Configuring BeagleBone White and OpenGL
Other Parts Discussed in Thread: DA8XX
I've been having issues getting the PowerVR driver working with the latest 06.00.00.00 SDK on a Beaglebone white. Here is break down of the steps I've taken so far:
Compiling TI EZSDK 06.00.00.00 for BeagleBone White with LCD7 Cape
1. Install Sitara SDK (ti-sdk-am335x-evm-06.00.00.00-Linux-x86-Install)
2. Clone sitara-board-linux git tree
    • git clone git://gitorious.org/sitara-board-port/sitara-board-port-linux.git
3. Pull template, MMC/SD support, Ethernet, and LCD support tags
    • git checkout 06.00.00.00-template
    • git checkout 06.00.00.00-mmc
    • git checkout 06.00.00.00-ethernet
    • git checkout 06.00.00.00-touchscreen
4. Configure make
    • make ARCH=arm CROSS_COMPILE=/home/sitara/ti-sdk-am335x-evm-06.00.00.00/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf-     tisdk_am335x-evm_defconfig
5. Build Kernel
    • make ARCH=arm CROSS_COMPILE=/home/sitara/ti-sdk-am335x-evm-06.00.00.00/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf- uImage
6. Build Modules
    • make ARCH=arm CROSS_COMPILE=/home/sitara/ti-sdk-am335x-evm-06.00.00.00/linux-devkit/sysroots/i686-arago-linux/usr/bin/arm-linux-gnueabihf- modules
7. Install Modules
    • sudo make ARCH=arm INSTALL_MOD_PATH=/home/sitara/ti-sdk-am335x-evm-06.00.00.00/targetNFS modules_install
8. Install Graphics SDK
    • /home/sitara/ti-sdk-am335x-evm-06.00.00.00/Graphics_SDK_setuplinux_4_09_00_01_hardfp_minimal_demos.bin
    • Install es8.x drivers to /home/sitara/Graphics_SDK_4_09_00_01
9. Modify Rules.make file to call out file locations per below:
    • HOME=/home/sitara/
    • CSTOOL_DIR=/home/sitara/ti-sdk-am335x-evm-06.00.00.00/linux-devkit/sysroots/i686-arago-linux/usr/
    • CSTOOL_PREFIX=arm-linux-gnueabihf-
    • KERNEL_INSTALL_DIR=/home/sitara/board-port/sitara-board-port-linux
    • TARGETFS_INSTALL_DIR=/home/sitara/ti-sdk-am335x-evm-06.00.00.00/targetNFS
    • GRAPHICS_INSTALL_DIR=/home/sitara/Graphics_SDK_4_09_00_01
10. Set source environment
    • export ARCH=arm
11. Build graphics SDK
    • make BUILD=release OMAPES=8.x all
12. Install graphics SDK
    • make BUILD=release OMAPES=8.x all install
13. Rebuild Kernel, Modules, and install modules (Steps 5,6,7)
14. Copy built uImage to /home/sitara/image
    • cp /home/sitara/board-port/sitara-board-port-linux/arch/arm/boot/uImage /home/sitara/image/uImage-board-port
15. Copy MLO and u-boot from prebuilt folder
    • cp /home/sitara/ti-sdk-am335x-evm-06.00.00.00/board-support/prebuilt-images/MLO-am335x-evm /home/sitara/image/MLO-board-port
    • cp /home/sitara/ti-sdk-am335x-evm-06.00.00.00/board-support/prebuilt-images/u-boot-am335x-evm.img /home/sitara/image/u-boot-board-port
16. Create SD card using create_sdcard script in SDK installation dir
Here is the what I get while booting:
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0+ (sitara@sitara-VM) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #8 Wed Jul 3 08:53:20 CDT 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext3 rootwait ip=none
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 253296k/253296k available, 8848k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0595000 (5684 kB)
[ 0.000000] .init : 0xc0595000 - 0xc05d0000 ( 236 kB)
[ 0.000000] .data : 0xc05d0000 - 0xc0638918 ( 419 kB)
[ 0.000000] .bss : 0xc063893c - 0xc0667624 ( 188 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000122] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.058532] pid_max: default: 32768 minimum: 301
[ 0.058654] Security Framework initialized
[ 0.058746] Mount-cache hash table entries: 512
[ 0.059143] CPU: Testing write buffer coherency: ok
[ 0.079650] omap_hwmod: pruss: failed to hardreset
[ 0.080841] print_constraints: dummy:
[ 0.081207] NET: Registered protocol family 16
[ 0.083343] OMAP GPIO hardware version 0.1
[ 0.085937] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.088439] da8xx_lcdc.0: alias fck already exists
[ 0.088775] _omap_mux_get_by_name: Could not find signal ain0.ain0
[ 0.088806] _omap_mux_get_by_name: Could not find signal ain1.ain1
[ 0.088806] _omap_mux_get_by_name: Could not find signal ain2.ain2
[ 0.088836] _omap_mux_get_by_name: Could not find signal ain3.ain3
[ 0.088836] _omap_mux_get_by_name: Could not find signal vrefp.vrefp
[ 0.088867] _omap_mux_get_by_name: Could not find signal vrefn.vrefn
[ 0.089263] omap_hsmmc.0: alias fck already exists
[ 0.090362] omap2_mcspi.1: alias fck already exists
[ 0.090606] omap2_mcspi.2: alias fck already exists
[ 0.091522] edma.0: alias fck already exists
[ 0.091552] edma.0: alias fck already exists
[ 0.118682] bio: create slab <bio-0> at 0
[ 0.120941] SCSI subsystem initialized
[ 0.122558] usbcore: registered new interface driver usbfs
[ 0.122863] usbcore: registered new interface driver hub
[ 0.123077] usbcore: registered new device driver usb
[ 0.125030] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.126129] Switching to clocksource gp timer
[ 0.141571] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.141967] NET: Registered protocol family 2
[ 0.142181] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.142486] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.142639] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.142730] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.142730] TCP reno registered
[ 0.142761] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.142791] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.143005] NET: Registered protocol family 1
[ 0.143249] RPC: Registered named UNIX socket transport module.
[ 0.143280] RPC: Registered udp transport module.
[ 0.143280] RPC: Registered tcp transport module.
[ 0.143280] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.143554] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.155548] VFS: Disk quotas dquot_6.5.2
[ 0.155609] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.156158] msgmni has been set to 494
[ 0.159454] alg: No test for stdrng (krng)
[ 0.160125] io scheduler noop registered
[ 0.160156] io scheduler deadline registered
[ 0.160217] io scheduler cfq registered (default)
[ 0.161560] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel
[ 0.172943] Console: switching to colour frame buffer device 100x30
[ 0.179840] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.674224] console [ttyO0] enabled
[ 0.678497] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.686309] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.694122] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 0.701904] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 0.709655] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 0.717926] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
[ 0.734283] brd: module loaded
[ 0.742401] loop: module loaded
[ 0.745880] i2c-core: driver [tsl2550] using legacy suspend method
[ 0.752380] i2c-core: driver [tsl2550] using legacy resume method
[ 0.761108] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.768280] omap2-nand driver initializing
[ 0.772735] OneNAND driver initializing
[ 0.778015] CAN device driver interface
[ 0.782043] CAN bus driver for Bosch D_CAN controller 1.0
[ 0.836669] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 0.843139] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 0.850341] davinci_mdio.0: probed
[ 0.853912] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 0.862823] usbcore: registered new interface driver zd1201
[ 0.868927] usbcore: registered new interface driver cdc_ether
[ 0.875183] usbcore: registered new interface driver cdc_eem
[ 0.881256] usbcore: registered new interface driver dm9601
[ 0.887145] cdc_ncm: 04-Aug-2011
[ 0.890655] usbcore: registered new interface driver cdc_ncm
[ 0.896575] Initializing USB Mass Storage driver...
[ 0.901855] usbcore: registered new interface driver usb-storage
[ 0.908111] USB Mass Storage support registered.
[ 0.913391] mousedev: PS/2 mouse device common for all mice
[ 0.920135] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input0
[ 0.928710] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[ 0.935729] am33xx-rtc: already running
[ 0.939910] i2c /dev entries driver
[ 0.943725] Linux video capture interface: v2.00
[ 0.948883] usbcore: registered new interface driver uvcvideo
[ 0.954864] USB Video Class driver (1.1.1)
[ 0.960083] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 0.966613] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[ 0.975341] cpuidle: using governor ladder
[ 0.980163] cpuidle: using governor menu
[ 0.986541] omap4_aes_mod_init: loading AM33X AES driver
[ 0.992248] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
[ 0.999023] omap4_aes_probe: probe() done
[ 1.003417] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
[ 1.009582] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
[ 1.027557] omap4_sham_probe: probe() done
[ 1.034240] usbcore: registered new interface driver usbhid
[ 1.040100] usbhid: USB HID core driver
[ 1.044891] usbcore: registered new interface driver snd-usb-audio
[ 1.053131] ALSA device list:
[ 1.056243] No soundcards found.
[ 1.059814] oprofile: hardware counters not available
[ 1.065063] oprofile: using timer interrupt.
[ 1.069580] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
[ 1.076324] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.082031] TCP cubic registered
[ 1.085418] NET: Registered protocol family 17
[ 1.090087] can: controller area network core (rev 20090105 abi 8)
[ 1.096618] NET: Registered protocol family 29
[ 1.101257] can: raw protocol (rev 20090105)
[ 1.105712] can: broadcast manager protocol (rev 20090105 t)
[ 1.111663] Registering the dns_resolver key type
[ 1.116668] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.124694] ThumbEE CPU extension supported.
[ 1.129211] mux: Failed to setup hwmod io irq -22
[ 1.134826] Power Management for AM33XX family
[ 1.139709] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 1.146392] Copied the M3 firmware to UMEM
[ 1.150756] Cortex M3 Firmware Version = 0x181
[ 1.156036] sr_init: platform driver register failed
[ 1.166625] clock: disabling unused clocks to save power
[ 1.185485] Detected MACID=50:56:63:c6:e6:94
[ 1.190704] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.199737] cpsw: Detected MACID = 50:56:63:c6:e6:95
[ 1.205474] mmc0: new high speed SDHC card at address 0007
[ 1.212463] omap_rtc am33xx-rtc: setting system clock to 2013-06-25 23:48:55 UTC (1372204135)
[ 1.221862] mmcblk0: mmc0:0007 SD08G 7.21 GiB
[ 1.228790] mmcblk0: p1 p2
[ 1.237335] EXT3-fs (mmcblk0p2): recovery required on readonly filesystem
[ 1.244415] EXT3-fs (mmcblk0p2): write access will be enabled during recovery
[ 10.683624] kjournald starting. Commit interval 5 seconds
[ 10.689483] EXT3-fs (mmcblk0p2): recovery complete
[ 10.703155] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 10.710418] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[ 10.717987] Freeing init memory: 236K
INIT: version 2.88 booting
Starting udev
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
[ 13.826629] EXT3-fs (mmcblk0p2): using internal journal
ALSA: Restoring mixer settings...
Configuring network interfaces... /usr/sbin/alsactl: load_state:1686: No soundcards found...
[ 14.491119] net eth0: CPSW phy found : id is : 0x7c0f1
udhcpc (v1.20.2) started
Sending discover...
Sending discover...
Sending discover...
No lease, failing
done.
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting Dropbear SSH server: dropbear.
Starting telnet daemon.
Performing wifi calibration...
rm: can't remove '/lib/firmware/ti-connectivity/wl1271-nvs.bin': No such file or directory
Error: Module wl12xx_sdio is not currently loaded
nl80211 not found.
FATAL: Module wl12xx_sdio not found.
Starting network benchmark server: netserver.
Starting syslogd/klogd: done
Starting thttpd.
Starting PVR
[ 24.616607] Disabling lock debugging due to kernel taint
[ 24.655670] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 24.664215] pgd = cf490000
[ 24.667022] [00000000] *pgd=8e05b831, *pte=00000000, *ppte=00000000
[ 24.673614] Internal error: Oops: 17 [#1]
[ 24.677795] Modules linked in: omaplfb(O+) pvrsrvkm(O)
[ 24.683166] CPU: 0 Tainted: G O (3.2.0+ #8)
[ 24.688934] PC is at AllocateDeviceID+0xc/0x54 [pvrsrvkm]
[ 24.694580] LR is at PVRSRVRegisterDCDeviceKM+0xfc/0x188 [pvrsrvkm]
[ 24.701110] pc : [<bf006ad4>] lr : [<bf0029a0>] psr: 40000013
[ 24.701141] sp : cf4e9e18 ip : cf4e9e28 fp : cf4e9e24
[ 24.713104] r10: bf037428 r9 : bf0371e0 r8 : bf037094
[ 24.718566] r7 : cf5b307c r6 : 00000000 r5 : cf5b3004 r4 : 00000000
[ 24.725372] r3 : cf4c6bc0 r2 : 00000001 r1 : cf4c6bc8 r0 : 00000000
[ 24.732177] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 24.739624] Control: 10c5387d Table: 8f490019 DAC: 00000015
[ 24.745605] Process modprobe (pid: 1312, stack limit = 0xcf4e82f0)
[ 24.752075] Stack: (0xcf4e9e18 to 0xcf4ea000)
[ 24.756622] 9e00: cf4e9e4c cf4e9e28
[ 24.765167] 9e20: bf0029a0 bf006ad4 ce07d140 cf4c6bc0 cf5b3000 bf03902c bf0370bc bf0370a8
[ 24.773681] 9e40: cf4e9e8c cf4e9e50 bf037cf8 bf0028b0 c01cc150 cf5c6010 cf5c6000 00000004
[ 24.782226] 9e60: 00000000 bf038ef8 bf038ef8 c0638940 cf4e8000 0000001c c0069754 bf03b000
[ 24.790771] 9e80: cf4e9e9c cf4e9e90 bf03b010 bf0379b0 cf4e9ef4 cf4e9ea0 c000876c bf03b00c
[ 24.799316] 9ea0: cf4e9ec4 cf4e9eb0 00000002 00000000 cf1e0300 d090d000 cf4e9ee4 cf4e9ec8
[ 24.807830] 9ec0: bf038ef8 bf038ef8 ce07d240 bf038ef8 bf038ef8 ce07d240 00000001 0000001c
[ 24.816375] 9ee0: c0069754 000007ed cf4e9fa4 cf4e9ef8 c006abec c0008650 bf038f04 c001a654
[ 24.824920] 9f00: 00000000 c0069854 d090f880 d0912904 00000000 bf038f40 cf6cf240 c05781b0
[ 24.833465] 9f20: 00000000 00000000 00000000 00000000 00000000 00000000 d090d000 00007da9
[ 24.842010] 9f40: d091242c d09122f5 d09145bc cf4c6bc0 00002034 000025c4 00000000 00000000
[ 24.850524] 9f60: 0000001e 0000001f 0000000f 0000000d 0000000c 00000000 00000002 00021f68
[ 24.859069] 9f80: 00000000 00021d80 00000080 c00148e8 cf4e8000 00000000 00000000 cf4e9fa8
[ 24.867614] 9fa0: c0014740 c006a814 00021f68 00000000 402c0000 00007da9 401d3230 00000002
[ 24.876159] 9fc0: 00021f68 00000000 00021d80 00000080 00021e80 00007da9 401d3230 00000000
[ 24.884674] 9fe0: 44baf5a0 be959980 401cbb24 44baf5b0 80000010 402c0000 fd030800 00086a02
[ 24.893218] Backtrace:
[ 24.895843] [<bf006ac8>] (AllocateDeviceID+0x0/0x54 [pvrsrvkm]) from [<bf0029a0>] (PVRSRVRegisterDCDeviceKM+0xfc/0x188 [pvrsrvkm])
[ 24.908142] [<bf0028a4>] (PVRSRVRegisterDCDeviceKM+0x0/0x188 [pvrsrvkm]) from [<bf037cf8>] (OMAPLFBInit+0x354/0x54c [omaplfb])
[ 24.920013] r7:bf0370a8 r6:bf0370bc r5:bf03902c r4:cf5b3000
[ 24.925964] [<bf0379a4>] (OMAPLFBInit+0x0/0x54c [omaplfb]) from [<bf03b010>] (OMAPLFB_Init+0x10/0x34 [omaplfb])
[ 24.936523] [<bf03b000>] (OMAPLFB_Init+0x0/0x34 [omaplfb]) from [<c000876c>] (do_one_initcall+0x128/0x1a8)
[ 24.946594] [<c0008644>] (do_one_initcall+0x0/0x1a8) from [<c006abec>] (sys_init_module+0x3e4/0x1b68)
[ 24.956237] [<c006a808>] (sys_init_module+0x0/0x1b68) from [<c0014740>] (ret_fast_syscall+0x0/0x30)
[ 24.965698] Code: e89da830 e1a0c00d e92dd800 e24cb004 (e5902000)
[ 24.972106] ---[ end trace 6bc764c963660d5e ]---
/etc/rc5.d/S30pvr-init: line 42: 1312 Segmentation fault modprobe omaplfb
FATAL: Module bufferclass_ti not found.
[ 25.080566] Unhandled fault: external abort on non-linefetch (0x1018) at 0x4012a014
/usr/bin/pvrsrvctl: SrvInit failed (already initialized?) (err=4)
Starting Lighttpd Web Server: 2013-06-25 23:49:18: (log.c.166) server started
lighttpd.
Starting Matrix GUI application.
ERROR: could not insert 'g_mass_storage': No such device
Any help or ideas would be greatly appreciated!
-Pat
  • Hi Pat,
    I suggest you should check below point based on the logs you have provided -
    Can you please check if the changes shown in below patch are already present in the kernel sources you are using - http://gitorious.org/rowboat/kernel/commit/d3ab5e87304b45dc594351ed091a6ae451f40de7?format=patch
    If the kernel source does not have the above changes, then you can build without using PM_RUNTIME command line option ie same way as you are building now. But if the kernel source already has the above changes present in the patch, then you should be building graphics SDK with PM_RUNTIME=1 command line option. Again, please note that building graphics SDK with PM_RUNTIME=1 command line option is required only if the changes that are part of above patch is already present in the kernel sources you are using. Otherwise you need not use PM_RUNTIME.
    Prathap.
  • Thanks so much for the reply Prathap! The kernel source I'm using does NOT contain the HWMOD patch. I have, however, tried compiling and testing the SGX driver with and without the PM_RUNTIME option at compilation. I get the "/usr/local/bin/pvrsrvctl: SrvInit failed (already initialized?) (err=4)" when I run  /etc/init.d/335x-demo. Sorry I probably should have mentioned that in my first post.
    -Pat
  • Hi Pat,
    Have you double checked/confirmed that the kernel source does not have sgx hwmod patch?
    If  the kernel does not contain the HWMOD patch, you need not build with PM_RUNTIME option.
    Please follow these steps (assuming the kernel sources do not have any sgx hwmod patch/changes) & you should get it working -
    1.Clean & Build graphics SDK as -
    make clean
    make BUILD=release OMAPES=8.x all_km.
    2.Install - sudo make BUILD=release OMAPES=8.x install.
    3.Make sure that by default ie as part of bootup rc scripts no graphics drivers are inserted & pvrsrvctl is not run by default during bootup. When the board boots up, issue lsmod to confirm that there are no sgx driver modules already inserted.
    4.Now run /etc/init.d/335x-demo.
    If this works, you can then make changes to run 335x-demo by default as part of your bootup scripts.
    If you are still facing an issue, you can apply the kernel source HWMOD patch & now try building graphics SDK with PM_RUNTIME=1.
    Please also see below thread where another user had reported a similar kind of problem & is now able to get it working as per the instructions provided -
    http://e2e.ti.com/support/arm/sitara_arm/f/791/p/275648/963030.aspx#963030
    Prathap.
  • Prathap,
    I removed all SGX driver insertions at startup and rebuilt the SGX modules (after make clean) with and without the PM_RUNTIME=1. I looked over the other forum post you noted in the last message and I see some differences in what Dima was seeing.
    After boot, I ran the /etc/init.d/335x-demo and I get this with and and without the PM_RUNTIME=1.
    Installation complete!
    You may now reboot your target.
    I then did the following:
    root@am335x-evm:/# modprobe pvrsrvkm
    root@am335x-evm:/# dmesg | tail
    [ 1.206909] Detected MACID=50:56:63:c6:e6:94
    [ 1.212585] cpsw: Detected MACID = 50:56:63:c6:e6:95
    [ 1.218933] omap_rtc am33xx-rtc: setting system clock to 2000-01-01 00:00:01 UTC (946684801)
    [ 1.237670] kjournald starting. Commit interval 5 seconds
    [ 1.243438] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
    [ 1.250701] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
    [ 1.258209] Freeing init memory: 236K
    [ 5.178039] EXT3-fs (mmcblk0p2): using internal journal
    [ 5.849548] net eth0: CPSW phy found : id is : 0x7c0f1
    [ 135.737243] Disabling lock debugging due to kernel taint
    root@am335x-evm:/# modprobe omaplfb
    [ 711.557342] Unable to handle kernel NULL pointer dereference at virtual address 00000000
    [ 711.565887] pgd = cf688000
    [ 711.568725] [00000000] *pgd=8f53f831, *pte=00000000, *ppte=00000000
    [ 711.575286] Internal error: Oops: 17 [#1]
    [ 711.579467] Modules linked in: omaplfb(O+) pvrsrvkm(O)
    [ 711.584838] CPU: 0 Tainted: G O (3.2.0-g8996363-dirty #1)
    [ 711.591857] PC is at AllocateDeviceID+0xc/0x54 [pvrsrvkm]
    [ 711.597534] LR is at PVRSRVRegisterDCDeviceKM+0xfc/0x188 [pvrsrvkm]
    [ 711.604064] pc : [<bf016ad4>] lr : [<bf0129a0>] psr: 40000013
    [ 711.604064] sp : cf6a5e18 ip : cf6a5e28 fp : cf6a5e24
    [ 711.616058] r10: bf047428 r9 : bf0471e0 r8 : bf047094
    [ 711.621490] r7 : cf67667c r6 : 00000000 r5 : cf676604 r4 : 00000000
    [ 711.628295] r3 : cf184680 r2 : 00000001 r1 : cf184688 r0 : 00000000
    [ 711.635131] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
    [ 711.642578] Control: 10c5387d Table: 8f688019 DAC: 00000015
    [ 711.648559] Process modprobe (pid: 2805, stack limit = 0xcf6a42f0)
    [ 711.654998] Stack: (0xcf6a5e18 to 0xcf6a6000)
    [ 711.659545] 5e00: cf6a5e4c cf6a5e28
    [ 711.668090] 5e20: bf0129a0 bf016ad4 cf564600 cf184680 cf676600 bf04902c bf0470bc bf0470a8
    [ 711.676635] 5e40: cf6a5e8c cf6a5e50 bf047cf8 bf0128b0 c01cc150 cf69e010 cf69e000 00000004
    [ 711.685150] 5e60: 00000000 bf048ef8 bf048ef8 c0638940 cf6a4000 0000001c c0069754 bf04b000
    [ 711.693695] 5e80: cf6a5e9c cf6a5e90 bf04b010 bf0479b0 cf6a5ef4 cf6a5ea0 c000876c bf04b00c
    [ 711.702239] 5ea0: cf6a5ec4 cf6a5eb0 00000002 00000000 cf679b80 d091e000 cf6a5ee4 cf6a5ec8
    [ 711.710784] 5ec0: bf048ef8 bf048ef8 cf564580 bf048ef8 bf048ef8 cf564580 00000001 0000001c
    [ 711.719299] 5ee0: c0069754 000007ed cf6a5fa4 cf6a5ef8 c006abec c0008650 bf048f04 c001a654
    [ 711.727844] 5f00: 00000000 c0069854 d092088c d0923910 00000000 bf048f40 cf4cab40 c05781c0
    [ 711.736389] 5f20: 00000000 00000000 00000000 00000000 00000000 00000000 d091e000 00007db5
    [ 711.744934] 5f40: d0923438 d0923301 d09255c8 cf184680 00002034 000025c4 00000000 00000000
    [ 711.753448] 5f60: 0000001e 0000001f 0000000f 0000000d 0000000c 00000000 00000002 00021f88
    [ 711.761993] 5f80: 00000000 00021d90 00000080 c00148e8 cf6a4000 00000000 00000000 cf6a5fa8
    [ 711.770538] 5fa0: c0014740 c006a814 00021f88 00000000 4038f000 00007db5 4017a230 00000002
    [ 711.779083] 5fc0: 00021f88 00000000 00021d90 00000080 00021e90 00007db5 4017a230 00000000
    [ 711.787597] 5fe0: 44baf5a0 be85e900 40172b24 44baf5b0 80000010 4038f000 00000000 00000000
    [ 711.796142] Backtrace:
    [ 711.798767] [<bf016ac8>] (AllocateDeviceID+0x0/0x54 [pvrsrvkm]) from [<bf0129a0>] (PVRSRVRegisterDCDeviceKM+0xfc/0x188 [pvrsrvkm])
    [ 711.811065] [<bf0128a4>] (PVRSRVRegisterDCDeviceKM+0x0/0x188 [pvrsrvkm]) from [<bf047cf8>] (OMAPLFBInit+0x354/0x54c [omaplfb])
    [ 711.822937] r7:bf0470a8 r6:bf0470bc r5:bf04902c r4:cf676600
    [ 711.828887] [<bf0479a4>] (OMAPLFBInit+0x0/0x54c [omaplfb]) from [<bf04b010>] (OMAPLFB_Init+0x10/0x34 [omaplfb])
    [ 711.839447] [<bf04b000>] (OMAPLFB_Init+0x0/0x34 [omaplfb]) from [<c000876c>] (do_one_initcall+0x128/0x1a8)
    [ 711.849517] [<c0008644>] (do_one_initcall+0x0/0x1a8) from [<c006abec>] (sys_init_module+0x3e4/0x1b68)
    [ 711.859161] [<c006a808>] (sys_init_module+0x0/0x1b68) from [<c0014740>] (ret_fast_syscall+0x0/0x30)
    [ 711.868591] Code: e89da830 e1a0c00d e92dd800 e24cb004 (e5902000)
    [ 711.875000] ---[ end trace bc316262f8bb1a00 ]---
    Segmentation fault
    root@am335x-evm:/# lsmod
    Module Size Used by
    omaplfb 15868 1
    pvrsrvkm 169061 1 omaplfb
    root@am335x-evm:/# ./gfx_check.sh
    WSEGL settings
    [default]
    WindowSystem=libpvrPVR2D_FRONTWSEGL.so
    #WindowSystem=libpvrPVR2D_FLIPWSEGL.so
    ARM CPU information
    Processor : ARMv7 Processor rev 2 (v7l)
    BogoMIPS : 718.02
    Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls
    CPU implementer : 0x41
    CPU architecture: 7
    CPU variant : 0x3
    CPU part : 0xc08
    CPU revision : 2
    Hardware : am335xevm
    Revision : 0000
    Serial : 0000000000000000
    SGX driver information
    Version SGX_DDK_Linux_CustomerTI sgxddk 19 1.9@2188537 (release) /home/sitara/Graphics_SDK_4_09_00_01/GFX_Linux_KM
    System Version String: None
    Framebuffer settings
    mode "800x480-62"
    # D: 30.000 MHz, H: 32.433 kHz, V: 61.895 Hz
    geometry 800 480 800 960 16
    timings 33333 39 39 29 13 47 2
    rgba 5/11,6/5,5/0,0/0
    endmode
    Frame buffer device information:
    Name : DA8xx FB Drv
    Address : 0x8f200000
    Type : PACKED PIXELS
    Visual : TRUECOLOR
    XPanStep : 0
    YPanStep : 1
    YWrapStep : 0
    LineLength : 1600
    Accelerator : No
    Rotation settings
    0
    Kernel Module information
    Module Size Used by
    omaplfb 15868 1
    Boot settings
    Linux Kernel version
    Linux am335x-evm 3.2.0-g8996363-dirty #1 Wed Jul 3 15:38:30 CDT 2013 armv7l GNU/Linux
    Is there anything else you'd like me to try?
    -Pat
  • I've got the SGX drivers loaded and they are working now. I believe the issue was that when I checked out the touchscreen branch from the repo I was using I blew away some important init routines.Thanks again Prathrap.
    -Pat
    What have you done to get it working?
    Alexander
  • Hi Alexander,
    I believe I pulled the GIT repo at https://gitorious.org/rowboat/kernel/ and compiled the kernel from that source. It included support for the 7" LCD cape. So essentially I replaced steps 2 & 3 with:
    git clone git://gitorious.org/rowboat/kernel.git
    All the other steps should be the same.
    Good luck!
    -Pat
  • Hi Patrick,
    I would like to create an OpenGL application for the beaglebone using Qt.
    I wonder whether your way works for me?
    Also, I would be glad if you could make a list in order to explain installation steps of the configuration for the beaglebone users who are willing to develop OpenGL applications on Qt like me.
    Thanks.
