Hi expert,
The default configuration is CPU@1Ghz + DRAM@400Mhz on J4, but we found the performance will increase 20% while using configuration CPU@900Mhz + DRAM@300Mhz.
It sounds not reasonable please also refer the attached file.
Could you please help
-1-
Is possible to measure the CPU clock on board(e.g. is there any hardware monitor pin which can be used to measure the CPU clock)?
-2-
Could you please guide us the register settings of CPU@1Ghz and CPU@900Mhz (e.g. MPU PLL settings + PMIC LDO settings)?
-3-
Could you please guide us how to check the DRAM timing parameters is proper settings? Is there any tool which can be used ?
Joe
