DAC38RF80: Questions regarding spec
Part Number: DAC38RF80
A few questions regarding the dac38RFXX –
  • Vout1&Vout2 relative amplitude and phase imbalance.
           Should I expect any amplitude and phase difference between the two output channels (in all of the temperature range)?
  • The Digital Latency : JESD Buffer to DAC output, how does it vary across temperature? only typical values are specified. Could you provide more info on this?
  • The PLL has a very wide Loop filter bandwidth (500KHz), this means the phase noise performance inside the BW should be
            designed more carefully. Could you provide data regarding the PLL FOM and  1/F noise? I'm trying to understand what are the phase noise
             requirements of the reference clock in order to achieve optimal results.
Thanks in advance,
Guy.
