Other Parts Discussed in Thread: CC2650
Hello All,
I added off-chip OAD into CC2640R2F's Multi-role example of BLE SDK v2.20.00.49 by following instructions of SimpleLink Academy's Enhanced OAD section. However, I needed to enable Cache as RAM to increase MAX_NUM_BLE_CONNS. I expect that somebody can ask same question so that I post this on E2E.
What do I need to change in default cc26xx_app_oad,cmd? It seems that linker command file isn't suitable with Cache as RAM.
Building target: "multi_role_cc2640r2lp_app.out"
Invoking: ARM Linker
"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.2.LTS/bin/armcl" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/config/factory_config.opt" --cmd_file="C:/ti/OAD_multi_role_CC2640R2F/multi_role_cc2640r2lp_stack_library/TOOLS/build_config.opt" --cmd_file="C:/ti/OAD_multi_role_CC2640R2F/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_compiler_defines.bcfg" -mv7M3 --code_state=16 -me -O4 --opt_for_speed=0 --define=DeviceFamily_CC26X0R2 --define=BOARD_DISPLAY_USE_LCD=0 --define=BOARD_DISPLAY_USE_UART=1 --define=BOARD_DISPLAY_USE_UART_ANSI=1 --define=CACHE_AS_RAM --define=CC2640R2_LAUNCHXL --define=CC26XX --define=CC26XX_R2 --define=ICALL_EVENTS --define=ICALL_JT --define=ICALL_LITE --define=ICALL_MAX_NUM_ENTITIES=6 --define=ICALL_MAX_NUM_TASKS=3 --define=ICALL_STACK0_ADDR --define=MAX_NUM_BLE_CONNS=4 --define=POWER_SAVING --define=TBM_ACTIVE_ITEMS_ONLY --define=USE_ICALL --define=MAX_PDU_SIZE=251 --define=SPLIT_APP_STACK_IMAGE --define=xdc_runtime_Assert_DISABLE_ALL --define=xdc_runtime_Log_DISABLE_ALL -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi -z -m"multi_role_cc2640r2lp_app.map" --heap_size=0 --stack_size=256 -i"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.2.LTS/lib" -i"C:/ti/ccsv8/tools/compiler/ti-cgt-arm_18.1.2.LTS/include" --reread_libs --define=CC26X0ROM=2 --define=CACHE_AS_RAM=1 --define=OAD_IMG_E=1 --diag_suppress=16002-D --diag_suppress=10247-D --diag_suppress=10325-D --diag_suppress=10229-D --diag_suppress=16032-D --diag_suppress=10068-D --diag_wrap=off --display_error_number --warn_sections --xml_link_info="multi_role_cc2640r2lp_app_linkInfo.xml" --rom_model -o "multi_role_cc2640r2lp_app.out" "./Application/bim_util.obj" "./Application/board_key.obj" "./Application/hal_assert.obj" "./Application/multi_role.obj" "./Application/multi_role_menu.obj" "./Application/two_btn_menu.obj" "./Application/util.obj" "./Drivers/ECC/ECCROMCC26XX.obj" "./Drivers/RF/RFCC26XX_singleMode.obj" "./Drivers/TRNG/TRNGCC26XX.obj" "./ICall/icall.obj" "./ICall/icall_cc2650.obj" "./ICall/icall_user_config.obj" "./ICallBLE/ble_user_config.obj" "./ICallBLE/icall_api_lite.obj" "./Middleware/extflash/ExtFlash.obj" "./OAD/crc32.obj" "./OAD/flash_interface_ext_rtos.obj" "./OAD/oad.obj" "./OAD/oad_image_header_app.obj" "./OAD/oad_util.obj" "./PROFILES/devinfoservice.obj" "./PROFILES/gatt_uuid.obj" "./PROFILES/gattservapp_util.obj" "./PROFILES/multi.obj" "./PROFILES/simple_gatt_profile.obj" "./Startup/board.obj" "./Startup/find_stack_entry.obj" "./Startup/main.obj" -l"configPkg/linker.cmd" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/devices/cc26x0r2/driverlib/bin/ccs/driverlib.lib" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/kernel/tirtos/packages/ti/dpl/lib/dpl_cc26x0r2.aem3" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/drivers/lib/drivers_cc26x0r2.aem3" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/display/lib/display.aem3" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/grlib/lib/ccs/m3/grlib.a" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/rom/ble_rom_releases/cc26xx_r2/Final_Release/common_r2.symbols" -l"C:/ti/OAD_multi_role_CC2640R2F/multi_role_cc2640r2lp_stack_library/TOOLS/ccs_linker_defines.cmd" -l"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/common/cc26xx/ccs/cc26xx_app_oad.cmd" -llibc.a
<Linking>
"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/common/cc26xx/ccs/cc26xx_app_oad.cmd", line 343: warning #10190-D: absolute symbol "heapStart" being redefined
"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/common/cc26xx/ccs/cc26xx_app_oad.cmd", line 348: warning #10097: memory range not found: GPRAM on page 0
"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/common/cc26xx/ccs/cc26xx_app_oad.cmd", line 345: error #10265: no valid memory range(null) available for placement of ".bss"
"C:/ti/simplelink_cc2640r2_sdk_2_20_00_49/source/ti/blestack/common/cc26xx/ccs/cc26xx_app_oad.cmd", line 345: error #10099-D: program will not fit into available memory. run placement with alignment fails for section ".bss" size 0xb59
error #10099-D: program will not fit into available memory. run placement with alignment fails for section ".TI.noinit" size 0
error #10010: errors encountered during linking; "multi_role_cc2640r2lp_app.out" not built
>> Compilation failure
makefile:199: recipe for target 'multi_role_cc2640r2lp_app.out' failed
gmake[1]: *** [multi_role_cc2640r2lp_app.out] Error 1
makefile:192: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
Richard Park
