Other Parts Discussed in Thread: MATHLIB, OMAPL138
Tool/software: Linux
Hi all,
I got the below error with Segmentation Fault while compiling IPC example (ipc_3_44_01_01/examples/DRA7XX_linux_elf/ex02_messageq)
root@f-ubuntu:/opt/ti/ipc_3_44_01_01/examples/DRA7XX_linux_elf/ex02_messageq# make all
# Making dsp1 ...
make -C dsp1 PROCLIST="dsp1 dsp2 ipu1 ipu2 host"
make[1]: Entering directory '/opt/ti/ipc_3_44_01_01/examples/DRA7XX_linux_elf/ex02_messageq/dsp1'
make PROFILE=debug PROCLIST="dsp1 dsp2 ipu1 ipu2 host" server_dsp1.x
make[2]: Entering directory '/opt/ti/ipc_3_44_01_01/examples/DRA7XX_linux_elf/ex02_messageq/dsp1'
# Making bin/debug/configuro/.config ...
/opt/ti/xdctools_3_32_02_25_core/xs --xdcpath="/opt/ti/bios_6_46_04_53/packages;/opt/ti/ipc_3_44_01_01/packages;/opt/ti/xdctools_3_32_02_25_core/packages" \
xdc.tools.configuro -o bin/debug/configuro \
-t ti.targets.elf.C66 \
-c /opt/ti/ccsv7/tools/compiler/ti-cgt-c6000_8.1.3 \
-p ti.platforms.evmDRA7XX:dsp1 \
-b ../shared/config.bld -r debug \
Dsp1.cfg
Segmentation fault (core dumped)
makefile:77: recipe for target 'bin/debug/configuro/.config' failed
make[2]: *** [bin/debug/configuro/.config] Error 139
make[2]: Leaving directory '/opt/ti/ipc_3_44_01_01/examples/DRA7XX_linux_elf/ex02_messageq/dsp1'
makefile:58: recipe for target 'debug' failed
make[1]: *** [debug] Error 2
make[1]: Leaving directory '/opt/ti/ipc_3_44_01_01/examples/DRA7XX_linux_elf/ex02_messageq/dsp1'
makefile:49: recipe for target 'dsp1' failed
make: *** [dsp1] Error 2
What may be the problem?
Here is the products.mak definitions:
DEPOT = /opt
PLATFORM = DRA7xx
TOOLCHAIN_LONGNAME = arm-linux-gnueabihf
TOOLCHAIN_INSTALL_DIR = $(DEPOT)/ti-processor-sdk-linux-am57xx-evm-03.03.00.04/linux-devkit/sysroots/x86_64-arago-linux/usr
TOOLCHAIN_PREFIX = $(TOOLCHAIN_INSTALL_DIR)/bin/$(TOOLCHAIN_LONGNAME)-
KERNEL_INSTALL_DIR = /opt/ti-processor-sdk-linux-am57xx-evm-03.03.00.04/board-support/linux-4.4.41+gitAUTOINC+f9f6f0db2d-gf9f6f0db2d/
XDC_INSTALL_DIR = $(DEPOT)/ti/xdctools_3_32_02_25_core
BIOS_INSTALL_DIR = $(DEPOT)/ti/bios_6_46_04_53
ti.targets.elf.C66 = /opt/ti/ti-cgt-c6000_8.1.3
