I used uartecho sample code and also write my own code to check whether CC3235 communicate to PC well via UART. But for both cases, there's no output on Teraterm Data port. I tried all baud rate settings 115200 and 921600, still has no output.Here's my code
void InitTerm(void) { int8_t i; UART_Params uartParams; char frameNum[] = "100"; char num_objs[] = "3"; char x[] = "1"; char y[] = "5"; char n = '\n'; /* Construct a Semaphore object */ Semaphore_Params semParams; Semaphore_Params_init(&semParams); Semaphore_construct(&mmwaveSemStruct, 0, &semParams); mmwaveSemHandle = Semaphore_handle(&mmwaveSemStruct); UART_init(); UART_Params_init(&uartParams); uartParams.writeDataMode = UART_DATA_BINARY; uartParams.readDataMode = UART_DATA_BINARY; uartParams.readReturnMode = UART_RETURN_FULL; uartParams.readEcho = UART_ECHO_OFF; uartParams.baudRate = 115200; //921600; uartHandle = UART_open(CONFIG_UART_0, &uartParams); /* remove uart receive from LPDS dependency */ //UART_control(uartHandle, UART_CMD_RXDISABLE, NULL); if (uartHandle == NULL) { /* UART_open() failed */ while (1); } while(1) { UART_write(uartHandle, frameNum, 4); UART_write(uartHandle, num_objs, 2); for(i=0; i<SMSGS_SENSOR_MMWAVE_MAX_OBJ; i++) { UART_write(uartHandle, x, 4); UART_write(uartHandle, y, 4); } UART_write(uartHandle, &n, 1); } } void * mainThread(void *arg) { SPI_init(); GPIO_init(); InitTerm(); }
Why don't I get any data shown on Teraterm data port? Even though I used UART source code in SimpleLink SDK still don't see any data. Please help me handle it.
