Other Parts Discussed in Thread: AM5728
EVM: Ti AM5728 evm
Kernel: 4.4.41
I use this pipeline to simple capture & display and is not working:
gst-launch-1.0 -v --gst-debug=2 v4l2src device=/dev/video1 num-buffers=1000 io-mode=4 ! 'video/x-raw, \
format=(string)YUY2, width=(int)1280, height=(int)720' ! vpe num-input-buffers=8 ! queue ! kmssink
root@am57xx-evm:/# gst-launch-1.0 -v --gst-debug=2 v4l2src device=/dev/video1 num-buffers=1000 io-mode=4 ! 'video/x-raw, \
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-m"
/GstPipeline:pipeline0/GstVpe:vpe0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction\)10"
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fraction"
/GstPipeline:pipeline0/GstKMSSink:kmssink0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fra"
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ framerate\=\(fractio"
/GstPipeline:pipeline0/GstVpe:vpe0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-mode\=\(string"
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = "video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)1280\,\ height\=\(int\)720\,\ pixel-aspect-ratio\=\(fraction\)1/1\,\ interlace-"
0:00:00.288726988 2332 0x143c30 WARN v4l2bufferpool gstv4l2bufferpool.c:749:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.436926081 2332 0x143c30 WARN vpe gstvpebufferpool.c:462:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 0/128, 0
0:00:00.447965780 2332 0x144030 WARN bufferpool gstbufferpool.c:300:do_alloc_buffer:<vpebufferpool1> alloc function failed
0:00:00.458225004 2332 0x144030 WARN bufferpool gstbufferpool.c:300:do_alloc_buffer:<vpebufferpool1> alloc function failed
0:00:00.460187252 2332 0x143c30 WARN vpe gstvpebufferpool.c:462:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 1/128, 0
0:00:00.468431198 2332 0x144030 WARN bufferpool gstbufferpool.c:300:do_alloc_buffer:<vpebufferpool1> alloc function failed
0:00:00.470062745 2332 0x144000 WARN kmssink gstkmssink.c:364:gst_kms_sink_show_frame:<kmssink0> error: drmModeSetPlane failed: Permission denied (13)
ERROR: from element /GstPipeline:pipeline0/GstKMSSink:kmssink0: GStreamer encountered a general resource error.
Additional debug info:
../../../git/sys/kms/gstkmssink.c(364): gst_kms_sink_show_frame (): /GstPipeline:pipeline0/GstKMSSink:kmssink0:
0:00:00.478578996 2332 0x144030 WARN bufferpool gstbufferpool.c:300:do_alloc_buffer:<vpebufferpool1> alloc function failed
Execution ended after 0:00:00.385884047
0:00:00.664821267 2332 0x143c30 WARN vpe gstvpebufferpool.c:462:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 2/128, 0
0:00:00.667199291 2332 0x143c30 WARN v4l2src gstv4l2src.c:827:gst_v4l2src_create:<v4l2src0> lost frames detected: count = 1 - ts: 0:00:00.263099244
Setting pipeline to READY ...
0:00:00.676525784 2332 0x1465a0 WARN bufferpool gstbufferpool.c:537:gst_buffer_pool_set_active:<vpebufferpool1> stop failed
0:00:00.681577723 2332 0x1465a0 WARN bufferpool gstbufferpool.c:537:gst_buffer_pool_set_active:<vpebufferpool1> stop failed
Setting pipeline to NULL ...
Freeing pipeline ...
root@am57xx-evm:/#
BR,
Faiez :)
