Hi
I am trying to boot the file system using the USB Ethernet Gadget, so far I was able to boot the kernel, but once in the kernel, my computer doesn't recognize it as a USB Ethernet device anymore, and I am including the USB Gadget in the kernel build, I am using AM335x custom board. Any help would be appreciated
This is my kernel config file
# # Automatically generated file; DO NOT EDIT. # Linux/arm 3.12.10 Kernel Configuration # CONFIG_ARM=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_RWSEM_GENERIC_SPINLOCK=y CONFIG_ARCH_HAS_CPUFREQ=y CONFIG_ARCH_HAS_BANDGAP=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_DMA_NONCOHERENT=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_EXTABLE_SORT=y # # General setup # CONFIG_BROKEN_ON_SMP=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="" # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="" CONFIG_LOCALVERSION_AUTO=y CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_FHANDLE is not set # CONFIG_AUDIT is not set # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y # CONFIG_IRQ_DOMAIN_DEBUG is not set CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y CONFIG_KTIME_SCALAR=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_GENERIC_CLOCKEVENTS_BUILD=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_IRQ_TIME_ACCOUNTING is not set CONFIG_BSD_PROCESS_ACCT=y # CONFIG_BSD_PROCESS_ACCT_V3 is not set # CONFIG_TASKSTATS is not set # # RCU Subsystem # CONFIG_TREE_PREEMPT_RCU=y CONFIG_PREEMPT_RCU=y CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_FANOUT=32 CONFIG_RCU_FANOUT_LEAF=16 # CONFIG_RCU_FANOUT_EXACT is not set # CONFIG_TREE_RCU_TRACE is not set # CONFIG_RCU_BOOST is not set # CONFIG_RCU_NOCB_CPU is not set CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_LOG_BUF_SHIFT=16 CONFIG_GENERIC_SCHED_CLOCK=y # CONFIG_CGROUPS is not set # CONFIG_CHECKPOINT_RESTORE is not set # CONFIG_NAMESPACES is not set # CONFIG_UIDGID_STRICT_TYPE_CHECKS is not set # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y # CONFIG_RD_BZIP2 is not set # CONFIG_RD_LZMA is not set # CONFIG_RD_XZ is not set # CONFIG_RD_LZO is not set # CONFIG_RD_LZ4 is not set # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_HAVE_UID16=y CONFIG_EXPERT=y CONFIG_UID16=y # CONFIG_SYSCTL_SYSCALL is not set CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_PCI_QUIRKS=y # CONFIG_EMBEDDED is not set CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set CONFIG_VM_EVENT_COUNTERS=y CONFIG_COMPAT_BRK=y CONFIG_SLAB=y # CONFIG_SLUB is not set # CONFIG_SLOB is not set CONFIG_PROFILING=y CONFIG_OPROFILE=y CONFIG_HAVE_OPROFILE=y CONFIG_KPROBES=y CONFIG_JUMP_LABEL=y # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set CONFIG_KRETPROBES=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_ATTRS=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y CONFIG_HAVE_DMA_API_DEBUG=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y CONFIG_MODULE_FORCE_LOAD=y CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y CONFIG_MODVERSIONS=y CONFIG_MODULE_SRCVERSION_ALL=y # CONFIG_MODULE_SIG is not set CONFIG_BLOCK=y CONFIG_LBDAF=y # CONFIG_BLK_DEV_BSG is not set # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_CMDLINE_PARSER is not set # # Partition Types # CONFIG_PARTITION_ADVANCED=y # CONFIG_ACORN_PARTITION is not set # CONFIG_AIX_PARTITION is not set # CONFIG_OSF_PARTITION is not set # CONFIG_AMIGA_PARTITION is not set # CONFIG_ATARI_PARTITION is not set # CONFIG_MAC_PARTITION is not set CONFIG_MSDOS_PARTITION=y # CONFIG_BSD_DISKLABEL is not set # CONFIG_MINIX_SUBPARTITION is not set # CONFIG_SOLARIS_X86_PARTITION is not set # CONFIG_UNIXWARE_DISKLABEL is not set # CONFIG_LDM_PARTITION is not set # CONFIG_SGI_PARTITION is not set # CONFIG_ULTRIX_PARTITION is not set # CONFIG_SUN_PARTITION is not set # CONFIG_KARMA_PARTITION is not set CONFIG_EFI_PARTITION=y # CONFIG_SYSV68_PARTITION is not set # CONFIG_CMDLINE_PARTITION is not set # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" CONFIG_UNINLINE_SPIN_UNLOCK=y CONFIG_FREEZER=y # # System Type # CONFIG_MMU=y # CONFIG_ARCH_MULTIPLATFORM is not set # CONFIG_ARCH_INTEGRATOR is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_VERSATILE is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_CLPS711X is not set # CONFIG_ARCH_GEMINI is not set # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KIRKWOOD is not set # CONFIG_ARCH_MV78XX0 is not set # CONFIG_ARCH_ORION5X is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_MSM is not set # CONFIG_ARCH_SHMOBILE is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_S3C64XX is not set # CONFIG_ARCH_S5P64X0 is not set # CONFIG_ARCH_S5PC100 is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_SHARK is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_OMAP1 is not set CONFIG_ARCH_OMAP2PLUS=y # # Multiple platform selection # # # CPU Core family selection # CONFIG_ARCH_MULTI_V6=y CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # CONFIG_ARCH_MULTI_CPU_AUTO is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BCM2835 is not set # CONFIG_ARCH_CNS3XXX is not set CONFIG_GPIO_PCA953X=y # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_MXC is not set # # TI OMAP Common Features # # # OMAP Feature Selections # CONFIG_OMAP_DEBUG_DEVICES=y CONFIG_OMAP_DEBUG_LEDS=y CONFIG_OMAP_RESET_CLOCKS=y CONFIG_OMAP_MUX=y CONFIG_OMAP_MUX_DEBUG=y CONFIG_OMAP_MUX_WARNINGS=y CONFIG_OMAP_32K_TIMER=y # CONFIG_OMAP3_L2_AUX_SECURE_SAVE_RESTORE is not set CONFIG_OMAP_DM_TIMER=y CONFIG_OMAP_PM_NOOP=y CONFIG_MACH_OMAP_GENERIC=y CONFIG_ARCH_OMAP=y CONFIG_ARCH_OMAP2=y CONFIG_ARCH_OMAP3=y CONFIG_ARCH_OMAP4=y CONFIG_SOC_OMAP5=y CONFIG_SOC_AM33XX=y CONFIG_SOC_AM43XX=y # # TI OMAP2/3/4 Specific Features # CONFIG_ARCH_OMAP2PLUS_TYPICAL=y CONFIG_SOC_HAS_OMAP2_SDRC=y CONFIG_SOC_HAS_REALTIME_COUNTER=y CONFIG_SOC_DRA7XX=y # # OMAP Core Type # CONFIG_SOC_OMAP2420=y CONFIG_SOC_OMAP2430=y CONFIG_SOC_OMAP3430=y CONFIG_SOC_TI81XX=y CONFIG_OMAP_PACKAGE_ZAF=y CONFIG_OMAP_PACKAGE_ZAC=y CONFIG_OMAP_PACKAGE_CBB=y CONFIG_OMAP_PACKAGE_CUS=y CONFIG_OMAP_PACKAGE_CBP=y # # OMAP Board Type # CONFIG_MACH_OMAP2_TUSB6010=y CONFIG_MACH_OMAP_H4=y CONFIG_MACH_OMAP_2430SDP=y CONFIG_MACH_OMAP3_BEAGLE=y CONFIG_MACH_DEVKIT8000=y CONFIG_MACH_OMAP_LDP=y CONFIG_MACH_OMAP3530_LV_SOM=y CONFIG_MACH_OMAP3_TORPEDO=y CONFIG_MACH_OVERO=y CONFIG_MACH_OMAP3EVM=y CONFIG_MACH_OMAP3517EVM=y # CONFIG_MACH_CRANEBOARD is not set CONFIG_MACH_OMAP3_PANDORA=y CONFIG_MACH_TOUCHBOOK=y CONFIG_MACH_OMAP_3430SDP=y CONFIG_MACH_NOKIA_N800=y CONFIG_MACH_NOKIA_N810=y CONFIG_MACH_NOKIA_N810_WIMAX=y CONFIG_MACH_NOKIA_N8X0=y CONFIG_MACH_NOKIA_RM680=y CONFIG_MACH_NOKIA_RX51=y CONFIG_MACH_OMAP_ZOOM2=y CONFIG_MACH_OMAP_ZOOM3=y CONFIG_MACH_CM_T35=y CONFIG_MACH_CM_T3517=y CONFIG_MACH_CM_T3730=y CONFIG_MACH_IGEP0020=y CONFIG_MACH_IGEP0030=y CONFIG_MACH_SBC3530=y CONFIG_MACH_OMAP_3630SDP=y CONFIG_MACH_TI8168EVM=y CONFIG_MACH_TI8148EVM=y # CONFIG_OMAP3_EMU is not set # CONFIG_OMAP3_SDRC_AC_TIMING is not set CONFIG_OMAP4_ERRATA_I688=y # CONFIG_ARCH_PICOXCELL is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_SHMOBILE_MULTI is not set # CONFIG_ARCH_SUNXI is not set # CONFIG_ARCH_SIRF is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_WM8750 is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V6=y CONFIG_CPU_V7=y CONFIG_CPU_32v6=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV6=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V6=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V6=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y CONFIG_CPU_USE_DOMAINS=y # # Processor Features # # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set CONFIG_ARM_THUMB=y CONFIG_ARM_THUMBEE=y CONFIG_ARM_VIRT_EXT=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_DCACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_KUSER_HELPERS=y CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARCH_HAS_BARRIERS=y CONFIG_ARM_NR_BANKS=8 CONFIG_MULTI_IRQ_HANDLER=y # CONFIG_ARM_ERRATA_326103 is not set CONFIG_ARM_ERRATA_411920=y # CONFIG_ARM_ERRATA_430973 is not set # CONFIG_ARM_ERRATA_458693 is not set # CONFIG_ARM_ERRATA_460075 is not set CONFIG_PL310_ERRATA_588369=y CONFIG_ARM_ERRATA_720789=y CONFIG_PL310_ERRATA_727915=y # CONFIG_ARM_ERRATA_743622 is not set # CONFIG_ARM_ERRATA_751472 is not set CONFIG_ARM_ERRATA_754322=y # CONFIG_ARM_ERRATA_364296 is not set # CONFIG_PL310_ERRATA_769419 is not set CONFIG_ARM_ERRATA_775420=y # CONFIG_ARM_ERRATA_773022 is not set CONFIG_ARM_ERRATA_799270=y CONFIG_TI_PRIV_EDMA=y # # Bus support # CONFIG_PCI=y CONFIG_PCI_SYSCALL=y # CONFIG_PCI_MSI is not set # CONFIG_PCI_DEBUG is not set # CONFIG_PCI_REALLOC_ENABLE_AUTO is not set # CONFIG_PCI_STUB is not set # CONFIG_PCI_IOV is not set # CONFIG_PCI_PRI is not set # CONFIG_PCI_PASID is not set # # PCI host controller drivers # CONFIG_PCIE_DRA7XX=y CONFIG_PCIE_DW=y CONFIG_PCIEPORTBUS=y CONFIG_PCIEAER=y # CONFIG_PCIE_ECRC is not set # CONFIG_PCIEAER_INJECT is not set CONFIG_PCIEASPM=y # CONFIG_PCIEASPM_DEBUG is not set CONFIG_PCIEASPM_DEFAULT=y # CONFIG_PCIEASPM_POWERSAVE is not set # CONFIG_PCIEASPM_PERFORMANCE is not set CONFIG_PCIE_PME=y # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_HAVE_SMP=y # CONFIG_SMP is not set CONFIG_HAVE_ARM_SCU=y CONFIG_HAVE_ARM_ARCH_TIMER=y CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 # CONFIG_ARM_PSCI is not set CONFIG_ARCH_NR_GPIO=512 # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_PREEMPT_COUNT=y CONFIG_HZ_FIXED=0 # CONFIG_HZ_100 is not set CONFIG_HZ_200=y # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=200 CONFIG_SCHED_HRTICK=y CONFIG_AEABI=y CONFIG_OABI_COMPAT=y CONFIG_ARCH_HAS_HOLES_MEMORYMODEL=y # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set CONFIG_HAVE_ARCH_PFN_VALID=y CONFIG_HIGHMEM=y # CONFIG_HIGHPTE is not set CONFIG_HW_PERF_EVENTS=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_HAVE_MEMBLOCK=y CONFIG_MEMORY_ISOLATION=y # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_MIGRATION=y # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_ZONE_DMA_FLAG=0 CONFIG_BOUNCE=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 CONFIG_CROSS_MEMORY_ATTACH=y CONFIG_NEED_PER_CPU_KM=y # CONFIG_CLEANCACHE is not set # CONFIG_FRONTSWAP is not set CONFIG_CMA=y # CONFIG_CMA_DEBUG is not set # CONFIG_ZBUD is not set CONFIG_FORCE_MAX_ZONEORDER=12 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_SECCOMP is not set # CONFIG_CC_STACKPROTECTOR is not set # # Boot options # CONFIG_USE_OF=y CONFIG_ATAGS=y # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ZBOOT_ROM_TEXT=0x0 CONFIG_ZBOOT_ROM_BSS=0x0 CONFIG_ARM_APPENDED_DTB=y CONFIG_ARM_ATAG_DTB_COMPAT=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set CONFIG_CMDLINE="root=/dev/mmcblk0p2 rootwait console=ttyO2,115200" CONFIG_CMDLINE_FROM_BOOTLOADER=y # CONFIG_CMDLINE_EXTEND is not set # CONFIG_CMDLINE_FORCE is not set # CONFIG_XIP_KERNEL is not set CONFIG_KEXEC=y CONFIG_ATAGS_PROC=y # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y # # CPU Power Management # # # CPU Frequency scaling # # CONFIG_CPU_FREQ is not set # # CPU Idle # # CONFIG_CPU_IDLE is not set # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set # # Floating point emulation # # # At least one emulation must be selected # CONFIG_FPE_NWFPE=y # CONFIG_FPE_NWFPE_XP is not set # CONFIG_FPE_FASTFPE is not set CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y # CONFIG_KERNEL_MODE_NEON is not set # # Userspace binary formats # CONFIG_BINFMT_ELF=y CONFIG_ARCH_BINFMT_ELF_RANDOMIZE_PIE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y # CONFIG_HAVE_AOUT is not set CONFIG_BINFMT_MISC=y CONFIG_COREDUMP=y # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y CONFIG_PM_SLEEP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM_RUNTIME=y CONFIG_PM=y CONFIG_PM_DEBUG=y # CONFIG_PM_ADVANCED_DEBUG is not set # CONFIG_PM_TEST_SUSPEND is not set CONFIG_PM_SLEEP_DEBUG=y # CONFIG_APM_EMULATION is not set CONFIG_ARCH_HAS_OPP=y CONFIG_PM_OPP=y CONFIG_PM_CLK=y # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_NET=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y # CONFIG_UNIX_DIAG is not set CONFIG_XFRM=y CONFIG_XFRM_ALGO=y CONFIG_XFRM_USER=y # CONFIG_XFRM_SUB_POLICY is not set CONFIG_XFRM_MIGRATE=y # CONFIG_XFRM_STATISTICS is not set CONFIG_NET_KEY=y CONFIG_NET_KEY_MIGRATE=y CONFIG_INET=y CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_ROUTE_CLASSID=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y CONFIG_IP_PNP_RARP=y # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set # CONFIG_NET_IP_TUNNEL is not set # CONFIG_IP_MROUTE is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_IPVTI is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set # CONFIG_INET_TUNNEL is not set CONFIG_INET_XFRM_MODE_TRANSPORT=m CONFIG_INET_XFRM_MODE_TUNNEL=m CONFIG_INET_XFRM_MODE_BEET=m # CONFIG_INET_LRO is not set CONFIG_INET_DIAG=m CONFIG_INET_TCP_DIAG=m # CONFIG_INET_UDP_DIAG is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set # CONFIG_IPV6 is not set # CONFIG_NETLABEL is not set # CONFIG_NETWORK_SECMARK is not set # CONFIG_NETWORK_PHY_TIMESTAMPING is not set CONFIG_NETFILTER=y # CONFIG_NETFILTER_DEBUG is not set CONFIG_NETFILTER_ADVANCED=y CONFIG_BRIDGE_NETFILTER=y # # Core Netfilter Configuration # CONFIG_NETFILTER_NETLINK=y CONFIG_NETFILTER_NETLINK_ACCT=y CONFIG_NETFILTER_NETLINK_QUEUE=y CONFIG_NETFILTER_NETLINK_LOG=y CONFIG_NF_CONNTRACK=y CONFIG_NF_CONNTRACK_MARK=y # CONFIG_NF_CONNTRACK_PROCFS is not set CONFIG_NF_CONNTRACK_EVENTS=y CONFIG_NF_CONNTRACK_TIMEOUT=y CONFIG_NF_CONNTRACK_TIMESTAMP=y CONFIG_NF_CONNTRACK_LABELS=y # CONFIG_NF_CT_PROTO_DCCP is not set # CONFIG_NF_CT_PROTO_SCTP is not set CONFIG_NF_CT_PROTO_UDPLITE=y # CONFIG_NF_CONNTRACK_AMANDA is not set # CONFIG_NF_CONNTRACK_FTP is not set # CONFIG_NF_CONNTRACK_H323 is not set # CONFIG_NF_CONNTRACK_IRC is not set # CONFIG_NF_CONNTRACK_NETBIOS_NS is not set # CONFIG_NF_CONNTRACK_SNMP is not set # CONFIG_NF_CONNTRACK_PPTP is not set # CONFIG_NF_CONNTRACK_SANE is not set # CONFIG_NF_CONNTRACK_SIP is not set # CONFIG_NF_CONNTRACK_TFTP is not set CONFIG_NF_CT_NETLINK=y CONFIG_NF_CT_NETLINK_TIMEOUT=y CONFIG_NF_CT_NETLINK_HELPER=y CONFIG_NETFILTER_NETLINK_QUEUE_CT=y CONFIG_NF_NAT=y CONFIG_NF_NAT_NEEDED=y CONFIG_NF_NAT_PROTO_UDPLITE=y # CONFIG_NF_NAT_AMANDA is not set # CONFIG_NF_NAT_FTP is not set # CONFIG_NF_NAT_IRC is not set # CONFIG_NF_NAT_SIP is not set # CONFIG_NF_NAT_TFTP is not set CONFIG_NETFILTER_XTABLES=y # # Xtables combined modules # CONFIG_NETFILTER_XT_MARK=y CONFIG_NETFILTER_XT_CONNMARK=y # # Xtables targets # # CONFIG_NETFILTER_XT_TARGET_CHECKSUM is not set CONFIG_NETFILTER_XT_TARGET_CLASSIFY=y CONFIG_NETFILTER_XT_TARGET_CONNMARK=y # CONFIG_NETFILTER_XT_TARGET_CT is not set # CONFIG_NETFILTER_XT_TARGET_DSCP is not set CONFIG_NETFILTER_XT_TARGET_HL=y CONFIG_NETFILTER_XT_TARGET_HMARK=y CONFIG_NETFILTER_XT_TARGET_IDLETIMER=y CONFIG_NETFILTER_XT_TARGET_LED=y CONFIG_NETFILTER_XT_TARGET_LOG=y CONFIG_NETFILTER_XT_TARGET_MARK=y CONFIG_NETFILTER_XT_TARGET_NETMAP=y CONFIG_NETFILTER_XT_TARGET_NFLOG=y CONFIG_NETFILTER_XT_TARGET_NFQUEUE=y # CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set CONFIG_NETFILTER_XT_TARGET_RATEEST=y CONFIG_NETFILTER_XT_TARGET_REDIRECT=y # CONFIG_NETFILTER_XT_TARGET_TEE is not set # CONFIG_NETFILTER_XT_TARGET_TPROXY is not set # CONFIG_NETFILTER_XT_TARGET_TRACE is not set CONFIG_NETFILTER_XT_TARGET_TCPMSS=y # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set # # Xtables matches # CONFIG_NETFILTER_XT_MATCH_ADDRTYPE=y # CONFIG_NETFILTER_XT_MATCH_BPF is not set CONFIG_NETFILTER_XT_MATCH_CLUSTER=y CONFIG_NETFILTER_XT_MATCH_COMMENT=y CONFIG_NETFILTER_XT_MATCH_CONNBYTES=y CONFIG_NETFILTER_XT_MATCH_CONNLABEL=y CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=y CONFIG_NETFILTER_XT_MATCH_CONNMARK=y CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y # CONFIG_NETFILTER_XT_MATCH_CPU is not set # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_DEVGROUP is not set # CONFIG_NETFILTER_XT_MATCH_DSCP is not set CONFIG_NETFILTER_XT_MATCH_ECN=y CONFIG_NETFILTER_XT_MATCH_ESP=y CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=y CONFIG_NETFILTER_XT_MATCH_HELPER=y CONFIG_NETFILTER_XT_MATCH_HL=y CONFIG_NETFILTER_XT_MATCH_IPRANGE=y CONFIG_NETFILTER_XT_MATCH_LENGTH=y CONFIG_NETFILTER_XT_MATCH_LIMIT=y CONFIG_NETFILTER_XT_MATCH_MAC=y CONFIG_NETFILTER_XT_MATCH_MARK=y CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y CONFIG_NETFILTER_XT_MATCH_NFACCT=y # CONFIG_NETFILTER_XT_MATCH_OSF is not set CONFIG_NETFILTER_XT_MATCH_OWNER=y # CONFIG_NETFILTER_XT_MATCH_POLICY is not set # CONFIG_NETFILTER_XT_MATCH_PHYSDEV is not set CONFIG_NETFILTER_XT_MATCH_PKTTYPE=y CONFIG_NETFILTER_XT_MATCH_QUOTA=y CONFIG_NETFILTER_XT_MATCH_RATEEST=y CONFIG_NETFILTER_XT_MATCH_REALM=y CONFIG_NETFILTER_XT_MATCH_RECENT=y # CONFIG_NETFILTER_XT_MATCH_SCTP is not set CONFIG_NETFILTER_XT_MATCH_SOCKET=y CONFIG_NETFILTER_XT_MATCH_STATE=y CONFIG_NETFILTER_XT_MATCH_STATISTIC=y CONFIG_NETFILTER_XT_MATCH_STRING=y CONFIG_NETFILTER_XT_MATCH_TCPMSS=y CONFIG_NETFILTER_XT_MATCH_TIME=y CONFIG_NETFILTER_XT_MATCH_U32=y # CONFIG_IP_SET is not set # CONFIG_IP_VS is not set # # IP: Netfilter Configuration # CONFIG_NF_DEFRAG_IPV4=y CONFIG_NF_CONNTRACK_IPV4=y CONFIG_IP_NF_IPTABLES=y CONFIG_IP_NF_MATCH_AH=y CONFIG_IP_NF_MATCH_ECN=y # CONFIG_IP_NF_MATCH_RPFILTER is not set CONFIG_IP_NF_MATCH_TTL=y CONFIG_IP_NF_FILTER=y CONFIG_IP_NF_TARGET_REJECT=y # CONFIG_IP_NF_TARGET_SYNPROXY is not set CONFIG_IP_NF_TARGET_ULOG=y CONFIG_NF_NAT_IPV4=y CONFIG_IP_NF_TARGET_MASQUERADE=y CONFIG_IP_NF_TARGET_NETMAP=y CONFIG_IP_NF_TARGET_REDIRECT=y # CONFIG_NF_NAT_PPTP is not set # CONFIG_NF_NAT_H323 is not set CONFIG_IP_NF_MANGLE=y CONFIG_IP_NF_TARGET_CLUSTERIP=y CONFIG_IP_NF_TARGET_ECN=y CONFIG_IP_NF_TARGET_TTL=y CONFIG_IP_NF_RAW=y CONFIG_IP_NF_SECURITY=y CONFIG_IP_NF_ARPTABLES=y # CONFIG_IP_NF_ARPFILTER is not set # CONFIG_IP_NF_ARP_MANGLE is not set # CONFIG_BRIDGE_NF_EBTABLES is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set CONFIG_STP=m CONFIG_BRIDGE=m CONFIG_BRIDGE_IGMP_SNOOPING=y # CONFIG_BRIDGE_VLAN_FILTERING is not set CONFIG_HAVE_NET_DSA=y CONFIG_VLAN_8021Q=y # CONFIG_VLAN_8021Q_GVRP is not set # CONFIG_VLAN_8021Q_MVRP is not set # CONFIG_DECNET is not set CONFIG_LLC=m # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set CONFIG_DNS_RESOLVER=y # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_MMAP is not set CONFIG_NETLINK_DIAG=y # CONFIG_NET_MPLS_GSO is not set CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_JIT is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_NET_TCPPROBE is not set # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_WIRELESS is not set # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set CONFIG_RFKILL_REGULATOR=m # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set CONFIG_HAVE_BPF_JIT=y # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="am335x-pm-firmware.bin" CONFIG_EXTRA_FIRMWARE_DIR="firmware" CONFIG_FW_LOADER_USER_HELPER=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_SYS_HYPERVISOR is not set # CONFIG_GENERIC_CPU_DEVICES is not set CONFIG_SOC_BUS=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_DMA_SHARED_BUFFER=y CONFIG_DMA_CMA=y # # Default contiguous memory area size: # CONFIG_CMA_SIZE_MBYTES=24 CONFIG_CMA_SIZE_SEL_MBYTES=y # CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set # CONFIG_CMA_SIZE_SEL_MIN is not set # CONFIG_CMA_SIZE_SEL_MAX is not set CONFIG_CMA_ALIGNMENT=8 CONFIG_CMA_AREAS=7 # # Bus devices # CONFIG_OMAP_OCP2SCP=y CONFIG_OMAP_INTERCONNECT=y # CONFIG_ARM_CCI is not set CONFIG_CONNECTOR=y CONFIG_PROC_EVENTS=y CONFIG_MTD=y # CONFIG_MTD_TESTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AR7_PARTS is not set # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set CONFIG_MTD_OOPS=y # CONFIG_MTD_SWAP is not set # # RAM/ROM/Flash chip drivers # CONFIG_MTD_CFI=y # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_GEN_PROBE=y # CONFIG_MTD_CFI_ADV_OPTIONS is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set CONFIG_MTD_CFI_INTELEXT=y # CONFIG_MTD_CFI_AMDSTD is not set # CONFIG_MTD_CFI_STAA is not set CONFIG_MTD_CFI_UTIL=y # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_PHYSMAP is not set # CONFIG_MTD_PHYSMAP_OF is not set # CONFIG_MTD_INTEL_VR_NOR is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_PMC551 is not set # CONFIG_MTD_DATAFLASH is not set CONFIG_MTD_M25P80=y # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set # CONFIG_MTD_BLOCK2MTD is not set # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set CONFIG_BCH_CONST_M=13 CONFIG_MTD_NAND_ECC=y # CONFIG_MTD_NAND_ECC_SMC is not set CONFIG_MTD_NAND=y # CONFIG_MTD_NAND_ECC_BCH is not set # CONFIG_MTD_SM_COMMON is not set # CONFIG_MTD_NAND_DENALI is not set # CONFIG_MTD_NAND_GPIO is not set CONFIG_MTD_NAND_OMAP2=y CONFIG_MTD_NAND_OMAP_BCH=y CONFIG_MTD_NAND_IDS=y # CONFIG_MTD_NAND_RICOH is not set # CONFIG_MTD_NAND_DISKONCHIP is not set # CONFIG_MTD_NAND_DOCG4 is not set # CONFIG_MTD_NAND_CAFE is not set # CONFIG_MTD_NAND_NANDSIM is not set # CONFIG_MTD_NAND_PLATFORM is not set # CONFIG_MTD_ONENAND is not set # # LPDDR flash memory drivers # # CONFIG_MTD_LPDDR is not set CONFIG_MTD_UBI=y CONFIG_MTD_UBI_WL_THRESHOLD=4096 CONFIG_MTD_UBI_BEB_LIMIT=20 # CONFIG_MTD_UBI_FASTMAP is not set # CONFIG_MTD_UBI_GLUEBI is not set CONFIG_DTC=y CONFIG_OF=y # # Device Tree and Open Firmware support # CONFIG_PROC_DEVICETREE=y # CONFIG_OF_SELFTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_NET=y CONFIG_OF_MDIO=y CONFIG_OF_PCI=y CONFIG_OF_PCI_IRQ=y CONFIG_OF_MTD=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_PCIESSD_MTIP32XX is not set # CONFIG_BLK_CPQ_CISS_DA is not set # CONFIG_BLK_DEV_DAC960 is not set # CONFIG_BLK_DEV_UMEM is not set # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=y CONFIG_BLK_DEV_LOOP_MIN_COUNT=8 # CONFIG_BLK_DEV_CRYPTOLOOP is not set # CONFIG_BLK_DEV_DRBD is not set # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_NVME is not set # CONFIG_BLK_DEV_SX8 is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=16384 # CONFIG_BLK_DEV_XIP is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_MG_DISK is not set # CONFIG_BLK_DEV_RBD is not set # CONFIG_BLK_DEV_RSXX is not set # # Misc devices # CONFIG_SENSORS_LIS3LV02D=m # CONFIG_AD525X_DPOT is not set # CONFIG_ATMEL_PWM is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_PHANTOM is not set # CONFIG_SGI_IOC4 is not set CONFIG_TIFM_CORE=y CONFIG_TIFM_7XX1=y # CONFIG_ICS932S401 is not set # CONFIG_ATMEL_SSC is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set CONFIG_SENSORS_TSL2550=m # CONFIG_SENSORS_BH1780 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_TI_DAC7512 is not set CONFIG_BMP085=y CONFIG_BMP085_I2C=m # CONFIG_BMP085_SPI is not set # CONFIG_PCH_PHUB is not set # CONFIG_USB_SWITCH_FSA9480 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set # CONFIG_SRAM is not set CONFIG_CROSSBAR=y # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set CONFIG_EEPROM_93CX6=y # CONFIG_EEPROM_93XX46 is not set # CONFIG_CB710_CORE is not set # # Texas Instruments shared transport line discipline # CONFIG_TI_ST=y CONFIG_ST_HCI=y # CONFIG_SENSORS_LIS3_SPI is not set CONFIG_SENSORS_LIS3_I2C=m # # Altera FPGA firmware download module # # CONFIG_ALTERA_STAPL is not set CONFIG_HAVE_IDE=y # CONFIG_IDE is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y # CONFIG_SCSI_TGT is not set # CONFIG_SCSI_NETLINK is not set CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set # CONFIG_BLK_DEV_SR is not set # CONFIG_CHR_DEV_SG is not set # CONFIG_CHR_DEV_SCH is not set CONFIG_SCSI_MULTI_LUN=y # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set CONFIG_SCSI_SCAN_ASYNC=y # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_CXGB3_ISCSI is not set # CONFIG_SCSI_CXGB4_ISCSI is not set # CONFIG_SCSI_BNX2_ISCSI is not set # CONFIG_SCSI_BNX2X_FCOE is not set # CONFIG_BE2ISCSI is not set # CONFIG_BLK_DEV_3W_XXXX_RAID is not set # CONFIG_SCSI_HPSA is not set # CONFIG_SCSI_3W_9XXX is not set # CONFIG_SCSI_3W_SAS is not set # CONFIG_SCSI_ACARD is not set # CONFIG_SCSI_AACRAID is not set # CONFIG_SCSI_AIC7XXX is not set # CONFIG_SCSI_AIC7XXX_OLD is not set # CONFIG_SCSI_AIC79XX is not set # CONFIG_SCSI_AIC94XX is not set # CONFIG_SCSI_MVSAS is not set # CONFIG_SCSI_MVUMI is not set # CONFIG_SCSI_ARCMSR is not set # CONFIG_SCSI_ESAS2R is not set # CONFIG_MEGARAID_NEWGEN is not set # CONFIG_MEGARAID_LEGACY is not set # CONFIG_MEGARAID_SAS is not set # CONFIG_SCSI_MPT2SAS is not set # CONFIG_SCSI_MPT3SAS is not set # CONFIG_SCSI_UFSHCD is not set # CONFIG_SCSI_HPTIOP is not set # CONFIG_LIBFC is not set # CONFIG_LIBFCOE is not set # CONFIG_FCOE is not set # CONFIG_SCSI_DMX3191D is not set # CONFIG_SCSI_FUTURE_DOMAIN is not set # CONFIG_SCSI_IPS is not set # CONFIG_SCSI_INITIO is not set # CONFIG_SCSI_INIA100 is not set # CONFIG_SCSI_STEX is not set # CONFIG_SCSI_SYM53C8XX_2 is not set # CONFIG_SCSI_IPR is not set # CONFIG_SCSI_QLOGIC_1280 is not set # CONFIG_SCSI_QLA_FC is not set # CONFIG_SCSI_QLA_ISCSI is not set # CONFIG_SCSI_LPFC is not set # CONFIG_SCSI_DC395x is not set # CONFIG_SCSI_DC390T is not set # CONFIG_SCSI_NSP32 is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_PMCRAID is not set # CONFIG_SCSI_PM8001 is not set # CONFIG_SCSI_SRP is not set # CONFIG_SCSI_BFA_FC is not set # CONFIG_SCSI_CHELSIO_FCOE is not set # CONFIG_SCSI_DH is not set # CONFIG_SCSI_OSD_INITIATOR is not set CONFIG_ATA=y # CONFIG_ATA_NONSTANDARD is not set CONFIG_ATA_VERBOSE_ERROR=y CONFIG_SATA_PMP=y # # Controllers with non-SFF native interface # # CONFIG_SATA_AHCI is not set CONFIG_SATA_AHCI_PLATFORM=y # CONFIG_AHCI_IMX is not set # CONFIG_SATA_INIC162X is not set # CONFIG_SATA_ACARD_AHCI is not set # CONFIG_SATA_SIL24 is not set CONFIG_SATA_TI=y CONFIG_ATA_SFF=y # # SFF controllers with custom DMA interface # # CONFIG_PDC_ADMA is not set # CONFIG_SATA_QSTOR is not set # CONFIG_SATA_SX4 is not set CONFIG_ATA_BMDMA=y # # SATA SFF controllers with BMDMA # # CONFIG_ATA_PIIX is not set # CONFIG_SATA_HIGHBANK is not set # CONFIG_SATA_MV is not set # CONFIG_SATA_NV is not set # CONFIG_SATA_PROMISE is not set # CONFIG_SATA_RCAR is not set # CONFIG_SATA_SIL is not set # CONFIG_SATA_SIS is not set # CONFIG_SATA_SVW is not set # CONFIG_SATA_ULI is not set # CONFIG_SATA_VIA is not set # CONFIG_SATA_VITESSE is not set # # PATA SFF controllers with BMDMA # # CONFIG_PATA_ALI is not set # CONFIG_PATA_AMD is not set # CONFIG_PATA_ARASAN_CF is not set # CONFIG_PATA_ARTOP is not set # CONFIG_PATA_ATIIXP is not set # CONFIG_PATA_ATP867X is not set # CONFIG_PATA_CMD64X is not set # CONFIG_PATA_CS5520 is not set # CONFIG_PATA_CS5530 is not set # CONFIG_PATA_CS5536 is not set # CONFIG_PATA_CYPRESS is not set # CONFIG_PATA_EFAR is not set # CONFIG_PATA_HPT366 is not set # CONFIG_PATA_HPT37X is not set # CONFIG_PATA_HPT3X2N is not set # CONFIG_PATA_HPT3X3 is not set # CONFIG_PATA_IT8213 is not set # CONFIG_PATA_IT821X is not set # CONFIG_PATA_JMICRON is not set # CONFIG_PATA_MARVELL is not set # CONFIG_PATA_NETCELL is not set # CONFIG_PATA_NINJA32 is not set # CONFIG_PATA_NS87415 is not set # CONFIG_PATA_OLDPIIX is not set # CONFIG_PATA_OPTIDMA is not set # CONFIG_PATA_PDC2027X is not set # CONFIG_PATA_PDC_OLD is not set # CONFIG_PATA_RADISYS is not set # CONFIG_PATA_RDC is not set # CONFIG_PATA_SC1200 is not set # CONFIG_PATA_SCH is not set # CONFIG_PATA_SERVERWORKS is not set # CONFIG_PATA_SIL680 is not set # CONFIG_PATA_SIS is not set # CONFIG_PATA_TOSHIBA is not set # CONFIG_PATA_TRIFLEX is not set # CONFIG_PATA_VIA is not set # CONFIG_PATA_WINBOND is not set # # PIO-only SFF controllers # # CONFIG_PATA_CMD640_PCI is not set # CONFIG_PATA_MPIIX is not set # CONFIG_PATA_NS87410 is not set # CONFIG_PATA_OPTI is not set # CONFIG_PATA_PLATFORM is not set # CONFIG_PATA_RZ1000 is not set # # Generic fallback / legacy drivers # # CONFIG_ATA_GENERIC is not set # CONFIG_PATA_LEGACY is not set CONFIG_MD=y # CONFIG_BLK_DEV_MD is not set # CONFIG_BCACHE is not set # CONFIG_BLK_DEV_DM is not set # CONFIG_TARGET_CORE is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # CONFIG_FIREWIRE is not set # CONFIG_FIREWIRE_NOSY is not set # CONFIG_I2O is not set CONFIG_NETDEVICES=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_FC is not set CONFIG_NET_TEAM=y # CONFIG_NET_TEAM_MODE_BROADCAST is not set # CONFIG_NET_TEAM_MODE_ROUNDROBIN is not set # CONFIG_NET_TEAM_MODE_RANDOM is not set # CONFIG_NET_TEAM_MODE_ACTIVEBACKUP is not set # CONFIG_NET_TEAM_MODE_LOADBALANCE is not set # CONFIG_MACVLAN is not set # CONFIG_VXLAN is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_TUN is not set # CONFIG_VETH is not set # CONFIG_NLMON is not set # CONFIG_ARCNET is not set # # CAIF transport drivers # # # Distributed Switch Architecture drivers # # CONFIG_NET_DSA_MV88E6XXX is not set # CONFIG_NET_DSA_MV88E6060 is not set # CONFIG_NET_DSA_MV88E6XXX_NEED_PPU is not set # CONFIG_NET_DSA_MV88E6131 is not set # CONFIG_NET_DSA_MV88E6123_61_65 is not set # CONFIG_ETHERNET is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set CONFIG_PHYLIB=y # # MII PHY device drivers # CONFIG_AT803X_PHY=y # CONFIG_AMD_PHY is not set # CONFIG_MARVELL_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_VITESSE_PHY is not set CONFIG_SMSC_PHY=y # CONFIG_BROADCOM_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_ICPLUS_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_STE10XP is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_MICREL_PHY is not set # CONFIG_FIXED_PHY is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # CONFIG_MICREL_KS8995MA is not set CONFIG_PPP=y CONFIG_PPP_BSDCOMP=y CONFIG_PPP_DEFLATE=y CONFIG_PPP_FILTER=y CONFIG_PPP_MPPE=y CONFIG_PPP_MULTILINK=y # CONFIG_PPPOE is not set CONFIG_PPP_ASYNC=y CONFIG_PPP_SYNC_TTY=y # CONFIG_SLIP is not set CONFIG_SLHC=y # # USB Network Adapters # # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set # CONFIG_USB_RTL8152 is not set # CONFIG_USB_USBNET is not set # CONFIG_USB_IPHETH is not set # CONFIG_WLAN is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_VMXNET3 is not set # CONFIG_ISDN is not set # # Input device support # CONFIG_INPUT=y # CONFIG_INPUT_FF_MEMLESS is not set CONFIG_INPUT_POLLDEV=m # CONFIG_INPUT_SPARSEKMAP is not set CONFIG_INPUT_MATRIXKMAP=y # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y CONFIG_INPUT_MOUSEDEV_PSAUX=y CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 CONFIG_INPUT_JOYDEV=y CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_LKKBD is not set CONFIG_KEYBOARD_GPIO=y # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set CONFIG_KEYBOARD_MATRIX=y # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_SAMSUNG is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_OMAP4 is not set CONFIG_KEYBOARD_TWL4030=y # CONFIG_KEYBOARD_XTKBD is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_CYPRESS=y CONFIG_MOUSE_PS2_TRACKPOINT=y # CONFIG_MOUSE_PS2_ELANTECH is not set # CONFIG_MOUSE_PS2_SENTELIC is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_APPLETOUCH is not set # CONFIG_MOUSE_BCM5974 is not set # CONFIG_MOUSE_CYAPA is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_MOUSE_GPIO is not set # CONFIG_MOUSE_SYNAPTICS_I2C is not set # CONFIG_MOUSE_SYNAPTICS_USB is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y CONFIG_TOUCHSCREEN_ADS7846=y # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set CONFIG_TOUCHSCREEN_ATMEL_MXT=y # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set # CONFIG_TOUCHSCREEN_ILI210X is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MMS114 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set # CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set CONFIG_TOUCHSCREEN_TI_AM335X_TSC=y CONFIG_TOUCHSCREEN_PIXCIR=m # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_W90X900 is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_MPU3050 is not set # CONFIG_INPUT_GP2A is not set # CONFIG_INPUT_GPIO_TILT_POLLED is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set CONFIG_INPUT_TWL4030_PWRBUTTON=y # CONFIG_INPUT_TWL4030_VIBRA is not set # CONFIG_INPUT_TWL6040_VIBRA is not set CONFIG_INPUT_UINPUT=y # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_PWM_BEEPER is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_ADXL34X is not set # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_CMA3000 is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_OLPC_APSP is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set # CONFIG_LEGACY_PTYS is not set # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_NOZOMI is not set # CONFIG_N_GSM is not set # CONFIG_TRACE_SINK is not set CONFIG_DEVKMEM=y # # Serial drivers # CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_NR_UARTS=32 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 CONFIG_SERIAL_8250_EXTENDED=y CONFIG_SERIAL_8250_MANY_PORTS=y CONFIG_SERIAL_8250_SHARE_IRQ=y CONFIG_SERIAL_8250_DETECT_IRQ=y CONFIG_SERIAL_8250_RSA=y # CONFIG_SERIAL_8250_DW is not set # CONFIG_SERIAL_8250_EM is not set # # Non-8250 serial port support # # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_MFD_HSU is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set # CONFIG_SERIAL_OF_PLATFORM is not set CONFIG_SERIAL_OMAP=y CONFIG_SERIAL_OMAP_CONSOLE=y # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_TIMBERDALE is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_IFX6X60 is not set # CONFIG_SERIAL_PCH_UART is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_RP2 is not set # CONFIG_SERIAL_FSL_LPUART is not set # CONFIG_SERIAL_ST_ASC is not set # CONFIG_TTY_PRINTK is not set # CONFIG_HVC_DCC is not set # CONFIG_IPMI_HANDLER is not set CONFIG_HW_RANDOM=y # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_HW_RANDOM_ATMEL is not set CONFIG_HW_RANDOM_OMAP=y # CONFIG_HW_RANDOM_EXYNOS is not set # CONFIG_R3964 is not set # CONFIG_APPLICOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_DEVPORT=y CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_DESIGNWARE_PCI is not set # CONFIG_I2C_EG20T is not set # CONFIG_I2C_GPIO is not set # CONFIG_I2C_OCORES is not set CONFIG_I2C_OMAP=y # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_PXA_PCI is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_BITBANG is not set # CONFIG_SPI_GPIO is not set # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_FSL_DSPI is not set # CONFIG_SPI_OC_TINY is not set CONFIG_SPI_OMAP24XX=y CONFIG_SPI_TI_QSPI=y # CONFIG_SPI_PXA2XX is not set # CONFIG_SPI_PXA2XX_PCI is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_TOPCLIFF_PCH is not set # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_DESIGNWARE is not set # # SPI Protocol Masters # # CONFIG_SPI_SPIDEV is not set # CONFIG_SPI_TLE62X0 is not set # CONFIG_HSI is not set # # PPS support # CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # CONFIG_PINCTRL=y # # Pin controllers # CONFIG_PINMUX=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y CONFIG_DEBUG_PINCTRL=y CONFIG_PINCTRL_SINGLE=y # CONFIG_PINCTRL_PALMAS is not set CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_ARCH_REQUIRE_GPIOLIB=y CONFIG_GPIO_DEVRES=y CONFIG_GPIOLIB=y CONFIG_OF_GPIO=y CONFIG_DEBUG_GPIO=y CONFIG_GPIO_SYSFS=y # # Memory mapped GPIO drivers: # # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_EM is not set # CONFIG_GPIO_RCAR is not set # CONFIG_GPIO_TS5500 is not set # CONFIG_GPIO_VX855 is not set # CONFIG_GPIO_GRGPIO is not set # # I2C GPIO expanders: # # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X_IRQ is not set CONFIG_GPIO_PCF857X=y # CONFIG_GPIO_SX150X is not set CONFIG_GPIO_TWL4030=y # CONFIG_GPIO_TWL6040 is not set # CONFIG_GPIO_ADP5588 is not set # CONFIG_GPIO_ADNP is not set # # PCI GPIO expanders: # # CONFIG_GPIO_BT8XX is not set # CONFIG_GPIO_AMD8111 is not set # CONFIG_GPIO_ML_IOH is not set # CONFIG_GPIO_RDC321X is not set # # SPI GPIO expanders: # # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MCP23S08 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_74X164 is not set # # AC97 GPIO expanders: # # # LPC GPIO expanders: # # # MODULbus GPIO expanders: # # CONFIG_GPIO_PALMAS is not set # CONFIG_GPIO_TPS65910 is not set # # USB GPIO expanders: # # CONFIG_W1 is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set # CONFIG_PDA_POWER is not set # CONFIG_GENERIC_ADC_BATTERY is not set # CONFIG_TEST_POWER is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SBS is not set # CONFIG_BATTERY_BQ27x00 is not set # CONFIG_BATTERY_MAX17040 is not set # CONFIG_BATTERY_MAX17042 is not set # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_TWL4030 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_POWER_RESET is not set # CONFIG_POWER_RESET_RESTART is not set # CONFIG_POWER_AVS is not set CONFIG_HWMON=y # CONFIG_HWMON_VID is not set # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_ADM1021 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_I5K_AMB is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_GPIO_FAN is not set # CONFIG_SENSORS_HIH6130 is not set # CONFIG_SENSORS_HTU21 is not set # CONFIG_SENSORS_IIO_HWMON is not set # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_JC42 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set CONFIG_SENSORS_LM75=m # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set # CONFIG_SENSORS_LM90 is not set # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set # CONFIG_SENSORS_LM95245 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6642 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NTC_THERMISTOR is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SIS5595 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH56XX_COMMON is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_ADS1015 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set # CONFIG_SENSORS_INA2XX is not set # CONFIG_SENSORS_THMC50 is not set # CONFIG_SENSORS_TMP102 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_VIA686A is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_VT8231 is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set CONFIG_THERMAL=y CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set CONFIG_THERMAL_GOV_FAIR_SHARE=y CONFIG_THERMAL_GOV_STEP_WISE=y CONFIG_THERMAL_GOV_USER_SPACE=y # CONFIG_THERMAL_EMULATION is not set # # Texas Instruments thermal drivers # CONFIG_TI_SOC_THERMAL=y CONFIG_OMAP4_THERMAL=y CONFIG_OMAP5_THERMAL=y CONFIG_DRA752_THERMAL=y CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set CONFIG_OMAP_WATCHDOG=y CONFIG_TWL4030_WATCHDOG=y # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_ALIM7101_WDT is not set # CONFIG_I6300ESB_WDT is not set # CONFIG_MEN_A21_WDT is not set # # PCI-based Watchdog Cards # # CONFIG_PCIPCWATCHDOG is not set # CONFIG_WDTPCI is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # # CONFIG_SSB is not set CONFIG_BCMA_POSSIBLE=y # # Broadcom specific AMBA # # CONFIG_BCMA is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_AS3711 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_CROS_EC is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_HTC_EGPIO is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_LPC_ICH is not set # CONFIG_LPC_SCH is not set # CONFIG_MFD_JANZ_CMODIO is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_RDC321X is not set # CONFIG_MFD_RTSX_PCI is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SMSC is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SYSCON=y CONFIG_MFD_TI_AM335X_TSCADC=y # CONFIG_MFD_LP8788 is not set CONFIG_MFD_PALMAS=y # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65090 is not set CONFIG_MFD_TPS65217=y CONFIG_MFD_TPS65218=y # CONFIG_MFD_TPS6586X is not set CONFIG_MFD_TPS65910=y # CONFIG_MFD_TPS65912 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS80031 is not set CONFIG_TWL4030_CORE=y # CONFIG_TWL4030_MADC is not set CONFIG_TWL4030_POWER=y CONFIG_MFD_TWL4030_AUDIO=y CONFIG_TWL6040_CORE=y CONFIG_MENELAUS=y # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TIMBERDALE is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_VX855 is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set # CONFIG_VEXPRESS_CONFIG is not set CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set # CONFIG_REGULATOR_DUMMY is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ANATOP is not set # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_FAN53555 is not set # CONFIG_REGULATOR_GPIO is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MAX8973 is not set CONFIG_REGULATOR_PALMAS=y CONFIG_REGULATOR_PBIAS=y # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_TI_ABB is not set # CONFIG_REGULATOR_TPS51632 is not set # CONFIG_REGULATOR_TPS62360 is not set CONFIG_REGULATOR_TPS65023=y CONFIG_REGULATOR_TPS6507X=y CONFIG_REGULATOR_TPS65217=y CONFIG_REGULATOR_TPS65218=y # CONFIG_REGULATOR_TPS6524X is not set CONFIG_REGULATOR_TPS65910=y CONFIG_REGULATOR_TWL4030=y CONFIG_REGULATOR_TIAVSCLASS0=y CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # CONFIG_MEDIA_CAMERA_SUPPORT=y # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set # CONFIG_MEDIA_RADIO_SUPPORT is not set # CONFIG_MEDIA_RC_SUPPORT is not set CONFIG_MEDIA_CONTROLLER=y CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2_SUBDEV_API=y CONFIG_VIDEO_V4L2=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_VIDEOBUF2_CORE=y CONFIG_VIDEOBUF2_MEMOPS=y CONFIG_VIDEOBUF2_DMA_CONTIG=y # CONFIG_VIDEO_V4L2_INT_DEVICE is not set # CONFIG_TTPCI_EEPROM is not set # # Media drivers # # CONFIG_MEDIA_USB_SUPPORT is not set # CONFIG_MEDIA_PCI_SUPPORT is not set CONFIG_V4L_PLATFORM_DRIVERS=y # CONFIG_VIDEO_CAFE_CCIC is not set # CONFIG_VIDEO_DM6446_CCDC is not set # CONFIG_VIDEO_OMAP2_VOUT is not set # CONFIG_VIDEO_TIMBERDALE is not set # CONFIG_SOC_CAMERA is not set CONFIG_VIDEO_AM437X_VPFE=y # CONFIG_V4L_MEM2MEM_DRIVERS is not set # CONFIG_V4L_TEST_DRIVERS is not set # # Supported MMC/SDIO adapters # # CONFIG_CYPRESS_FIRMWARE is not set # # Media ancillary drivers (tuners, sensors, i2c, frontends) # # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # # Encoders, decoders, sensors and other helper chips # # # Audio decoders, processors and mixers # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # # CONFIG_VIDEO_ADV7180 is not set # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_ADV7604 is not set # CONFIG_VIDEO_ADV7842 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_ML86V7667 is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_SAA7191 is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_ADV7511 is not set # CONFIG_VIDEO_AD9389B is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_THS8200 is not set # # Camera sensor devices # CONFIG_VIDEO_OV2659=y # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_OV9650 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_MT9M032 is not set # CONFIG_VIDEO_MT9P031 is not set # CONFIG_VIDEO_MT9T001 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_MT9V032 is not set # CONFIG_VIDEO_SR030PC30 is not set # CONFIG_VIDEO_NOON010PC30 is not set # CONFIG_VIDEO_M5MOLS is not set # CONFIG_VIDEO_S5K6AA is not set # CONFIG_VIDEO_S5K4ECGX is not set # CONFIG_VIDEO_SMIAPP is not set # CONFIG_VIDEO_S5C73M3 is not set # # Flash devices # # CONFIG_VIDEO_ADP1653 is not set # CONFIG_VIDEO_AS3645A is not set # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # # Miscelaneous helper chips # # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_M52790 is not set # # Sensors used on soc_camera driver # # # Customise DVB Frontends # CONFIG_DVB_AU8522=m CONFIG_DVB_AU8522_V4L=m CONFIG_DVB_TUNER_DIB0070=m CONFIG_DVB_TUNER_DIB0090=m # # Tools to develop new frontends # # CONFIG_DVB_DUMMY_FE is not set # # Graphics support # # CONFIG_VGA_ARB is not set # CONFIG_DRM is not set # CONFIG_VGASTATE is not set # CONFIG_VIDEO_OUTPUT_CONTROL is not set # CONFIG_FB is not set # CONFIG_OMAP2_DSS is not set # CONFIG_EXYNOS_VIDEO is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # # Console display driver support # CONFIG_DUMMY_CONSOLE=y # CONFIG_SOUND is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # # CONFIG_HID_A4TECH is not set # CONFIG_HID_ACRUX is not set # CONFIG_HID_APPLE is not set # CONFIG_HID_APPLEIR is not set # CONFIG_HID_AUREAL is not set # CONFIG_HID_BELKIN is not set # CONFIG_HID_CHERRY is not set # CONFIG_HID_CHICONY is not set # CONFIG_HID_CYPRESS is not set # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set # CONFIG_HID_EZKEY is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_HUION is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set # CONFIG_HID_TWINHAN is not set # CONFIG_HID_KENSINGTON is not set # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LENOVO_TPKBD is not set # CONFIG_HID_LOGITECH is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MICROSOFT is not set # CONFIG_HID_MONTEREY is not set # CONFIG_HID_MULTITOUCH is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # # USB HID support # CONFIG_USB_HID=m # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # # USB HID Boot Protocol drivers # # CONFIG_USB_KBD is not set # CONFIG_USB_MOUSE is not set # # I2C HID support # # CONFIG_I2C_HID is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_ARCH_HAS_EHCI=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y CONFIG_USB_DEBUG=y CONFIG_USB_ANNOUNCE_NEW_DEVICES=y # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_DYNAMIC_MINORS is not set CONFIG_USB_OTG=y CONFIG_USB_OTG_WHITELIST=y # CONFIG_USB_OTG_BLACKLIST_HUB is not set CONFIG_USB_MON=m # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_XHCI_HCD is not set # CONFIG_USB_EHCI_HCD is not set # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1760_HCD is not set # CONFIG_USB_ISP1362_HCD is not set # CONFIG_USB_FUSBH200_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_OHCI_HCD is not set # CONFIG_USB_UHCI_HCD is not set # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HCD_TEST_MODE is not set CONFIG_USB_MUSB_HDRC=y # CONFIG_USB_MUSB_HOST is not set CONFIG_USB_MUSB_GADGET=y # CONFIG_USB_MUSB_DUAL_ROLE is not set # CONFIG_USB_MUSB_TUSB6010 is not set # CONFIG_USB_MUSB_OMAP2PLUS is not set CONFIG_USB_MUSB_AM35X=y # CONFIG_USB_MUSB_DSPS is not set # CONFIG_USB_MUSB_UX500 is not set CONFIG_USB_TI_CPPI41_DMA=y # CONFIG_MUSB_PIO_ONLY is not set # CONFIG_USB_RENESAS_USBHS is not set # # USB Device Class drivers # CONFIG_USB_ACM=y # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # # CONFIG_USB_STORAGE is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set CONFIG_USB_DWC3=m # CONFIG_USB_DWC3_HOST is not set CONFIG_USB_DWC3_GADGET=y # CONFIG_USB_DWC3_DUAL_ROLE is not set # # Platform Glue Driver Support # CONFIG_USB_DWC3_OMAP=m # CONFIG_USB_DWC3_EXYNOS is not set # CONFIG_USB_DWC3_PCI is not set # # Debugging features # # CONFIG_USB_DWC3_DEBUG is not set # CONFIG_USB_CHIPIDEA is not set # # USB port drivers # # CONFIG_USB_SERIAL is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_LED is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HSIC_USB3503 is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=y CONFIG_AM335X_CONTROL_USB=y CONFIG_AM335X_PHY_USB=y # CONFIG_SAMSUNG_USB2PHY is not set # CONFIG_SAMSUNG_USB3PHY is not set # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ISP1301 is not set # CONFIG_USB_RCAR_PHY is not set # CONFIG_USB_ULPI is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DEBUG=y # CONFIG_USB_GADGET_VERBOSE is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2 # # USB Peripheral Controller # CONFIG_USB_FUSB300=y CONFIG_USB_FOTG210_UDC=y CONFIG_USB_R8A66597=y CONFIG_USB_PXA27X=y CONFIG_USB_MV_UDC=y CONFIG_USB_MV_U3D=y CONFIG_USB_M66592=y CONFIG_USB_AMD5536UDC=y CONFIG_USB_NET2272=y CONFIG_USB_NET2272_DMA=y CONFIG_USB_NET2280=y CONFIG_USB_GOKU=y CONFIG_USB_EG20T=y # CONFIG_USB_DUMMY_HCD is not set CONFIG_USB_LIBCOMPOSITE=y CONFIG_USB_U_ETHER=y CONFIG_USB_U_RNDIS=y CONFIG_USB_F_ECM=y CONFIG_USB_F_SUBSET=y CONFIG_USB_F_RNDIS=y # CONFIG_USB_CONFIGFS is not set # CONFIG_USB_ZERO is not set CONFIG_USB_ETH=y CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set # CONFIG_USB_G_NCM is not set # CONFIG_USB_GADGETFS is not set # CONFIG_USB_FUNCTIONFS is not set # CONFIG_USB_MASS_STORAGE is not set # CONFIG_USB_G_SERIAL is not set # CONFIG_USB_G_PRINTER is not set # CONFIG_USB_CDC_COMPOSITE is not set # CONFIG_USB_G_ACM_MS is not set # CONFIG_USB_G_MULTI is not set # CONFIG_USB_G_HID is not set # CONFIG_USB_G_DBGP is not set # CONFIG_USB_G_WEBCAM is not set # CONFIG_UWB is not set CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set CONFIG_MMC_UNSAFE_RESUME=y # CONFIG_MMC_CLKGATE is not set # # MMC/SD/SDIO Card Drivers # CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=8 CONFIG_MMC_BLOCK_BOUNCE=y CONFIG_SDIO_UART=y CONFIG_MMC_TEST=y # # MMC/SD/SDIO Host Controller Drivers # CONFIG_MMC_SDHCI=y # CONFIG_MMC_SDHCI_PCI is not set CONFIG_MMC_SDHCI_PLTFM=y # CONFIG_MMC_SDHCI_PXAV3 is not set # CONFIG_MMC_SDHCI_PXAV2 is not set CONFIG_MMC_OMAP=y CONFIG_MMC_OMAP_HS=y CONFIG_MMC_TIFM_SD=y # CONFIG_MMC_CB710 is not set # CONFIG_MMC_VIA_SDMMC is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # # LED drivers # # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP5521 is not set # CONFIG_LEDS_LP5523 is not set # CONFIG_LEDS_LP5562 is not set # CONFIG_LEDS_LP8501 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set # CONFIG_LEDS_PWM is not set # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_OT200 is not set # CONFIG_LEDS_BLINKM is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y CONFIG_LEDS_TRIGGER_TIMER=y CONFIG_LEDS_TRIGGER_ONESHOT=y CONFIG_LEDS_TRIGGER_HEARTBEAT=y CONFIG_LEDS_TRIGGER_BACKLIGHT=y CONFIG_LEDS_TRIGGER_CPU=y CONFIG_LEDS_TRIGGER_GPIO=y CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_LEDS_TRIGGER_TRANSIENT is not set # CONFIG_LEDS_TRIGGER_CAMERA is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set # CONFIG_EDAC is not set CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_SYSTOHC=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set # # RTC interfaces # CONFIG_RTC_INTF_SYSFS=y CONFIG_RTC_INTF_PROC=y CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_X1205 is not set CONFIG_RTC_DRV_PALMAS=y # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF8563 is not set # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set CONFIG_RTC_DRV_TWL92330=y CONFIG_RTC_DRV_TWL4030=y # CONFIG_RTC_DRV_TPS65910 is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_DS3234 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_RX4581 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_DS2404 is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_OMAP=y # CONFIG_RTC_DRV_SNVS is not set # CONFIG_RTC_DRV_MOXART is not set # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # # CONFIG_DW_DMAC_CORE is not set # CONFIG_DW_DMAC is not set # CONFIG_DW_DMAC_PCI is not set # CONFIG_TIMB_DMA is not set CONFIG_TI_EDMA=y CONFIG_DMA_OMAP=y CONFIG_TI_CPPI41=y CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # CONFIG_VIRT_DRIVERS is not set # # Virtio drivers # # CONFIG_VIRTIO_PCI is not set # CONFIG_VIRTIO_MMIO is not set # # Microsoft Hyper-V guest support # # CONFIG_STAGING is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # CONFIG_COMMON_CLK_DEBUG=y # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_CLK_TWL6040 is not set CONFIG_COMMON_CLK_PALMAS=y # # Hardware Spinlock drivers # # CONFIG_HWSPINLOCK_OMAP is not set CONFIG_CLKSRC_OF=y CONFIG_CLKSRC_MMIO=y CONFIG_ARM_ARCH_TIMER=y CONFIG_MAILBOX=y CONFIG_OMAP_MBOX=y CONFIG_OMAP2PLUS_MBOX=y CONFIG_OMAP_MBOX_KFIFO_SIZE=256 CONFIG_IOMMU_SUPPORT=y CONFIG_OF_IOMMU=y # CONFIG_OMAP_IOMMU is not set # # Remoteproc drivers # # CONFIG_STE_MODEM_RPROC is not set # CONFIG_PRUSS_REMOTEPROC is not set # # Rpmsg drivers # # CONFIG_PM_DEVFREQ is not set CONFIG_EXTCON=y # # Extcon Device Drivers # CONFIG_OF_EXTCON=y # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_ADC_JACK is not set CONFIG_EXTCON_PALMAS=y CONFIG_EXTCON_GPIO_USBVID=y # CONFIG_MEMORY is not set CONFIG_IIO=y CONFIG_IIO_BUFFER=y CONFIG_IIO_BUFFER_CB=y CONFIG_IIO_KFIFO_BUF=y CONFIG_IIO_TRIGGER=y CONFIG_IIO_CONSUMERS_PER_TRIGGER=2 # # Accelerometers # # CONFIG_BMA180 is not set # CONFIG_IIO_ST_ACCEL_3AXIS is not set # CONFIG_KXSD9 is not set # # Analog to digital converters # # CONFIG_AD7266 is not set # CONFIG_AD7298 is not set # CONFIG_AD7476 is not set # CONFIG_AD7791 is not set # CONFIG_AD7793 is not set # CONFIG_AD7887 is not set # CONFIG_AD7923 is not set # CONFIG_EXYNOS_ADC is not set # CONFIG_MAX1363 is not set # CONFIG_MCP320X is not set # CONFIG_NAU7802 is not set # CONFIG_TI_ADC081C is not set CONFIG_TI_AM335X_ADC=y # CONFIG_TWL6030_GPADC is not set # # Amplifiers # # CONFIG_AD8366 is not set # # Hid Sensor IIO Common # # # Digital to analog converters # # CONFIG_AD5064 is not set # CONFIG_AD5360 is not set # CONFIG_AD5380 is not set # CONFIG_AD5421 is not set # CONFIG_AD5446 is not set # CONFIG_AD5449 is not set # CONFIG_AD5504 is not set # CONFIG_AD5624R_SPI is not set # CONFIG_AD5686 is not set # CONFIG_AD5755 is not set # CONFIG_AD5764 is not set # CONFIG_AD5791 is not set # CONFIG_AD7303 is not set # CONFIG_MAX517 is not set # CONFIG_MCP4725 is not set # # Frequency Synthesizers DDS/PLL # # # Clock Generator/Distribution # # CONFIG_AD9523 is not set # # Phase-Locked Loop (PLL) frequency synthesizers # # CONFIG_ADF4350 is not set # # Digital gyroscope sensors # # CONFIG_ADIS16080 is not set # CONFIG_ADIS16130 is not set # CONFIG_ADIS16136 is not set # CONFIG_ADIS16260 is not set # CONFIG_ADXRS450 is not set # CONFIG_IIO_ST_GYRO_3AXIS is not set # CONFIG_ITG3200 is not set # # Inertial measurement units # # CONFIG_ADIS16400 is not set # CONFIG_ADIS16480 is not set # CONFIG_INV_MPU6050_IIO is not set # # Light sensors # # CONFIG_ADJD_S311 is not set # CONFIG_APDS9300 is not set # CONFIG_SENSORS_TSL2563 is not set # CONFIG_VCNL4000 is not set # # Magnetometer sensors # # CONFIG_AK8975 is not set # CONFIG_IIO_ST_MAGN_3AXIS is not set # # Triggers - standalone # # CONFIG_IIO_INTERRUPT_TRIGGER is not set # CONFIG_IIO_SYSFS_TRIGGER is not set # # Pressure sensors # # CONFIG_IIO_ST_PRESS is not set # # Temperature sensors # # CONFIG_TMP006 is not set # CONFIG_VME_BUS is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_PCA9685 is not set CONFIG_PWM_TIECAP=y CONFIG_PWM_TIEHRPWM=y CONFIG_PWM_TIPWMSS=y # CONFIG_PWM_TWL is not set # CONFIG_PWM_TWL_LED is not set CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y # CONFIG_IPACK_BUS is not set CONFIG_ARCH_HAS_RESET_CONTROLLER=y CONFIG_RESET_CONTROLLER=y CONFIG_RESET_TI=y # CONFIG_FMC is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y CONFIG_OMAP_CONTROL_PHY=y CONFIG_OMAP_USB2=y CONFIG_OMAP_PIPE3=y # # File systems # CONFIG_DCACHE_WORD_ACCESS=y CONFIG_EXT2_FS=y # CONFIG_EXT2_FS_XATTR is not set # CONFIG_EXT2_FS_XIP is not set CONFIG_EXT3_FS=y CONFIG_EXT3_DEFAULTS_TO_ORDERED=y # CONFIG_EXT3_FS_XATTR is not set CONFIG_EXT4_FS=y # CONFIG_EXT4_FS_POSIX_ACL is not set # CONFIG_EXT4_FS_SECURITY is not set # CONFIG_EXT4_DEBUG is not set CONFIG_JBD=y # CONFIG_JBD_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_FILE_LOCKING=y CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set CONFIG_QUOTA=y # CONFIG_QUOTA_NETLINK_INTERFACE is not set CONFIG_PRINT_QUOTA_WARNING=y # CONFIG_QUOTA_DEBUG is not set CONFIG_QUOTA_TREE=y # CONFIG_QFMT_V1 is not set CONFIG_QFMT_V2=y CONFIG_QUOTACTL=y # CONFIG_AUTOFS4_FS is not set # CONFIG_FUSE_FS is not set # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_NTFS_FS is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y CONFIG_TMPFS=y # CONFIG_TMPFS_POSIX_ACL is not set # CONFIG_TMPFS_XATTR is not set # CONFIG_HUGETLB_PAGE is not set CONFIG_CONFIGFS_FS=y CONFIG_MISC_FILESYSTEMS=y # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_ECRYPT_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set CONFIG_JFFS2_FS=y CONFIG_JFFS2_FS_DEBUG=0 CONFIG_JFFS2_FS_WRITEBUFFER=y # CONFIG_JFFS2_FS_WBUF_VERIFY is not set CONFIG_JFFS2_SUMMARY=y CONFIG_JFFS2_FS_XATTR=y CONFIG_JFFS2_FS_POSIX_ACL=y CONFIG_JFFS2_FS_SECURITY=y CONFIG_JFFS2_COMPRESSION_OPTIONS=y CONFIG_JFFS2_ZLIB=y CONFIG_JFFS2_LZO=y CONFIG_JFFS2_RTIME=y CONFIG_JFFS2_RUBIN=y # CONFIG_JFFS2_CMODE_NONE is not set CONFIG_JFFS2_CMODE_PRIORITY=y # CONFIG_JFFS2_CMODE_SIZE is not set # CONFIG_JFFS2_CMODE_FAVOURLZO is not set CONFIG_UBIFS_FS=y # CONFIG_UBIFS_FS_ADVANCED_COMPR is not set CONFIG_UBIFS_FS_LZO=y CONFIG_UBIFS_FS_ZLIB=y # CONFIG_LOGFS is not set CONFIG_CRAMFS=y # CONFIG_SQUASHFS is not set # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_PSTORE is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_F2FS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V2=y CONFIG_NFS_V3=y CONFIG_NFS_V3_ACL=y CONFIG_NFS_V4=y # CONFIG_NFS_SWAP is not set CONFIG_NFS_V4_1=y CONFIG_NFS_V4_2=y CONFIG_PNFS_FILE_LAYOUT=m CONFIG_NFS_V4_1_IMPLEMENTATION_ID_DOMAIN="kernel.org" CONFIG_NFS_V4_SECURITY_LABEL=y CONFIG_ROOT_NFS=y # CONFIG_NFS_USE_LEGACY_DNS is not set CONFIG_NFS_USE_KERNEL_DNS=y # CONFIG_NFSD is not set CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_NFS_ACL_SUPPORT=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y CONFIG_SUNRPC_GSS=y CONFIG_SUNRPC_BACKCHANNEL=y # CONFIG_SUNRPC_DEBUG is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set # CONFIG_NLS_UTF8 is not set # CONFIG_DLM is not set # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y CONFIG_DEFAULT_MESSAGE_LOGLEVEL=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # # Compile-time checks and compiler options # CONFIG_DEBUG_INFO=y # CONFIG_DEBUG_INFO_REDUCED is not set CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_UNUSED_SYMBOLS is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_FRAME_POINTER=y # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set CONFIG_MAGIC_SYSRQ=y CONFIG_DEBUG_KERNEL=y # # Memory Debugging # # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_DEBUG_SLAB is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_VM is not set # CONFIG_DEBUG_MEMORY_INIT is not set # CONFIG_DEBUG_HIGHMEM is not set # CONFIG_DEBUG_SHIRQ is not set # # Debug Lockups and Hangs # # CONFIG_LOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 # CONFIG_SCHED_DEBUG is not set # CONFIG_SCHEDSTATS is not set # CONFIG_TIMER_STATS is not set CONFIG_DEBUG_PREEMPT=y # # Lock Debugging (spinlocks, mutexes, etc...) # # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_RT_MUTEX_TESTER is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_DEBUG_KOBJECT is not set # CONFIG_DEBUG_BUGVERBOSE is not set # CONFIG_DEBUG_WRITECOUNT is not set # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_PROVE_RCU_DELAY is not set # CONFIG_SPARSE_RCU_POINTER is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_CPU_STALL_VERBOSE=y # CONFIG_RCU_CPU_STALL_INFO is not set # CONFIG_RCU_TRACE is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACE_CLOCK=y CONFIG_RING_BUFFER=y CONFIG_RING_BUFFER_ALLOW_SWAP=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # # Runtime Testing # # CONFIG_LKDTM is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_KPROBES_SANITY_TEST is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_RBTREE_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_DMA_API_DEBUG is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_STRICT_DEVMEM is not set # CONFIG_ARM_UNWIND is not set # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_LL is not set CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S" # CONFIG_DEBUG_UART_PL01X is not set # CONFIG_DEBUG_UART_8250 is not set CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" # CONFIG_ARM_KPROBES_TEST is not set # CONFIG_PID_IN_CONTEXTIDR is not set # # Security options # CONFIG_KEYS=y # CONFIG_ENCRYPTED_KEYS is not set # CONFIG_KEYS_DEBUG_PROC_KEYS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set CONFIG_SECURITY=y # CONFIG_SECURITYFS is not set # CONFIG_SECURITY_NETWORK is not set # CONFIG_SECURITY_PATH is not set # CONFIG_SECURITY_SMACK is not set # CONFIG_SECURITY_TOMOYO is not set # CONFIG_SECURITY_APPARMOR is not set # CONFIG_SECURITY_YAMA is not set # CONFIG_IMA is not set # CONFIG_EVM is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_DEFAULT_SECURITY="" CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=y CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_PCOMP2=y CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y # CONFIG_CRYPTO_GF128MUL is not set # CONFIG_CRYPTO_NULL is not set CONFIG_CRYPTO_WORKQUEUE=y # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set CONFIG_CRYPTO_TEST=m # # Authenticated Encryption with Associated Data # # CONFIG_CRYPTO_CCM is not set # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_SEQIV is not set # # Block modes # # CONFIG_CRYPTO_CBC is not set # CONFIG_CRYPTO_CTR is not set # CONFIG_CRYPTO_CTS is not set CONFIG_CRYPTO_ECB=y # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # # Hash modes # # CONFIG_CRYPTO_CMAC is not set CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set CONFIG_CRYPTO_CRCT10DIF=y # CONFIG_CRYPTO_GHASH is not set # CONFIG_CRYPTO_MD4 is not set CONFIG_CRYPTO_MD5=y CONFIG_CRYPTO_MICHAEL_MIC=y # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set CONFIG_CRYPTO_SHA1=y # CONFIG_CRYPTO_SHA1_ARM is not set CONFIG_CRYPTO_SHA256=y CONFIG_CRYPTO_SHA512=y # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_ARM is not set # CONFIG_CRYPTO_ANUBIS is not set CONFIG_CRYPTO_ARC4=y # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=y # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # CONFIG_CRYPTO_DEFLATE=y # CONFIG_CRYPTO_ZLIB is not set CONFIG_CRYPTO_LZO=y # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_USER_API=y CONFIG_CRYPTO_USER_API_HASH=y CONFIG_CRYPTO_USER_API_SKCIPHER=y CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_HIFN_795X is not set CONFIG_CRYPTO_DEV_OMAP_SHAM=y CONFIG_CRYPTO_DEV_OMAP_AES=y CONFIG_CRYPTO_DEV_OMAP_DES=y # CONFIG_ASYMMETRIC_KEY_TYPE is not set # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_GENERIC_IO=y CONFIG_CRC_CCITT=y CONFIG_CRC16=y CONFIG_CRC_T10DIF=y CONFIG_CRC_ITU_T=y CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set CONFIG_CRC7=y CONFIG_LIBCRC32C=y # CONFIG_CRC8 is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y # CONFIG_XZ_DEC is not set # CONFIG_XZ_DEC_BCJ is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_BCH=y CONFIG_TEXTSEARCH=y CONFIG_TEXTSEARCH_KMP=y CONFIG_TEXTSEARCH_BM=y CONFIG_TEXTSEARCH_FSM=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT=y CONFIG_HAS_DMA=y CONFIG_DQL=y CONFIG_NLATTR=y CONFIG_GENERIC_ATOMIC64=y CONFIG_ARCH_HAS_ATOMIC64_DEC_IF_POSITIVE=y CONFIG_AVERAGE=y # CONFIG_CORDIC is not set # CONFIG_DDR is not set CONFIG_OID_REGISTRY=y # CONFIG_VIRTUALIZATION is not set
Thanks in advance
this is my bootup
U-Boot SPL 2014.04-rc1-00233-gd689780 (Aug 01 2014 - 09:48:44) Using default environment usb_ether using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC 20:cd:39:f5:a7:49 HOST MAC de:ad:be:af:00:00 RNDIS ready musb-hdrc: peripheral reset irq lost! high speed config #2: 2 mA, Ethernet Gadget, using RNDIS USB RNDIS network up! BOOTP broadcast 1 BOOTP broadcast 2 Using usb_ether device TFTP from server 192.168.2.151; our IP address is 192.168.2.6 Filename 'u-boot-restore.img'. Load address: 0x807fffc0 Loading: ########################### 620.1 KiB/s done Bytes transferred = 393796 (60244 hex) U-Boot 2014.04-rc1-00232-g50a91da-dirty (Apr 28 2015 - 11:15:12) I2C: ready DRAM: 512 MiB NAND: 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - readenv() failed, using default environment Incorrect magic number (0xffffffff) in EEPROM Could not get board ID. Net: <ethaddr> not set. Validating first E-fuse MAC Incorrect magic number (0xffffffff) in EEPROM Could not get board ID. Could not get PHY for cpsw: addr 0 cpsw, usb_ether Hit any key to stop autoboot: 0 WARNING: Could not determine device tree to use Booting from usb0 ... using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC 20:cd:39:f5:a7:49 HOST MAC de:ad:be:af:00:00 RNDIS ready musb-hdrc: peripheral reset irq lost! high speed config #2: 2 mA, Ethernet Gadget, using RNDIS USB RNDIS network up! Using usb_ether device TFTP from server 192.168.2.151; our IP address is 192.168.2.3 Filename 'zImage'. Load address: 0x80300000 Loading: ################################################################# ################################################################# ################################################################# ################################################################# ############################ 1.2 MiB/s done Bytes transferred = 4215256 (4051d8 hex) using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in MAC 20:cd:39:f5:a7:49 HOST MAC de:ad:be:af:00:00 RNDIS ready high speed config #2: 2 mA, Ethernet Gadget, using RNDIS USB RNDIS network up! Using usb_ether device TFTP from server 192.168.2.151; our IP address is 192.168.2.3 Filename 'am335x.dtb'. Load address: 0x815f0000 Loading: ### 1.1 MiB/s done Bytes transferred = 35430 (8a66 hex) Kernel image @ 0x80300000 [ 0x000000 - 0x4051d8 ] ## Flattened Device Tree blob at 815f0000 Booting using the fdt blob at 0x815f0000 Using Device Tree in place at 815f0000, end 815fba65 Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.12.10 (nmakkiya@nmakkiya-OptiPlex-9010) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #14 PREEMPT Fri May 1 16:48:19 PDT 2015 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x Falcon [ 0.000000] cma: CMA: reserved 24 MiB at 9e000000 [ 0.000000] Memory policy: ECC disabled, Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129280 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/nfs rw nfsroot=192.168.2.151:/export/fs,nolock rw rootfstype=nfs ip=192.168.2.151 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 483184K/521216K available (5791K kernel code, 551K rwdata, 1836K rodata, 340K init, 211K bss, 38032K reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc077b04c (7629 kB) [ 0.000000] .init : 0xc077c000 - 0xc07d1044 ( 341 kB) [ 0.000000] .data : 0xc07d2000 - 0xc085bc38 ( 552 kB) [ 0.000000] .bss : 0xc085bc44 - 0xc0890ae8 ( 212 kB) [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms [ 0.000000] OMAP clocksource: timer1 at 24000000 Hz [ 0.000000] Console: colour dummy device 80x30 [ 0.000268] Calibrating delay loop... 663.55 BogoMIPS (lpj=1658880) [ 0.059796] pid_max: default: 32768 minimum: 301 [ 0.059888] Security Framework initialized [ 0.059932] Mount-cache hash table entries: 512 [ 0.066913] CPU: Testing write buffer coherency: ok [ 0.067266] Setting up static identity map for 0xc05ad5e8 - 0xc05ad658 [ 0.068170] devtmpfs: initialized [ 0.069698] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.130339] omap_hwmod: debugss: _wait_target_disable failed [ 0.130922] pinctrl core: initialized pinctrl subsystem [ 0.131685] regulator-dummy: no parameters [ 0.133707] NET: Registered protocol family 16 [ 0.135664] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.144421] platform mpu.1: FIXME: clock-name 'fck' DOES NOT exist in dt! [ 0.146533] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.147274] platform 49000000.edma: FIXME: clock-name 'fck' DOES NOT exist in dt! [ 0.148344] OMAP GPIO hardware version 0.1 [ 0.157740] platform 56000000.sgx: FIXME: clock-name 'fck' DOES NOT exist in dt! [ 0.160493] DSS not supported on this SoC [ 0.160515] No ATAGs? [ 0.160524] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.186803] bio: create slab <bio-0> at 0 [ 0.199709] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [ 0.200922] vmmcsd_fixed: 3300 mV [ 0.201366] wlan-en-regulator: 1800 mV [ 0.205403] SCSI subsystem initialized [ 0.206552] usbcore: registered new interface driver usbfs [ 0.206718] usbcore: registered new interface driver hub [ 0.206898] usbcore: registered new device driver usb [ 0.210169] DCDC1: at 1500 mV [ 0.211100] vdd_mpu: 925 <--> 1375 mV at 1325 mV [ 0.211929] vdd_core: 925 <--> 1150 mV at 1125 mV [ 0.212753] LDO1: at 1800 mV [ 0.213569] LDO2: at 3300 mV [ 0.215119] LDO3: 1800 mV [ 0.216000] LDO4: at 3300 mV [ 0.216206] Assiging LDO2 to STROBE14, so that it will be active during PMIC Sleep state [ 0.216998] tps65217 0-0024: TPS65217 ID 0xe version 1.2 [ 0.217044] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 0.217732] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz [ 0.218038] media: Linux media interface: v0.10 [ 0.218202] Linux video capture interface: v2.00 [ 0.218435] pps_core: LinuxPPS API ver. 1 registered [ 0.218444] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.218555] PTP clock support registered [ 0.220699] Switched to clocksource timer1 [ 0.237122] NET: Registered protocol family 2 [ 0.237686] TCP established hash table entries: 4096 (order: 3, 32768 bytes) [ 0.237756] TCP bind hash table entries: 4096 (order: 2, 16384 bytes) [ 0.237794] TCP: Hash tables configured (established 4096 bind 4096) [ 0.237855] TCP: reno registered [ 0.237867] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.237883] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.238047] NET: Registered protocol family 1 [ 0.238394] RPC: Registered named UNIX socket transport module. [ 0.238406] RPC: Registered udp transport module. [ 0.238412] RPC: Registered tcp transport module. [ 0.238418] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.238766] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.239442] PM: Loading am335x-pm-firmware.bin [ 0.345465] VFS: Disk quotas dquot_6.5.2 [ 0.345529] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.346183] NFS: Registering the id_resolver key type [ 0.346259] Key type id_resolver registered [ 0.346266] Key type id_legacy registered [ 0.346303] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 0.346461] msgmni has been set to 991 [ 0.347956] NET: Registered protocol family 38 [ 0.348001] io scheduler noop registered [ 0.348009] io scheduler deadline registered [ 0.348029] io scheduler cfq registered (default) [ 0.352027] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 0.354469] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a OMAP UART0 [ 0.983565] console [ttyO0] enabled [ 0.988085] 48022000.serial: ttyO1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a OMAP UART1 [ 0.998527] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a OMAP UART2 [ 1.008963] 481a8000.serial: ttyO4 at MMIO 0x481a8000 (irq = 61, base_baud = 3000000) is a OMAP UART4 [ 1.019147] pinctrl-single 44e10800.pinmux: pin 44e108dc.0 already requested by 44e10800.pinmux; cannot claim for 481aa000.serial [ 1.031519] pinctrl-single 44e10800.pinmux: pin-55 (481aa000.serial) status -22 [ 1.039232] pinctrl-single 44e10800.pinmux: could not request pin 55 (44e108dc.0) from group pinmux_uart5_pins_default on device pinctrl-single [ 1.052852] omap_uart 481aa000.serial: Error applying setting, reverse things back [ 1.133707] PPP BSD Compression module registered [ 1.138836] PPP Deflate Compression module registered [ 1.144219] PPP MPPE Compression module registered [ 1.149482] usbcore: registered new interface driver cdc_acm [ 1.155480] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.167598] mousedev: PS/2 mouse device common for all mice [ 1.176235] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ 1.184628] i2c /dev entries driver [ 1.191123] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 1.199336] sdhci: Secure Digital Host Controller Interface driver [ 1.205955] sdhci: Copyright(c) Pierre Ossman [ 1.211474] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25 [ 1.218748] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24 [ 1.256191] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3 [ 1.264324] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2 [ 1.301005] edma-dma-engine edma-dma-engine.0: allocated channel for 0:13 [ 1.308245] edma-dma-engine edma-dma-engine.0: allocated channel for 0:12 [ 1.364632] mmc1: BKOPS_EN bit is not set [ 1.379956] mmc1: new high speed MMC card at address 0001 [ 1.395757] mmcblk0: mmc1:0001 MMC04G 3.52 GiB [ 1.400652] mmcblk0boot0: mmc1:0001 MMC04G partition 1 16.0 MiB [ 1.414461] mmcblk0boot1: mmc1:0001 MMC04G partition 2 16.0 MiB [ 1.422885] mmcblk0: [ 1.427149] mmcblk0boot1: unknown partition table [ 1.433769] mmcblk0boot0: unknown partition table [ 1.441343] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.451560] ledtrig-cpu: registered to indicate activity on CPUs [ 1.457964] mmc2: card claims to support voltages below the defined range. These will be ignored. [ 1.467713] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36 [ 1.474967] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 1.482275] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 1.488471] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5 [ 1.495575] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6 [ 1.506159] oprofile: no performance counters [ 1.511182] oprofile: using timer interrupt. [ 1.515853] Netfilter messages via NETLINK v0.30. [ 1.521151] nfnl_acct: registering with nfnetlink. [ 1.526338] nf_conntrack version 0.5.0 (7933 buckets, 31732 max) [ 1.532942] ctnetlink v0.93: registering with nfnetlink. [ 1.539163] xt_time: kernel timezone is -0000 [ 1.544090] ip_tables: (C) 2000-2006 Netfilter Core Team [ 1.549903] ipt_CLUSTERIP: ClusterIP Version 0.8 loaded successfully [ 1.556686] arp_tables: (C) 2002 David S. Miller [ 1.561608] TCP: cubic registered [ 1.565099] Initializing XFRM netlink socket [ 1.569642] NET: Registered protocol family 17 [ 1.574744] NET: Registered protocol family 15 [ 1.579670] mmc2: queuing unknown CIS tuple 0x91 (3 bytes) [ 1.585516] 8021q: 802.1Q VLAN Support v1.8 [ 1.590507] mmc2: new high speed SDIO card at address 0001 [ 1.596353] Key type dns_resolver registered [ 1.603286] PM: CM3 Firmware Version = 0x186 [ 1.608400] ThumbEE CPU extension supported. [ 1.615120] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) [ 108.711212] VFS: Unable to mount root fs via NFS, trying floppy. [ 108.717644] List of all partitions: [ 108.721380] b300 3694592 mmcblk0 driver: mmcblk [ 108.726998] b310 16384 mmcblk0boot1 (driver?) [ 108.732592] b308 16384 mmcblk0boot0 (driver?) [ 108.738176] No filesystem could mount root, tried: nfs [ 108.743678] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
