31.001463] nf_conntrack version 0.5.0 (8192 buckets, 32768 max) Mar 3 00:47:34 icg kernel: [ 31.781239] usb 1-1.2: new high-speed USB device number 5 using musb-hdrc Mar 3 00:47:34 icg kernel: [ 31.943505] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0047 Mar 3 00:47:34 icg kernel: [ 31.950918] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:47:34 icg kernel: [ 31.958656] usb 1-1.2: Product: 'Alt3100 devboard' Mar 3 00:47:34 icg kernel: [ 31.963713] usb 1-1.2: Manufacturer: 'Altair Semiconductor' Mar 3 00:47:34 icg kernel: [ 31.969580] usb 1-1.2: SerialNumber: usb_serial_num_0 Mar 3 00:47:35 icg kernel: [ 32.268442] cdc_acm 1-1.2:1.2: ttyACM0: USB ACM device Mar 3 00:47:35 icg kernel: [ 32.580519] cdc_ether 1-1.2:1.0 eth1: register 'cdc_ether' at usb-musb-hdrc.2.auto-1.2, CDC Ethernet Device, 94:b9:b4:18:e4:1a Mar 3 00:47:35 icg kernel: [ 32.714168] usbcore: registered new interface driver cdc_ether Mar 3 00:47:35 icg kernel: [ 32.915641] cdc_ether 1-1.2:1.0 quanta_lm172: renamed from eth1 Mar 3 00:47:48 icg kernel: [ 45.446528] net eth0: initializing cpsw version 1.12 (0) Mar 3 00:47:48 icg kernel: [ 45.628196] RTL8211F Gigabit Ethernet 4a101000.mdio:00: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=-1) Mar 3 00:47:48 icg kernel: [ 45.784782] RTL8211F Gigabit Ethernet 4a101000.mdio:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=4a101000.mdio:01, irq=-1) Mar 3 00:47:48 icg kernel: [ 45.932321] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Mar 3 00:47:49 icg kernel: [ 46.294554] usb 1-1.2: USB disconnect, device number 5 Mar 3 00:47:49 icg kernel: [ 46.300136] cdc_acm 1-1.2:1.2: acm_ctrl_irq - usb_submit_urb failed: -19 Mar 3 00:47:49 icg kernel: [ 46.391552] cdc_ether 1-1.2:1.0 quanta_lm172: unregister 'cdc_ether' usb-musb-hdrc.2.auto-1.2, CDC Ethernet Device Mar 3 00:47:49 icg kernel: [ 46.737093] cpsw 4a100000.ethernet eth0: Link is Up - Unknown/Half - flow control off Mar 3 00:47:49 icg kernel: [ 46.872861] wl18xx_driver wl18xx.0.auto: firmware: direct-loading firmware ti-connectivity/wl18xx-fw-4.bin Mar 3 00:47:49 icg kernel: [ 46.937091] cpsw 4a100000.ethernet eth0: Link is Down Mar 3 00:47:49 icg kernel: [ 47.011651] wlcore: PHY firmware version: Rev 8.2.0.0.236 Mar 3 00:47:49 icg kernel: [ 47.160584] wlcore: firmware booted (Rev 8.9.0.0.69) Mar 3 00:47:49 icg kernel: [ 47.231993] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready Mar 3 00:47:50 icg kernel: [ 47.278072] cdc_acm 1-1.2:1.2: failed to set dtr/rts Mar 3 00:47:51 icg kernel: [ 48.686812] wlcore: down Mar 3 00:47:52 icg kernel: [ 49.601268] usb 1-1.2: new high-speed USB device number 6 using musb-hdrc Mar 3 00:47:52 icg kernel: [ 49.752972] usb 1-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 255, changing to 11 Mar 3 00:47:52 icg kernel: [ 49.823346] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0051 Mar 3 00:47:52 icg kernel: [ 49.830775] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:47:52 icg kernel: [ 49.838532] usb 1-1.2: Product: U-Boot 2010.12 Mar 3 00:47:52 icg kernel: [ 49.843259] usb 1-1.2: Manufacturer: Das U-Boot Mar 3 00:47:52 icg kernel: [ 49.848069] usb 1-1.2: SerialNumber: 0000000 Mar 3 00:47:52 icg kernel: [ 50.005770] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device Mar 3 00:47:53 icg kernel: [ 50.301484] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready Mar 3 00:47:54 icg kernel: [ 52.137242] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Mar 3 00:47:54 icg kernel: [ 52.171290] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready Mar 3 00:47:55 icg kernel: [ 53.057323] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx Mar 3 00:47:57 icg kernel: [ 54.647675] usb 1-1.2: USB disconnect, device number 6 Mar 3 00:47:59 icg kernel: [ 57.216337] usb 1-1.2: new high-speed USB device number 7 using musb-hdrc Mar 3 00:48:00 icg kernel: [ 57.367782] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0047 Mar 3 00:48:00 icg kernel: [ 57.375163] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:48:00 icg kernel: [ 57.382911] usb 1-1.2: Product: 'Alt3100 devboard' Mar 3 00:48:00 icg kernel: [ 57.387978] usb 1-1.2: Manufacturer: 'Altair Semiconductor' Mar 3 00:48:00 icg kernel: [ 57.393861] usb 1-1.2: SerialNumber: usb_serial_num_0 Mar 3 00:48:00 icg kernel: [ 57.500459] cdc_ether 1-1.2:1.0 eth1: register 'cdc_ether' at usb-musb-hdrc.2.auto-1.2, CDC Ethernet Device, 94:b9:b4:18:e4:1a Mar 3 00:48:00 icg kernel: [ 57.582947] cdc_acm 1-1.2:1.2: ttyACM1: USB ACM device Mar 3 00:48:00 icg kernel: [ 57.744839] cdc_ether 1-1.2:1.0 quanta_lm172: renamed from eth1 Mar 3 00:48:04 icg kernel: [ 61.489587] usb 1-1.2: USB disconnect, device number 7 Mar 3 00:48:04 icg kernel: [ 61.495017] cdc_acm 1-1.2:1.2: acm_ctrl_irq - usb_submit_urb failed: -19 Mar 3 00:48:04 icg kernel: [ 61.541674] cdc_ether 1-1.2:1.0 quanta_lm172: unregister 'cdc_ether' usb-musb-hdrc.2.auto-1.2, CDC Ethernet Device Mar 3 00:48:04 icg kernel: [ 61.591679] cdc_acm 1-1.2:1.2: failed to set dtr/rts Mar 3 00:48:06 icg kernel: [ 63.981347] usb 1-1.2: new high-speed USB device number 8 using musb-hdrc Mar 3 00:48:06 icg kernel: [ 64.143262] usb 1-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 255, changing to 11 Mar 3 00:48:06 icg kernel: [ 64.213025] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0051 Mar 3 00:48:06 icg kernel: [ 64.220379] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:48:06 icg kernel: [ 64.228144] usb 1-1.2: Product: U-Boot 2010.12 Mar 3 00:48:06 icg kernel: [ 64.232837] usb 1-1.2: Manufacturer: Das U-Boot Mar 3 00:48:06 icg kernel: [ 64.237611] usb 1-1.2: SerialNumber: 0000000 Mar 3 00:48:07 icg kernel: [ 64.361920] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device Mar 3 00:48:11 icg kernel: [ 69.022573] usb 1-1.2: USB disconnect, device number 8 Mar 3 00:48:14 icg kernel: [ 71.606368] usb 1-1.2: new high-speed USB device number 9 using musb-hdrc Mar 3 00:48:14 icg kernel: [ 71.762607] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0047 Mar 3 00:48:14 icg kernel: [ 71.769987] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:48:14 icg kernel: [ 71.777732] usb 1-1.2: Product: 'Alt3100 devboard' Mar 3 00:48:14 icg kernel: [ 71.782805] usb 1-1.2: Manufacturer: 'Altair Semiconductor' Mar 3 00:48:14 icg kernel: [ 71.788694] usb 1-1.2: SerialNumber: usb_serial_num_0 Mar 3 00:48:14 icg kernel: [ 71.917987] cdc_ether 1-1.2:1.0 eth1: register 'cdc_ether' at usb-musb-hdrc.2.auto-1.2, CDC Ethernet Device, 94:b9:b4:18:e4:1a Mar 3 00:48:14 icg kernel: [ 71.987322] cdc_acm 1-1.2:1.2: ttyACM0: USB ACM device Mar 3 00:48:14 icg kernel: [ 72.217344] cdc_ether 1-1.2:1.0 quanta_lm172: renamed from eth1 Mar 3 00:48:24 icg kernel: [ 81.255847] usb 1-1.2: USB disconnect, device number 9 Mar 3 00:48:24 icg kernel: [ 81.261277] cdc_acm 1-1.2:1.2: acm_ctrl_irq - usb_submit_urb failed: -19 Mar 3 00:48:24 icg kernel: [ 81.311913] cdc_ether 1-1.2:1.0 quanta_lm172: unregister 'cdc_ether' usb-musb-hdrc.2.auto-1.2, CDC Ethernet Device Mar 3 00:48:24 icg kernel: [ 81.384644] cdc_acm 1-1.2:1.2: failed to set dtr/rts Mar 3 00:48:26 icg kernel: [ 83.701606] usb 1-1.2: new high-speed USB device number 10 using musb-hdrc Mar 3 00:48:26 icg kernel: [ 83.864160] usb 1-1.2: config 1 interface 0 altsetting 0 endpoint 0x83 has an invalid bInterval 255, changing to 11 Mar 3 00:48:26 icg kernel: [ 83.943907] usb 1-1.2: New USB device found, idVendor=216f, idProduct=0051 Mar 3 00:48:26 icg kernel: [ 83.951329] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Mar 3 00:48:26 icg kernel: [ 83.959057] usb 1-1.2: Product: U-Boot 2010.12 Mar 3 00:48:26 icg kernel: [ 83.963757] usb 1-1.2: Manufacturer: Das U-Boot Mar 3 00:48:26 icg kernel: [ 83.968543] usb 1-1.2: SerialNumber: 0000000 Mar 3 00:48:26 icg kernel: [ 84.102239] cdc_acm 1-1.2:1.0: ttyACM1: USB ACM device Mar 3 00:48:27 icg kernel: [ 84.645276] Bluetooth: Core ver 2.22 Mar 3 00:48:27 icg kernel: [ 84.661719] NET: Registered protocol family 31 Mar 3 00:48:27 icg kernel: [ 84.666502] Bluetooth: HCI device and connection manager initialized Mar 3 00:48:27 icg kernel: [ 84.717968] Bluetooth: HCI socket layer initialized Mar 3 00:48:27 icg kernel: [ 84.730428] Bluetooth: L2CAP socket layer initialized Mar 3 00:48:27 icg kernel: [ 84.751565] Bluetooth: SCO socket layer initialized
We're in the process of updating the kernel for one of our boards (an AM335x-based system, architecturally very close to the AM335x EVM) (see [0] for more details). Unfortunately the upgrade has broken bluetooth entirely. Running "hcitool dev" reports zero devices, and there's nothing that appears to be wrong in dmesg. Unlike our previous issues with wifi at [0], this problem appears on all systems.
The old kernel was 3.14, new is 4.9. Under 3.16 the device and interfaces worked
correctly without any issue. [0] https://e2e.ti.com/support/wireless-connectivity/other-wireless/f/667/t/849611 Again, any idea what might be wrong, or what we might need to check next? I've attached /var/log/kern.log from an affected system. For the avoidance of doubt, the wifi fix identified in [0] is applied.
