CC2652P: create host application on iMX8
Part Number: CC2652P
We are developing a ZigBee3.0 gateway with Host processor i.MX8Mini running on Linux kernel version 5.4.47 and CC2652P as ZNP.
I would like to know what are libraries/drivers  which we need to integrate with my host application ? Do you have drivers/libraries available for i.MX8Mini ?
Vikas
    1. TI provides https://www.ti.com/tool/download/ZIGBEE-LINUX-SENSOR-TO-CLOUD which you can use as your reference design.
  • Hi YiKai Chen,
    By using ZIGBEE-LINUX-SENSOR-TO-CLOUD we tried building for x86 and IMX8 platform. The steps followed are :
    Compiling the zstack Linux Gateway source for X86 ARCH on UBUNTU 20.04 LTS:
    step-1: Downloaded Zigbee_3_0_Linux_Gateway_1_0_1.run file from the below link
    step-2: Installed zstack into a folder by  running the Zigbee_3_0_Linux_Gateway_1_0_1.run file
    step-3: Followed the steps mentioned in the Linux OS setup and Linux Gateway Setup sections of the below link
    http://software-dl.ti.com/simplelink/esd/zigbee_3_0_Linux/1.0.1/exports/Documents/Z-Stack%20Linux%20Gateway%20-%20Quick%20Start%20Guide.html
    step-4: After running setup.sh script, we are unable to get out folder, getting ERROR__out folder. And attached the build_x86.log file in the attachments
    step-5: Connect the ZNP node and detected as /dev/ttyACM0, /dev/ttyACM1
    step-6: Added ZNP device node name(/dev/ttyACM0) in source/ERROR__out/Precompiled/servers/NPI_Gateway.cfg. Attaching the same file in the attachment
    step-7: Run sudo ./zigbeeHAgw file and attached the zigbeeHAgw_x86.log in the attachments
    step-8: Run sudo ./start_application file and attached the start_application_x86.png in the attachments.
    Compiling the zstack Linux Gateway source for i.MX8 ARCH:
    step-1: Generated(from Yocto) and installed the cross compiler for i.MX8
    step-2: Downloaded Zigbee_3_0_Linux_Gateway_1_0_1.run file from the below link
    step-3: Installed zstack into a folder bu running the Zigbee_3_0_Linux_Gateway_1_0_1.run file
    step-4: Exported the toolchain by using the command: . /opt/fsl-imx-xwayland/5.4-zeus/environment-setup-aarch64-poky-linux
    step-5: Modified(Added TARGET_PLATFORM=IMX8) the scripts/package_builder file and attached the file in the attachments
    step-6: After running setup.sh script, we are unable to get out folder, getting ERROR__out folder and got some build errors as well. And attached the build_imx8.log, content.txt and expected_content.txt files in the attachments
    Please let me know the steps we followed is correct or not. Also I would like to know how we can build the Zigbee_3_0_Linux_Gateway  for IMX8 .
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ aa-
    aa-enabled         aa-exec            aa-remove-unknown  aa-status          aa-teardown
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ aa-^C
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ . /opt/fsl-imx-xwayland/5.4-zeus/environment-setup-aarch64-poky-linux
    aa-enabled                             aarch64-poky-linux-lld                 aarch64-poky-linux-musl-ld.bfd
    aa-exec                                aarch64-poky-linux-llvm-ar             aarch64-poky-linux-musl-ld.gold
    aarch64-poky-linux-addr2line           aarch64-poky-linux-llvm-nm             aarch64-poky-linux-musl-ld.lld
    aarch64-poky-linux-ar                  aarch64-poky-linux-llvm-profdata       aarch64-poky-linux-musl-lld
    aarch64-poky-linux-as                  aarch64-poky-linux-llvm-ranlib         aarch64-poky-linux-musl-llvm-ar
    aarch64-poky-linux-c++filt             aarch64-poky-linux-musl-addr2line      aarch64-poky-linux-musl-llvm-nm
    aarch64-poky-linux-clang               aarch64-poky-linux-musl-ar             aarch64-poky-linux-musl-llvm-profdata
    aarch64-poky-linux-clang++             aarch64-poky-linux-musl-as             aarch64-poky-linux-musl-llvm-ranlib
    aarch64-poky-linux-clang-tidy          aarch64-poky-linux-musl-c++filt        aarch64-poky-linux-musl-nm
    aarch64-poky-linux-cpp                 aarch64-poky-linux-musl-clang          aarch64-poky-linux-musl-objcopy
    aarch64-poky-linux-dwp                 aarch64-poky-linux-musl-clang++        aarch64-poky-linux-musl-objdump
    aarch64-poky-linux-elfedit             aarch64-poky-linux-musl-clang-tidy     aarch64-poky-linux-musl-ranlib
    aarch64-poky-linux-g++                 aarch64-poky-linux-musl-cpp            aarch64-poky-linux-musl-readelf
    aarch64-poky-linux-gcc                 aarch64-poky-linux-musl-dwp            aarch64-poky-linux-musl-size
    aarch64-poky-linux-gcc-ar              aarch64-poky-linux-musl-elfedit        aarch64-poky-linux-musl-strings
    aarch64-poky-linux-gcc-nm              aarch64-poky-linux-musl-g++            aarch64-poky-linux-musl-strip
    aarch64-poky-linux-gcc-ranlib          aarch64-poky-linux-musl-gcc            aarch64-poky-linux-nm
    aarch64-poky-linux-gcov                aarch64-poky-linux-musl-gcc-ar         aarch64-poky-linux-objcopy
    aarch64-poky-linux-gcov-dump           aarch64-poky-linux-musl-gcc-nm         aarch64-poky-linux-objdump
    aarch64-poky-linux-gcov-tool           aarch64-poky-linux-musl-gcc-ranlib     aarch64-poky-linux-ranlib
    aarch64-poky-linux-gdb                 aarch64-poky-linux-musl-gcov           aarch64-poky-linux-readelf
    aarch64-poky-linux-gdb-add-index       aarch64-poky-linux-musl-gcov-dump      aarch64-poky-linux-size
    aarch64-poky-linux-gprof               aarch64-poky-linux-musl-gcov-tool      aarch64-poky-linux-strings
    aarch64-poky-linux-ld                  aarch64-poky-linux-musl-gdb            aarch64-poky-linux-strip
    aarch64-poky-linux-ld.bfd              aarch64-poky-linux-musl-gdb-add-index  aa-remove-unknown
    aarch64-poky-linux-ld.gold             aarch64-poky-linux-musl-gprof          aa-status
    aarch64-poky-linux-ld.lld              aarch64-poky-linux-musl-ld             aa-teardown
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ aa^C
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ echo $CC
    aarch64-poky-linux-gcc -mcpu=cortex-a53+crc+crypto -fstack-protector-strong -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -Werror=format-security --sysroot=/opt/fsl-imx-xwayland/5.4-zeus/sysroots/aarch64-poky-linux
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ sudo ./setup.sh
    ******************* BEGIN SETUP! ********************
    This setup script will:
      - make all necessary scripts executable
      - ensure necessary files have UNIX line endings
      - remove prebuilt directories
      - install Node Modules for Node.js Zigbee Gateway
      - build Linux Zigbee Gateway
      - extract Linux Zigbee Gateway binaries
    Entered /Projets/node Directory
    Make the gateway scripts executable
    SUCCESS - gateway scripts executable
    /home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source
    Remove ERROR__out or out Directory if present
    Removed Previous built package.
    Convert all files from dos2unix
    dos2unix: converting file ./Projects/zstack/OTA/Source/ota_common.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/source/OnBoard.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/source/pb_utils.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/source/pb_utils.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/source/OnBoard.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/source/zmain.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrservices.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgr.pb-c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrsrv.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrsrv.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrservices.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgr_pb_ctrl.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrdatabase.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrp2p.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgr.pb-c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrp2p.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgr_config.ini to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgrdatabase.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/zcl_ha.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/nwkmgr_pb_ctrl.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/nwkmgr/aps_groups.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gatewayservices.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/aps_groups.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gatewaysrvr.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/zcl_port.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gatewayservices.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gatewaysrvr.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway_config.tlg to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway_pb_ctrl.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway.pb-c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway_pb_ctrl.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway.pb-c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway_config.ini to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/zcl_ha.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/zcl_port.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/gateway.proto to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hagateway/aps_groups.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zmac/zmac_internal.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hal/hal_mcu.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hal/hal_timer.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hal/hal_types.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hal/hal_board_cfg.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/hal/hal_defs.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/OSAL.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/OSAL_Memory.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/sdata.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/comdef.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/OSAL_Timers.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/OSAL_PwrMgr.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/ZComDef.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/OSAL_Tasks.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/saddr.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/include/OSAL_Nv.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/common/OSAL_PwrMgr.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/common/OSAL.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/common/OSAL_Timers.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/linux_osal/common/OSAL_Memory.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sdb/SimpleDBTxt.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sdb/SimpleDBTxt.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sdb/SimpleDB.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sdb/SimpleDB.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/zcl_ota.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/zcl_otaserver_lnx.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otasrvr_pb_ctrl.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/utils.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otasrvr.pb-c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otasrvr.pb-c.h to Unix format...
    dos2unix: Binary symbol 0x1E found at line 1
    dos2unix: Skipping binary file ./Projects/zstack/linux/otaserver/ota_sample_images/5678-1234-0000AAAA.zigbee
    dos2unix: Skipping binary file ./Projects/zstack/linux/otaserver/ota_sample_images/5678-1234-0000BBBB.zigbee
    dos2unix: converting file ./Projects/zstack/linux/otaserver/ota_sample_images/Readme.txt to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/ota_common.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otasrvr.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/zcl_ota.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otaserver.ini to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/OtaServer_db.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/OtaServer.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/OtaServer.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/OtaServer_db.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otasrvr_pb_ctrl.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/otasrvr.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/zcl_port.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/otaserver/aps_groups.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackpb/zstackpb.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackpb/zstackpb.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackpb/zstack.pb-c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackpb/zstack.pb-c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvepconfig/serverep.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvepconfig/serverep.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/serverpb/gatewayp2p.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/serverpb/server.pb-c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/serverpb/server.pb-c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/serverpb/gatewayp2p.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/serverpb/server_pb_ctrl.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/serverpb/server_pb_ctrl.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/bbb_usbreset/source/bbb_usbreset.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/bbb_usbreset/project/makefile to Unix format...
    dos2unix: Binary symbol 0x01 found at line 1
    dos2unix: Skipping binary file ./Projects/zstack/linux/bbb_usbreset/project/out/bbb_usbreset.o
    dos2unix: Skipping binary file ./Projects/zstack/linux/bbb_usbreset/project/bbb_usbreset.bin
    dos2unix: Binary symbol 0x00 found at line 3
    dos2unix: Skipping binary file ./Projects/zstack/linux/protobuf-c/lib/x86/libprotobuf-c.a
    dos2unix: Skipping binary file ./Projects/zstack/linux/protobuf-c/lib/x86/libprotobuf-c.so
    dos2unix: Skipping binary file ./Projects/zstack/linux/protobuf-c/lib/x86/libprotobuf-c.so.1.0.0
    dos2unix: Skipping binary file ./Projects/zstack/linux/protobuf-c/lib/arm/libprotobuf-c.a
    dos2unix: converting file ./Projects/zstack/linux/protobuf-c/lib/arm/libprotobuf-c.la to Unix format...
    dos2unix: Skipping binary file ./Projects/zstack/linux/protobuf-c/lib/arm/libprotobuf-c.so.1.0.0
    dos2unix: converting file ./Projects/zstack/linux/protobuf-c/lib/arm/pkgconfig/libprotobuf-c.pc to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/protobuf-c/include/google/protobuf-c/protobuf-c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sbl_tool/project/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sbl_tool/Source/zbSocTransportUart.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sbl_tool/Source/zbSocCmd.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sbl_tool/Source/main.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sbl_tool/Source/zbSocCmd.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/sbl_tool/Source/zbSocTransportUart.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/version_query_minitool/project/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/version_query_minitool/Source/zbSocTransportUart.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/version_query_minitool/Source/zbSocCmd.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/version_query_minitool/Source/main.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/version_query_minitool/Source/zbSocCmd.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/version_query_minitool/Source/zbSocTransportUart.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/hagateway/track_servers to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/hagateway/reset/soc_reset_hold to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/hagateway/reset/soc_reset_release to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/hagateway/reset/bbb/soc_reset_hold to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/hagateway/reset/bbb/soc_reset_release to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/hagateway/zigbeeHAgw to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/package_builder_expected_content_RUNTIME_arm.txt to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/sample_app/start_application to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/scripts/package_builder_expected_content_RUNTIME_x86.txt to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/NPI_Gateway.cfg to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/hal_spi.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/hal_gpio.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_i2c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_i2c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/hal_i2c.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_spi.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_ipc.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/hal_spi.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/hal_gpio.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_uart.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_uart.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/aic.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/npi_lnx_spi.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/server/hal_i2c.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/common/npi_lnx.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/common/hal_types.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/common/hal_rpc.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/common/npi_lnx_error.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost/ipclib/common/npi_lnx_ipc_rpc.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/zstack_pb_ctrl.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/znp_af.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/znp_zdo.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/osal_zstack_server_znp.c to Unix format...
    dos2unix: Skipping binary file ./Projects/zstack/linux/zstackserverznp/ZLSZNP_arm
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/config.ini to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/f8wConfig.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/zstack_pb_ctrl.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/zstackserverznp/znp_misc.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/soc_images/CC2531_USB_Dongle/CC2531-GW-ZNP_39203_sbl39186.hex to Unix format...
    dos2unix: Binary symbol 0x02 found at line 1
    dos2unix: Skipping binary file ./Projects/zstack/linux/soc_images/CC2531_USB_Dongle/CC2531-GW-ZNP_39203.bin
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/ota_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/actions_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/commissioning_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/device_list_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/network_info_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/ota_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/system_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/device_list_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/sensor_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/network_info_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/attribute_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/group_scene_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/state_reflector.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/commissioning_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/attribute_engine.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/state_reflector.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/system_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/actions_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/sensor_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/engines/group_scene_engine.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/project/makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/project/main.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/project/sample_app_ota.cfg to Unix format...
    dos2unix: Skipping binary file ./Projects/zstack/linux/demo/project/images/5678-1234-BBBB0000.zigbee
    dos2unix: Skipping binary file ./Projects/zstack/linux/demo/project/images/5678-1234-AAAA0000.zigbee
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/user_interface.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/socket_interface.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/polling.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/tcp_client.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/user_interface.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/timer_utils.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/data_structures.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/macros.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/types.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/tcp_client.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/data_structures.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/macros.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/timer_utils.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/socket_interface.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/demo/framework/polling.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/Makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/ccxxxxdnld.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/ccxxxxdnld.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/sblUart.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/main.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/sblUart.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/cc-rom-sbl/deviceTypes.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/usbreset/source/usbreset.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/usbreset/project/makefile to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/api_server.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/trace.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/api_server.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/api_client.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/trace.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/main.c to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/hal_rpc.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/api_lnx_ipc_rpc.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/api_client.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/configparser.h to Unix format...
    dos2unix: converting file ./Projects/zstack/linux/srvwrapper/configparser.c to Unix format...
    dos2unix: converting file ./Projects/node/start_gateway.sh to Unix format...
    dos2unix: converting file ./Projects/node/start_local.sh to Unix format...
    dos2unix: converting file ./Projects/node/README.html to Unix format...
    dos2unix: converting file ./Projects/node/README.md to Unix format...
    dos2unix: converting file ./Projects/node/start_ibm.sh to Unix format...
    dos2unix: converting file ./Projects/node/end.sh to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/app.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/webapp.html to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/webapp.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.bundle.min.js.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.bundle.min.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/Chart.min.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.bundle.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.js.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.bundle.js.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/popper.min.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.min.js.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.min.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/js/bootstrap.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap.min.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-reboot.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap.css.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/slider.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-reboot.min.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-grid.min.css.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-reboot.css.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-grid.css.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-grid.min.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-grid.css to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap-reboot.min.css.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/css/bootstrap.min.css.map to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/jquery/jquery-1.12.0.min.js to Unix format...
    dos2unix: Binary symbol 0x1A found at line 2
    dos2unix: Skipping binary file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/img/light_on.png
    dos2unix: Skipping binary file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/img/light_off.png
    dos2unix: Skipping binary file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/img/unlock.png
    dos2unix: Skipping binary file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/dist/img/lock.png
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/public/zb_lib.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/cloudWebServer/cloudWebServer.js to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/package.json to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/manifest.yml to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/ibmConfig.json to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/README.html to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/.project to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/README.md to Unix format...
    dos2unix: converting file ./Projects/cloud_apps/ibm-webapp/.cfignore to Unix format...
    dos2unix: converting file ./Components/zmac/ZMAC.h to Unix format...
    dos2unix: converting file ./Components/hal/include/hal_board.h to Unix format...
    dos2unix: converting file ./Components/hal/include/hal_drivers.h to Unix format...
    dos2unix: converting file ./Components/hal/include/hal_timer.h to Unix format...
    dos2unix: converting file ./Components/hal/include/hal_key.h to Unix format...
    dos2unix: converting file ./Components/hal/include/hal_led.h to Unix format...
    dos2unix: converting file ./Components/hal/include/hal_uart.h to Unix format...
    dos2unix: converting file ./Components/mt/MT_RPC.h to Unix format...
    dos2unix: converting file ./Components/mt/MT.h to Unix format...
    dos2unix: converting file ./Components/mac/include/mac_api.h to Unix format...
    dos2unix: converting file ./Components/stack/sys/ZGlobals.h to Unix format...
    dos2unix: converting file ./Components/stack/sec/ssp.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/nwk_bufs.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/AssocList.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/nwk.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/stub_aps.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/rtg.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/APSMEDE.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/NLMEDE.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/BindingTable.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/reflecttrack.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/nwk_util.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/APS.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/nwk_globals.h to Unix format...
    dos2unix: converting file ./Components/stack/nwk/aps_groups.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_hvac.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_ss.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_hvac.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_poll_control.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_lighting.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_ss.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_general.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_green_power.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_lighting.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_green_power.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_ezmode.h to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_closures.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_general.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_poll_control.c to Unix format...
    dos2unix: converting file ./Components/stack/zcl/zcl_closures.h to Unix format...
    dos2unix: converting file ./Components/stack/gp/gp_common.c to Unix format...
    dos2unix: converting file ./Components/stack/gp/gp_proxyTbl.c to Unix format...
    dos2unix: converting file ./Components/stack/gp/dGP_stub.h to Unix format...
    dos2unix: converting file ./Components/stack/gp/gp_common.h to Unix format...
    dos2unix: converting file ./Components/stack/gp/gp_interface.h to Unix format...
    dos2unix: converting file ./Components/stack/gp/cGP_stub.h to Unix format...
    dos2unix: converting file ./Components/stack/af/AF.h to Unix format...
    dos2unix: converting file ./Components/stack/zdo/ZDApp.h to Unix format...
    dos2unix: converting file ./Components/stack/zdo/ZDProfile.h to Unix format...
    dos2unix: converting file ./Components/stack/zdo/ZDObject.h to Unix format...
    dos2unix: converting file ./Components/stack/zdo/ZDConfig.h to Unix format...
    dos2unix: converting file ./Components/stack/zdo/ZDSecMgr.h to Unix format...
    dos2unix: converting file ./Components/services/saddr/saddr.h to Unix format...
    dos2unix: converting file ./Components/services/saddr/saddr.c to Unix format...
    dos2unix: converting file ./build_all to Unix format...
    dos2unix: converting file ./scripts/package_builder to Unix format...
    dos2unix: converting file ./setup.sh to Unix format...
    SUCCESS: Converted Scripts to Unix Line endings
    Entered /Projets/node/nodejs_zb_gateway Directory
    Installing Node Modules
    npm WARN deprecated json3@3.2.6: Please use the native JSON object instead of JSON 3
    npm WARN deprecated axios@0.5.4: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
    added 232 packages, and audited 233 packages in 12s
    2 packages are looking for funding
      run `npm fund` for details
    14 vulnerabilities (2 low, 4 moderate, 8 high)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    SUCCESS: Installed all Node Modules Successfully
    Make build_all executable
    SUCCESS: build_all script is now executable
    Make scripts/ executable
    SUCCESS: scripts/ folder is now executable
    Run ./build_all
    SVN Version =  Unversioned directory
    Main project\'s base directory: GATEWAY=/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source (leave blank to use the detault)
    Project output subdirectory: PKGS_OUTPUT_DIR=/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/out (leave blank to use the detault)
    Building RUNTIME package for IMX8 platform
    Cleaning all
    if test -d out; then rm -rf out; fi
    rm -f project_file_list.txt
    Check existance of output folder
    if test ! -d out; then mkdir out; fi
    COMPILING SERVER FOR ARM BEAGLE BONE
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost'
    Compiling ipclib/server/npi_lnx_ipc.c ...
    make[1]: arm-linux-gnueabihf-gcc: Command not found
    make[1]: *** [makefile:211: out/npi_lnx_ipc.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost'
    make: *** [makefile:98: arch-all-arm] Error 2
    Cleaning up out/*
    COMPILING APP FOR ARM
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/zstackserverznp'
    Compiling osal_zstack_server_znp.c ...
    make[1]: aarch64-poky-linux-gcc: Command not found
    make[1]: *** [Makefile:136: out/osal_zstack_server_znp.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/zstackserverznp'
    make: *** [Makefile:89: arch-all-arm] Error 2
    Cleaning all
    /bin/rm -f project_file_list.txt
    /bin/rm -f actual_standard_project_file_list.txt
    /bin/rm -f actual_specific_project_file_list.txt
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/nwkmgr'
    Compiling ../srvepconfig/serverep.c ...
    make[1]: *** [Makefile:200: out/serverep.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/nwkmgr'
    make: *** [Makefile:106: arch-all-arm] Error 2
    Cleaning all
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/hagateway'
    make[1]: *** [Makefile:218: out/serverep.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/hagateway'
    make: *** [Makefile:130: arch-all-arm] Error 2
    Cleaning all
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/otaserver'
    Compiling ../zstackpb/zstack.pb-c.c ...
    make[1]: *** [Makefile:172: out/zstack.pb-c.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/otaserver'
    make: *** [Makefile:113: arch-all-arm] Error 2
    Cleaning up ./out/*
    if test -d ./out; then rm -rf ./out; fi
    rm -f main.bin
    if test ! -d ./out; then mkdir ./out; fi
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/demo/project'
    Compiling main.c ...
    make[1]: *** [makefile:123: out/main.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/demo/project'
    make: *** [makefile:75: arch-all-arm] Error 2
    rm -rf *.o sbl_tool.bin
    aarch64-poky-linux-gcc -Wall -DVERSION_NUMBER="0.1"  -D_GNU_SOURCE -DxHAL_UART_SPI -c -o main.o ../Source/main.c
    /bin/sh: 1: aarch64-poky-linux-gcc: not found
    make: *** [Makefile:31: main.o] Error 127
    rm -rf *.o gw_soc_fw_version_query.bin
    make: *** [Makefile:30: main.o] Error 127
    Cleaning up out/*
    /bin/rm -f usbreset.bin out/*
    /bin/rm -f *project_file_list.txt
    VPATH is .
    make[1]: Entering directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/usbreset/project'
    Compiling ../source/usbreset.c ...
    make[1]: *** [makefile:80: out/usbreset.o] Error 127
    make[1]: Leaving directory '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/usbreset/project'
    make: *** [makefile:39: arch-all-arm] Error 2
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/RemoTI-Linux-master//Projects/tools/LinuxHost/out/NPI_lnx_arm_server': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/zstackserverznp/out/ZLSZNP_arm': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/nwkmgr/out/NWKMGR_SRVR_arm': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/hagateway/out/GATEWAY_SRVR_arm': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/otaserver/out/OTA_SRVR_arm': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/demo/project/main.bin': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/sbl_tool/project/sbl_tool.bin': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/version_query_minitool/project/gw_soc_fw_version_query.bin': No such file or directory
    cp: cannot stat '/home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/Projects/zstack/linux/usbreset/project/usbreset.bin': No such file or directory
    Package verification results:
    ERROR: 16 error(s) occured during make
    diff /home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/out/content.txt /home/user/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/out/expected_content.txt
    4a5
    > ./Precompiled/app/main.bin
    15a17
    > ./Precompiled/servers/GATEWAY_SRVR_arm
    16a19
    > ./Precompiled/servers/NPI_lnx_arm_server
    17a21,22
    > ./Precompiled/servers/NWKMGR_SRVR_arm
    > ./Precompiled/servers/OTA_SRVR_arm
    21a27
    > ./Precompiled/servers/ZLSZNP_arm
    22a29,30
    > ./Precompiled/tools/gw_soc_fw_version_query.bin
    > ./Precompiled/tools/sbl_tool.bin
    24a33
    > ./Precompiled/tools/usbreset.bin
    ERROR: Content verification failed
    mv: target 'directory.tar' is not a directory
    ERROR: RUNTIME package for arm creation failed. See details above. Output folder/tar name prefixed with "ERROR_."
    SUCCESS: build_all finished.
    ./setup.sh: line 156: cd: out/Precompiled/: No such file or directory
    Entered Precompiled directory.
    app/
    misc/
    misc/ota_sample_images/
    misc/ota_sample_images/5678-1234-0000AAAA.zigbee
    misc/ota_sample_images/5678-1234-0000BBBB.zigbee
    misc/CC2531-GW-ZNP_39203.bin
    protobuf/
    protobuf/libprotobuf-c.so.1.0.0
    servers/
    servers/track_servers
    servers/gateway_config.tlg
    servers/config.ini
    servers/nwkmgr_config.ini
    servers/gateway_config.ini
    servers/sample_app_ota.cfg
    servers/zigbeeHAgw
    servers/start_application
    tools/
    tools/soc_reset_hold
    tools/soc_reset_release
    SUCCESS: Extracted binaries
    Entered servers/ directory
    Make apps exe, copy protobuf files
    SUCCESS: Made servers and applications executable
    SUCCESS: Made /tools/ folder executable
    Copy Protobuf Files to /usr/lib directory
    SUCCESS: Copied Protobuf Files
    ********** SETUP SUCCESSFUL! **********
     --------- Getting Started Tips -----------
    Navigate to Node Scripts ==> cd Projects/node
    Start Linux Zigbee Gateway and Node.js Zigbee Local Gateway ==> sudo ./start_local.sh
    Start Linux Zigbee Gateway and Node.js IBM Gateway ==> sudo ./start_ibm.sh
    Start Linux Zigbee Gateway Only ==> sudo ./start_gateway.sh
    Kill All Gateways ==> sudo ./end.sh
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ ls
    build_all  Components  ERROR__out  Projects  scripts  setup.sh
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ ls ERROR__out/
    content.txt  expected_content.txt  Precompiled  Precompiled.tar
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ ls ERROR__out/Precompiled
    Precompiled/     Precompiled.tar
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ ls ERROR__out/Precompiled/
    app/      misc/     protobuf/ servers/  tools/
    user@user-pc5:~/zstack_i.MX8_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source$ ls ERROR__out/Precompiled/servers/
    config.ini          gateway_config.tlg  nwkmgr_config.ini   start_application  zigbeeHAgw
    gateway_config.ini  NPI_Gateway.cfg     sample_app_ota.cfg  track_servers
    build_x86.log
    ./content.txt
    ./Precompiled
    ./Precompiled/app
    ./Precompiled/misc
    ./Precompiled/misc/CC2531-GW-ZNP_39203.bin
    ./Precompiled/misc/ota_sample_images
    ./Precompiled/misc/ota_sample_images/5678-1234-0000AAAA.zigbee
    ./Precompiled/misc/ota_sample_images/5678-1234-0000BBBB.zigbee
    ./Precompiled/protobuf
    ./Precompiled/protobuf/libprotobuf-c.so.1.0.0
    ./Precompiled/servers/config.ini
    ./Precompiled/servers/gateway_config.ini
    ./Precompiled/servers/gateway_config.tlg
    ./Precompiled/servers/NPI_Gateway.cfg
    ./Precompiled/servers/nwkmgr_config.ini
    ./Precompiled/servers/sample_app_ota.cfg
    ./Precompiled/servers/start_application
    ./Precompiled/servers/track_servers
    ./Precompiled/servers/zigbeeHAgw
    ./Precompiled/tools
    ./Precompiled/tools/soc_reset_hold
    ./Precompiled/tools/soc_reset_release
    ./content.txt
    ./Precompiled
    ./Precompiled/app
    ./Precompiled/misc
    ./Precompiled/tools
    6114.NPI_Gateway.cfgpackage_builder.dat
    user@user-pc5:~/zstack_x86_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/ERROR__out/Precompiled/servers$
    user@user-pc5:~/zstack_x86_compilation/Zigbee_3_0_Linux_Gateway_1_0_1/source/ERROR__out/Precompiled/servers$ sudo ./zigbeeHAgw
    Platform type selected automatically as x86.
    To override this selection, please stop this script, and then run it again,
    specifying the desired platform type at the command line:
      ./zigbeeHAgw [help | bbb | x86 ]
    running ./zigbeeHAgw on an x86
    done processing arguments, board type x86, target x86
    NPI                 is 'NPI_lnx_x86_server'
    Zstack linux server is 'ZLSZNP_x86'
    gateway server      is 'GATEWAY_SRVR_x86'
    network manager     is 'NWKMGR_SRVR_x86'
    OTA server     	  is 'OTA_SRVR_x86'
    Starting the ZigBee gateway subsystem
    making sure there are no lingering servers...
    there are 0 NPI servers
    there are 0 ZLS servers
    there are 0 GATEWAY servers
    there are 0 NWKMGR servers
    there are 0 OTA servers
    (total 0)
    done
    Executing reset from external scripts
    starting NPI, cmd ' ./NPI_lnx_x86_server NPI_Gateway.cfg ' on Tuesday 30 March 2021 06:37:14 PM IST
    [18:37:14.515,149] [NPISRVR/MAIN] UNMSKBL:
    [18:37:14.515,245] [NPISRVR/MAIN] UNMSKBL:  ************************************************
    [18:37:14.515,255] [NPISRVR/MAIN] UNMSKBL:  *  NPI Server v1.0.2d                          *
    [18:37:14.515,262] [NPISRVR/MAIN] UNMSKBL:  ************************************************
    [18:37:14.515,268] [NPISRVR/MAIN] UNMSKBL:
    Startup phase 1 completed successfully, server started (NPI_PID=282362) on Tuesday 30 March 2021 06:37:14 PM IST
    starting ZLSZNP, cmd ' ./ZLSZNP_x86 127.0.0.1:2533 config.ini ' on Tuesday 30 March 2021 06:37:14 PM IST
    [18:37:14.519,992] [Z_STACK/MAIN] UNMSKBL:
    [18:37:14.520,033] [Z_STACK/MAIN] UNMSKBL:  ************************************************
    [18:37:14.520,040] [Z_STACK/MAIN] UNMSKBL:  *  ZStack Server for ZNP v1.0.2d               *
    [18:37:14.520,045] [Z_STACK/MAIN] UNMSKBL:  ************************************************
    [18:37:14.520,049] [Z_STACK/MAIN] UNMSKBL:
    Startup phase 2 completed successfully, server started (ZLSZNP_PID=282368) on Tuesday 30 March 2021 06:37:14 PM IST
    starting NETWORK_MGR, cmd ' ./NWKMGR_SRVR_x86 127.0.0.1:2536 ' on Tuesday 30 March 2021 06:37:14 PM IST
    [18:37:14.551,195] [NWK_MGR/MAIN] UNMSKBL:
    [18:37:14.551,252] [NWK_MGR/MAIN] UNMSKBL:  ************************************************
    [18:37:14.551,259] [NWK_MGR/MAIN] UNMSKBL:  *  Network Manager Server v1.0.2d              *
    [18:37:14.551,264] [NWK_MGR/MAIN] UNMSKBL:  ************************************************
    [18:37:14.551,269] [NWK_MGR/MAIN] UNMSKBL:
    Startup phase 3 completed successfully, server started (NETWORK_MGR_PID=282375) on Tuesday 30 March 2021 06:37:14 PM IST
    starting GATEWAY_SERVER, cmd ' ./GATEWAY_SRVR_x86 127.0.0.1:2536 127.0.0.1:2540 ' on Tuesday 30 March 2021 06:37:14 PM IST
    [18:37:14.610,226] [GATEWAY/MAIN] UNMSKBL:
    [18:37:14.610,328] [GATEWAY/MAIN] UNMSKBL:  ************************************************
    [18:37:14.610,336] [GATEWAY/MAIN] UNMSKBL:  *  Gateway Server v1.0.2d                      *
    [18:37:14.610,343] [GATEWAY/MAIN] UNMSKBL:  ************************************************
    [18:37:14.610,360] [GATEWAY/MAIN] UNMSKBL:
    Startup phase 4 completed successfully, server started (GATEWAY_SERVER_PID=282382) on Tuesday 30 March 2021 06:37:14 PM IST
    starting OTA_SERVER, cmd './OTA_SRVR_x86 127.0.0.1:2536 127.0.0.1:2540 ' on Tuesday 30 March 2021 06:37:14 PM IST
    [18:37:14.723,029] [OTASRVR/MAIN] UNMSKBL:
    [18:37:14.723,095] [OTASRVR/MAIN] UNMSKBL:  ************************************************
    [18:37:14.723,105] [OTASRVR/MAIN] UNMSKBL:  *  OTA Upgrade Server v1.0.2d                  *
    [18:37:14.723,112] [OTASRVR/MAIN] UNMSKBL:  ************************************************
    [18:37:14.723,118] [OTASRVR/MAIN] UNMSKBL:
    Startup phase 5 completed successfully, server started (OTA_SERVER_PID=282391) on Tuesday 30 March 2021 06:37:14 PM IST
    starting tracker with our pid ./zigbeeHAgw and pid list 282362 282368 282382 282391
    tracking 4 pids, 282362 282368 282382 282391
    when we see something missing we will send a SIGUSR2 to pid 282319
    waiting for netmgr to exit ( pid 282375 ) on Tuesday 30 March 2021 06:37:14 PM IST
    Vikas
  • It seems that you build x86 linux gateway which is not correct for your platform. You can refer to "BeagleBone Black Setup:" section in "Z-Stack Linux Gateway - Quick Start Guide" to build binary correctly for your i.Mx platform and make sure you do the step: "Ensure that the source/scripts/package_builder script has TARGET_PLATFORM set to "BEAGLEBONE_BLACK" (ie. export TARGET_PLATFORM="BEAGLEBONE_BLACK")"
  • Part Number: CC2652P
      npm audit fix
    Run ./build_all
    Cleaning all
    Cleaning up out/*
    Cleaning all
    Cleaning all
    Cleaning all
    Cleaning up ./out/*
    rm -f main.bin
    Cleaning up out/*
    VPATH is .
    4a5
    15a17
    16a19
    17a21,22
    21a27
    22a29,30
    24a33
    app/
    misc/
    protobuf/
    servers/
    servers/config.ini
    servers/zigbeeHAgw
    tools/
    0652.build_x86.log
    ./content.txt
    ./Precompiled
    ./Precompiled/app
    ./Precompiled/misc
    ./Precompiled/tools
    ./content.txt
    ./Precompiled
    ./Precompiled/app
    ./Precompiled/misc
    ./Precompiled/tools
    6445.NPI_Gateway.cfg8446.package_builder.dat
    (total 0)
    done
  • According to your 6562.build_imx8.log, it shows "make[1]: arm-linux-gnueabihf-gcc: Command not found" which means that you don't setup cross-compiler properly.
  • Hi Vikas, Barbara,
    The ZIGBEE-LINUX-SENSOR-TO-CLOUD example application has only been tested on a BeagleBone Black Debian v9.3 or Linux Ubuntu v18.04, developers will need to modify the setup accordingly to accommodate different operating systems.
    Ryan
  • Hi ,
        Is there an example to run on Linux Ubuntu 18.04,or userguide. I don't have BeagleBone Black.
    we have setup the cross compiler and now we get some files missing error while creating server.The object files are getting created the issue happens while linking.
    Attached the package_builder,Makefile and compilation log.
    Please let me know your input .
    # Makefile for NPI Server
    #Compilation output
    OBJS = out
    #temporary output for lib generation
    TEMP = temp
    #library to use
    LIBS_x86= -lpthread
    # -lusb-1.0
    LIBS_armBeagleBoard= -lpthread
    LIBS_arm= -lpthread
    LIBS_bbb= -lpthread
    LIBS_arago= -lpthread
    # -lusb-1.0
    LIBS_armBeagleBone= -lpthread
    # -lusb-1.0
    #include path
    INCLUDES= -I application\
    	-I ipclib/server \
    	-I ipclib/common \
    	-I ../../../../srvwrapper \
    	-I /opt/fsl-wayland/3.0/sysroots/aarch64-fsl-linux/usr/include
    #compilation tools
    CC_armBeagleBoard = arm-linux-gnueabihf-gcc
    CC_aragoBeagleBone = arm-arago-linux-gnueabi-gcc
    # arm-arago-gnueabi-gcc is for default Angstrom that comes with BeagleBone
    # The below line commented by sai
    #CC_armBeagleBone = arm-linux-gnueabihf-gcc
    CC_armBeagleBone = aarch64-poky-linux-gcc
    CC_armArago=arm-arago-linux-gnueabi-gcc
    # arm-linux-gnueabihf-gcc is for Ubuntu on BeagleBone Black
    # get it here: eewiki.net/display/linuxonarm/BeagleBone+Black#BeagleBoneBlack-ARMCrossCompiler:GCC
    CC_x86 = gcc
    #predefine
    #DEFINES = -DRNP_HOST -D__BIG_DEBUG__
    #DEFINES = -DRNP_HOST -DSRDY_INTERRUPT -DNPI_UNIX
    DEFINES = -DMRDY_EARLY_FIX -DRNP_HOST -DNPI_SPI=TRUE -DNPI_UART=TRUE -DNPI_I2C=TRUE -D__DEBUG_TIME__ -D__DEBUG_TIME__I2C -DSRDY_INTERRUPT -DSERVER_NAME=NPISRVR
    # -D__DEBUG_TIME__HID -D__DEBUG_MUTEX__ -DNPI_HID=TRUE
    #compilation Option
    COMPILO_FLAGS_x86 = "-Wall  $(INCLUDES) $(DEFINES) -m32 -D_GNU_SOURCE"
    #COMPILO_FLAGS_armBeagleBoard = "-Wall  $(INCLUDES) $(DEFINES) -mcpu=cortex-a8 -march=armv7-a"
    COMPILO_FLAGS_armBeagleBoard = "-Wall  $(INCLUDES) $(DEFINES) -tune=cortex-a9 -arch=armv7-a"
    #COMPILO_FLAGS_armBeagleBone = "-Wall  $(INCLUDES) $(DEFINES) -mcpu=cortex-a8 -march=armv7-a"
    COMPILO_FLAGS_armBeagleBone = "-Wall  $(INCLUDES) $(DEFINES) -mcpu=cortex-a53 -march=armv8-a"
    COMPILO_FLAGS_arago = "-Wall  $(INCLUDES) $(DEFINES) -mcpu=cortex-a8 -march=armv7-a"
    #list of object file to compile for the server
    SERVER_OBJS= \
    	$(OBJS)/npi_lnx_ipc.o \
    	$(OBJS)/npi_lnx_uart.o \
    	$(OBJS)/npi_lnx_spi.o \
    	$(OBJS)/npi_lnx_i2c.o \
    	$(OBJS)/hal_gpio.o \
    	$(OBJS)/hal_i2c.o \
    	$(OBJS)/trace.o \
    	$(OBJS)/hal_spi.o \
    	$(OBJS)/configparser.o
    #by default, do not use the library.
    #PROJ_OBJS=$(SERVER_OBJS)
    .PHONY: all clean lib create_output arch-all-x86 arch-all-arm arch-all-armBeagleBoard arch-all-armBeagleBone exec_all_x86 exec_all_armBeagleBoard exec_all_armBeagleBone arch-all-x86 clean_obj clean_obj2 arago bbb
    all: \
    	create_output \
    	clean_obj \
    	arch-all-x86 \
    	arch-all-arm \
    	clean_obj2 \
    	arch-all-armBeagleBoard \
    	clean_obj3 \
    	arch-all-armBeagleBone \
    create_output:
    	@echo "********************************************************"
    	@echo "Check existance of output folder"
    	-if test ! -d $(OBJS); then mkdir $(OBJS); fi
    arch-all-x86:
    	@echo "COMPILING NPI SERVER FOR x86"
    	@$(MAKE) COMPILO=$(CC_x86) COMPILO_FLAGS=$(COMPILO_FLAGS_x86) exec_all_x86
    	@if [ -n "$(EXTRACT_FILES)" ]; then echo $(MAKEFILE_LIST) | $(EXTRACT_FILES) >> project_file_list.txt; fi
    	@if [ -n "$(EXTRACT_FILES)" ]; then sort -u -V project_file_list.txt | grep -v /usr/ >actual_specific_project_file_list.txt; fi
    	@if [ -n "$(EXTRACT_FILES)" ]; then sort -u -V project_file_list.txt | grep /usr/ >actual_standard_project_file_list.txt; fi
    arch-all-arago:
    	@echo "COMPILING NPI SERVER FOR $@ "
    	@$(MAKE) COMPILO=$(CC_armArago) COMPILO_FLAGS=$(COMPILO_FLAGS_arago) exec_all_arago
    arch-all-arm:
    	@echo "COMPILING SERVER FOR ARM BEAGLE BONE"
    	@$(MAKE) COMPILO=$(CC_armBeagleBone) COMPILO_FLAGS=$(COMPILO_FLAGS_armBeagleBone) exec_all_arm
    bbb:
    	@$(MAKE) COMPILO=$(CC_armBeagleBone) COMPILO_FLAGS=$(COMPILO_FLAGS_armBeagleBone) exec_bbb
    arago:
    	@$(MAKE) COMPILO=$(CC_armArago) COMPILO_FLAGS=$(COMPILO_FLAGS_arago) exec_arago
    arch-all-armBeagleBoard:
    	@echo "COMPILING NPI SERVER FOR ARM BEAGLE BOARD"
    	@$(MAKE) COMPILO=$(CC_armBeagleBoard) COMPILO_FLAGS=$(COMPILO_FLAGS_armBeagleBoard) exec_all_armBeagleBoard
    arch-all-armBeagleBone:
    	@$(MAKE) COMPILO=$(CC_armBeagleBone) COMPILO_FLAGS=$(COMPILO_FLAGS_armBeagleBone) exec_all_armBeagleBone
    arch-all-aragoBeagleBone:
    	@$(MAKE) COMPILO=$(CC_aragoBeagleBone) COMPILO_FLAGS=$(COMPILO_FLAGS_armBeagleBone) exec_all_armBeagleBone
    exec_all_x86: $(OBJS)/NPI_lnx_x86_server
    exec_all_arm: $(OBJS)/NPI_lnx_arm_server
    exec_all_armBeagleBoard: $(OBJS)/NPI_lnx_armBeagleBoard_server
    exec_all_armBeagleBone: $(OBJS)/NPI_lnx_armBeagleBone_server
    exec_all_armBeagleBone: $(OBJS)/NPI_lnx_arago_server
    exec_bbb: $(OBJS)/NPI_lnx_bbb_server
    exec_arago: $(OBJS)/NPI_lnx_arago_server
    clean_obj:
    	@echo "Cleaning Existing object"
    	-if test -d $(OBJS); then rm -f $(OBJS)/*.o; fi
    clean_obj2:
    clean_obj3:
    clean:
    	@echo "Cleaning all"
    	-if test -d $(OBJS); then rm -rf $(OBJS); fi
    $(OBJS)/NPI_lnx_armBeagleBoard_server: $(SERVER_OBJS)
    	@echo "Building target" $@ "..."
    	@$(COMPILO) -o $@ $(SERVER_OBJS) $(LIBS_armBeagleBoard)
    $(OBJS)/NPI_lnx_armBeagleBone_server: $(SERVER_OBJS)
    	@$(COMPILO) -o $@ $(SERVER_OBJS) $(LIBS_armBeagleBone)
    $(OBJS)/NPI_lnx_arago_server: $(SERVER_OBJS)
    	@$(COMPILO) -o $@ $(SERVER_OBJS) $(LIBS_bbb)
    $(OBJS)/NPI_lnx_bbb_server: $(SERVER_OBJS)
    	@$(COMPILO) -o $@ $(SERVER_OBJS) $(LIBS_arago)
    $(OBJS)/NPI_lnx_x86_server: $(SERVER_OBJS)
    	@$(COMPILO) -m32 -o $@ $(SERVER_OBJS) $(LIBS_x86)
    $(OBJS)/NPI_lnx_arm_server: $(SERVER_OBJS)
    	@$(COMPILO) -o $@ $(SERVER_OBJS) $(LIBS_arm)
    $(OBJS)/npi_lnx_ipc.o: ipclib/server/npi_lnx_ipc.c
    	@echo "Compiling" $< "..."
    	@echo "Compiling" $(COMPILO) "..."
    	@echo "Compiling" $(COMPILO_FLAGS) "..."
    	@$(COMPILO) $(COMPILO_FLAGS) -c -o $@ $<
    	@if [ -n "$(EXTRACT_FILES)" ]; then $(COMPILO) -M $< $(COMPILO_FLAGS) | $(EXTRACT_FILES) >> project_file_list.txt; fi
    $(OBJS)/npi_lnx_spi.o: ipclib/server/npi_lnx_spi.c
    	@$(COMPILO) -c -o $@ $(COMPILO_FLAGS) $<
    $(OBJS)/npi_lnx_uart.o: ipclib/server/npi_lnx_uart.c
    $(OBJS)/npi_lnx_i2c.o: ipclib/server/npi_lnx_i2c.c
    #$(OBJS)/npi_lnx_hid.o: ipclib/server/npi_lnx_hid.c
    #	@echo "Compiling" $< "..."
    #	@$(COMPILO) -c -o $@ $(COMPILO_FLAGS) $<
    $(OBJS)/hal_spi.o: ipclib/server/hal_spi.c
    $(OBJS)/hal_i2c.o: ipclib/server/hal_i2c.c
    $(OBJS)/trace.o: ../../../../srvwrapper/trace.c
    $(OBJS)/configparser.o: ../../../../srvwrapper/configparser.c
    #$(OBJS)/hid.o: ipclib/server/hid.c
    $(OBJS)/hal_gpio.o: ipclib/server/hal_gpio.c
    1638.package_builder.dat
  • Apologies for the delayed response.
    It looks like real-ld is not able to find some libraries.
    Have you referred to some of these posts?
    - https://stackoverflow.com/questions/30600978/cpp-usr-bin-ld-cannot-find-lnameofthelibrary
    - https://stackoverflow.com/questions/6329887/compiling-problems-cannot-find-crt1-o
    - https://stackoverflow.com/questions/91576/crti-o-file-missing
    If this is related to cross compiling (using ubuntu) to imx8 platform, I would maybe re-direct you to either the imx8 manufacturer or the developers of the cross compiler.
  • Hi Toby Pan,
    Initially we were building gateway on ubuntu 20.04 and toolchain was build using yocto .
    Now we are building the gateway on Ubuntu 16.04 machine.
    Target platform is IMX8.
    The steps followed are :
    Step 1:
    Download the toolchain.
    gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu.tar.xz
    Step 2:
    Extract the tar file using
    tar -xvf gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu.tar.xz
    Step 3:
    Created the env.sh file
    $vi env.sh
    #!/bin/bash
    export PATH=$PATH:/media/acer/d16451e3-e767-4107-b519-6c8799a157ec/vineesha/linaro_toolchain/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/bin
    export ARCH=arm
    export CROSS_COMPILE=aarch64-linux-gnu
    export CC=aarch64-linux-gnu-gcc
    Step 4:
    Run the environment file using   $. env.sh
    Copied the Libraries to Zigbee source:
    /usr/lib64$ ls libprotobuf-c.
    libprotobuf-c.a         libprotobuf-c.so        libprotobuf-c.so.1      libprotobuf-c.so.1.0.0
    acer@acer-Aspire-4738:/usr/lib64$ cp libprotobuf-c.* /media/acer/d16451e3-e767-4107-b519-6c8799a157ec/vineesha/Mindteck/Zigbee_3_0_Linux_Gateway_1_0_1_linaro/source/Projects/zstack/linux/protobuf-c/lib/arm/
    Copied the Libraries to Toolchain:
    acer@acer-Aspire-4738:/usr/lib64$ cp libprotobuf-c.*  /linaro_toolchain/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/lib
    Now are getting erros related to libprotobuf.
    Attached the build log for your reference. Please let me know your input on this.
    VikasZigbee_cross_compilation_log_imx8mm_16.04.docx
  • May need to cross-compile the protobuf-c libraries themselves, similar to this post: https://e2e.ti.com/support/wireless-connectivity/zigbee-thread-group/zigbee-and-thread/f/zigbee-thread-forum/993930/running-z-stack-linux-on-raspberry-pi-zero-w/3675900?tisearch=e2e-sitesearch&keymatch=protobuf#3675900
    The default ones we provide are in C:\ti\Zigbee_3_0_Linux_Gateway_1_0_1\source\Projects\zstack\linux\protobuf-c\lib.
