Other Parts Discussed in Thread: CC3220SF, CC3220SDK, UNIFLASH
I'm trying to import the SimpleLink OTA library into a project with a CC3220SF module, but I'm getting the error:
Error: Import failed for project 'ota' because its meta-data cannot be interpreted. Please contact support.
I've seen other people on the forum run into similar issues, and frequently they're running an old version of CCS or the SDK, but I don't think that's the problem here.
For anyone else following along, the OTA library has .h files that you have to modify, so you can't just build a precompiled lib into your project.
Relevant info:
- I use the TI default directory locations
- I'm running CCS version 7.3.0.00019
- I'm using version 1.50 of the CC32XX SDK (C:\ti\simplelink_cc32xx_sdk_1_50_00_06)
- I'm not trying to copy the OTA library into my workspace
- I tried restarting CCS and re-importing
- I'll attach my main project's .cproject, .project, and .ccsproject files in case they're useful, but I don't see anything that looks wrong
Any thoughts? Some config file somewhere that needs to be reset?
Thanks...
